View Full Version : PCM Diagnostics & Tuning
  1. Speed Density Conversion
  2. small problem with a code
  3. Ordered Hp Tuners...
  4. need help with a code
  5. bolt on tunes
  6. Problem with Predator
  7. TR224 cam tune with MS3 cam?
  8. This is driving me nuts!!
  9. Hard starting when warm
  10. Diagnostic Help
  11. This is weird?
  12. Down 30 HP on the Dyno,What are your Thoughts?
  13. My timing tables are set, why the fluctuation in boost?
  14. Need help throwing code P1626
  15. Bolt on/Stock Tune
  16. fueling/tuning help
  17. Got Tunercat? Got a PDA? Want to test PCM flashing software for PocketPC?
  18. PCM Gas Mileage?
  19. Whiteautoandmedia ???
  20. questions about getting a tune and cam
  21. What are Ya'lls HP#s Before and After Tune?
  22. Bought A Granatelli Big G Flash Tool And Need Advice
  23. Do ya think I'm running rich? Video
  24. Headers change AFR?
  25. 24x reluctor, electronic throttlebody ?'s
  26. tuning needed when Change CAm
  27. Ls1 edit and vista
  28. Cam install AFTER dyno tune ?
  29. Need Help Asap
  30. PCM Engine Speed Signal
  31. Can I tune in a weekend
  32. Which 02's are which?
  33. Re Tuned
  34. Lingenfelter 100mm MAF?
  35. LC1 Help
  36. Which Wideband with a Gauge for trouble-free interaction with EFILive?
  37. Jumpy needles, ses, and higher idle in park.
  38. "Texas speed mail order tune"
  39. speed density newb
  40. Got a few codes to take care of
  41. Horrid gas mileage
  42. No Spark, Won't Crank
  43. did i forget anything?
  44. any efi or hpt users around Newark De?
  45. MAF translator pro???
  46. What to Look for,Number 8 Cylinder not showing Firing
  47. Need help identifing a plug and a part
  48. Tuning shift points
  49. Anyone successfully install a Racelogic traction control system on an LSX motor?
  50. Speed Limiter??
  51. narrow band front o2s
  52. VHP Problem help !!
  53. bucking off the throttle
  54. P1415 or P1416 Trouble codes - my fix
  55. code p0108 help please
  56. New to Hp Tuners and car is running lean!!!!
  57. Things you wish Predetor would have explained better!
  58. Bought V2 efilive...can I sell V1?
  59. Any pics of a clean lc1 controller install
  60. what are the best o2s to buy?
  61. WTF?? My TCC slip % is 1040!!!
  62. on start ..spark help
  63. EFI Live users in Twin Cities
  64. Turbo tuning with a gen 6
  65. OBD2 "not ready"???
  66. P1870 after tune
  67. Creating Primary VE off Secondary?
  68. help with codes please
  69. re-tune
  70. VSS Changes going from M6 to TH400?
  71. Flucuating MAP at WOT
  72. Installing RoadRunner PCM and Locked PCM
  73. bad computer?
  74. superchip Programmer
  75. After cam swap car won't always start on first crank?
  76. You know what I hate?
  77. Question about OBDII inspection and Tuning
  78. Removal Of Computer
  79. Tunercat for LS1?
  80. HP Tuners - cylinder balance
  81. Evaporative purge system not ready?
  82. Tune or not to tune...
  83. Another Question on TPS sensor output wire?
  84. Start up Idle hunt and throttle response issues
  85. car stumbling and throwing a code
  86. nelson harness question......
  87. Need help with ls2 408 in a 2000 firebird
  88. throttle position sensor
  89. Ms4 + Efilive Base Map
  90. ok got a question about codes
  91. Trims and WB dont match
  92. Not a LS1 but a 2.2l boosted????
  93. HPT to EFILive
  94. tuned or not?
  95. HELP!! Idle problems on a 2004 Z06 with G5X-3 Cam in Kansas City
  96. Hp tuners claims im throwing a code (no check engine light)
  97. question about turning off p1133 & 1153
  98. accelerator pump like table?
  99. misfire
  100. HPTuners Mutliple computers?
  101. Startup is very lean, 19.2 on W/B
  102. PLEASE HELP. Expert Tuners Needed
  103. Tuning for Readiness
  104. I am an idiot!!
  105. Needing a tune in Georgia
  106. Codes being thrown
  107. Tsp Ls2 Fbody Swap-no Tach!
  108. Anyone have EFI Live?
  109. Emissions help...
  110. Please help on tuning for e85
  111. help with SES codes (p102 and p113)
  112. Minimum pulsewidth with 42Lb SVO injectors
  113. Need Some Help on OBDI DTC
  114. Help with Logworks and LC-1
  115. Question on tranny parameters
  116. Pulling timing via maf..What OS?
  117. GM PCM or ???
  118. First startup tune... (HPT)
  119. SES bulb replacement
  120. No Voltage towards Cam Positioning Sensor.....Disable?
  121. my untuned 99z
  122. p1133 p1153
  123. Shift light and delivered timing...
  124. HELP!!! ELECTRICAL PROBLEM! Guages flashing while shifting
  125. under 40 mph goes like hell
  126. speedo signal issue
  127. maf ?
  128. How do I set my TCC min and max duty cycles?
  129. tuning idiot ?s
  130. 98 to 02 PCM
  131. 02 sensor thrown
  132. could this be the reason for crappy dyno relsults
  133. Logging oil temps in HPTuners?
  134. OSX plus Tuning suite?
  135. just wich tuner will be easyer to work on
  136. LT1- Open headers, & now O2's reading lean???
  137. Look at this please
  138. Cam Position Sensor Problem
  139. What WB is REALLY better. one with free air cal or ones that don't need to cal
  140. Highest timing at idle.
  141. lost power after puting 110 fuel and removing airfilter
  142. Lean A:F (leancruise) vs spark timing
  143. Emission test question
  144. Backfire through the intake????
  145. Injectors won't fire at all...hp tuners..Please help
  146. Does The PE Table play a roll in a Open Loop Tune?
  147. Need some help Tuning my Converter
  148. Tuning Option for 97 Vette
  149. Open Loop and Closed Loop
  150. Will Fouled o2's Effect WOT with a Open Loop Tune?
  151. Question about Fowled Spark plugs.
  152. body wiring question
  153. disabling air bag lights?
  154. how much power is a stock pcm good for?
  155. Turning off ABS light
  156. Predator
  157. O2 sensor problem perhaps PCM
  158. Off Idle Hesitation...
  159. Car staying at 2k RPM
  160. Need Help Please--1999 Z28
  161. IFR question..............
  162. question about tuning
  163. Strange lazy idle gremlin
  164. Knock sensor keeps going nuts on an 03z06
  165. Got Hypertech...Have Problem
  166. vaccum question.. please help
  167. Timing/Fuel Trim help
  168. ASR kicking in at 38 mph
  169. Question On Rear O2 Sensors After Programming Out
  170. Stock engine and stock tune, drivability problems?
  171. question
  172. aem uego gauge
  173. Cammed cars/low map VE problems
  174. Efi Live 3 bar for 97-98 gunna happen?
  175. ac aridium plugs vs ngk tr55
  176. Can anyone help me setup a pid in hptuner?
  177. Does the Innovative LC1 come with the Logworks software?
  178. Driving the car without the instrument cluster?
  179. Help with LS1 Edit Hanging when reading PCM
  180. Turned off all 4L60e Codes after th350 install, now hatch wont open
  181. Ve table stock with cam? I can't turn maf off.
  182. I need my ses light back on
  183. i need a obd-2 cable
  184. Backfire between shifts/ HPT
  185. PLX install pix
  186. Codes P1635 And P0335 After New Engine
  187. Anyone have issues with undetected, audible knock?
  188. WOW!!! Turned off MAF
  189. shifting issues
  190. MAF values and horsepower.
  191. ls1 edit tach signal
  192. MAF or SD?
  193. Quick ? about CAGS disable.
  194. AEM Wideband Not Reading Correctly
  195. 2001 Trans Am Pin Out
  196. Predator question?
  197. time for a tune?
  198. LC1 to HPT EIO
  199. Fuel injector synchronization on GM
  200. want to start tuning
  201. Tuning issue or vaccum leak?
  202. Can my HPTuners scan codes on non-GM cars?
  203. LTFT question?
  204. Innovate LC1 LM Programmer..
  205. Does Wet System Need retune?
  206. Please Help MS4 Problem!!!!
  207. Stumbling when cold??????
  208. Idle misfire - cant figure it out
  209. What Does your HPT Say for Voltage when Flashing?
  210. How do you properly reset PCM?
  211. EFI live, other cars??
  212. Dynojet wideband with hp tuners
  213. Got a few tuning issues/?
  214. Wideband setup....
  215. Idle Spark tables/ HPT?
  216. lid and descreened maf = hp loss ???!?
  217. car dyno'd and would not richen up after checking AFR
  218. Need help Quick w/ 2003 GMC Sonoma 2.2L !!!
  219. Help, Vinci Tuner Not Working
  220. what is the purpose of a open loop tune??
  221. AIC valve not working?
  222. Dialing in MAF
  223. Need suggestions on LS1Edit changes
  224. passing emmissions after tune
  225. Why would fuel trims not match afr?
  226. [b]i Need A Nitrous .bin File For Hp Tuners[/b]
  227. Map not logging
  228. LT1 PCM problem
  229. problem with efi live connecting and autotap
  230. Car wont Idle, surges, and stalls. Plz help!
  231. How-To. Record with DS Predator.
  232. 408ci first startup....P0342
  233. MAP Sensors
  234. Timing Question
  235. Idle Surging and Low End VE Table Accuracy
  236. P0122 code? wtf?
  237. Throwing P0102 After Z06 MAF install?
  238. boost & fuel pressure gauge install
  239. Help with VE table, SD tune
  240. In NEED of some HELP!!!!!
  241. Who feels like teaching a class?
  242. Anyone who tunes their car using HP tuners.
  243. No way to disable maf on TBSS?
  244. Wanted: tech details on LS crank wheel
  245. Computer won't let me in
  246. O2's High Voltage Po158 Po138 REALLY QUICK QUESTION PLEASE HELP
  247. o2 code
  248. A little help needed please!!! MAF Related!!!
  249. anybody here used the Acel Gen 7 product?
  250. Help with deleting rear o2's(EFI Live)
