- Tuning for Speed Density, wont pass State Inspection
- Anyone know a way to settle down a PLX Wide band?
- Can tuners give there opinion on this?
- '07 Sky engine swap
- '04 CTS -- can I get the VIN through a J2190 message?
- GM tech 2 question
- Drive By Wire Problems!!!???
- I Don't Know Nothing
- LS1 EDIT anybody still using this?
- my tune has gone to shit
- rear o2's
- Check engine light with BS3
- Tuner ?
- 3 bar
- 1999 Camaro Fuel Gauge not working after 1998 tank install
- help with tuning
- Stand Alone....
- Hypertech Hyperpac
- Wideband calibrating
- Need Help with TBI tunning
- Diablosport DS downloader
- Frustrated
- What to do for blank ecm?
- datalogging with aem wideband.
- LC1 Calibration
- O2 sensor ?
- MAF & Boost
- Nothing serious just annoying...
- How do i fix the KR on my car
- For you wiring gurus...
- air/fuel kits?
- Trans tuning
- HP Tuner Question, Serial Cable to USB Cable
- Need stock '97 M6 .LT1 file (LT1Edit)
- Check this out: Is YOUR TACH this slow?!?
- No start condition. Crank Sensor?
- Diablo Tune
- Truck harness can I use?
- dynamic spetrum tuner
- Bcm/alarm issue..bestplace to ask?
- SLP diablosport & Torque Management
- Swapping front and rear O2's
- Need HP Tuners bin file for SD 415
- AFR question.
- tune question
- i have no idea whats going on
- Lose MAP readings when convert to SD tune.
- help!! misfire on cylinder 4
- Ft Myers - Formato Fasterproms Tuning on Feb 3rd
- Predator scan question
- Gainesville - Formato Fasterproms Tuning Jan 28th and 29th
- Tuners....question about the MAF...
- Wideband on Boat?
- HPTuners + Windows 7
- Big Stuff 3 HELP...
- How to Re-wire from PCM?
- Tuning Question regarding injectors
- Think I fried my pcm?
- tuning A/F w/ new MAFT
- tapping pcm
- tuning the right
- Tranmission Logging w/Datamaster
- adding a screened maf
- 2 step help
- does this look like bad o2's?
- Holley Dominator EFI ECU, pricing?
- Wideband ?
- LS6 crate motor swap into camaro. tuning question....
- Tuning or Cam for best MPG?
- Need help, p1336 code, no tuner available
- how much timing?
- Will I pass emissions in CT?
- lt1 map sensor circuit high code
- HP Tuners related- Simple questions step inside
- compared tuners
- Newb question... How do I save my current tune to my computer?
- First start up, will it start with my tune?
- Do i need a wide band O2 setup for mail order tune?
- new to tuning just got HP tuners!! reading pa area
- STUMPED?? 02 sensor issue
- Power Programmer problems.
- ls2 stand alone pcm pinouts needed
- 2000 A4 pin#47
- Computer flashed Vats deleted no fuel?
- New to hp
- head and cam ecu tuning
- Random Cylinder Misfire Code after Cam swap
- Mail Order Tune From SLP?
- What happens to PCM/BCM in a wreck
- who should i get to dyno tune my VVT LY6?
- Do you need a wideband o2?
- Came code sensor code keeps popping up?
- Guess I gotta learn to Tune "Where to start"
- Tuning Questions on 240sx Swap
- Wiring harness help
- anyone converted a 2008 LS3 M6 e38 HPtuner tune for a e67 ECM
- Short to ground? No start (again)
- 02 Camaro SS rough idle and thick smoke
- Possible Computer Problem
- Bad PCM symptoms??
- boost with stock e38ecm/maf
- Ls 1 edit
- NEED smog tune!
- PCM Help
- No injector pulse..Help
- High idle?
- Check out my logs... I'm getting horrible MPG. Any ideas?
- obd1 to obd2 conversion ?
- Install complete now need tune
- Where is my problem (car not turning on)
- Will This Wideband Sensor Work with My Gauge?
- tuning ?
- BS3 and remove stock PCM??
- mail order tune need help
- need help with setting my 4l60e up (hptuners)
- DBC vs DBW
- Replaced PCM, now I can't get my trans to shift right!!
- Best LT1 tuning options?
- O2 Sensor
- Need ls1 basemap with efi live and big cam
- New Parts Installed need help!
- need base MS4 tune
- Getting into tuning
- Dyno / Tuning around Huntsville, AL
- Underhood fuse box pics
- Need Some Help
- tunnercats help
- LS7 starts and then dies
- C0045
- fuel presure
- LNC-002 & HSW wet kit
- TTS Datamaster Download?
- Vcm making me crazy
- electrical problem need help
- pcm can read tune but can't flash, failed bootloader
- re-tuned my mostly stock SS
- HP Tuners application key? Anyone have an old one I can use?
- Need help with Speed Density Tune
- looking for a ls2 cam sensor
- Installing a BBC carbed into 01 TA????
- Dyno Dash?
- should i use predator on a tunned ecm
- I'm looking for a 2001 fbody .bin file (not .hpt, not .tun)
- Best Approach For Tuning My 427?
- Avg Tuning Time
- True tuning expertise?
- bcm or not
- planar vs. thimble O2 sensors
- Tenn FI tuners
- obd-2 port not working
- LC1 wiring question
- Kind of a big tuning issue
- Help...wierd O2 sensor signal
- Hptuners in a Virtual Machine (os X)
- Simple to use stand alone Data Logger?
- idle problem on new ls1 + hot cam
- Need tuner recommendations in the Kansas City MO surrounding area-cammed LS7
- 2010 Camaro TCM Issue
- Need help...new 85mm maf and 98mm lid
- Is it ok to eliminate Burst Knock Retard?
- p0500 code help please...
- oxygen sensor keeps going bad
- Help With Codes
- 2003 hummer help
- odd problems! help?
- 2, 3, or 4 02 Sensors?
- help delete codes
- PCM s/n decodes
- Low end Sputter
- Stage 2 Intake and Tuning Results
- Tuners in arizona/california
- first startup of LS2 402 on stock 98 tune?
- 98 fi car d1sc 408cu 125duty cycle?
- A4 staying in 3rd gear after trans swap!!
- HELP Surging after blackwing and cold weather
- Need help HP tuner ???
- Banish's GM EFI Tuning Beginners Guide or the beginner course at the Tuning School?
- Anyone Used Rev and an Interceptor or DashHawk?
- PO171 and PO174 help...
- gm performance parts pcm
- 6speed pcm to automatic?
- Need help big time with pcm someone help me
- P0430...P1133...P1153...and a P0430 PENDING...HELP
- Spark advance problems!!
- DTC lookup software
- Using a single O2 sensor
- Rear o2 readiness tests not completing.
- HP Tuner???
- So i through the code p0430
- HP Tuners question..
- FAST Xfi harness to retain gauges & A/C??
- crane cams
- Tuning A4 in PCM vs Trans Controller
- Do I have to run knock sensors?
- p0120, malfunction??? on my 5.3 jeep wrangler
- BMW M3 w/ LS1 1500rpm stumble?
- Bad PCM?
- No starter, no gauges, OBD2 not working either
- Looking for a basic Hptuners tune
- Running a wideband with HP Tuners Std.?
- Need an STS tune
- Power Window Switches flash every 8 seconds
- !cats pass emissions with a tune??
- newb tunning a turbo car
- still getting SES light in the morning
- 01 vette "reduced engine power"??
- So who's the LS1 GOD?
- P0135 - How much to fix?
- Mail order tuning
- Car failed smog test.. but passed emissions... need help!
- Gauges recommended for tuning?
- MSD 6010 timing curve question
- Cam'd LS3 help
- Trifecta Tunes First 2010 Camaro V6!!
- Ordered a new ECM....got questions
- HP Tuners VCM Suite standard or Pro
- My car seems to have lost a couple cylinders...HELP
- CA Emissions IDEAS..
- P0101 & p0106 code Help
- A/F way off.
- hpt file to efi live file anyone can help?
- just bought diablo sport predator and i need a custom tune
- Master efi tuner - gm efi...pre-order now
- Tach signal wire for 05 vette
- Do it all Standalone
- EFI Live 98 2bar sd base tune?
- o2 heater sensor
- Universal o2 sims
- changing pcm
- 382 Stoker Tune. Drives great. Looks funny.
- SLP Diablosport vs mail tune
- PCM Pegged out (MAF)...
- holley 950 help
- flooded parking lot....intermittant missing...codes
- what does adjusting impact factor do?
- lq9 silverado tuner
- Can someone help me with o2 sensor wiring?
- Need some Predator Codes
- Custom Predator tune, where to get one.
- wondering how much a tune will benefit me
- Time for a new tune?
- What type of tune?
- G8 GXP tuning
- Left bank ?
- Replacement ECM, rough idle?
- Gm uses microsoft
- Oil Pressure to PMC
- LS1 Conversion With Issue of Computer Pulling Timing after Running for a while!
- Random Cylinder Missfire Code
- knock sensors problems
