View Full Version : PCM Diagnostics & Tuning
  1. My first Speed-Density Tune
  2. Lt1 Edit Help Please!!
  3. trans codes = limp mode???
  4. Runs fine for a min when cold then starts misfiring...help
  5. Tuning? How much will it help?
  6. Tuning for consistency
  7. P0300 code... please help!
  8. Throwing P0300 Code, please help!
  9. P1635 (Aux reference)
  10. Speartech releases latest edition of Offboard Programming Harnesses
  11. Bad Injector or Bad O2?? Help me out
  12. blawar ???
  13. LT4 PCM Question?
  14. 0300 misfire after header install
  15. o2 won't go away...:-(
  16. Tuning question
  17. LC-1 install
  18. Why dont FI guys just delete P1514 code?
  19. Need Help/Check ENG light
  20. Car keeps maintains throttle once gas is let off....
  21. what would i need?
  22. mega with wideband
  23. All of this because of a converter install??
  24. Disabling VATS with EFILive
  25. Passing emissions with Big Stuff 3.
  26. SES Code P0175
  27. .600 242/236 off idle tuning problem
  28. Engine swap
  29. c5 big cam tuning: stop me from drilling a hole in my throttle body.
  30. Idle tuning 408 automatics??
  31. What am I missing? LTFT/VE tuning.
  32. Electrical relays
  33. flow rate
  34. I need a new pcm for a dyno tune??
  35. Help with knock (graph inside)
  36. What options should I get with the Innovate LM-1
  37. INOP and Trac Off light
  38. changed gears in Hptuners ... not installed on car yet
  39. My SD TEST!
  40. Tune
  41. what a nightmare
  42. Best way to tune with 2 bar MAF
  43. Where to TUNE around me?
  44. Torquer v.2 bin.
  45. Granateli Mass Air Flow Thing?
  46. OBD Codes!
  47. HPTuners: extra eio pig tails for serial interface?
  48. Turned SES light off, now funky idle.
  49. what is causing this lean cold start *graph inside*
  50. Advantages/disadvantages of SD
  51. which wideband 02 allows me to do this? (split the output)
  52. Random misfires on all cylinders
  53. Need some histo help.......
  54. IFR For Stock 01 26lb injectors
  55. how to tune for 30#injectors
  56. Smog is killing me
  57. Has anyone heard of Kalmaker?
  58. Adding aux inputs to HPT pro interface
  59. how to clean maf
  60. Is a Vinci tuner really worth the $$$?
  61. NO "FOB TRAINING" diplayed on DIC on 1997 corvette
  62. Sct???
  63. Help! Failed NJ Inspection, HC too high!
  64. Innovate RPM converter hook-up
  65. main VE and backup VE in Autotune
  66. Tuning Differences Between 350LT1 & LT1 Stroked To A 383?
  67. Tuning for N2O
  68. O2 Sensor Balance
  69. please help
  70. Looking for a TSP 233/239 .bin
  71. TCC slip???
  72. Diablosport predator questions
  73. Looking for a laptop that will support LS1 edit.
  74. Keeping Stock Gauges w/ BS3
  75. Non WOT Above 4K SpeedDensity A/F
  76. Using EGR for wideband input, on NON-EGR eqipped vehicle
  77. Can H/P tuner reprogram for 3.90 gears?
  78. EFILive Scan tool not connecting to vehicle?
  79. Tuning help: hotcam=rich idle
  80. Electrical woes - Pulling my hair out!
  81. subaru sti tuning
  82. 98 PCM questions
  83. A.I.R. control valve connector
  84. .598, .608 236/242 cam and stg 1 heads tune needed
  85. Handheld Tuners
  86. HPtuners screenshot. What does this mean?
  87. Disconecting problem
  88. Speed Density dry nitrous question
  89. which scanner should I get?
  90. Would someone be willing to look over my tune...
  91. PO336 code on new 408" startup, wont idle or run more than a few seconds???
  92. "Completing" Evaporative System Readiness Test?
  93. Tuning in DFW area
  94. can pcm control variable speed rad. fan
  95. Smoothing
  96. PCM went out, now all electrical is messed up, ABS always on, misses/dies
  97. O2 Sensor
  98. Noob to tuning, not to OBDII. Need some advice and direction.
  99. Now accepting Pre-Orders for EFILive FlashScan V2!!
  100. non LS1 check engine light
  101. maft-pro + stock ecm + thumper?
  102. V2 is Released to the public!!
  103. Surging idle issues - please help!
  104. quickest seen ls1 with minor mods 1/8 mile
  105. Maggie Tune and Efilive
  106. Tuning for relocated knock sensors
  107. Any New Tuning Books avalible with Tranny Help?
  108. Dyno results...funny read
  109. Car running without vats module now... No check engine light self check....
  110. delivered engine torque in hpt
  111. Car is shutting off out the whole???
  112. How much HP is a "tune" worth.
  113. Style of electrical connectors, metripack? or GT 150?
  114. Would ABS delete cause code U1000?
  115. Basic Tune or Dyno Tune, that is the question.
  116. Emissions test and tuning?
  117. Car missing above 2500rpms
  118. Is there a PCM difference in vettes? 97-99
  119. How many wideband o2 oxygen sensors do I need?
  120. Power loss at the start line
  121. Tuning Gurus New SS3800 converter,Please help me Tune
  122. changing vin in ecu
  123. 98 pcm's
  124. Check inside for a quick laugh something I found in the G-TECH PRO SS manual
  125. Need Help with power programmer plus
  126. P0154 DTC Does it effect Performance?
  127. What does Tuning Cost?
  128. Have searched eveywhere...Please help.. Idle issues???
  129. idle dips with maf plugged in
  130. efi live
  131. new ver of hptuners 2.14 and rtt
  132. How to test if a wideband sensor needs to be replaced?
  133. Tuning gurus please help with AF ratio question
  134. Cause of LT B1 norm & LT B2 maxed out ?
  135. Pulling timing and leaning out.
  136. I NEED HELP@!!! chevy messed up my car!
  137. LS1 and Megasquirt trigger wheels
  138. Air pump always on
  139. Lean @ WOT after LT's
  140. BCM Replacement 2000 Yukon Xl - Does it need reprogramming?
  141. What is P0154 code?
  142. Super Low Dyno Today
  143. starting issues
  144. Lost Power
  145. HPTuners v2.1.14 RTT now car won't start...
  146. Alternator charging question.
  147. Running Lean
  148. Can I swap computers
  149. HP Tuners WOT Shift Question
  150. Could somebody help me with this file?
  151. HPT MPVI logging off Autometer Cobalt Fuel Pressure gauge-has anyone done it?
  152. obdII not working?
  153. Newer GM 2 BAR MAP (the small one) - Proper HP Tuners Values (scalar)?
  154. Look What I Have Been Playing With...
  155. Quarter Mile Customs- WTF???
  156. CEL and surgeing
  157. Can anyone tune a '03 4.3L Sonoma?
  158. NEED HELP!!! 2 Bar MAP key on says 2.22V but 0kpa
  159. Learn me on some timing
  160. Gains Stock Engine
  161. Any software to support both 97 & 02 fbody?
  162. MAF Flow vs. Frequency?
  163. Really odd electrical problem.
  164. 2007 LS1Tech Calendars Available!!!
  165. If dealer scans a tuned car...(Predator)
  166. Def file
  167. How do BLM modifications affect tuning?
  168. slp maf and ms4???
  169. What is correct key on reading for 2 bar MAP???
  170. Help!!! I need computer files
  171. 2002 Escalade ECU help???????
  172. How to get rid of "Check Gas Cap"
  173. idle question
  174. HTPP3 question
  175. code not in HPT?
  176. Speed Density Tuning
  177. WOT timing
  178. Retuning (Converter Replacement?)
  179. Gen 7 Install
  180. Not Enough Vaccuum
  181. HP Tuners VCM Suite v2.1.14 is Now Available!
  182. Could I use injectors, or get away with the stockers?>>
  183. I Need A Tune
  184. Random Misfire with no codes
  185. what are the best computer tuners for the LS1
  186. Bosch o2 used w/ LM-1: standalone p/n?
  187. granitelli hand held
  188. need help! Tuning prob. after gear swap
  189. 99-00 complete conversion need help w/ vats
  190. 02 Sensor Voltage Switching
  191. rev limiter
  192. Are all LSU (WB) sensors pretty much the same?
  193. Torque Management Question...
  194. Transmission help
  195. Off idle knock at track...suggestions??
  196. Installing a Wideband question
  197. my procharged car is making 250+ temps
  198. please help ASAP
  199. How to test O2 sensors.
  200. Speedometer correction ratio for Gear swap needed 98 F-Body
  201. Please Help
  202. pcm guru's
  203. LT1 OBD 1 Tuners!!!!!!!!!! NEED HELP
  204. where to go to delete codes?
  205. tuning? is it worth it?
  206. C0240, C0041 and C0036 Codes after cam
  207. help! Knock sensor!
  208. Checked the stickies...and
  209. Do they make a serial port to USB adapter?
  210. 98 A4 WOT Shifting
  211. OL SD... break it down big bird-barney style for me
  212. Bin repository access??
  213. Anyone using an FJO WBAFR to output to the PCM?
  214. ECM programming for slightly modded 00 LS1
  215. PO103 MAF code fixed
  216. TSP 228R Tune
  217. serial number Help
  218. Anyone have a wiring diagram for an FJO wideband?
  219. what is grams/cyl ? and timing help
  220. Tuning Questions
  221. wideband install
  222. Rich after LongTube and "low end loss" explained
  223. Newbie Needs some help
  224. Help! Car will not start until i reset the pcm manually
  225. Need a 98 Fbody PCM any one have one for sale?
  226. 98 to 99+ LS1 PCM conversion?
  227. lt1 edit vs. Tunercat
  228. tune for turbo with diablo
  229. when auto ve why does it create huge spikes
  230. C5 O2 adapter needed--Flat to square connector
  231. Need list of codes to disable for EGR and AIR pump removal
  232. check engine light please help
  233. throttle body wiring connectors
  234. Can you sell an HP tuner suite?
  235. help on efilive LS1 tuning?
  236. How Do I reset the TPS ?
  237. any HPTuners bin based on near Stock LS1 engine in repository??
  238. OBDII cable compatibilty
  239. What Tune Should I Go With
  240. code problems...need help
  241. PE Fuel Adder vs. IAT
  242. Predator tire size for gear change
  243. Any way to tell when this ECU was Made?
  244. What is a cell
  245. Tuning newb
  246. Changing my tune for a stall
  247. flashscan not reading what the lm1 does
  248. Question about VATS bypass.
  249. What would cause 4 lights to be on at once? Brake, Service vehicle, TCS OFF, and ABS?
  250. What causes an A4 to not Go when floored?
