View Full Version : PCM Diagnostics & Tuning
  1. Help with shock sensor removal
  2. Bolt-on Car tune E.T.
  3. Why Does B2S1 Fluctuate Weird At Idle? Scan Attached.
  4. Tunner question. I want to deside. Diablo,LS1Edit,HPTunner
  5. Taking a tune from a 2002 LS1 and transfering it to a 2000 LS1
  6. new head/cam tune help!
  7. Poll: P0343, What fixed it for you?
  8. Question on 00 & 01 PCM
  9. Numbers are awfully low after tune...what's the deal??
  10. Help getting my car started
  11. tuners in NORcal?
  12. Tune it yourself?
  13. Twin Turbo getting a retune. Look at my current Dyno graph!
  14. ABS INOP, Brake Light, Service Vehicle Lights
  15. p0307 after doing mopar combustion chamber cleaner
  16. Weird wiring issue.
  17. Need help!
  18. No spark after moving maf
  19. How do you tune for a manual 4l80e?
  20. Knock sensors
  21. Need HP Base Tune for T-Rex cam
  22. Ses!!!!!!!!!!!!!!!!
  23. open loop with short term trims enabled ?
  24. New tune, some issues I'm having
  25. inaccurate fuel gauge or someone is stealing my gas? ha
  26. Bank 1 is lean! Help please
  27. need help, security code...
  28. Is lean cruise possible for an LS2 GTO?
  29. wont pass inspection
  30. Running siemens 80s in your car..check in ,tips ,etc
  31. Scan Tool Question - Controlling Emissions - P403
  32. no start
  33. DTC 33 Problem
  34. dynotune pricing.... how's this sound to u guys?
  35. PCM out of a 02 s10
  36. Tuning question? Speed density problems
  37. LS1 TPS Sensor Specs
  38. Running way to rich!
  39. gto gauges
  40. Tunercat error message
  41. My car cuts out at 85 MPH!!
  42. vats questions, searched and searched....
  43. Can anyone recommend a stand-alone harness for 12586243
  44. Need help with Timing Tuner "HP in a box"
  45. EFI Live upgrade?
  46. OBD II not working
  47. Need DFW Tuner
  48. My car is a gas guzzler
  49. Help needed for 383 supercharged LT1
  50. Antilag using hptuners
  51. Looking for Cos5/Efi Live
  52. My car has 3 Codes.... What do I need to check ?
  53. What sensors do SD tunes remove?
  54. Do i need a tune? help!
  55. Voltage issue
  56. Need Tune In Southwest Kansas
  57. HELP:::what is the best way to do this swap
  58. Valet Tune??? Prevent strangers from joyriding my car.
  59. Please help electrical issue
  60. How accurate can a mail order tune get A/F raito
  61. fast system on a camaro
  62. Need start-up tune
  63. Somebody with Efilive, please help
  64. Traction Control
  65. Help identifying o2 locations
  66. Noticed a little idle problem and found some dtc
  67. 02 zo6 timing tables in a stock truck on 93 octane?
  68. Looking for input what Tuning software to buy
  69. BS3 Help
  70. a few questions about a mailorder tune
  71. Idle VE tuning seems to be wrong....
  72. LSx Distributor
  73. Desperately need help-No Interior Gauges
  74. Help! Intermitent no start
  75. L92 error codes????
  76. PRC 5.3 Ls1 set up's timing?
  77. Normal KR?
  78. 98 pcm.... searched and searched
  79. IAC Delete???
  80. Strange issue - bad PCM or reluctor wheel?
  81. help with tach hookup
  82. Cold Startup Tuning
  83. Shift Tuning question
  84. Stock 26s to Stock 28s, need help
  85. HP tuners Tuning help
  86. Help diagnosing a truck
  87. E38 Pinout for OBD II Port
  88. Need a tuner In the northwest suburbs illinois
  89. pcm hookup question
  90. p430 and p420 and check engine light on
  91. SCHEDULING: CSP's $200-250 GRAND OPENING Dyno Tune Special! June 7-20th!
  92. Why NOT to do mail order tunes - 66 rwhp gain inside!
  93. Knoxk sensor readings..... problem
  94. Base Running Air Tuning Help
  95. complete newbie
  96. How to check if coils are firing?
  97. Easiest-to-tune injector type in the 60# range?
  98. Walker Dyno tune in Trussvile AL (phone#)
  99. Reset PCM after O2 sensors install?
  100. Injectors going up in DTC when wet N20 kit comes on??
  101. Code PO343 hard starting cam sensor fix LS1 LS6
  102. need someone in Fort Worth area tune my car
  103. hard start
  104. Where can I get these??
  105. Idle issues, cant do the idle lol
  106. Setting Idle on a LS1
  107. Car only runs for 3 seconds- LT1
  108. EGR settings in Tunercat w/ LT1
  109. New motor in - Problems
  110. Weird KR issue....
  111. How much of a change in the tune?
  112. Question going from ls6 intake to vic jr and 90mm tb.
  113. SEs light wont come on? what are possible causes?
  114. 1999 vs 2001+ ECU
  115. need help!!!
  116. Avalanche speed limiter?!
  117. My wires broke from connector.
  118. how much timing on 93 octane fuel?
  119. How Much Timing At What PSI Are You Running?
  120. Holley hp and dominator efi ecu for LSX
  121. Any Megasquirt 3 info out there?
  122. predator erased my custom tune?
  123. EFI deleting codes.
  124. fuel trims on stock 2002z28
  125. Speedo reads 50mph with truck OFF!
  126. quick ? about HPTuners
  127. Stupid po327
  128. shift points
  129. Pcm lost connection while reprogramming..
  130. New guy help with shift points
  131. Anyone have the injector flow vs map kpa table for 83# injectors.
  132. Warning lights in dash???
  133. DBW throttle quits after flooring it
  134. Plugs after running at the track
  135. Where is the wire to go to the temp gauge from the PCM?
  136. M6 to T400 tune?
  137. modified stock timing table
  138. Speedo and Odo not registering Miles
  139. Ls1 speed densiety tunes?
  140. Can I start it before I get it tuned?
  141. problems with motor running right
  142. How to Check a Crank Position Sensor?
  143. sputtering and temp gauge goes nuts
  144. Whats a good wideband to use with HP tuners?
  145. LS2 PCM - Controlling Fans Issue
  146. Rear 02's still throwing an SES after tune.
  147. AC With a cam
  148. t56 pcm controlling 4L60e? Please read!!!
  149. Breaking up at 5k rpm
  150. Car starts then dies...
  151. buddy got his car tuned at new era performance
  152. This sounds like a MAJOR problem....
  153. LTFT Bank 2 showing lean Help
  154. Tuning in South Florida
  155. What can you tell me from these pics
  156. H/C tuning cold idle?
  157. What is the PNP switch signal?
  158. LM1 Wideband voltage problem with hptuners
  159. Do you need O2's? 2 bar SD
  160. Check out my log file, am I shifting?
  161. obd1 vs obd2
  162. Spark rev limitier?
  163. LC-1 wideband
  164. Using factory tune from different car
  165. Pulling timing bad!! Need some insight!!
  166. What is the HP tuners parameter for Speedometer PPM setting?
  167. How to properly tune for Misfire detection
  168. Switching from 99 F-bod PCM to Truck's
  169. Anyone have voltage table for MAP?
  170. Anyone lean out inj flow table to suit pressure?
  171. IAT heat soak make idle lean? HP Tuners
  172. Attention k-mart shoppers
  173. 2 BAR SD Timing Table...
  174. What are the symtoms of a broken ground wire??
  175. BS3 Datalogger
  176. 2000rpm idle.... sometimes
  177. tuneing ?
  178. cam only timing
  179. pcm
  180. Need Tuner In So. Calif.
  181. Can Diablo Predator fix my idle issue?
  182. code reader!
  183. idle issue after tune please help
  184. missing .5* of timing from commanded at WOT
  185. NEW 383 tune question HELP
  186. what timing to run in my 6010 msd box for startup
  187. Help me tune my car!
  188. pcm
  189. EFI Live OS swap?
  190. ignition timing
  191. Need LT1 OBD1 A4 Shift help please. Datamaster file
  192. non lsx car fuel pressure help/question
  193. I need a 98 PCM
  194. LC-1 or LM-1.....which is preferred?
  195. I have been told I can get my HP Tuners to read my wideband????
  196. Old LS1Edit .. Tuner can't get into my PCM?!
  197. Which stock GM vehicles use 42# Delphi injectors @ 59 PSI?
  198. po102 again...
  199. Magnacharged ctsv---knock sensor issues
  200. ? on 5.3 harness w/ls1 ecu
  201. Need help with a pcm swap 98 to 99+
  202. Idle issue after Fast & L/T install....WHERE TO ADJ.???
  203. 3 Bar SD Tune... leaning out when hot. Help.
  204. WOW! just installed my diablosport tune.
  205. 2 Step with Hp Tuners
  206. EFI Alchemy in FLA?
  207. Gonna dyno, what a/f / spark combos to try?
  208. HELP! LS1 GTO idle w/MS3
  209. p0420 please help, quick question.
  210. Tuneing on open down pipe
  211. Hitting rev limiter on 1-2 shift ???
  212. Anyone use a Gen II Scan Gauge?
  213. testing coil packs with a DVOM
  214. tuning for gears need help
  215. Tuning process/advice
  216. Do I need a new PCM? or is this fixable
  217. thrown codes
  218. Looking for simple datalogger/code reader/dashboard
  219. Logging 2 bar MAP in HPtuner only hits 105kpa
  220. Manual to Auto (I know)
  221. o2 sims
  222. How does the PCM control A/C?
  223. Weird computer question
  224. 93 z28 has speed limiter
  225. p102 help
  226. how can I tell if my car has an hp tuner?
  227. Help! New laptop and wont read AFR through AC
  228. HP Tuner Credit Question
  229. is this at all posible???? skip shift came BACK!!!??
  230. Corvettes of Westchester
  231. All out performance Springfield MO
  232. HP Tuners 2.22 and 2.23beta on the same computer, How?
  233. ABS INOP Light
  234. DLC & MIL wiring questions
  235. Cold Start Problem
  236. HP Tuners logging through AC wire? how?
  237. Running cool, is this a problem
  238. Pressure sensing spark plugs
  239. HP tuner. unable to open file?
  240. 98 Z28 question
  241. Need help with speedometer recalibration
  242. LT1 with classic fast questions
  243. E-Mail order tuning?
  244. Need HELP!!!
  245. just wondering
  246. Autometer tach issue.
  247. base tune help
  248. Need some tuning advice-Vinci owners help..
  249. Underload backfire/misfire/not sure "log info" included
  250. Formato Fasterproms Tuning and Porting Gettysburg June 20th thru the 27th
