View Full Version : PCM Diagnostics & Tuning
  1. i need help with the predator
  2. Hypertech programmer ??? ??
  3. What to do????
  4. 1998 to 1999+ _PCM swap, TCS OFF after swap
  5. speed density tune with 2 dtCs
  6. Another P1637 story...
  7. ??Stalling after start up???
  8. Help with inaccurate speedometer
  9. dyno tune
  10. Mail order tune for a bolt-on/small cam car?
  11. TPS problems check it out.
  12. Tach tune
  13. possible tune needed
  14. Big stuff 3 needed?
  15. Maf or SD Tune >?
  16. 2 different maf's 2 different AFR's
  17. Car wiring issues?
  18. Any Variances running 60lb motrons ?
  19. car idleing questions cam 230 234 110+2
  20. Basic LTFT question
  21. Bouncing off rev limiter help!!!!
  22. is the hypertech programmer any good?
  23. Looking For Help/ Tuning
  24. Is Speed Density Tuning right for me?
  25. BS3 (BigStuff3) Sale at EPP!
  26. Wideband Install
  27. What on YOUR favorite tables list?
  28. Low Vacuum at Idle - in the tune?
  29. LS7 Swap/Crank Relearn
  30. buy the wideband sensor or the whole kit
  31. Loggin Boost with HPtuners
  32. Tuning with open headers?
  33. GTP injectors
  34. kind of a weird ? someone might know though
  35. Hypertech Problems
  36. what chip to get
  37. Diablo Predator or HPTuners???
  38. SD tune help
  39. REV limiter on 2000 RPM's
  40. lc1 wb02 using nb02 stock harness
  41. Ls1 swapped into fox body.. computer issues yet again
  42. Ls1 swapped into fox body.. computer issues yet again
  43. What to look into & log?
  44. Tuning prefrence???
  45. obd11 & efi live
  46. What would make "Absolute TPS" read 17.4% at IDLE?
  47. were is the computer
  48. I want to read boost in EFI Live.
  49. Superchips Max MicroTuner for 99-02 Z28/Firebird/Trans-Am
  50. wtf??
  51. Logging injectors with hptuners
  52. AFR at WOT 12.7 12.8 good
  53. Getting tuned on a mustang dyno vs dyno jet
  54. EFI LIve timing
  55. Getting IAC counts down
  56. Acceptable % between LTFT"s
  57. 2 O2 codes creating SES light, help
  58. Anyone Need a Vinci/Crane tuner for 98-up ls1
  59. Need some code help
  60. Efi Live,Does anyone have a converter/shift file?
  61. MAF effects on idle tuning?
  62. Mailorder Tune or Dyno Tune, which do i need?
  63. LC1 Wiring through rear 02s
  64. codes
  65. Which LM-1 is ideal for EFILive/Roadrunner?
  66. Advice....dyno-tune or HP Tuners since they are same price?
  67. Help please - getting started on SD, new LS2 402
  68. My tune... HELP PLease.. HPTUNERS..
  69. HELP...will these DTC's make my car low on power?
  70. speedo signal wire?
  71. Help white face install needle off!
  72. E38 Mil Light
  73. Radio and Windows stop working?
  74. MAF vs SD Stock Internal???
  75. Does Anyone Know If Ed Wright Locks His Computers When He Tunes Them?
  76. car won't idle
  77. is pcm going?
  78. Runs rough
  79. Those with EFI Live V1 scan and tune
  80. Tuning question, searched and now confused
  81. O2s SLOW TO RESPOND
  82. Electrical problem???
  83. Racetronix/Lucas/Delphi 42# Injector Settings
  84. WOT Wideband
  85. Car wont start please help
  86. diablosport predator spark advance for nitrous
  87. What's my reflashing program options for a 95LT1
  88. Computer reset problem!! PLease help!
  89. pulling timing with HP Tuners
  90. FS: FAST B2B setup for LSx engines w/ EDIST, WB02, and stand alone wiring harness
  91. Anyone using the Max Energy tuner from Hypertech? what do you all think?
  92. question about ecu
  93. Edited out vats with hptuners still won't start
  94. loosing fuel pressure up top?
  95. p1133 with stock car
  96. BS3 and RacePak...
  97. HP Tuners
  98. Practical RPM limit for BS3,Pectel with stock triggers?
  99. knock and timming
  100. Fuel pump relay control
  101. GM Tuner
  102. speed density open loop ???
  103. dyno tune or not??
  104. affects of untuned 90/90 setup???
  105. 02's and tuning
  106. Need tune download '99 C5 with cam & exhaust
  107. EGT install WHAT cyl?
  108. Electrical gremlins from hell
  109. A couple of questions for you seasoned vets...
  110. The Dreaded DTC gremlins .Just looking For Input
  111. af and pressure guages
  112. Stock Ws6 Tire Height????? Anyone?
  113. how much does a good tune cost
  114. Big Stuff 3 Schematic
  115. PE and VE table with the tunercats
  116. Anyone want to Tune my car??-NJ
  117. Narrowband Output on UEGO
  118. Starts great cold, but struggles to start/find idle when hot
  119. I need 2 license to tune my 06?
  120. ABS INOP, ASR off, Brake lights on. HELP!
  121. hptuners shipping
  122. Bosch 13111's good or not?
  123. Need a wideband?
  124. Are there any scanning or even tuning tools that work on a PDA/SmartPhone or similar?
  125. Itb Ecu
  126. no start unless scanner is connected
  127. Need a good MAF file
  128. Using a GM Tech 2, Tuning??
  129. who's put a cable driven throttle pedal in a c5?
  130. Anyone using the racepak dash for the BS3?
  131. MSD box ?
  132. What happend to Injector Scaling Calculation
  133. Where's the extra timing coming from??
  134. unplugging 02's ??
  135. Retune???
  136. Anyone want Hptuners?
  137. h/c tuning question with a preditor
  138. 06 C6 P3001 ? Anyone
  139. what cause mph and tach to stop working?
  140. IPC no abs or tcs
  141. P0102 will not go away
  142. please help with p0412&po418
  143. Lockup Tuning
  144. Have To pass Emissions But have 2 Codes
  145. Need Help with misfire
  146. Oil Pres sensor & ECU..NOT used?
  147. will a 2002 ABS control box work in a 2000?
  148. coolant temp sensor -40
  149. EfiLive smoothing question................
  150. Mail order tune
  151. Turbo A/F Ratio before boost on SD tune?
  152. diablo ?
  153. Vacuum leaks and tune?
  154. handheld or hptuners, ls1 edit
  155. FAST Flash
  156. SD check question
  157. Line Pressure Offset vs TPS vs Gear
  158. MAF sensor going crazy?
  159. Reading my in car wideband?
  160. WTF +25 ltrim 1 side
  161. hp gains???
  162. AFR graph
  163. help
  164. tune vs taller tire
  165. MS4 installed now getting 0106 code!
  166. Bolt-On VE and Inj DC
  167. replace MAP sensor how to?
  168. Question about VATS and installing remote start
  169. Applying & Using HP Tuners Real Time Tuning Custom Operating Systems
  170. Auto vs. Manual ECU, couple questions...
  171. help me out
  172. AEM, DJ wideband sensor repalcement part #?
  173. Cold start problems
  174. Loosing all boost,could it be the tune???
  175. EFI Live: BIG Auto VE problem - Tune files attached
  176. Any ideas?
  177. PCM internal differences, cable vs electric throttle
  178. P0171 & P0174 Question
  179. DTC p00108? I just got my car tuned too!
  180. Autometer Wideband Gauge.....
  181. Buying injectors, which is the best way to tune?
  182. with these mods...what do I need tuned
  183. Tuning Variable Valve timing in a 07 TBSS
  184. Edelbrock Fuel injection
  185. EFI Live compatible with previously tuned car with HP Tuners.
  186. HP Tuners 1-2.5 bar E38/E67 ECM's features
  187. 2007 Trailblazer SS communication problem while writing with HPtuners
  188. TB Hole size - MS4 Cam, IAC maxxed out
  189. PCM issue w/convertion
  190. help me please! car wont start
  191. How to install a 2 bar pressure sensor
  192. Help! New 408 will crank and backfire but not start
  193. Laptop Hook Up
  194. I am looking for data that puts a narrowband and wideband log next to each other
  195. Gen 7 question
  196. Virginian Pricks...
  197. Can custom tune in the PCM be saved to my Predator?
  198. Problems with car... Comes on And off tuners come inside
  199. did lt1 swap. need HELP!!!
  200. Big stuff 3?
  201. Need Help Tuning My Isuzu Ascender
  202. uning Help with MS4 cam!
  203. I think I killed my PCM... HELP!
  204. One bank super rich, other stoich?
  205. Quick Question about MAP readings
  206. 98 pcm question with a solid roller and victo jr
  207. California Emissions in Tennessee??
  208. 160lb injectors
  209. 2 step
  210. Tow Haul indicator PCm pin?
  211. toasted the pcm...?
  212. HP Tuner Question
  213. VE table scale up by how much?
  214. 85mm SLP MAF resistor cut or not to cut?
  215. Popping during WOT runs
  216. P0327 - specific question
  217. Check my tune
  218. Need Help With Running Problem
  219. Paid Good $ For Prof. Tune & Car Still Won't Launch!
  220. injector scaling problems
  221. iac issues
  222. computer cant be found!?!?
  223. Car wont start
  224. TPS on LS2 TB
  225. Did I fry my PCM?
  226. At the track troubles..
  227. Logs showing less than 100% WOT?
  228. headlites
  229. Turning off EGR controls???
  230. Upgraded to HPtuners MPVI Pro - having LC-1 issues
  231. Hand held tuners??
  232. 98 trans am pcm wire question
  233. HP TUNERS for new injectors?
  234. HP Tuners for new injectors?
  235. Lean Code Problem
  236. o2 sensor linking
  237. Formato tuning and Porting in Gettysburg PA 10/17-10/20
  238. 408 going in, base tune for initial fire-up - critical
  239. To MAF or not?
  240. whats causing ltft to shoot up at idle?
  241. LTFT's ---> adjustment confusion!
  242. Check out my logs/tune..
  243. This is a weird one....HELP????
  244. Puzzle for the smart guys...
  245. VE table tuning question??
  246. What affects fuel trims?
  247. Leaning out on quick TPS movements ... I need some advice.
  248. Idaho Dyno Tuning
  249. Question about emission delete....
  250. wiring harness question?
