View Full Version : PCM Diagnostics & Tuning
  1. calling Don (slowhawk) or any other tuning specialist
  2. Help With po336 Please?????
  3. New to tuning
  4. Tick performance dyno tuning
  5. HP Tuner 2-bar SD - can you add MAF?
  6. Anyone running s2(android) tuning apps?
  7. Hell Just Froze Over
  8. Knock at WOT--FALSE KNOCK???
  9. Bad IAC??
  10. GREAT SERVICE edcmat-l1 hitechtuning.com
  11. Critique my 5.3 turbo tune...mainly timing 2 bar SD HPtuners
  12. DiabloSport dspI1000, DiabloSport inTune Touch Screen Tuner
  13. turbo c5 wot knock
  14. efi live v1 trouble
  15. Car Miss-fires above 50mph
  16. AFR sensor placement?
  17. mail order tune??
  18. Holley EFI Dominator Questions
  19. need a new laptop for tuning
  20. Tuning in Twin Cities - Rear O2 Delete
  21. hanging idle and car wont idle at target idle
  22. Ls2 l77...
  23. Cars/Cags Lamp Pinout, 99 F-body
  24. Cammed ls1/t56: sudden lean and high idle conditions
  25. Sct programmer
  26. Need help ses light cuts in and out pin loose on ecu
  27. looking for help on STFT and LTFT normal readings
  28. efi live help
  29. FAST 90mm: going to redo idle tuning, tips and tricks welcome
  30. gen IV problems.
  31. tuning books
  32. Multiport Retro-Fit EZ-EFI Questions
  33. 99 z28 no start
  34. New e-testing?
  35. 99 ss problems
  36. quality of autometer wideband O2's for tunning?
  37. Need tuner in Delaware area
  38. Carb back to EFI
  39. 2 issues: Lterms frozen at 0.0 and -3.1 cruising and running WAY hot.
  40. Re-Tune?
  41. HPTuners....adding percentages across the table?
  42. changing intake
  43. alter tune for 100mm MAF
  44. How much timing advance on a turbo LS2?
  45. Does E40 ECM works with a 2001 5.3 (24x) Motor ?
  46. 98 Chevy prizm hesitation
  47. Predator
  48. Trouble codes for low 02 switching with brand new sensors
  49. Effects of larger intercooler on VE and AFR?
  50. Need Some Bin files
  51. surging issue after MOT and cam install
  52. *UPDATE* 4/17/13 4L60e No 3rd Unless Selected?
  53. Tuning in Salt Lake City Utah
  54. HP tuners - 5.3 timing table vs LS1 timing table
  55. New tuner need help
  56. Tuning with individual EGT!
  57. P2135 Code
  58. 4.8 vs 5.3 computer?
  59. PCM question
  60. Idle Timing with Cam?
  61. Efi live
  62. speedo not correct after gear change
  63. Engine swap/pcm compatibility question.
  64. 98 to 99-02 harness??
  65. Tuned to run too rich?
  66. Tuning question
  67. A/f ?
  68. (Video) What does this surge/stall issue look like to you?
  69. new tb/intake+wot=p0123?
  70. Displacement On Demand
  71. vats-passlock
  72. Is there any digital gash gauges out there ?
  73. Holley EFI use with stock gauges
  74. Can I tranfer a tune from my 98 speed density to a 99 with a Maf
  75. battery disconnect bad for the ecm?
  76. Tune questions
  77. Would a frost tune fix this?
  78. Tuning maf vs speed density
  79. Ls1 gauges sweeping
  80. High tps voltage with nw 102 tb
  81. Ltft bank 2 help
  82. Problems after shift light install
  83. trouble shooting codes p0174/p0171 and others
  84. Need best hp tuner person in the alabama area
  85. Need tech help - Want to convert CSFI injector controls to LT1 injectors
  86. Help, MAF Issue?
  87. PCM Not Seeing MAP Output
  88. help no start no spark
  89. Contact help, frost?
  90. Does this tune make my plugs look fat??
  91. Looking for tuners?
  92. Help need tune Huntsville Alabama
  93. 95# injectors help with efi live flow rate table
  94. EFI live ?
  95. Hp tuners sale?
  96. Question about emailing a tune HP Tuners
  97. looking for a tech 2 scanner
  98. Curing the "reduced engine power" TAC issues.
  99. Moving HP tuners to another computer
  100. best ecu for twin turbo project? 24x reluctor
  101. wideband o2 sensor help!!
  102. Need help for my 05 GMC?
  103. Buying HPT - how long did it take you all to "pick" it up
  104. 99 5.3 tsp problems
  105. Misfiring, please I just want some opinions
  106. 5.3 Tune help
  107. help with my setup!!!
  108. A/C Compressor control PCM?
  109. Tuning drop throttle response
  110. Anyone know if 96 with LS1 and PCM can pass emissions by changing VIN/deleting codes
  111. keep changing ve table but no difference 2 bar turbo
  112. AEM wideband issue
  113. 1996 Z28 Built with 24x conversion Need tune
  114. Max VE for an stroked L76?
  115. Battery Died While Reflashing, Now PCM Is Locked
  116. Need help mail in order tune C5
  117. Question, can I pass emissions, LT1 to LQ4 swap
  118. Need help Tuning my new LS3 Xim please
  119. Changing back to stock MAF
  120. Can you switch ecm from one cammed car to another?
  121. Reading AFR using LM1 & HPTuners...having problems!
  122. Bank 1 sensor 1
  123. swaping tunes via hpt
  124. can you have switch activated maps?
  125. P0118 two times in one week even after replacing ECT
  126. LS1 denotation in low gears only...ideas?
  127. What else could cause Fuel trims to go high and O2 sensors to read lean?
  128. O2 sensor not working HELP
  129. Engine will not start
  130. cat-less engine light tuning
  131. can i adjust shift points with intune?
  132. High RPM idle; Ive about had it!! Arg.
  133. P0200 & P0121 codes need HELP!
  134. Bought a 2001 5.3 LS & 700R4 but no computer or wire harness. Which one do I need?
  135. Tuning after mail order tune?
  136. what tables to change from 5.7 to 6.0
  137. c6 m6 reasembly
  138. Fixed p0102 now running worse, HELP!
  139. Ls2 408 fbody firing and fuel problem!!!
  140. DBW help!
  141. WOT AFR very rich from what commanded AFR should be.
  142. TOTAL OBD & ECU Auto Diagnostics (TOAD)
  143. Thinking about switching to a 2 Bar MAP Speed Density Tune
  144. 71 camaro ls1/4l40 swap to t-56
  145. Need wiring help!!!
  146. Bone Stock 2003 zo6 - 96% duty cycle
  147. How Do You Adjust Idle Airflow Using EFI Live?
  148. Any advantage from a Frost tune on almost stock ride?
  149. LS7 card style MAF and tube info
  150. How long does C6Z PCM retard timing for knock?
  151. newb question
  152. bad tune? p0300
  153. Question on a frost tune.
  154. No start Hptuners vats?
  155. 4.8l Dyno mule
  156. Diablo tune for Procharger?
  157. Tuners near valley forge Pa
  158. I need a 6.0 4l60e .JCL .BIN or .CAL file!
  159. Ls powered gen 1 cutting fuel
  160. what am i missing??
  161. Does anyone have an HP Tuner in the DFW area?
  162. 99+ pcm swap tachometer issue
  163. Ls1pcm will works on ls3 engine?
  164. Need help ASAP please!!!
  165. DBW WOT problem
  166. Figuring out wiring of harness
  167. Which wideband a/f gauge?
  168. tuning please help!!!
  169. Help with these charts
  170. Ls7 swap in f-body
  171. Mail in tune
  172. Need help figuring out wiring harness/pin outs on plugs
  173. Computer help on 98 Trans Am!!
  174. Tune needed if changing thermostat?
  175. Input Needed on Honeycomb for lS7 MAF Sensor
  176. Slight Surging
  177. button on automatic shifter sticking
  178. ARH Wide Band Bung Location
  179. WTB: HPTuners Suite (pro) with at least a couple credits
  180. Could a Reputable tuner give me a moment please?
  181. Hypertech questions
  182. Greer Performance in Ft. Wayne Indiana
  183. need help wiring an SES light
  184. H&P Performance Offering Tuning Solutions in the midwest!!
  185. ECM flash?
  186. Temp gauge signal??
  187. Knock Sensor Location
  188. 6.0 tune for Jet DST?
  189. hp tuner question
  190. New tuning/turbo fabrication shop in iowa!!
  191. Air Fuel question
  192. Finally some good data for Siemens 60lb Injector
  193. cutting wires
  194. Will scaling 200lb inj from 60lb inj be risky?
  195. RPM/Engine will Not Respond to Pedal, CAM Tune E38 HELP!!!!!!!!
  196. Gas Mileage Question....
  197. Tune all of a sudden running lean?
  198. Car turns over then dies after starts
  199. 2001 Pontiac TA
  200. Hitting the next gear problem
  201. Tire height wrong in computer?
  202. Looking for the trigger wire for LS-3
  203. 5.3l swap... HELP!
  204. Tuning for Hanging Idle
  205. ls1 wont run
  206. what is the best AFR for 12.5 cr engine ?
  207. Full tune or monitor?
  208. P0300 Code Can't figure it out
  209. Time for a tune or not?
  210. First Start Tune Recommendations
  211. Problems =\
  212. First time w/ EFILive, getting knock retard?
  213. how much timing are you guys running with CR less than 10.0:1? Chime in plz
  214. Power band
  215. How to test for VSS signal
  216. TPS WOES - Getting pissed
  217. Adjusting Map Offest
  218. innovate lc-1 wideband ???
  219. Innovate Wideband Installation
  220. Tunning 4l80e
  221. tuner near middle tn
  222. Holley hp efi enough for TT 5.3
  223. New mods, Can I drive to dyno???
  224. hp tuners help...
  225. obdwiz software qusetions ?
  226. dumb wideband O2 tuning question
  227. Car started hesitating bad after clutch install
  228. no tach signal, ecu?
  229. PCM programing
  230. When to throw it on the Dyno?
  231. Should I try fix my own tune or just re-tune from scratch???
  232. Lets Talk GMLAN (J2411 SWCAN-Bus)
  233. Hp tuners with hypertech
  234. Turbo injector issue... Help
  235. Camaro gauge cluster oil pressure and gas gauge help
  236. GMPP engine controller a/c request pin?
  237. tuning a brand new vehicle, why ?
  238. Any tuners in Northwest Ohio? Lima area?
  239. LS7 MAF Help.....I Have searched and cant find my answer
  240. HP Tuners
  241. need help! LQ9 runs great UNTIL it reaches operating temperature?
  242. how to hook up a PCM to HP tuners without going through harness?
  243. 4L80E Input Torque
  244. LM-1 and IAT/CLT tables
  245. What to use for speed density tune
  246. Anyone here knowledgeable with tuning?
  247. Tune or stall problem?
  248. off idle reponse falls on face
  249. PCM Question
  250. No com with Tcm or PCM with tech 2
