- what was your initial and total timing ?
- Tuning in so flordia
- Handheld tuner code delete
- stock pcm and low impedence injectors
- Help with autometer dpss lv3
- Installing Stroker - Can it be broken in w/ the old tune?
- service vehical soon is appearing on my dash after sd tune
- car bogs at full throttle mid rpm
- po154 is stumping me
- Lingenfelter 2 step issue
- Differences between 98-99 IAC and 00+ IAC Sensors?
- Car idles most of the time???
- A/F monitor
- DiabloSport Questions
- HPTuners & Launcher wide band
- o2 and egr will this cause missfires
- The best mail order tune for trex and bolt-ons
- Can't get datamaster to work - vista
- Split STFTs only in a certain RPM range?
- Car stays at constant speed, foot off throttle?
- SES light on very dim
- Re-set pcm
- stumped
- Misfire scan but no code?
- How to without HPtuner or EFIlive (4L80)
- Wideband is off the charts
- Need help checking ecm and wiring
- LC1 issue....STUMPED!
- Im done......Yaaaaaaaay
- Speed Incs Tuners Names?
- hypertech handheld question
- hp tuners users
- SLP Diablosport predator octane question???
- megasquirt msII and ls1
- Anyone Have TunerCats(JET)or any LT1 Tuning for Obd2
- Is my ported tb causing these problems?
- HANDHELD TUNING QUESTION...and GEARS
- can i use a wideband with HPtuners standard?
- Stuck at step one predator install!
- Bad idle problem.. park and neutral
- brown smoke
- A wideband/HP Tuners problem no one can answer
- laptop / notebook with efilive
- What will give me more HP & TQ?
- how much can a stock 75mm maf sensor flow
- Lean right after wide open throttle HPT
- just got done with my 'full bolt ons' now car dies
- TPS sensor questions
- 2 step lounch controler
- issues with computer
- looking for a good tuner in dfw
- What is the best tuner for an 02 LS1?
- How much tm is decreased in the predator tune?
- tuning software for linux?
- How do you know if HP Tuners is reading the wideband accurately
- Timing question - need to figure this out before I spray a 125 shot
- Needed: 98 & 99 LS1 F-Body Connector Pin-outs
- tune or o2 sensor
- Ameture Dynotune or Mail order tune????
- Speed Density on a NA motor
- Looking for a Tuner in Vancouver
- Using a ls3 map sensor with a ls1 pcm
- evap system
- Performa trans Yank stall. My tune, efi live
- some idle issues (log inside) HELP
- Is something wrong with my tune
- trying to learn...please help....
- What yr PCM is this?
- Ls1 Tuner Near Lansing,MI
- open vs closed loop
- how to know if your pCM is going bad?
- sputtering in rain
- First time tuning for stall......
- whats up with these weird codes?? (C0240,C0237,U1000,U1016)
- Tuner Directory....
- Do big cams need alot of fuel on startup??
- What harness do I have
- service vehicle light ?
- surging only in open loop
- lock and unlock converter
- wiring problem
- mail order tune
- Torque management????
- LQ4 block with a ls1 harness
- Is this HP Tuners PID set up correct?
- 99 LS1 Engine/PCM/Wiring Harness in a 1998 Z28?
- Need help code po336a
- New Company Announcement
- Need help, again
- How to force the converter to lockup WOT
- HP Tuners Noob....ecu questions
- Swap to LS6 manifold = P0107 !?
- Will Hptuners or EFi Live work with a 96 LT1
- what sensers tell the PCM to shift?
- Idle problem.
- New Online Video Training Course
- O2 issues
- need a base tune
- Please Helo.. EFI Live-Adding Wideband PID
- M6 to TH 400 swap (tune advice)
- Help help help!!!
- My MPH is off, can i fiz with tuner?
- Knock Sensor
- Start up tune?
- LS1 Edit... About to purchase~ Is it worth it?
- Diablosport Predator Tuning
- MAF accidentally left unplugged, tune fubar'd?
- Need a .bin Dont have license yet
- New Era Performance or Redline Motorsports
- What's causing this spark knock on the N20?
- Injector flow rates for 36lb bosch and HPT
- RICH RICH idle and cruise HELP
- dynotune and hp tune
- MAP Readings: Where should they be?
- Hp tuners help!!!
- Car runs like shit! Help
- P0151 code does anybody know how to correct it.
- getting tuned with liteweight battery
- Car wont idle after starting..
- SCT tuning Questions
- considering buying HPtuners or EFIlive instead of getting a dyno tune
- EFILive V1 vs. V2
- New cam won't idle... Help!
- Bigger MAF sensor w/ hypertech max energy
- No LTFT'S or STFT'S after Trans Install!!!!!!!!!
- 98 pcm
- SES Code P0300
- ls2 to ls6 adapter harness notice
- Simple step by step overview of going to 3 bar with my hptuners.
- Wiring question, which wire is hot when the brake is depressed?
- What is the going rate for Custom Dyno Tunes in the USA
- Tuning 12.1:1 compression
- WOT on DBW
- looking for GM part numbers
- Vinci Handheld Programmer
- Driveability Issue Driving Us Crazy
- Timing Spike @ WOT on Nitrous Oxide
- need tune help
- any good widebands us a 2 1/16 guage?
- Can someone help me?
- dynojet wideband commander problems
- car keeps reseting?
- efi live vs. hp tuners
- Best, cheapest mail order tune?
- Olfa afr
- Would a good tune benefit a close to stock daily driver?
- flashing ses after motor swap
- Retune for 42# injectors?
- Looking for a tuner in or Near Austin TX
- LT1 tuner
- Will a tune make a huge difference?
- computer...need tech help?
- o2 sensor - wideband question
- Speedometer not working
- part # for 3bar
- 30# Fuel Injector Values
- 1 Bar MAP,2 Bar MAP,3 Bar MAP
- O2 sensor wiring
- Does this sound like my tune is off?
- Where is the best place to weld the bung for a wideband? For LT1
- Question about this tuner
- What are LTFT's?
- 2009 GXP HP tuners question?
- Tuner Cat Question
- TCS light off ?
- Tuner for multiple tunes on the fly?
- torquer 2 cam tuning
- problems running
- Magden performance computer
- Lean Bank CEL P0174 on '97 C5... HELP!
- Engine/PCM swap, no VIN, how to program?
- Sensitivity knock sensor
- Guys with cams...you happy with how your car runs, the tune,etc?
- To check out your tune or tune file (bin), do you need tunign software?
- Tunercat Stall Wall Fix
- Missfire breaks up around 5k rpm, p0358
- high idle
- Tune question???
- Any tuners in Central New York?
- IFR table for red 30# Bosch gen 3 injectors
- P0155 Help?
- Shift LIght
- MAF Change Question
- Could a low windshield washer fluid reservoir make the low fluid light come on?
- Generator Warning light
- LS6 to LS2 throttle body
- truck LS tuning ?
- When is it necessary to reset fuel trims?
- No spark and car won't start, no power in fuse box.
- NHRA Stock / Super Stock - Which Tuner?
- Is the AEM wideband any good?
- LS1 and LT1 FBody A4 shift tables the same?
- Low Oil Light?
- PCM tuned, still seeing misfires...
- Will this void my cat warranty replacement?
- SES Code Help
- Innovate Wideband Gauges/Controllers On Sale!!!
- Found 4 inch 3.5 tube on ebay right size to replace maf for SD
- EFI Live or HP Tuners
- Anyone been tuned by..
- Question on tuning
- 2 P0102 codes help please
- PCM for manual?
- P1153 I searched....
- Guy's with carb/MSD setup, what kind of timing?
- How do I lower my WOT Air/Fuel ratio in tunercats obd1?
- Best big cube SD tuner?
- Reading 10:1 AFR on the dyno, please help. Have tune, scan, printouts
- is my engine vacuum in line?
- Do any of the standalones let me run obd2 diagnostics thru the daignostic port ?
- New Moderator
- UD pulley effect?
- what table to adjust to stop idle hang EFI Live
- Ltb2 -100 ??
- Reduced power / traction control
- Cranks With no Fire
- Open Loop Question
- Got a diablosport tuner, doesnt fit.
- Siemens 60# numbers...
- Do I need a tune other than speedo after S60 (4:11) rearend install?
- HyperTech Max Energy Programmer
- A/F Gauge Connection...Need Help
- sd tune question
- Where in San Diego to get a good tune??
- Wiring Diagram
- deleting the o2 sensors
- Help with p0133,p0135,p0300
- Hot start problem finally fixed after a year EFI Live
- Big power/stock ECU users inside
- dash-hawk users, some questions..
- i believe i may have a MAF(or MAP)\airflow problem. can someone please help me?
- Computer compatibility
- having issues...
- Which stock tables to use going to 28lb injectors
- Tuning question
- Speedometer calibration ????
- Question for the Diablosport guys
- DiabloSport Hand-Held Tuner Question
- looking for a pic/file of a timing table
- Tach is Still Off After Swap, What do i need to do ?
- need some help tuning ve table (raise or lower)
- Flashing SES light(Misfire)...Disable?
- what can i do with this software? is it full tuning software?
- Hptuners help! A4 to t56 tune
- How does one completely delete the knock sensors in EFILive?
- Predator STS tuning needed
- computer
- TCI or PCS tranny controller
- Megasquirt Setup
- Locations for for car tuning?
