View Full Version : PCM Diagnostics & Tuning
  1. what does this code mean
  2. Would you drive this 200 miles to the tuner?
  3. does frost offer a discount for a retune?
  4. anybody know hat the KOEO and KOER tests actually test
  5. Newb switching to 3-bar SD Tune... questions
  6. what's best tune Maf or Mafless ?
  7. LS6 Wire Harness to Coil/injector Plug ?
  8. WTB HP Tuner Pro and Wideband
  9. Maf or map tune ?
  10. Top 5 tuners in dfw??
  11. 2010 Camaro PCM Swap
  12. Tuning/wideband placement questions
  13. Rearend Change
  14. Transmission shifting 1>2>1>2>1>2 @ WOT
  15. need some help
  16. Emissions delete?
  17. C5 Idle Relearn?
  18. need some help with DTC's
  19. PO118 engine coolant temp sensor problem
  20. Injctor size base tune?
  21. timing curve, carburator?
  22. wideband o2 location?
  23. good tuner in the n.c.-s.c area
  24. Jeff @ JR racing
  25. P0300 random miss fire slightly modified 4.8L
  26. LS3 swap failed smog.
  27. Please Help. LC-1 through EGR on 01 car...
  28. Injectors flow rate for 1999 camaro
  29. PCM Help
  30. Thanks For Your Time Geoff!
  31. Street Dyno (Redhardtopsupra's newest blog)
  32. need stock tune
  33. Surging Idle. I'm out of ideas and need your help.
  34. Hpt?
  35. What extent of tuning do I need?
  36. ABS Problem
  37. Fuel pressure accuracy via OBD-II?
  38. 02 TA How to Adjust Timing Table with HP Tuners
  39. What frequency is the GM LS1 Knock sensor looking for?
  40. Any Tuning Schools Around IL?
  41. Splicing 02 sensors
  42. EGR P0405 Poor Performance
  43. Cold start, won't hold steady idle, stalls at stops.
  44. LC1 and HPTuners
  45. Best Wide Band Controller to use with HP tuners Pro
  46. RPM Surging after cam install and tune
  47. ls1 will not idle, help
  48. Predator Instruction Manual 5.7 ls1 Z28 unit
  49. Idle Question
  50. Wide Band Controller?
  51. 2002 TA Vats Disable with HP Tuiners??
  52. Tuning a GTO with Magnacharger using HP Tuners
  53. SLP tune....just the tune files
  54. What to Do?
  55. Quick PCM lock question..
  56. does anyone have the wiring diagram for the 3 and 5 wire maff
  57. longterm fuel trim
  58. Tuning book, Noobie learning
  59. Who is the best with tuning FAST ecu?
  60. 02 sensor error codes, fronts same as rear?
  61. PCM question????
  62. fuel trim issues where to start? closed loop
  63. Where to start? Trying to learn EFI.
  64. 03 LQ4 w/DBW, which ECM?
  65. Scan tool for evap sensors
  66. 02 TA Replaced Radio now Vats is stopping car from starting???
  67. 2009 CTSV started while computer was uploaded and waiting for performance data.
  68. Swapping in some Ford SVO 30# red top injectors, what changes to make in HP Tuners?
  69. Need help 98 to 02 PCM swap
  70. Trigger wheel help (megasquirt install)
  71. LS3 mated to a T56 using a TBSS OS E67 ECM and Harness
  72. Hptuner using different hardware on same car?
  73. DLC Connection Issues
  74. IFR Table
  75. Any tuners in Wichita Kansas?
  76. 100% b2 ltft
  77. Any tuners in Wa?
  78. 2006 GTO LS2 ECM wiring questions - what are these things?
  79. Stroker tune question
  80. Readiness monitors...HELP.
  81. v6 to v8 question
  82. superchips
  83. How do I change shift points with Diablo
  84. Sensor Readings
  85. How do I tell if I bricked my PCM?
  86. BMW PCM flashing?
  87. Idling problem
  88. LS3 MAF Table...
  89. P0410
  90. Stumbling issue
  91. I need a CAN bus expert- Want to run a Lotus Elise dash with LS3 computer
  92. Having to disconnect injector plugs to start
  93. P0300 on pretty much Stock 4.8
  94. TREX tune
  95. wth is wrong with my car??
  96. HP Tuners Alabama!!!
  97. can anyone check an EFIlive tune
  98. random misfire confusion
  99. The Tuning School Learn-at-Home Course
  100. bogging down issue
  101. got my aldl usb cable, still cant figure out whats up with my car
  102. 2002 Tahoe electric fan?
  103. need help with trouble codes on a buddies car!!
  104. e 85 flex fuel conversion
  105. i need a engine harness
  106. car wont start it only cranks...
  107. Dyno near by
  108. VVT rev limiter from comp cams
  109. Passing OBD2 emissions with EVAP code?
  110. using HPT , bit of bucking
  111. Help: E85
  112. Does anybody do HP or dyno tunes in the KC area?
  113. using available licenses with efilive
  114. Mechanical Engineering and Tuning
  115. Anyone have the GL1 OBD-II to iPhone/iTouch cable
  116. proscan obd link problems please help
  117. 2010 camaro PE mode?
  118. Good tuners in OC, CA
  119. PO171 & PO174 I'm outta ideas
  120. HPT not downloading
  121. CalEditor is THE MAN!!!!!!
  122. Wideband placement
  123. Fuel cutoff comes on early, but only in second gear
  124. crate LS3 into 2002 camaro, PCM questions
  125. Auto Meter Air Fuel Ratio Gauge - Good Choice?
  126. Need to tune my swap, but no OBDII port how do I go about it
  127. Help needed in troubleshooting problem
  128. Will Error P1637 Prevent Car from Starting?
  129. E40 06 GTO 2.5bar tuning
  130. Rear O2's Question
  131. Tune is next on the list, who should I go with?
  132. most bang for your buck?
  133. Diablosport and 85mm maf question.
  134. Can you identify this PCM?
  135. Reflash and no start up
  136. 98 pcm and harness
  137. ls2 ... what sensors will work on my engine?
  138. got some codes need help figuring out
  139. Ls1 Edit/Scanner help a noob
  140. Mass sensor LS7
  141. 2003 Corvette LS1 PCM questions
  142. Ls1 Wont start, drove fine yesterday, today cranks but not firing
  143. 3 bar tune question with 411 pcm
  144. Previous Tune???? Diablosport??
  145. 98 to 02 PCM Swap and Keep Traction Control???
  146. Make '411 E85 capatable for Fbody?
  147. Help!! Need LS1 Edit Stock tune for 02 M6
  148. Data Logging - Problem with hardware/software/other?
  149. Running Rich
  150. Ls3 pcm
  151. tune rechecked, still maf code. ecm bad?
  152. How to Data log 97 OBII
  153. Tuning after head swap?
  154. Engine harness for L92 in a 94 TA???
  155. (VID) Misfire w/o DTC .... **Confused**
  156. diablo tunner
  157. DTC 463 and 507 after LT and magnaflow exhaust install
  158. Help!!!! IM New I Need Help With My PCM
  159. Idling at 3k RPM
  160. speedometer help
  161. P0102, P0121, P0803 Help Please!
  162. Piston Protection & TVS2300 tune
  163. ducks in order for tune
  164. PCM History / Overview website?
  165. efi emissons stuff
  166. 98 ls1 help
  167. Wideband 02 location
  168. Engine Speed Signal Pin 10
  169. good tuners
  170. NEED SUM OBD2 or OBD1 HELP
  171. NC Fbody owners come on i! Need recommendations.
  172. Help wiring up LC1
  173. strange misfire problem
  174. CMR tuning
  175. Looking to get a tune ?
  176. Help! I screwed something up trying to delete A4 DTCs for M6
  177. LTFT Question
  178. Car idles higher on startup, please help
  179. 97-98 ECM and 85mm MAF
  180. made my own V dash. check it out
  181. Ported throttle body and tuning
  182. BS3 and factory tach problem(99 trans am)
  183. '99 Suburban 5.3L - Code P0404
  184. need help new to efi
  185. 2002 ta 408 f1a
  186. Rob Raymer at AutoMotion, THANKS!
  187. Do I need a New PCM or one already programmed?
  188. c5 corvette tuning question
  189. Tachometer not working on 2000 Camaro
  190. Best tuning mods for a stock car
  191. Backfiring help!
  192. tuning a 98 pcm with edit
  193. vac leak + maf delete tune = smooth idle??
  194. Tuning a 93 Z28
  195. 02 ss ck engine light after headers, pcm reprogram
  196. 98 to 99+ PCM Question
  197. VE Table Value Over 100%
  198. 5 "not ready" codes WTF! cant pass OBD2 inspection
  199. Innovate Questions
  200. Best Tuner to disable the misfire code in 2002 TA?
  201. Ecm tunning for a swap
  202. Calibrating Autometer Wideband?
  203. No codes but car stumbles, voltage drops when slowing down
  204. Keep throwing P0154 and car misses
  205. Tune only ls2 questions
  206. misfire issues
  207. Mail order tune - "Saved data"?
  208. Diablo fan settings
  209. 102mm NW Tuning Question?
  210. Any PID's for determining misfire?
  211. Would unplugged knock sensors reduce power?
  212. P0327 Code ?
  213. Looking for a good tuner
  214. LC-1 through 02 sensor
  215. MAF question
  216. How to wire an LC-1 for portable tuning
  217. newbie question
  218. what coils do I have? Which will work best with AEM?
  219. Best tune for a friend?
  220. help car wont start dtc codes thrown
  221. Using fuel trims to do a quick tune
  222. VVT compatable computers
  223. Help with Cam position adjustment
  224. looking for a cam tune for 98 z with a4 efi live
  225. Need AEM UEGO Serial Cable
  226. Need tuning advice for a turbo Lt1 impala
  227. TAQ cables no more?
  228. PCM/BCM crashed, no start?
  229. help with p0300 please
  230. Move to megasquirt?
  231. E10 AFR different?
  232. Whats the purpose of PE
  233. threaded IAT and 3-bar MAP Sensors
  234. what is the best afr for a stock ls1
  235. Abit rusty can somebody run down tuning for me
  236. Auto tap, EFI Live and HP Tuners
  237. Swap efi live tune to hp tuners.
  238. NEED HELP!!!! TUNNING 98 BANK 2 o2 NOT RESPONDING
  239. Throwning p0343 code
  240. Z06 codes not making much sense..
  241. ls6 cam in 5.3
  242. Need Help: OBDII Scanner does not plug in!!!
  243. Case learn issues in swapped/hybrid car
  244. rear o2 sensors and cats
  245. Thank you to Poconojoe and G-body for their help
  246. Scangauge mpg going wonky, MAF CEL, stock MAF no idle...
  247. 1999 wireing harnes to 2000 PCM?
  248. What Pieces to a wideband do I need?
  249. Confused on which would be cheaper for me. EFI Live or HPTuners??
  250. PCM Choice for Engine Swap?
