View Full Version : PCM Diagnostics & Tuning
  1. where to put lc1 controller??
  2. LM-2 through EGR
  3. 98 pcm help
  4. 05 C6 Cam and bolt ons 453 RWHP
  5. Think my pcm took a dump
  6. Car jerks when letting off the brake
  7. lots of wierd codes being thrown
  8. LT1 with EFI Connection 24x need base tune
  9. bolt-on tunercat files? 94 lt1
  10. How to change vin
  11. BS3 Crank trigger MSD7531 belt drive dist
  12. Does any tuning software allow "profiles"?
  13. Looking for a Tuner around Lansing,Mi
  14. VIN Changing Question
  15. H.e.l.p
  16. Did the blackbox to 411 swap .. problems
  17. FAST A/F digital dual sensor meter?
  18. Anyone use the fast flash tuner?
  19. Tuner for a 98 t/a
  20. AFR for WOT and Idle question
  21. Is this true or not?
  22. Really lost on fuel trims
  23. coils
  24. Looking for a scan tool w/ABS and bi-directional functionality
  25. Can I find a PCM for a 5.3 Manual?
  26. AEM WB readout in HPT
  27. need advice about whipple dyno tune tomorrow
  28. Changing PCM type and engine harness
  29. Do i need a tune?
  30. Need computer tuned Georgia
  31. Anyone have efi scanner in mesa arizona to perform a CKP relearn
  32. Box Fear....
  33. LS6 swap Tuning Issues
  34. code po106
  35. tune in hawaii?
  36. Do i need a tune after stall
  37. Cam tuning with and without headers??
  38. diablo sport predator 2 gm series
  39. Maryland/NY tuning companies
  40. Buffalo/Rochester-NY tuners?
  41. Is there a possibility that a PCM could accept a tune but still be bad?
  42. 04 got heads cam tune today numbers...TQ Low?
  43. What type of engine control and programming to use?
  44. TPS Values out of range?
  45. Anyone have experience desoldering, programming and resoldering chips?
  46. 0 vaccuum
  47. PO134 and P0101 What the hell.
  48. Open Loop Slowing Me Down?
  49. Opinion Change LS1 Edit to Hp Tuners
  50. predator is it worth it
  51. VERY high Eq Ratios (?)
  52. Can my tuner "borrow" my EFILive V2 to tune my car?
  53. Lm1 problem?
  54. Part Throttle Shift Pressure w/ Diablosport
  55. Idle relearn anybody???
  56. maf vs speed density
  57. Does the clutch switch affect fueling?
  58. Injector scaling issues
  59. Erratic timing during spool up...
  60. Just posting some readings at idle
  61. high/low timing table ??? when??
  62. SES need help pulled code using HP Tuner.
  63. wtb hptuners
  64. PO134 after LT install........Insight?
  65. BCM question?
  66. hooking up LC1 wb gauge..
  67. silverado truck tune
  68. hp tuners or efi live
  69. weird wideband readings
  70. large injector tuning - E40
  71. evap leak problem
  72. In need of a stock 2004 LQ4 tune for manual transmission
  73. Hand held tuners for the 1998 model year...
  74. FAST 37 lb./hr LS3 injector data
  75. PCM after nitrous backfire.
  76. Need Good Tuning Advice...
  77. Couple of codes: P0101 and P0135/0155
  78. Car Starts, then dies within 20 seconds
  79. e38 ecu VSS output problems
  80. what pcm to use?
  81. Intermittent SES Light on 2000 SS I Just Bought, Any Ideas?
  82. Can you guys tell if i have a blown head gasket?
  83. tuning with hpt 1bar maf rtt?
  84. Not my LS1 this time.
  85. switched computers on LS6 no spark
  86. Service Engine Soon Light.
  87. ltft's maxed after getting car back from shop rear end work why?? MIKE L please help!
  88. what happens at 70 seconds??
  89. Stalling -- rpm gauge dies / motor running
  90. L76 injector values
  91. ls3 carb motor question
  92. where to find tuning sites
  93. PLX wideband w/guage need help hooking it up.
  94. frustered...
  95. Need help pin out for a 98 chevy
  96. where to get pcm flashed???
  97. 4l60e pulse pr minute
  98. multiple codes, hopefully related
  99. Msd 2 step
  100. Just finished turbo build, first time using HPT, having issues. . .
  101. Is this a EBCM or BPMV Issue?
  102. Lc-1
  103. What Idle MAP pressure w/ H/C/I swaps do you generally see?
  104. A4 Shift Settings
  105. PCM fuse
  106. suggestions on who to use for harness and ecu
  107. I think im having computer issues...reflash needed??
  108. ABS INOP, Brake, and SVS lights turned on
  109. Wideband acting funny....
  110. Electrical probelm after tranny install.
  111. Tuning help
  112. PO121 code after LQ4 swap
  113. need help, data log attached
  114. tr224 bin file request.
  115. Torque Mgt & Knock Learn Factor: Help please
  116. LS3 40# injector tables on LS1 PCM...
  117. OBDII Scanner can't connect(Resolved)
  118. speed density tune in Oklahoma City?????
  119. Just Finished my Wideband O2 LC1 Install Lots photos
  120. Diablo....do not use if not factory tune warning...question
  121. Four SES Codes.. Help
  122. need name of good tuner around desmoines iowa
  123. Retard Modules and PCM readings
  124. slight misfires, driver side only
  125. I need some tune info
  126. Way lean!20-23/guru's help!
  127. Tuning Help Please
  128. gauges stopped working
  129. low voltage on knock sensor??
  130. LC1 ground questions. did search and found conflicting answers
  131. MS4 and Dart 205's tell me what is wrong here.
  132. BS3 Updates
  133. AFR not scanning
  134. Safe Rev limit for an LQ4?
  135. OBDII CAT monitor not running
  136. no spark
  137. fast standalone question
  138. 2004 LQ4 auto to manual tune: questions about this
  139. SES light & 2 codes NEED A LITTLE help
  140. MAF readings at Idle/WOT
  141. What the hell is this INSIDE my pcm?
  142. Help with a H/C Trex!
  143. Need HP Tuner .bin file
  144. TUNING HELP~ Battle Creek, MI
  145. Performabuilt transmission...What tuning needed on install?
  146. Which predator to buy?
  147. who does dyno tunning in tenn.
  148. Predator Tuner?
  149. attempted maf tune.
  150. Finally got the timing up. now please help me get this one little tweak.
  151. why is my car getting leaner?
  152. xfi tunes
  153. New O2 sensors
  154. Accel DFI, intermittent no spak, no start issues.
  155. what sponsers offer mail tune
  156. Another motor with KR problems.... AFR ok, very low spark, and still getting KR!
  157. Do I need a Tune
  158. pcm harness diagram
  159. Runs better in open loop?
  160. accel gen 7 install, no power wire for starter
  161. Ford Racing #30 injectors
  162. Issues with my tune/O2 sensor
  163. Dead PCM?
  164. reset superchips programmer
  165. need help big stuff 3
  166. Hypertech question? (I know there junk)
  167. e38 ecu speedo and tach problems
  168. Need a raw .bin
  169. Left my car at a gas station...help me out!
  170. Need Rear 02 sensors tuned out in Oregon
  171. Rev limiter wont change!
  172. LM1 LMA-2 RPM converter TPS and VSS hookup
  173. Little lean? Too much timing?
  174. My KR and octane table problems
  175. AUTOTAP Question...
  176. Newbie about pcm/ecu's and tuning. Help me please.
  177. Diablo Sport Tuner II worth it?
  178. ITB tunning
  179. thinking of buying HP Tuners
  180. GM EFI Tuning Beginners Guide DVD
  181. Scanner wont read my car
  182. Good Dyno tuner for a 355 LT1 around Kansas City
  183. what can fix these codes
  184. sd tune ?
  185. pcm lock?
  186. HP Tunners Credits
  187. Tps,map sensor
  188. MIL Installed
  189. do you think a tune would help this setup alot
  190. tach / e 38 setting - # of pulses ?
  191. factory tune wont work
  192. tunning transmission?????
  193. Oxygen Sensor Wire Switch
  194. Help-fuel pressure problem
  195. VSS question
  196. Newb to 2 Bar MAP tuning.. HELP!
  197. PCM Question
  198. looking for a tuner
  199. Stock tune what to expect
  200. tcs code help please
  201. My ECTs and AFR are dropping and stopping the motor
  202. Need help tuning with efilive using a .hpt file
  203. how to run LS1 out of car
  204. SCT Dash Scan help
  205. Is hptuners.com down
  206. Help With my LS1m Scanner
  207. OBD2 Connector Location
  208. E38 vs E40 vs E67 - live tunable?
  209. Tuning School
  210. single or dual wideband setup?
  211. Mail order tune?
  212. Would a gauge cluster from an 01 work in a 98?
  213. Mail order tune using a new PCM.
  214. GM Tech 2
  215. Truck PCM reflash to Camaro PCM?
  216. Getting a tune, question
  217. No Cats, Need PCM information
  218. Yet another "won't fire" thread. Help
  219. Threw a AIR code.
  220. Looking to buy efi live v2
  221. i'm lost...
  222. Need help !!
  223. Reverse Lockout Malfunction after new Master
  224. Tuning with HPT ..Need advice
  225. AIM/Yahoo/ICQ
  226. Just got HP Tuners
  227. anyone with El Torro cam or similar please read
  228. Big stuff 3 tuners..help please
  229. need help....with electrical prob.
  230. Problem with alarm and car wont start. NEED HELP ASAP
  231. MS4 Tuning with HPtuners ?
  232. Need help cant find problem
  233. Breaking down please help asap!!!!!!!
  234. I want Lambda..efi live
  235. wideband wiring...
  236. P0300 code in Idle
  237. obd 2 to usb, will it flash my pcm or do i need a converter
  238. Clutch Pedal Switch PID or Sensor number?
  239. 2000 Camaro Z28 - stock LS1 trouble
  240. ECU for LSX?
  241. 263/242 110 (g5x3ish) VE table needed
  242. tuning in camaro 2010
  243. How complete does my car need to be for a dyno tune?
  244. anyone help with the iat tables
  245. How to tune the car to open loop at all times??
  246. Best Tuner in the boston area
  247. SD tuning for bracket racing
  248. Protocol guru's--question re: 11-bit and 29-bit CAN identifier?
  249. Marine SD tune needed (W/O 02 sensors)
  250. Houston Area Tuners COME IN
