View Full Version : PCM Diagnostics & Tuning
  1. ltft's maxed after getting car back from shop rear end work why?? MIKE L please help!
  2. what happens at 70 seconds??
  3. Stalling -- rpm gauge dies / motor running
  4. L76 injector values
  5. ls3 carb motor question
  6. where to find tuning sites
  7. PLX wideband w/guage need help hooking it up.
  8. frustered...
  9. Need help pin out for a 98 chevy
  10. where to get pcm flashed???
  11. 4l60e pulse pr minute
  12. multiple codes, hopefully related
  13. Msd 2 step
  14. Just finished turbo build, first time using HPT, having issues. . .
  15. Is this a EBCM or BPMV Issue?
  16. Lc-1
  17. What Idle MAP pressure w/ H/C/I swaps do you generally see?
  18. A4 Shift Settings
  19. PCM fuse
  20. suggestions on who to use for harness and ecu
  21. I think im having computer issues...reflash needed??
  22. ABS INOP, Brake, and SVS lights turned on
  23. Wideband acting funny....
  24. Electrical probelm after tranny install.
  25. Tuning help
  26. PO121 code after LQ4 swap
  27. need help, data log attached
  28. tr224 bin file request.
  29. Torque Mgt & Knock Learn Factor: Help please
  30. LS3 40# injector tables on LS1 PCM...
  31. OBDII Scanner can't connect(Resolved)
  32. speed density tune in Oklahoma City?????
  33. Just Finished my Wideband O2 LC1 Install Lots photos
  34. Diablo....do not use if not factory tune warning...question
  35. Four SES Codes.. Help
  36. need name of good tuner around desmoines iowa
  37. Retard Modules and PCM readings
  38. slight misfires, driver side only
  39. I need some tune info
  40. Way lean!20-23/guru's help!
  41. Tuning Help Please
  42. gauges stopped working
  43. low voltage on knock sensor??
  44. LC1 ground questions. did search and found conflicting answers
  45. MS4 and Dart 205's tell me what is wrong here.
  46. BS3 Updates
  47. AFR not scanning
  48. Safe Rev limit for an LQ4?
  49. OBDII CAT monitor not running
  50. no spark
  51. fast standalone question
  52. 2004 LQ4 auto to manual tune: questions about this
  53. SES light & 2 codes NEED A LITTLE help
  54. MAF readings at Idle/WOT
  55. What the hell is this INSIDE my pcm?
  56. Help with a H/C Trex!
  57. Need HP Tuner .bin file
  58. TUNING HELP~ Battle Creek, MI
  59. Performabuilt transmission...What tuning needed on install?
  60. Which predator to buy?
  61. who does dyno tunning in tenn.
  62. Predator Tuner?
  63. attempted maf tune.
  64. Finally got the timing up. now please help me get this one little tweak.
  65. why is my car getting leaner?
  66. xfi tunes
  67. New O2 sensors
  68. Accel DFI, intermittent no spak, no start issues.
  69. what sponsers offer mail tune
  70. Another motor with KR problems.... AFR ok, very low spark, and still getting KR!
  71. Do I need a Tune
  72. pcm harness diagram
  73. Runs better in open loop?
  74. accel gen 7 install, no power wire for starter
  75. Ford Racing #30 injectors
  76. Issues with my tune/O2 sensor
  77. Dead PCM?
  78. reset superchips programmer
  79. need help big stuff 3
  80. Hypertech question? (I know there junk)
  81. e38 ecu speedo and tach problems
  82. Need a raw .bin
  83. Left my car at a gas station...help me out!
  84. Need Rear 02 sensors tuned out in Oregon
  85. Rev limiter wont change!
  86. LM1 LMA-2 RPM converter TPS and VSS hookup
  87. Little lean? Too much timing?
  88. My KR and octane table problems
  89. AUTOTAP Question...
  90. Newbie about pcm/ecu's and tuning. Help me please.
  91. Diablo Sport Tuner II worth it?
  92. ITB tunning
  93. thinking of buying HP Tuners
  94. GM EFI Tuning Beginners Guide DVD
  95. Scanner wont read my car
  96. Good Dyno tuner for a 355 LT1 around Kansas City
  97. what can fix these codes
  98. sd tune ?
  99. pcm lock?
  100. HP Tunners Credits
  101. Tps,map sensor
  102. MIL Installed
  103. do you think a tune would help this setup alot
  104. tach / e 38 setting - # of pulses ?
  105. factory tune wont work
  106. tunning transmission?????
  107. Oxygen Sensor Wire Switch
  108. Help-fuel pressure problem
  109. VSS question
  110. Newb to 2 Bar MAP tuning.. HELP!
  111. PCM Question
  112. looking for a tuner
  113. Stock tune what to expect
  114. tcs code help please
  115. My ECTs and AFR are dropping and stopping the motor
  116. Need help tuning with efilive using a .hpt file
  117. how to run LS1 out of car
  118. SCT Dash Scan help
  119. Is hptuners.com down
  120. Help With my LS1m Scanner
  121. OBD2 Connector Location
  122. E38 vs E40 vs E67 - live tunable?
  123. Tuning School
  124. single or dual wideband setup?
  125. Mail order tune?
  126. Would a gauge cluster from an 01 work in a 98?
  127. Mail order tune using a new PCM.
  128. GM Tech 2
  129. Truck PCM reflash to Camaro PCM?
  130. Getting a tune, question
  131. No Cats, Need PCM information
  132. Yet another "won't fire" thread. Help
  133. Threw a AIR code.
  134. Looking to buy efi live v2
  135. i'm lost...
  136. Need help !!
  137. Reverse Lockout Malfunction after new Master
  138. Tuning with HPT ..Need advice
  139. AIM/Yahoo/ICQ
  140. Just got HP Tuners
  141. anyone with El Torro cam or similar please read
  142. Big stuff 3 tuners..help please
  143. need help....with electrical prob.
  144. Problem with alarm and car wont start. NEED HELP ASAP
  145. MS4 Tuning with HPtuners ?
  146. Need help cant find problem
  147. Breaking down please help asap!!!!!!!
  148. I want Lambda..efi live
  149. wideband wiring...
  150. P0300 code in Idle
  151. obd 2 to usb, will it flash my pcm or do i need a converter
  152. Clutch Pedal Switch PID or Sensor number?
  153. 2000 Camaro Z28 - stock LS1 trouble
  154. ECU for LSX?
  155. 263/242 110 (g5x3ish) VE table needed
  156. tuning in camaro 2010
  157. How complete does my car need to be for a dyno tune?
  158. anyone help with the iat tables
  159. How to tune the car to open loop at all times??
  160. Best Tuner in the boston area
  161. SD tuning for bracket racing
  162. Protocol guru's--question re: 11-bit and 29-bit CAN identifier?
  163. Marine SD tune needed (W/O 02 sensors)
  164. Houston Area Tuners COME IN
  165. Slow tach?
  166. Whats the stock shift point for the 2-3?
  167. 3Bar SD tune, please take a look.
  168. E85 tunners look at this.
  169. do i need to retune my SD tuned car???
  170. LS6 to LS2 injector Question...
  171. Tuning a TSP 228R Cam
  172. 06 Corvette ECu/PCM Pinout or Wiring Diagram
  173. New motor, passenger side fires, driver side doesnt
  174. laptop wont connect to pcm
  175. Big cam, rich idle...
  176. 80 lb/hr Deka injector data, Please help
  177. whats going on here? -short-
  178. 04 LS1 pinout question
  179. lnc-002 wiring question.....
  180. 02 voltages dropping
  181. Getting more timing out of Predator?
  182. Pittsburgh area.
  183. Fried ECU?
  184. siemens injectors #5255
  185. NEED HELP! Codes!
  186. p0307 help
  187. a brief on SD...
  188. car wont stay started
  189. Question about 98' ECU
  190. tps showing throttle idle open loop
  191. IAT pin location
  192. Just bought a Diablo tuner for a ls1
  193. I need a tuner in the Minneapolis area.
  194. Check gauges light?
  195. Hanging idle, what to look at
  196. Po102 & po155
  197. LS1edit Q's adjusting MAF table and PE vs RPM
  198. What Would You Do If You Paid $500 For This Tune???
  199. Connecting FlashScan V1 to the LM-1 LM1 wideband controller
  200. Can this be done 1994 Z28 engine harness into 1996 Trans am
  201. Max NA timing and nitrous retard on SAME tune??
  202. Individual cylinder knock control
  203. hp tuners customer login.
  204. possible misfire on turbo car above 12psi, any ideas
  205. need help with misfires before i go crazy
  206. can i use this programmer on my 02?
  207. EMS tuning
  208. I need a 1997 PCM any for sale PN 16232148?
  209. Analog NB voltage programming LM-1 LC-1
  210. 2002 firebird tuning?
  211. Anyone know best crimper for Metripack 150 connectors?
  212. More o2 problems
  213. Need experiences shared to help me decide tuner. Located in Kansas
  214. running lean?
  215. new motor, backfireing at idle
  216. EGR codes/need tuner near Syracuse,NY
  217. Tuner Needed/ Indy
  218. Pros/Cons No Maf
  219. tune for 98 TA with 228r 111lsa
  220. tuning for supercharger pulley
  221. Anyone able to repair dead pcms?
  222. Code after tune
  223. Tuning in kansas city area
  224. superchips programmer? worth it?
  225. built in IAT SLP MAF?
  226. Best Michigan Tuners?
  227. clearing SES with car on?
  228. Intermittent problem: ABS INOP, BRAKE, and TCS off lights.
  229. got a quick question about frost
  230. a/f ratio conversion?
  231. hp tuners...
  232. Need help with TCC apply and release
  233. Need an obd2 to usb connector In Arizona
  234. Lost HP tuners cd but still have cable
  235. installed catch can. advance timing?
  236. Car revs up to 3grand with A/C???
  237. can a 95 lt1 convert to speed density w/factory pcm
  238. mail order tuner?
  239. P0332
  240. P0200 and P1635
  241. Is there a list for a mail order tune?
  242. any free way to clear pcm of codes
  243. copy stock segment to cos3??
  244. header install tune?
  245. "SES" Light on then off
  246. Who makes the best???
  247. Pro SD tuning w/ load bearing dyno in/near Florida?
  248. 2 codes up all the time
  249. idle tuning for br7ef
  250. I need help!
