View Full Version : PCM Diagnostics & Tuning
  1. idle issue...MS3
  2. what voltage for brake input for crank sensor relearn?
  3. whats this mean?
  4. 3000 RPM Idle, will not come down
  5. Ethanol In Gas
  6. Anyone use the Dynojet Wideband 2 ?
  7. HELP Code 171
  8. connecting air/fuel gauge, ecu pin nr?
  9. LS1 Wiring harness VS 5.3 Wiring harness
  10. Uncontrollable idle with A/C
  11. New tune?
  12. won't idle, cannot rev up?
  13. Can someone give me an estimate?
  14. bad knock sensor?
  15. LC-1 install questions
  16. Engine Light Keeps Popping up...Now im worried
  17. LTFT Question
  18. (hp tuners) What does the "non-active test write" do
  19. Any Local Tuners 361 area?
  20. Something weird going on
  21. Diagnostics of an LS1 Engine in a Malibu Ski Boat
  22. what determines a missfire
  23. sponsor that sell hp tunner look in side
  24. Programing 1996 LT1
  25. Map Bar ?
  26. Why Bad Gas Mileage?!
  27. SD or Closed Loop-MAF tune????? and why?
  28. crank learn/CASE in north jersey??
  29. Security light problem
  30. Quick LC1 ground question
  31. Need help with these codes...
  32. need help ls1 edit... converting m6 to auto
  33. tune repository for fast?
  34. Computer died before completing load of file
  35. A couple basic EFI questions
  36. quick qestion
  37. Few questions about my FlashScan V2
  38. Very easy question but Im a numpty
  39. No communication with ODBII Port
  40. Tune Required
  41. Question regarding tune?
  42. turbo sd tune?
  43. Knock Sensor
  44. tunercat datalogging question
  45. Please help me get started with HPTuners
  46. Quick Question regarding an issue with HP Tuners..
  47. help me flash the e67 ecm
  48. knock sensor pegged out after startup
  49. Bank 1 lean... Take a look at my log ( efi live )
  50. only real tuners please
  51. What wideband for HP tuners pro?
  52. high idle
  53. Air / Fuel Ratio?????
  54. Jesse (EFILive), FROST or joecar inside please
  55. Anyone Know How To Re-Program BCM
  56. WTF is wrong with my tune???????
  57. Any way to dial in stft?
  58. 60# boost tune
  59. Predator tuner O2 code deleting
  60. Controlling spark only with the LS1 PCM?
  61. what tuner to use?
  62. runs horrible in closed loop great in open LT1
  63. help with tuning a built car...
  64. Bad PCM???
  65. Whos running Vista with a new laptop? Come in. need help
  66. Wont stay running after rebuild! help me
  67. Lingenfelter 2 step issue
  68. P0200 on 408
  69. Need a tuner...???
  70. cat. overtemp
  71. Can i use my Fast Dual Wideband 02 system to run with my painless LS1 EFI harness?
  72. Race proven motorsports...
  73. what do these codes mean
  74. How can i tell what injectors my pcm is tuned for?
  75. Master EFI Tuner Book ?
  76. AFM (Active Fuel Management) on the Silverado's.
  77. Lean bank due to lifter issue?
  78. having ignition trouble
  79. FAST Flash programmer
  80. can anyone help with passing emissions!!!
  81. Converting carb setup to efi in my 68, want a crash course in what im getting into
  82. How to hook up a Tach to 98 Camaro?
  83. 1998 ECU to 1999+
  84. rear wheel speed erratic
  85. Car runs bad with new motor no power
  86. Anyone tune a Supercharged LT1 with TunerCat/Freescan?
  87. Scanmaster or Wideband????
  88. I just bought this computer for my 1998
  89. moates question
  90. possible 2 turn off the abs lite?
  91. timing question
  92. Backfire upon lifting
  93. Comp. Ratio on pump gas??
  94. HP tuners..anyone have a basemap for an LS2 cam only?
  95. HELP!!!!! P0200 Injector Circuit Malfunction
  96. Reverse Solenoid fuse keeps burning?
  97. p0122 code?
  98. GMPP Controllers and readiness codes
  99. There any shops in North Louisiana that can delete codes?
  100. startup without tune???
  101. T42 OS wrong for my setup?
  102. Codes remedy?
  103. question about tuning software
  104. Intermiten codes
  105. MAF to SD tune, using HP tuners, what do i need to change?
  106. GMPP PCm Kit narrowband O2's need wide Band
  107. dynotune question
  108. cam surge ?
  109. can the ngk afx be ran with a 2 1/16 guage?
  110. cam surge ?
  111. efilive b5910 spark ect
  112. Lt b1- lt b2
  113. where should i get my ms4 car tuned
  114. Possible tuning related backfire...please help
  115. PCM Question
  116. 98 computer swap.
  117. Anyone have a wiring schematic of the E67 and/or E38?
  118. Burst Knock and 98 pcms?...
  119. I need help
  120. Need Help - Injector slope and WOT
  121. Rough idle
  122. Rough idle
  123. hypter tech tuning- how to?
  124. Street/Dyno tune whats better?
  125. Flashing a A4 to M6
  126. LM1 tailpipe
  127. PCM part #?
  128. Multiple tunes on one PCM?
  129. Computer Fried?
  130. Motec MLS - LS1 specific ECU
  131. nate(elky498) fresno performance!! A++++
  132. timing at wot
  133. 100mm Texas Speed MAF
  134. IAT effect on afr
  135. Need Help!!!!!!
  136. idle is very rich need help tuneing
  137. absolute throttle position
  138. LT1 Edit File
  139. RPM limiter or some other way to limit power or speed?
  140. What timming should I be targeting?
  141. injector offset Vs. Battery voltage table
  142. What PID's to log for initial tuning?
  143. Tuning my own car
  144. Anybody use Autotap as a scanner?
  145. OMG, exhaust mod & VE table result....am questioning the effect on the tune
  146. Dyno Tuning
  147. car running rich suddenly help!!!!
  148. no start after heads/cam/intake install
  149. Cool Practice Tree download.
  150. AEM WB vs. Stock NB accuracy
  151. Can any sponsor help me with this?
  152. Speed Inc Dyno Tune?
  153. Timing at max tourqe vs timing at max hp?
  154. Anybody in OK that can tune for a resonable price?
  155. Bank 1 fuel trim fluctuations
  156. Can I drive without a tune after headers & intake?
  157. Idle issue after tune
  158. my 02 z28 has no buttons on dash for
  159. [b]tune gone bad?[/b]
  160. wont run after cam install
  161. wont run
  162. How high to rev the motor
  163. need my car tuned, im around louisville, ky
  164. MAF is bouncing all over? Can someone look at the log/tune?
  165. What can cause "False Knock"?
  166. advance ground into cam..... tuning question...
  167. 05 silverado tps/map/ REP problems
  168. My gears read as 322...
  169. Speedo not working, VSS replaced, still not working
  170. Idle won't stay at Stoich
  171. Cam position ?
  172. is my trans toast? *log inside*
  173. torque management
  174. Wont pass inspection...readiness test help
  175. PCM reprogramming
  176. In IL Need Tuner Suggestions
  177. Anyone with HPTuners and a CTS-V?
  178. What is concidered the best Wide Band to be used with HP Tuners
  179. Has Anyone Been Tuned By Simpson Performance?
  180. Possible to delete MAF?
  181. HELP!! wierd problem with my car tonight.
  182. Help!!
  183. Hand-held tuner with aftermarket MAF
  184. New Injectors and the tune...
  185. question about tuning LTFTs on HPT.
  186. map conversion
  187. t56 conversion etc. w/ tunercat
  188. Innovate Wideband Sale!!!
  189. megasqeuir boot control cant keep pressure?
  190. Are canned tunes safe/recommended for daily drivers or not?
  191. Major MAF Problems in '03 Silverado SS
  192. Application key does not work help..
  193. AF Ratio on Throttle off
  194. injector slope
  195. Can i do an SD tune without a wideband?
  196. o2 sensor missfire, need new tune?
  197. how to check voltage at MAF question
  198. F/S Hypertech Power Programmer III 98 Camaro/ Firebird LS1
  199. Truck PCM in F-body
  200. Coil problem, need help!!
  201. anyone in the bay area good with hptuners
  202. wide band question
  203. Launch Control w/ HP Tuners?
  204. 2002 engine harness question
  205. Tuning For Torque Management
  206. 98 3.8 PCM reprogram to Ls1?
  207. LTFT and STFT
  208. Turbo PCM4Less Calibrations Question
  209. what is the target a/f on a supercharged car
  210. tuner locked my computer
  211. A couple of wiring questions...
  212. FS- Do you need a laptop for tuning. Step in
  213. Need Help IFR tables for 60# s/c LS2
  214. best deal on lc1's
  215. Methanol on a DD
  216. Slight Tuning Issue
  217. Reading deleted codes...
  218. Can a Fast Classic box be run fuel only using a tach signal?
  219. looking for tuner in wisconsin
  220. 2 step activation wire?
  221. can I use the GM VATS system?????
  222. Torquer v2 idle tuning
  223. F/S LM2 Wideband
  224. code p1336 out of no where
  225. air/fuel ration
  226. Seeking advice on mail order tune/engine break in
  227. Tuning available for 98 WS6?
  228. No Narrowband Signal
  229. Tuning out traction control?
  230. COT Enabled or Disabled
  231. P0108 and two other o2 sensor codes
  232. Multi spark ingnition control
  233. Idle issues with carb LS
  234. Pleaseee help , trying to get car running with diablosport tuner
  235. recalibrating speedometer....
  236. 240/242 with 580 lift cam, 2K WS6 stalled auto
  237. Quick question
  238. Driver side bank 1 completely lean...?
  239. Turning off code 0327 killed the car
  240. can i run nitrous with like this?
  241. Calibrating Speedo
  242. 12.1 compression for a dd
  243. gm controller
  244. help car still dies...
  245. Car runs very rough - log attached
  246. Just got tha long tubes installed
  247. knock sensor and timing tables
  248. Anyone using the AEM PnP EMS set up?
  249. Locked Tune
  250. Adjusting Converter lockup with diablosport??
