- Autometer Weird install issues.
- So fucking lost>
- LC1 software download
- rpm gauge doesn’t work after cam instal
- 97' Spark Question-Power High vs Low tables
- Looking for a good Tuner
- Handheld Scan Tool Advice - Equus Innova 3110?
- Is GM's ASA ECM Locked?
- Check engine trouble
- What does Patrick Use
- Few more tuning Questions
- Can i buy a pretuned PCM for my 1999 TA A4 with an LS2 engine
- lean tuning for mileage?? anyone try it or know anything about it?
- nitrous tables in efilive?
- Can anyone help with LS1 computer values?
- Anyone have instructions and diagrams for repinning 98 to 99+
- Lock on Tunes?
- tuning on bad gas
- p0480 - how, what, where, etc to fix
- LS2 Piggyback with aftermarket PCM
- MAF TRANSLATOR, will it function????
- Verify this part number for Dynojet Wideband sensor
- Problem with HPT
- Wideband O2 to EGR Input for Logging
- need someone to re-tune my 2000 gmc 5.3 computer
- What wire for logging Autometer fuel pressure?
- ecm oil pressure
- My MAF isnt reading
- Laptop stands?
- Misfire issue, can' figure it out
- dfi and stock gauges? need help
- Advise on a tune
- Who has the better real time tuning ? EFI or HP ?
- help with hp tuners pro or standard
- Lc1 Keeps Killnig Sensors
- 383 Tune???????
- Can I download something to view hptuner datalogs?
- fast xfi contact
- long trips..car dies
- The Interceptor OBD2 scan gauge
- Maf Fueling
- stumble on launch
- EFI Live File for CTS-V
- Tuner question plus self tune or dyno tune
- Code 1133
- Altenator not charging but tests good?
- best connector to pcm pin?
- Which tuner solution fits this description please?
- AIM Sports MXL with GTO LS2 over CAN
- Shift points
- Hypertech's new Max Power Programmer?!
- High idle question
- wet behind the ears, what to do in EFILive?
- how much timing is too much
- Best Tune shop
- Gauge Help Please!!
- 2000 rpm idle
- 4l80e hp tuners file needed
- Thinking of getting tune.
- wiring harness help
- Predator mess up dyno tune?
- tune???
- LC-1 problems?
- Wideband install...
- Help me with the o2 Sensor problem after LT header install
- 3rd party hardware
- gear/tire size
- Patrick G or Tuning god please enter!!!!
- 02 Wideband Bung Location?
- Delphi 85mm Maf Tables
- Please Help!! 403 LS2 Tuning
- Anyone is Sac area with HP Tuners or ???
- bucking
- Ran into torrential rainstorm now 2001 SS runs like crap
- turbo tune
- Which o2 for afr???
- IAC-A/C Airflow (IAC_AC_DMA)
- Any Good Nj Tuners?
- U1000/ ECT not working
- Can't get rid of this code..
- Pcm Trouble???
- back fire after 37lb ractronics
- three codes
- No spark on #2 coil
- 05 GTO lsx 454 throttle ?
- hand held programmers any good?
- Is this tune ok
- Torque Management / HP Tuners - How Do I Get Around The 640 ft-lbf Limit?
- Jetchip Module
- Help tuning a 427 with an E38 PCM, lean condition, O2s going wild
- Mil Status report???
- tune
- 98 ss fuel pump wiring
- mount wideband sensor
- Dead coolant gauge
- fast xfi to factory style pump setup????????
- hissing noise under passenger floorboard
- Digital Maf?
- Changing GEAR RATIO in HPTUNER
- HELP with Wideband O2 Sensor Install
- Got a tune but car dies
- VE tuning E38/LS2
- EFILive or HP Tuner??? Whish one is the best???
- What ECM is this?
- Car Won't Idel????
- Crank relearn
- Can I benefit from a tune?
- M6-a4 Swap Tune
- Need help or input with tuning a ls2 403
- Who is the God in Tunning HP Tuners for LS1??????
- Ohm output on a ls1???
- How do you post a screen shot from EFI Live?
- Death of a LS1
- P0101 after head swap
- question about tuning strokers
- L92 Ls2: difference in wiring?
- What HP Tuner You recommend
- EFIlive users please help
- Can't reset PCM?
- Cannot Dial in A/F on the top end..
- Please Help!!! AIR FUEL RATIO
- Not the norm wideband??? Please look...
- No Spark No Start 408 Conversion
- ls7 in a c5/ hp tuners bin file?
- 91 Camaro tuning software
- Hypertech Power Programer
- To EFILive Users and the Auto VE Tuning
- where to get a 3-5 pin adapter for ZO6 MAF
- Misfire problem
- LT1 Tuning Tips
- time to change injectors?
- BIGSTUFF3 408ci E85 tuning
- Idle & tuning for a 228R cam with HPtuner.. HPtuners help please!
- Can anyone tell me what laptop to buy for EFI Live?
- Tune for headers?
- The money pit gets deeper yet again...
- The value of my wait4Me tune and EFILive
- fuel trim troubles
- Stock PCM or Standalone?
- EFILive
- In EFI Live how do you make the Hp Calculator work??
- Read if you are in the market for HP Tuners
- Need some tuning help, 2bar related
- C6 ZO6 slight surge at 1500rpm
- Backfiring under low RPM high load conditions
- Converter locking too early!!!
- RPM vs Injector Pulsewidth
- EFI Live dyno tuner in IL?
- Tuning packages
- Crane Cams Programmer
- car sounds like redlineing at full throttle but really only at 4000 rpms
- I dont have a vin or a pcm for my ls1
- What can be the problem cant figure it out PLEASE HELP
- Automated knock alarms -- video inside
- Define this OBD1 code for me please
- EFI Live and Innovate sale
- VE value is 0 and LTFT is -10. What's wrong?
- Re: LT1 edit. Will not correct speedo with different gears
- Disable Lockup???
- MAF sensor ends
- AEM UEGO gauge...can I replace the stock 02 with this?
- hypertech for a 99ss work on 02ss?
- Put LT's & Ypipe on..now it smells like it running rich..I have HPtuner..how do I...?
- Knock sensors
- Drive by wire adjustment?
- FAST XFI Questions
- corvette ls2 wiring and computer on a ls1 block?
- New Tuner School opening
- please please help me idle is swinging bad...
- p0121...searched
- Please someone help. I am at my end with this car.
- bad tune maybe?
- Standalone Fuel Cell
- 408 with no tune
- concidering a Diablo for my WS6
- SES light comes and goes..
- Cold & Hot Start Up
- LC1 Problems
- keep maf or delete maf???
- LTFT seems off.
- Lighter clutch assembly/flywheel tuning
- motorsport tuners
- 3 bar Map Tuning
- Injector flow rates
- changing computer
- ses light after shift light install????
- Idle issue
- Looking for something similar to the MSD Dashhawk
- Help...want to go back to MAF tune from SD
- Can anyone send me in the right direction? EFILIVE
- Vinci won't read.
- programmers
- Any thoughts on what could cause pinging when hitting the gas while cruising?
- 75mm mass air vs 85mm
- Another beginner tuning ?
- Can EFi Live tell me if there is enough voltage going to my fuel pump?
- Unplugging 02's lead to wacky results
- 98 ls1 progammer by diablo????
- engine codes...
- Car Wont Idle And Runs Rich At Idle ( Tune Inside)
- EFI Live?
- Can I shorten the harness on my AEM Wide Band?
- Still cant get this POS to idle right!
- Changing stock fuel pump for a 255 lph, do I need a new tune?
- Where do I find this Table in EFI Scanner??
- I'm going to attempt a full Mega Squirt setup in parallel with the stock ECU
- cold start EFI live
- Help with tune and KR
- wait4me PCM tune/VIN flashing question
- Replacement LSU4 wideband sensors
- sum advice on tuning for torquer 2
- Need some Tuning Advise???
- Green Light Motorsports - Please Read All
- O2 Sensors
- wierd engine problem
- truck tune
- which tune is for me
- Any good tips?
- Unlocking Predator VIN
- Problem with a MSD 6LS ignition box
- Vette PCM-F body PCM
- AFR Goes lean ..... Sometimes
- Place to Custom Tune around Philly, PA?
- O2 signal
- need wideband install help
- Need to check my air/fuel ratio.
- Data logging need some help
- 03 elect TB acting very strange...help
- Stumble/miss, MAF Problems
- PYROMETER TEMPS How much is too high?
- Can anybody tell me what this does
- Resetting the PCM
- WTB HP tuner Software
- I got it on video
- Service Engine Soon Light???
- DTC detection
- LS3 Corvette TM Tuning
- Tuning BigStuff3
- HandHeld Tuner Question
- A/F Question
- Help! Frustrating Problem Inside
- Jet DST anyone?
- HP Tuners for commercial use???
- p1810...HELP!
- superchips
- What would cause guages to spike and trip to reset...
- p0103 - 2nd gear issues on 98 LS1
- History Codes
- Calling Tuners In Ny
- Will millivolts tell if an O2 sensor is dead?
