View Full Version : PCM Diagnostics & Tuning
  1. rich at WOT 11.5 AFR
  2. comparison tune
  3. Question about tuning 98 Camaro(handheld tuner)
  4. Is there a tune expert here?
  5. MAF table scale by 134%...strange?
  6. advice please...
  7. Options for tuning '97 C5?
  8. AEM EMS - problem wit idle control valve and setting base timing.
  9. looking for tuner in the USA near the New brunswick border
  10. fuel gage not working?!
  11. Damage car?
  12. O2 sensor/Wideband question
  13. Code P0507
  14. Help with Scan tools
  15. Passenger o2 sensor stuck?
  16. Bad start up, idle, and no LTFT
  17. O4 Truck PCM?
  18. stock tachometer not working
  19. TPS question??
  20. SD tuning upper rpm
  21. What are the odds?
  22. Need professional help on a tune, who to call?
  23. PCM/VCM Tuning VS a Bully Dog Gt Tuner for Gas Chevy Engine 6.0
  24. Help needed, starts but wont run
  25. Got 2 codes driving me nuts
  26. Tune help !
  27. p0353 p0354 p0355 and p0357 all came up
  28. Yet another crank re-learn question
  29. whats the diff in std and pro hp tuners
  30. idle surge as soon as pcm sees wheelspeed
  31. hp tuner prob
  32. Tuning an ASA Spec LS1
  33. How much will dyno tune help my full bolt on 01 WS6?
  34. need a tune to fix a tranny problem
  35. cant get to idle
  36. will i need a tune?
  37. Limp Mode 3800 II GTP HELP PLEASEEEE!!
  38. Cant get idle puslewidth down and stable? Well versed guys inside
  39. LS timing advance goes to 0 at WOT
  40. Leaded fuel and O2 sensors
  41. Looking for hpt bin file for 2002 Express van
  42. Check out this log?
  43. Speed density LS3 tune?
  44. bad tune? or bad combination of parts?
  45. ECH Blue/Red Connectors??
  46. n/a vs n2o tune
  47. Checking temps from pcm
  48. P0327/P0332 Help
  49. code 420, 2001 Firebird
  50. DBW tps shows 100% at only 60% pedal travel (very sensitive pedal)
  51. P0171
  52. Best handheld tuner? Does it exist?
  53. Formula_LS1 log
  54. EFI Live tune
  55. 2000 LS1 tune
  56. At what level of a FI build should i step up to a aftermarket computer?
  57. Help ! Lq4 skipping popping backfiring rough idle gauges going crazy
  58. HEY SPONSORS! Alternative to Dashhawk?
  59. Trans Tuning
  60. do i need a tune to run a 150 shot of nitrous
  61. H/C guys, how much spark at idle on average seeing?
  62. Tuner in NE Texas
  63. can ecm be programed not to see misfire
  64. Misfiring Intermitently on all cylinders
  65. HELP HELP MAP sensor problem
  66. what wideband are you tuners useing?
  67. reset cpu to stock without tuner?
  68. help.. ecm and program for lq9
  69. Tuner wants to drill a hole in my TB
  70. SD tuning option
  71. Help My camaro wont run right bad ecu tune?
  72. is a 96 3.8 Camaro PCM OBD2?
  73. anyone have a ultra guage
  74. no spark help please
  75. 2002 TA + 370ci + LS3 top end + HP tuners Pro = no spark or fuel...
  76. PE commanded AFR leaning out at WOT??
  77. C0236
  78. Help Check engine light ?
  79. ECT thinks its overheating
  80. Need Help....??? speedo makes car idle high?
  81. AEM UEGO Wideband
  82. Need Help, Summit Racing's Version Of LC-1, Gauge Wiring
  83. How much timing?
  84. Quick cluster question
  85. Need help with testing MAP Sensor
  86. I have 2 HP Tuners - hows this work?
  87. Quick stock O2 sensor question
  88. Northstar Challenge. Possible!?
  89. when is a rich idle with a cam too rich?
  90. Resetting oil change light?
  91. Anyway to tune a 98PCM for dry Direct port N20
  92. Car dies at 5500RPM
  93. car will not rev past 2000 unless i ground 32+34
  94. p0300 misfire HELP!!!
  95. Formato's Fasterproms Gettysburg, PA Tuning From Oct 19-24th
  96. PCM Question
  97. what does this mean reflash ? help?
  98. Buy Tuning software, or have it done by a pro?
  99. trustworthy tuner in indianapolis
  100. 98 pcm wanting to do a 2 bar.
  101. Help, please check out my tune
  102. Low idle and vibration 2000 SS automatic
  103. best tunner in or around Missouri !!
  104. PCM Fail
  105. ASA LS1 won't run once car at operating temp
  106. Fastest Stock PCM controlled car?
  107. Anyone know of kaltechtuning.com in NY?
  108. Trying to ID my ECM (ECU) LS7 and diagnose a problem
  109. Need Help motor idles but wont revup( Got data log posted )
  110. U1000 code will spin over, has spark, no fuel?
  111. Smog fail. need to run leaner
  112. pulling lots of fuel and then misfire
  113. LT1 intermittent crank no start...ECU???
  114. Low Octane tables
  115. LT1 tuning?
  116. LG motorsports G5X1 cam
  117. dnyo tune
  118. Which bank is which?
  119. Can you re-define the "airflow modes" in HPT?
  120. Bucking and surging?
  121. MAF scale adjustment
  122. what should i change w/ headers and cat back? hptuners...
  123. map table adjustments for polluter cam
  124. Hp tuners
  125. Mail order tune accuracy?
  126. T42 TCM VSS Signal
  127. Is my car throwing out my tune??
  128. BS3 and major MAP issue
  129. 98LS1 & Trans in 2000 camaro ain't working
  130. Double check before I head out tomorrow
  131. Engine light comes on and power goes to NILCH... No stored codes
  132. AFR setup
  133. has anybody upgraded to pro on hptuners
  134. Help with injectors plz!!
  135. tune out emissions DTCs AIR, EGR, Rear O2
  136. Request: SD tune for stock ls1 w/ headers
  137. Rain kills my car!
  138. I need help for my heads and cam...
  139. HELP!!! SES P0161, P1133, and P1153 Bank 2 Sensor 2
  140. use hypertech with a custom tune also?
  141. upload tunes ?
  142. Looking for a close tune?
  143. psyco alarm.
  144. when to install injectors
  145. Fuel gauge issues on custom install...
  146. Need help with high idle
  147. SCT Advantage III or Diablosport CMR?
  148. Delete tq mgmt?
  149. A/F Ratio At cruise issues
  150. Slowhawk performance in Bridgewater MA
  151. Off idle/part throttle stumble
  152. o2 sensor code
  153. Lingenfelter 58 to 24 converter
  154. Tuning 36lb Gtp Bosch injectors
  155. 98 Starter Relay & Neutral Safety Switch
  156. Did I kill my MAF? ...LS1
  157. Bad PCM or Harness??? LT1 Car
  158. I need instructions for installing 2-bar SD OS on my new computer
  159. MAF loction and tube shape? Driveability Issues....
  160. starting problems....
  161. vats question
  162. Can my pcm be reprogrammed to lower cooling fan on temp.
  163. Just About Ready To Purchase.....!!!!!
  164. Cant keep the car running at idle after cam
  165. Cant get engine running. DTC 1336
  166. Looking for a tune
  167. th400 rpm versus mph
  168. (% Change To Fuel/Air Ratio Vs. RPM) lt1
  169. Pulls timing at WOT
  170. Someone with hptuners
  171. P0171/0174 Fuel Trim system Lean Bank1/2
  172. Wideband O2 Bung Placement?
  173. ABS inop and break light on after the Taller 295/45/17 Mickys went on
  174. help!! car suddenly dies after warm-up
  175. Idle tuning clarification
  176. tuning right
  177. Connecting WB through rear 02 HELP
  178. Low Traction question, a little different
  179. TBSS bogs below 3500RPM's
  180. Can i use a Diablosport Trinity on my 98 TA LS1?
  181. I need a Wide Band set up for HP. Any buyers guides or recomendations?
  182. What could cause the MAF signal to drop out?
  183. Runs like poo after 228r cam install
  184. (UPDATE !!) P0336 Crankshaft position, Help I am at my end, I cant take this anymore
  185. ........ Maf or Mafless ????? better?
  186. O2 mv SLOW TO RESPOND ON BOTH BANKS?
  187. Any tuning shops near Charlotte NC?
  188. Tune?
  189. Tuning problems. Car leans out no matter what
  190. Can some one walk me through installing my NGK wideband on my 2001 c5
  191. Is it possible to tell when the car enters closed loop?
  192. Dead PCM
  193. 02 Escalade LQ9 Twin-Turbo Startup???
  194. Here we go, P0418 code.
  195. 02 ta car won't idle and runs aweful
  196. Mechanical or HPTuners issue ??
  197. heads cam and tons of problems help needed
  198. Please help :(
  199. someone please help
  200. overdrive is not kicking-in
  201. Worth the trouble?
  202. pcm woes
  203. Free Tune!!!
  204. 98 pcm tuning
  205. 04 z06 procharged tune.
  206. Sputtering and Backfire HELP!!!!!!!!
  207. Questions about the diablosport
  208. hypertech power programmer specs
  209. Lets talk ECMs :D
  210. p1153... halp please
  211. How do you measure WOT performance while street tuning?
  212. FYI Wire Harness Sale
  213. Fuel trims all over!
  214. Timing dropping out intermittently under WOT? Ideas?
  215. hypertech max energy thoughts?
  216. -- lean when i press the gas pedal
  217. Fans
  218. does this sound right
  219. base tune
  220. Speed Density question
  221. LS2 not getting full throttle
  222. Do any sponsors sell the LC-1 wideband?
  223. Lowering cam for CA emissions, no tuning here, can I drive it to a tuner?
  224. pcm question
  225. build near complete - do I need a dyno tune or is a street tune adequate?
  226. Tuners in Kansas, Missouri, and Oklahoma?
  227. Starter tune for a cam install?
  228. Tuners in Oklahoma or Dallas
  229. HELP procharged car no timing log file inside
  230. trex-carb-single plane- timing?
  231. retune when you move a car to a different state?
  232. Diablosport ?
  233. Hptuners bin question
  234. Tuning gurus....have a question
  235. Deleting BCM help on a 96 firebird please.
  236. Will a 04 Grand prix PCM work on a 05 C6?
  237. ECM not communicating with Trans Controller
  238. limitations of my 98 pcm and a few questions
  239. Custom fuel guage calibration?
  240. frost tune questions?
  241. Dyno operator's comment has me puzzled.
  242. IAT Sensor required for Speed Density?
  243. ls1 to ls2 knock sensors
  244. Difference in pcms from 98-02
  245. Time drops on launch and shifts...help
  246. Please HELP!! No Start, No Gauges, No Fuel Prime!
  247. ASR turning off when A/C on?
  248. Getting weird random knock after tune
  249. ODBII How to connect? Serial Data Wire?
  250. Ls2 90mm throttle body questions
