View Full Version : PCM Diagnostics & Tuning
  1. Car Died
  2. Hanging Idle
  3. P-0410 Code
  4. Stock or Modified VE table
  5. Mail order pcm question.
  6. KR on Stock Car
  7. No Start!!!
  8. where do i start?
  9. Whos your tuner???
  10. vortech ls1 tune help!!!!!!!!
  11. will it work
  12. Please help
  13. Why do we need DFCO?
  14. Throttle cracker table zeroed - I like it!
  15. Advantages of EGR removing?
  16. pulsewidths are bad and 1 not reading
  17. Cam Tuning Question (gas mileage)
  18. TPS / Trans C5 question
  19. OK Tuner Guys !!!!!!!
  20. So my converter isnt staying locked....
  21. Idle hunt
  22. who can take a look at this lt1 data log?
  23. 99+ ecm/harness swap in 98 thread anyone.
  24. vortech ls1 edit tune
  25. Question?
  26. C5 corvette Throttle position sensor help
  27. Heeelpp!!
  28. Air Fuel Gauge
  29. Code P1336? Help
  30. bad gas milage
  31. is this a tunning issue... *VIDEO*
  32. 402 first start no idle warm
  33. will someone look at my tune.
  34. Crankshaft position sensor
  35. updated EFI live now i cant scan
  36. AEM AC pressure question
  37. ls2 wiring harness
  38. 454 LSX, LS7 heads and Kenne Bell SC and PCM?
  39. ls6 maf into a 2000 camaro?
  40. cluster panel going nuts
  41. Just bought with Hypertech...
  42. Got my wideband today
  43. Differences between LS2 and LS7 PCM
  44. Question About Tuner Please Help
  45. tune question
  46. HPT, enabling high resolution rear speed signal
  47. Afr tuning with a wideband
  48. HP Tuner switch to credit system
  49. TCS off light coming on?
  50. For those tired of the airbag light...
  51. G tech performance meter
  52. Throwing code P0420
  53. LSx 402 bins?
  54. question about the actual stock pcm programming
  55. thinking about buying hptuners
  56. Wiring
  57. multi postion tuners
  58. how do i convert a pcm from obd2 to obd1 and a4 to m6
  59. anybody else find themselves spending time on redhardsupras blog?
  60. Will a Motor Plate or Dual Valve Springs trip the Knock Sensors?
  61. OL idle tunning and DFCO
  62. newb question
  63. Swapping Wiring Harness
  64. wide band = 12.5
  65. s/c tune
  66. tuning help blinking ses
  67. Need some clarification on BS3
  68. IAC problem...
  69. Care to give me suggestions to attempt fixing my LC-1 before I return it?
  70. need second opinion
  71. Mobile LC1?
  72. wideband help
  73. Different PCM's same year
  74. Wideband permanent install?
  75. Idle question
  76. Alternator Output Question
  77. my p0135 problem...
  78. Question about SCT
  79. FAST and DEltq system
  80. care to look at my tune? need help on cold starts
  81. Changed injector table and now minor probs
  82. Desifer this for me..
  83. F.A.S.T. 90/90 > no tune ... how hard can I run it?
  84. sporatic knock
  85. Can't Decide on Which hptuners os
  86. What to do to my tune?
  87. MAF question ???
  88. lm-1 and hpt
  89. Head-aches and ill after a tune.
  90. Newb to A4's and 3K stall with 3.42's . . . Little Help?
  91. DiabloSport 2 step
  92. P0157 Sensor 2 Bank 2
  93. Anyone have EFI live tune for my combo? heads/cam
  94. Tune "worth it" on a stock car?
  95. O2 sensor and slip on collectors
  96. i need help with a diablo predator programmer
  97. i need with diablo predator programmer
  98. switchable tune
  99. Got a problem....
  100. 6.0 Popping
  101. bad maf?
  102. dyno tune in orlando area
  103. Gear vs Speed calculator (macro and non-macro)
  104. fuel pressure
  105. need some advice
  106. Injector flow rate identifacation!
  107. NO Rear 02 sims = high LTFT ???
  108. whats with my lt1edit
  109. coil pack testing question
  110. VE LTFTs
  111. Computer problem?
  112. AFR question
  113. MS3 and Max timing
  114. Ghost in the Machine
  115. HPT RTT question
  116. Maf High frequency
  117. code p0300 random mutiple missfire..help
  118. 42 lb injector problems
  119. hp tuners+zex 150 wet kit
  120. I need to know how to fix these codes please!
  121. For those of you who live in cold climates...
  122. SD Tune STILL poping through exhaust around 3k
  123. LC-1 simulating narrowband and setting codes
  124. battery relocation
  125. Using Predator to change Camaro Timing
  126. Mail order tune ok just for LT's?
  127. Widebands and TD's...how many?
  128. EFILive and adverse OIL GAUGE READINGS???
  129. code p0300 random mutiple missfire..help
  130. o2 Sensors???
  131. lc1 gauge?
  132. can I remove this wire?
  133. Ls1 shiftpoints????
  134. Autotap and wideband
  135. crank sensor??
  136. Accel Gen 6
  137. Air/Fuel gauge install???
  138. EFI Live VIN# reprogramming
  139. Check out efilive RTACS in action
  140. Mercruiser BBC EFI in a car?
  141. Can HP Tuners modify an LS1 Edit tune?
  142. predator broken?
  143. Reseting predator
  144. What causes KR
  145. SES Problems with 2000 Camaro
  146. P0430
  147. I need someone that can tune
  148. Tech 2 question
  149. Have a .hpt file...but no way to read...can anyone help?
  150. MS4 tune file
  151. weird P0704 - w??
  152. Has anybody ever heard of this??????
  153. Help with tons o codes?????
  154. Predator Tuning Problem??(trans)
  155. LM-1 and Hp tuners..help!!
  156. Where is the IFR calculator??
  157. New EFILive Tutorials
  158. Tuning Issue?
  159. Power programmer on a 6 speed question?
  160. code p0300 random mutiple missfire
  161. Megasquirt please help!
  162. Idle problems...
  163. Any tips on SD tuning a T-Rex cammed car?
  164. Knock Sensor adjustment
  165. Gas Analyzers for tuning?
  166. What do ya think?
  167. EFILive Auto-Cal?
  168. PCM relearn
  169. Maggie Z06 'tuned' what a joke -HPtuners log att.
  170. Help! SES P1614
  171. Anyone interested in the AEM EMS?
  172. crank relearn for pcm?
  173. ls1edit crashes, searched, found nada...
  174. Wideband with STD Interface
  175. misfire question?
  176. looking for a procharger bin for a 05 C6 A4
  177. Problem with HP Tuner 2.1.16
  178. Idle graph
  179. To those who have the AeroForce Interceptor
  180. Ms3 PP heads
  181. What A/F should I use for wot??
  182. wbo2 opinios
  183. rotten eggs
  184. Sd Tuned/snow Meth Controller (maf)
  185. car idels fine almost!!
  186. Wideband and what?
  187. USB -> serial converter issue
  188. Knock sensor low voltage
  189. Cold start and KR help with HP Tuners
  190. Tach not working
  191. car runs like poo
  192. HP Tuners VCM Suite 2.1.16 Released!
  193. Wide band commander help
  194. HP Tuner Narrowband O2 Tune Help please..
  195. help me please
  196. can u use mutiple tuning programs on the same PCM?
  197. DTC reset
  198. Portable WB opinion.
  199. hypertech lost now tuning with hp tuner?
  200. Tuned for n2o, but I removed the n2o. Would a handheld move my timing back to stock?
  201. kind off a newbie quiestion on a dyno tune
  202. Relacement PCM ?'s
  203. Help with ditching SLP MAF for stock unit
  204. Convertor Box and Stock ECM
  205. P0161
  206. 99 ls1 automatic into 02 ls1 6speed.
  207. autometer tach is way off help please!!!
  208. Help with voltometer
  209. rpm drops when ctuch is in
  210. EFILive Training classes to begin March 10th 2007
  211. Cluster question
  212. GMS Fuego
  213. narrow band
  214. Quick Help - Throttle Screw
  215. Iat
  216. best tuner for 1998 z28
  217. Does the PCM monitor the low oil level sensor?
  218. Temp Gauge Crazy
  219. Spark Advance
  220. HPT wont read LC1 correctly
  221. speed inc electronics page
  222. Dynamic and Maf
  223. How is it possible idel
  224. A/C compressor at WOT?
  225. Air Flow Decay and Delay Hptuners
  226. Base Running Airflow Hptuners
  227. How can i go from dual fans to a single fan with HPtuners?
  228. PIN remover?
  229. texas speed mail order tune
  230. Stock O2's - higher reading before or after cat??
  231. quick ?
  232. BUYING AFTER MARKET MAF'S (if u are, tune the MAF table before runnin ur car
  233. tuning question
  234. new to tuning
  235. Better to tune with the stock MAF maxed? Or with the new LPE MAF?
  236. MAF VS Speed Density Tune!
  237. diablo tuner question...
  238. Interesting Read
  239. AeroForce Tech?
  240. anybody played with leaning things out during cruise for gas mileage?
  241. Where to mount PLX wb o2 on LG Long Pros
  242. 83% throttle at WOT
  243. Went from stick to auto-now how do I dyno this car properly?
  244. tuners
  245. CR3 files
  246. Predator question?
  247. hypertech
  248. Can too low of timing hurt?
  249. NEW PRODUCT: MSD Dashhawk
  250. Tuning for manual transmission in 00-04 truck ?
