View Full Version : PCM Diagnostics & Tuning
  1. aem plug and play?????
  2. pcm tune columbus ohio?
  3. any lt1 tuners in memphis
  4. lc1 wiring
  5. How much Altitude change allowed before retune?
  6. hptuners wideband offset
  7. P0704 Code and throwing codes for both O2s.
  8. need help slight vibration.....
  9. HP Tuners question
  10. Which tuner is right for me?
  11. GMPP LS3 controller-anyone from GM think you can help?
  12. Sniffer Emissions
  13. Tuning software?
  14. Is it ok disable "power enrich" and "boost enrich when tuning in HPTuners?
  15. The Process of Frost (Review)
  16. A4 To M6 Tune?
  17. Fast managment tuning question
  18. Using 83#injectors HPtuners only goes to 63....
  19. Help TPS 1.25v from pcm at the plug
  20. Dyno tune now or wait until summre blen gas?
  21. please help ( P1111 and P0113 )
  22. Input on troublesome codes
  23. Low res circuit code 0016
  24. Hp tuners learn here!!!
  25. Need to change driver side cat, will it shut off SES?
  26. will this harness fit the d585 truck coils
  27. Passing OBD II with EGR, AIR, and rear O2 sensor tuned out
  28. Using A Predator Programer To Play With Shit Points When I Have A Custom Tune
  29. Stall converter tune question
  30. Generator L Terminal P1637? / Possible alternator problem?
  31. Wideband AFR Problem?
  32. AFR at WOT in the 3k area??
  33. Bosch or AC Delco front O2 Sensors?
  34. got Dyno tuned today
  35. Throwing bad o2 sensor codes after axle install and tune
  36. fbody gauges and truck harness?
  37. p2008, p0020, p1000
  38. HELP!! denso o2 sensor part# ?'s ls1
  39. Knock Retard???
  40. Cruise Control won't work after wheel spin
  41. Will a PCM reflash at the dealer reset my tune?
  42. Idling Problem
  43. HELP lt car puting ls in it!!
  44. Gainesville and South Florida - Formato Fasterproms Tuning and Porting
  45. gear change - speedo tuning
  46. data logging and turbo math help
  47. True Respect! Frost!!!!!!!!!!!!
  48. Intial Tuning for speed density and 60 lb injectors.
  49. o2 questions? need help!
  50. looking for the best how to and learning info for useing HP tuners
  51. trying to see how much of need i am for a tune...
  52. Hooked a battery charger up,Now my WS6 wont run???????
  53. Hp pro or standard. Turbo car way to rich
  54. tuning with converter swap?
  55. Random engine misfire code- please help
  56. Looking for a tune
  57. anyone know how to get ahold of Glenn Lipinski?
  58. New LS3 only runs at 3000-4000 ????
  59. need help 04 GTO 402 stroker!!!
  60. About to get a tune
  61. o2 sensor problem
  62. Worth it to get a tune right now?
  63. I Read the VCM with the DOORS OPEN !!!!
  64. LS3 5th Gen Pin out diagram?
  65. tune question
  66. 24 byte 98 PCM question
  67. Airflow error to Effective Area
  68. need youR help guys need tune software for 94 trans am(LT1)
  69. 98PCM to 99+PCM Questions
  70. Wideband power
  71. Where is the injector scaling chart ??
  72. WB AFR shows something differnet to O2's
  73. needing a hptuners bin for 5.3 turbo
  74. narrowband O2 and LC-1
  75. Car won't start with new injector data
  76. where do i find iac counts
  77. O2 sensor question
  78. Dissabling the rear O2's & AIR
  79. engine wire harness question
  80. Please help!!! Very frustrated
  81. question 98 ls1 ecu and limits for 4l60e tuning
  82. 1987 shortbed chevy with a 6.0and a 4L80E
  83. answer needed asap. attn foff667
  84. Horse power house
  85. Can a Automatic PCM be flashed for a Manual Transmission?
  86. ABS Inop and Spazzing Lights
  87. Tune and use as generic scan tool
  88. Bad BCM?
  89. P0152, P1133 and P1152
  90. (LT1 OBD2) Anyone use Auterra Dynoscan?
  91. Can you adjust your a/f with the lc1
  92. Need help/info....
  93. Why am i getting this p1510
  94. 1999 Camaro Wiring Diagrams
  95. Datamaster logs - Something not right with my LT1 - Any ideas?
  96. Wiring up an ls6
  97. Idle Issues: hanging at 12-1400
  98. Re-flashing to stock parameters?
  99. Hp Tuners credits
  100. LC1 error code 2
  101. ground locations
  102. Summit EFI tuning DVD
  103. Timing under WOT ??? help!
  104. vin and os
  105. Would a modified MAF turn on bank1 and bank2 lean condition codes?
  106. '96 LT1 VIN into a '02 LS1 PCM? EFI Live/HPT
  107. Wiring Spek A/F Gauge for Wideband
  108. video of "part throttle lean" condition!! tuners please advise!!
  109. MAF bad?
  110. HP Tuners Issue can read but not write to computer
  111. tuning and wide band questions
  112. Engine light on a 05 Malibu due to opened gas cap.
  113. Help idle problems
  114. If I buy a new PCM...can I have my current tune dumped into it.....
  115. Wideband question on installing?
  116. help me learn from this log
  117. MA tune needed
  118. Front Oxygen Sensors - Intermittent Problem
  119. Who has racecar tuning tips?
  120. who is considered the best tuner in PA?
  121. intermittent low oil light even with sensor unplugged
  122. O2 Simulators
  123. types of tunes
  124. ls1 swap in a toyota with dbw help!
  125. Can someone take a stab at this.....maybe PCM related
  126. Another "which" wideband question
  127. Its been awhile, and I'm rusty
  128. Racepac dealers...
  129. Can Datamaster datalog AEM Uego wideband?
  130. PIST, Car finally done and my tune goes to Safe mode..
  131. diablo predator + Gear settings ((Need help))
  132. Whats the (BEST) Wideban/AFR tach ????
  133. DBW throttle pedal compatibility
  134. Need help engine swap cluster acting up.
  135. Fast or big stuff3
  136. CEL off with o2 codes on?
  137. Autotap question
  138. Richer and Richer at idle with SD tune
  139. hp tuners bullshit
  140. dynotune?
  141. is this a decent wide band guage?
  142. Impact of Exhaust Flow on Tune
  143. E67 ECU FI tuners or tunees CHIME IN!!
  144. Rear 02 Sensor Question
  145. 99+ knock sensors on 98
  146. totally new to tuning, diablo predator
  147. Wait4Me tune and Diablosport compatibliity
  148. L92 VVT e38 cam swap tune with a t56?
  149. Tuners in Houston area
  150. do i need a tune
  151. Clearing Codes Permanent?
  152. wireing harnesses
  153. refresh my memory...
  154. gm vdr(vehicle data recorder) / scan tool 1996-2010
  155. Opinions on my thoughts/plan...
  156. weird iat issue on h/c ls7
  157. Where would one learn to tune professionally?
  158. obd1 Tuning software
  159. 99 pcm ?
  160. Truck maf from a 99 sierra 5.3 is it 85mm?
  161. 2000 TA LS1/T56 tune issues
  162. Tuning a turbo LS1 with EFI Live
  163. Wideband placement
  164. h/c ls7 wont start easy
  165. P0160 code(heated 02 sensor)
  166. tuning gains from headers
  167. lq9 swap
  168. WTF LC1 wiring question
  169. need help with tunercat
  170. P0157 O2 sensor Bank 2 Sensor 2 - Help
  171. whats the stock pcm limits
  172. Are these number OK or a bit low?
  173. need help with my wiring harness
  174. Where can I get the computer reprogram
  175. Wideband!?
  176. needing tuned
  177. Tuning My Car.
  178. Do I need LTFT trims
  179. HELP! My diagnostic connector isn't working?
  180. tuning&injectors?
  181. HP Tuners to FJO wideband Q's
  182. New to Tuning..
  183. im thinking about getting into tuning myself
  184. Steering sensor code
  185. anyone know how to fix this code???
  186. jet dst/mxscan
  187. LC1 will go lean as soon as the coolant reaches 192*
  188. Tuners in So-Cal???
  189. po327 code
  190. need help
  191. knock warning system?
  192. misfire after cam install
  193. E38 ECM, does it have the TAC.........
  194. Do I need MAF and rear O2?
  195. Mail order Tuners!!! Step Inside!
  196. How to remove pins?
  197. C5 PCM question
  198. Can anyone explain the details of how the LS1 control system works?
  199. PCM programming.com - Feedback?
  200. Help! Did M6 to A4 swap...trying to load A4 tune with LS1 edit...
  201. tune or not after ls6 intake?
  202. lt1 meets turbo now time for a tune...?
  203. tuner in arkansas?
  204. Mass Air vs Speed Density
  205. 2000 Stock 6-Speed Tune
  206. O2 sensors
  207. Help
  208. HELP spedo not working after header/full exhaust install
  209. looking for pcm pin outs and wiring diagram
  210. ecm/pcm recommendations
  211. GMPP LS3 E67 ECM on my Blazer Won't Start.
  212. Mail Order Tune
  213. Can you swap front and rear O2 sensors to get rid of code P0133?
  214. ECM vs. PCM vs. ECU?
  215. Where can I get pins for PCM and blue and red covers for terminals
  216. Have an AEM wideband need cable for tuner to use??
  217. Who has FI Setups that make 900+RWHP?
  218. 98 PCM, Big Cam Issue
  219. Crate Motor Tune
  220. VE tuning on a '99 C5
  221. LC1 setup (ground offset)
  222. About 20 miles after tune car pops a P0101 runs like crap? At a total loss..
  223. Do I need a tune after gear change?
  224. EFi live help
  225. I need a tuner. Who can do it?
  226. any problems with dashdaq
  227. Tuning a GMPP PCM
  228. No start issue. Need help!!
  229. 08 Z06 Misfire Issue
  230. Looking for a Reliable Tuner in or near OH!
  231. Which tune to go with?
  232. LS3 Hot Cam Tune
  233. Where do I take it for a TUNE???
  234. PO704 code help!
  235. Data Link Connector PROBS and QUESTIONS...???
  236. SD tune and total conversion?
  237. Can anyone use HP Tuners?
  238. Tune Issue?
  239. Need Tuner near Yuma,az
  240. Is it safe to start and drive my ls1 without a tune?
  241. wierd idle
  242. 98 sd ???
  243. Tuners please come in..!!!! VIDEO ADDED
  244. Is this a startup tune issue??
  245. 2006 5.2 Wiring diagram
  246. After 180 amp alternator pcm acting funny.
  247. bigstuff3 tuning
  248. lookin for Mike Brown
  249. Tuning for Speed Density, wont pass State Inspection
  250. Anyone know a way to settle down a PLX Wide band?
