View Full Version : PCM Diagnostics & Tuning
  1. How to fix code 1336?
  2. Important info about using BS3 with 16V systems
  3. Pro HP and LC-1
  4. new cam in and cant get it to idle
  5. question
  6. Computer and sensor question
  7. Quite a few codes. Help please
  8. cfg? What do you do with them
  9. tuning for wet nitrous
  10. Performance tune with stock cam
  11. Can HP tuners be used on multiple laptops?
  12. Fuel injector tuning
  13. idle issues
  14. Can I turn off the throttle follower in an LT1 PCM?
  15. Took truck to the DYNO (PIG RICH)
  16. diagnostic port not working
  17. Car going lean at WOT
  18. hp tuners criusing prob
  19. What tables in hp tuners are changed for 42lb ford green tops?
  20. 2002 ECM 12206841 same as 12200411?
  21. How to you pull codes on a 2002 TA?
  22. Can you down load custom LS1 edit tunes?
  23. Who is using a Abaco Digital MAF, any real results?
  24. Will HP tune save on SCT tool?
  25. VE tuning question
  26. Using a Dash-hawk, how can i tell my intake restriction?
  27. Hypertech tuners: The probelem needs to be addressed.
  28. DBW pedal and TAC module differences
  29. handheld tuner for a 1998
  30. SES light???
  31. Anyone ever use a Predator to go from stock injs to 42's?
  32. scaling for an 85mm truck maf in 98 f-body
  33. tuning my self(first timer)
  34. E85 Mail tune??
  35. Best place to buy HP tuners?
  36. How do you wire in the clutch to a 99+ pcm in a 98 TA
  37. OK to drive without tune?
  38. Any tuners in Northern Colorado?
  39. Anyone have a copy of Calibrate Success DVD for sale?
  40. Can't Clear History Codes (2 A/C Related)
  41. MAF Problem?
  42. Fast System for Mustang
  43. Fuel Pump change
  44. My LT1 PCM Fried?
  45. tps loses referance
  46. Would it be hard to tune this type if set-up....
  47. got some lights to turn off...HPT
  48. HPTuners Questions and help
  49. Custom Tune for NOS with Dibalo Sport tuner???
  50. HELP strange power cut please
  51. Don't forget to check the basics
  52. tuning question
  53. SD 2bar upping boost
  54. need help! 02 sensor question
  55. LC-1 problem
  56. Torque Management
  57. Code 1336
  58. Is the speed desity tune the way to go for me?
  59. General/Simple opinion regarding tune tweaks for gear swaps
  60. E40 PCM Cam Sensor Lingenfelter TRG-001A
  61. Horsepower Logic
  62. Yes...another tuner ?. Looking for a GOOD tuner in Texas, please advise.
  63. Tune Questions
  64. A/C pressure sensor volts vs pressure?
  65. Intermitant popping and backfiring on startup after new fuel system.
  66. Limit throttle opening on LS7 crate engine with GMPP 19166567 ECU kit?
  67. 02 ls6 98 pcm
  68. Computer?
  69. Going back to stock settings
  70. Getting inspection ready with HPT
  71. Used hypertech tuners: Can it be used on a different car?
  72. How To Look At My Tune?
  73. diablo hand held tuning out rear 02's
  74. 99 wiring with a 2002 computer
  75. Adjusting WOT afr With hptuners
  76. right way to strip down factory harness to essentials?
  77. Need HELP. No signal to fuel injectors. ECM?
  78. different wideband readings
  79. Should Tuning an LT1 take 3 days?
  80. Who is good with tuning in KC with LT-1
  81. MAP issues, couple questions
  82. Need help from you tuners!!!!
  83. fuel trims?
  84. Factory PCM vs. MEFI . . . .why MEFI on buggies / boats?
  85. HELP: cyls 2 and 3 not firing, getting 0336 and 1336
  86. data logging with hp tuners
  87. I need help!!!
  88. Car idles but dies with throttle
  89. putting in a 3200 stall later this week
  90. newb question: Can tuning change torque curve?
  91. runs with starter fluid. No injector pulse
  92. 99 harness what pcms?
  93. check engine light = rich?
  94. LS1 to LS2 or LS3 conversion tuning
  95. does anybody know about?
  96. Running rich...tuning problem?
  97. Problems with 1998 PCM tuning?
  98. red connector pin 53
  99. No spark on a new standalone install
  100. P0200a?
  101. HELP! PCM & Wiring Question
  102. optispark problem?
  103. Hey Fuel Guage issue after 98 to 99+ pcm conversion
  104. at a loss
  105. LTFT way off one bank
  106. Some WOT log numbers off my 383 10 second LT1 input needed.
  107. PCM Red Connector Pin 10 Help
  108. Start up RPM
  109. PCM tune? what do I have?
  110. Who can do a flash tune for me?
  111. Got a problem
  112. Can't reset codes
  113. Trifecta Performance
  114. DTC PO343 and PO343
  115. any one wanna check my tune
  116. hp tuner newbie
  117. HPT serial upgrade + EIO question...
  118. Problems??
  119. Afterstart Enrichment (choke)
  120. Engine Stays Revving?!?!
  121. Newb question
  122. Problem with tach output pin #10 white wire
  123. how to turn off engine light "hptuner"
  124. Can a tune just 'go away' ?
  125. P0178 Flex Fuel Sensor
  126. HPTuner question
  127. 02 Sensor Problem,Need Help ASAP!!
  128. Obd1 tuner cable ???????
  129. question on VATS delete module...
  130. 3 bar map error- high injector duty 1800%
  131. How to tune For magnacharger
  132. HP tune for 3200-3500 stall
  133. BS3 No rpm/spark
  134. Could this problem be fixed with a tune?
  135. tunercat won't read PCM - tried search already
  136. OBDII All in one
  137. LS9 ECm Run kit
  138. wideband going nutz!! 12 to 16 A/F HELP!
  139. Speed Density tuning?
  140. Is this possible?
  141. Help on 2 Injectors not firing
  142. Tuning Question about IAT Sensor
  143. Realistic question: Is HPtuners hard?
  144. Primary header tube temps
  145. LS1 tuner in N. Alabama
  146. need help found broken pcm pin
  147. weird misfire issue
  148. 98 to 02 PCM now only low charge altenator
  149. PO174 system lean bank 2
  150. 88% ls2
  151. Opinions on mail order til I can get a dyno tune
  152. tuning and reprogramming without a dyno possible?
  153. Open Loop Tuning Is Not Easy
  154. is my tune bad?
  155. Ambient Air Temp Question
  156. injectors at 1800%,help
  157. Stranded at a friend's house.. HELP!!!
  158. Open loop speed density poll..
  159. Those who have/still do tune on LT1's. Come in please!
  160. car idles down to 500 rpm and dies????
  161. asking for tune advice
  162. Has anyone got HP Tuners to work with Vista
  163. Should I go MAF or SD?
  164. tranning tuning issues
  165. Please flash my PCM
  166. need tuner in east tn or help with mail order
  167. Emissions Tune questions.
  168. Car throwing codes p0102,p0332,and p0327!!
  169. Question
  170. HP tuner in Mississippi
  171. stock maf on 402?
  172. reduced engine power with new throttle body
  173. Racetronix/Lucas/Delphi 42# injectors - voltage offsets
  174. Tuning 383 LT1 - need someone with a similar setup for a starting point
  175. Need help with this tune! EFIlivers please check it out!
  176. TSP Torquer 2 tune...
  177. IAT sensor relocation
  178. Odd dip in top of torque curve, ideas?
  179. best tuners in fort worth speed density, maf, or cmr?
  180. Misfire count - but no codes!
  181. Could I be down 5-6 mph from a bad tune?
  182. LS6 cam and springs
  183. LS7 wiring diagram
  184. corvette pcm for 6.0?
  185. hptuners and plx
  186. 98 camaro ls1
  187. Mail order tuning
  188. idle problems with comp cam xr281
  189. High idle only when ac is on.
  190. PCM Fuses
  191. Crank and no fire
  192. O2 Sensor? Service Engine Light
  193. Where to find Torque Management tables with a Tech2?
  194. computer extension
  195. 4.3 High idle while moving
  196. Predator tuners help and questions
  197. is it my tuner or is it my injectors?
  198. best tuner in midwest for turbo LT1 with F.A.S.T.
  199. A good Tuner in Tucson
  200. My car wont tune for crap!!!
  201. few questions inside
  202. Rev. Limiter
  203. Is my tune bad? 383 stroker.
  204. Fuel guage
  205. Fuel guage
  206. PCM is turning off the fuel pump!
  207. EFI Live B4317 to drop idle faster when coming to a stop?
  208. hp tuner reads engine coolant temps 104* too low??
  209. high idle
  210. cannot tune with hp tuner. previously tuned with road runner
  211. O2 signal wire
  212. car is throwing p0300, ses blinking randome multilple missfire
  213. ABS Codes Please Help
  214. HPTuner Read File Liscense Problem
  215. anyone have a base tune?
  216. o2 sensor plug to o2 simulater plug
  217. Questions before I buy EFI live
  218. inspection readiness test wont complete help
  219. B5913 High Octane table has no values above .042 oz/cyl??
  220. Can Someone PLEASE check my tune out?
  221. hp tuners OS change...OSMOD locked
  222. Just picked up a 5.3
  223. How much HP should I Really have?
  224. Motor swap. Wiring harness help.
  225. Could my tune be off that much???
  226. Computer Tune Question
  227. Do I need to disable VATS?
  228. what tables for cam
  229. LS1 Coils
  230. I need a little help trying to figure out my tuning situation
  231. need a tuner
  232. My OBD2 won't connect, what gives?
  233. HP Tuners limits?
  234. Exciter wire
  235. HELP!! grrr
  236. Fastass 92RS LS2 with code problems
  237. parts that can be used with stock computer?
  238. handheld question
  239. Switch from pump gas to e-85 with big stuff 3
  240. high octane/ low octan.e tables
  241. Sticky Idle?
  242. 02 TA not running right, pease help
  243. Helpppp
  244. speed density tune in wisconsin
  245. 3.8SC Torque Mgmt
  246. Lm1 to efi live hook up cable
  247. Who is good at tuning LS7s
  248. Engine died during dyno and won't restart!
  249. how to use a dvom to check my cps
  250. Does this MAF reading see right with the MAP reading?
