View Full Version : PCM Diagnostics & Tuning
  1. Dumping fuel - Why?
  2. stock 02 file onto a 99 pcm with hp tuners
  3. Engine Startup Lean Adjustment
  4. BigStuff3 vs stock PCM
  5. Handheld tuner question
  6. Do I need a retune for LS6/ported TB vs FAST90/90 ptm
  7. hp tuners 2 laptops
  8. p0135 help
  9. LS1edit won't/can't read
  10. harness and tune
  11. MAF Calibration - Diff AFR at same MAF HZ at different speeds/loads
  12. question about autometer tach w/2002 pcm
  13. Diablo mv readings?
  14. Intermittent idle and shift problems
  15. HPT won't log maf
  16. Any other sources for o2 sensor harness kits?
  17. maxing out map sensor @255 KPA- power reduction
  18. Program to do VE on E38/E67 LS7 style pcm
  19. Stumbles under acceleration
  20. Car won't go into pe mode at WOT
  21. I need the 97-98 pcm internal schematics
  22. ses light
  23. What to set LC1 output settings to, and HPT PID formula? (egr logging)
  24. Black smoke, tune problem?
  25. How hard to tune the hotcam?
  26. still waiting on HP Tuners
  27. Tune with stand alone trans
  28. Guys posting questions>POST IN FREEGIN DETAIL
  29. Hi Every Body
  30. LS1 Edit & PE Table Adjustment
  31. how would a leaky map sensor effect idle / drivability?
  32. idle charge problems
  33. wtf i have no idea whats going on
  34. computer case
  35. VE table Idle tuning question with cammed car
  36. Need help with tune please !!!!!!!!
  37. The LS1 & E85
  38. HP tuners demo
  39. Bank 1 fuel trim not working? need help
  40. Need help with tune please !!!!!!!!
  41. Already tuned... adding...
  42. Using Factory Clutch Switch for 2-Step Activation
  43. Gauges question
  44. Noise??? on NEW 402ci
  45. 02 LS1 engine harness with 04 GTO Body Harness
  46. Fried PCM
  47. LS3 Vette Tuning
  48. PCM question
  49. Does it matter is ecm is a4 or m6 ??
  50. Diagnostic port problem!!! HELP
  51. G-Meter's Accuracy?
  52. Using LS1 PCM/ECM for LS6
  53. o2 sensors
  54. Trans tunning issue - please read
  55. Anyone using the Predator?
  56. who's all ripped into their PCM before???
  57. Alarm System Malfunction??
  58. ms4 tune?
  59. Question on LS2 engine wiring harness
  60. Detonation problem please help
  61. LC-1 questions/issues
  62. Car runs like crap after header install!!! Please help
  63. Can LS1 Be Multi-Displacement?
  64. 1998 Camaro LS1 OBD2 Secondary Air System Monitor
  65. handheld or mail order tune?????
  66. Messing with the tach? Pro's please help.
  67. stuck in fuel cell 22
  68. question please help
  69. which PCM and wire harness
  70. Base 96lb Low Impedence Injector Program??
  71. HP Tuners VCM Suite v2.2.0 is Now Available!
  72. Looking for Wideband A/F Gauge
  73. Auto Trans tuning with HPT
  74. FAST vs. big stuff 3 opinions
  75. AFR Change day/night
  76. Security System Problem! Wont Start Engine! HELP!
  77. Custom programming has never been easier
  78. First log with new motor
  79. V.A.T.S. question, speartech please look inside!
  80. old autotap ????
  81. car hits 4600rpm and POW, backfire and shuts off???
  82. Another crank relearn question
  83. efi live & fast widband setup
  84. HPT site down?
  85. How Much Choke Flow Time with HPT
  86. Independently Tested INJECTOR FLOW NUMBERS!!!
  87. What should I look for?????
  88. MAF normal range?
  89. wideband tune --> remote start not working
  90. Multiple Injector Offsets Found
  91. Rich idle after cam, VERY rich
  92. Predator Tuner and P0757
  93. FAST 36lb Injectors rated at what PSI? Anyone have a good base IFR table for them?
  94. p0152, p0300
  95. t rex xar was running fine, now wont run for shit. stockish tune
  96. Detonation problem persists
  97. Tunning Gen 7 , Looking For Tune File 408 Na
  98. wb sensor location
  99. TPS sensor p0121
  100. PCM Calls Injector to open at what point?
  101. Diablo Predator tuning help
  102. PLX SM-AFR installation
  103. tune for Noz
  104. got problem need some help asap
  105. VATS/Security problem I think...
  106. battery problems
  107. Which tuner to adjust for bigger injectors?
  108. EfiLive Guys, could you Please critique my tune...........
  109. Running Rich
  110. eFI LIVE
  111. Need Help with VE Tuning
  112. NEED help trying to get this "stock" ls1 tune back to stock
  113. question about HP Tuners Credits
  114. please help possible tuning issue?
  115. EFILIVE speedometer problem
  116. tune
  117. My stock tach is off
  118. Spark timing
  119. My New Computer Flashed with Traction Control?
  120. 99 Camaro wont stay running .... ????
  121. Changing from 24X to 58X reluctor?
  122. VATS detune
  123. TSP tuning prob...
  124. Timothy Slovert Orlando, Fl Tuner?
  125. Need Help - Open Loop Bucking and Surging
  126. Need a WB A/F gauge for my LC1
  127. COT: what happens when CAT's overheat?
  128. Need a pic or link to FTC graphic
  129. hp tuners questions in bremerton, wa
  130. pcm unused 5 volt inputs
  131. ses light on
  132. Adjusting part throttle shift points
  133. 2002 Z28 PCM and a 2003 LQ4 engine
  134. Could this be from stock tune with mods?
  135. Injector Offset Tunning
  136. Tune killing my tranny?
  137. Ran my newly acquired scanner last night...
  138. 450 to much for dyno tune?
  139. rear O2 sensor question
  140. Why am I suddenly running lean at idle?
  141. Conversion wont start
  142. PCM fan control ?
  143. Any Tips For 01 Firebird LS1?
  144. Can't find anything on this problem..
  145. Do i need a programer?
  146. Wrecked car won't start
  147. Bs3
  148. Knock Sensors
  149. IAT effecting IAC steps. How?
  150. 383 lt1 probs.
  151. Big thanks to RUTANTA
  152. Walk-Through Grams/Cylinder --> Grams/Sec
  153. help with a problem
  154. What could be the problem?
  155. Lamp Circuit Failure code B1061
  156. No tach, cam sensor code
  157. Will EFI Live flash my VIN in another pcm?
  158. DTC P0704 Clutch Switch Input Circuit Malfunction and HP tuners
  159. Maf Hp??
  160. Wife turned key off while flashing PCM!!
  161. scangauge II
  162. Wideband Hook up. Does this sound ok?
  163. Put MSD6a on a 96 LT1 Now It misses,Kills
  164. Tunners for LT1
  165. FAST double bank wideband
  166. Hit the gas...car dies!!
  167. SD w/ th350, having problems with rich decel (dfco)
  168. weird problem need help asap
  169. weird problem need help asap
  170. shiftpoint logging
  171. Is there any way to bypass having to have the BCM in the car to stay on?
  172. PCM conx connector 18g Where to find
  173. long trims at -15 at wot, with cutout open
  174. problem when trying to copy ve tables
  175. How can VSS read 30 mph and speedo say 0
  176. reflash pcm
  177. cam sensor adjustment ?
  178. Where to buy hp tuners or ls1 edit?
  179. Where can I get a LS1 wiring harness?
  180. Guys I need some help tunning with EFI Live
  181. LS1 conversion: possible to get a 98 auto harness to work with a 6 speed 02 PCM?
  182. Is my IAC Gone South?
  183. 427 RX-7 Tune input needed...
  184. B1001 Restraint code...SES?
  185. Windows Vista and Datalogging.
  186. HELP! Rev limiter kicks in randomly!
  187. Car like 11:1 AFR using BIDI. I am Confused
  188. Need help with new LS2 problems
  189. HP Tuners or EFI Live
  190. p1018 causing fuel problems?
  191. Detonation/Ping on vacation trip
  192. t rex tune?
  193. Would someone be willing to look at my tune and logs to help with an idle flare?
  194. What software for 4.3 V6?
  195. wideband inaccuracies
  196. Low speed surge
  197. is this a tuning problem?
  198. MAP/TPS codes simultaniously
  199. Any way to test each injector and/or cylinder to see if ok?
  200. need pcm info on a 99 LS1 (SS camaro). pin #s specifically...
  201. a/f ratio
  202. Logs attached
  203. need some help.......
  204. Help with 408 tune....
  205. very intrested in efi live??
  206. Affordable wideband controller kit ?
  207. whats the best a/f guage for tuning??
  208. Changing OS with HPTuners
  209. Airfuel logging??
  210. LS1 Edit Questions
  211. Injector Driver failure
  212. Stock computer's limits
  213. Need Help tuning
  214. Please Help
  215. Rear O2 delete
  216. Car misfires when warmed up.
  217. Cam position sensor
  218. How do the numbers read in Base Running Airflow chart
  219. Help with SES code.
  220. MAF-less / SD folk...bellows??
  221. slow HPT orders ?
  222. help, i need someone good to make a mail order tune for me
  223. bad tune?
  224. Got mice?
  225. Mis/Sputter at low rpm Clogged/stuck injectors LS1 Swap
  226. Need a Little Help with logging with HPT
  227. Will this work?
  228. Tuning Veterans...whats up with my WOT Tune?
  229. Car is acting funny on highway
  230. AFR < 4000 rpm discusion 14.7 ?
  231. SES light... P1133 & P0135
  232. Very lean idle problem
  233. TPS on Gen 7
  234. No DTC, car runs terrible
  235. Maf tuning that simple?
  236. How do I upgrade to 2001 and up operating system?
  237. Swapping PCM's
  238. Air/Fuel way off need help
  239. anyonehaving issues with their MSD timing twister???
  240. I need Help with my Tune File
  241. Air/Fuel way off need help
  242. New PCM install and Code P1637
  243. can somebody look at my tune?
  244. What tables can be modified in RTT in HPT?
  245. Is It Possible?
  246. MAF tune vs Speed D tune
  247. Can't get rid of bad pop at 2800-3200
  248. EFI Live, Flashscan V1.2, where's the tuning software?
  249. New PCM, fuel pump does not turn on--sure way to check if PCM is functioning?
  250. Drop into Gear stalls Immediately (Cold Engine)
