- once in a blue moon miss
- afr's and cat damage
- P0654 and p0748
- car not shifting right after gear install
- VE AFR histo quit working hptuners
- E85 mpgs. What are you guys getting?
- Using wideband output for PCM?
- pcm/dyno tune
- multiple missfire
- max hertz on a stock ls1 2002 maf
- pcmforless
- 2002 ws6 a4 wot issue
- descreening a maf?
- tuning injector help
- Did you tune out P0343 / Cam position sensor? Come in here, need help!
- ***~~~frost~~~***
- help installing a maf
- I have a p0101 code
- New dyno tune but won't run at parcel throttle. Help!
- Abuse Mode??
- 98 z28 torque management
- HP EFI tune/ output help
- inTune now supports lots of GM apps back to 1999!
- TB SS MPG with Tuning
- Looking for timing table for TSP 228r cam and 243 heads!
- NYS inpection FAIL
- DFW Tuner
- Trouble Codes
- Bank 1 Sensor 1 problems
- HP TUNERS offer
- Can anyone tell me what engine wiring harnesses are compatible with a 2001 camaro ss?
- does any of this explain bad mpg?
- Explain knock in my log
- Serial Number Blank, won't allow to reflash. EFILive v2
- Holley: I need Harness 558-309 for my setup ASAP!
- 2005 c-6 rear o2 light on ??
- Goes to 0 timing in gear, cause?
- Opinions on log. (HPT)
- Is my LS7 MAF in an ok spot
- Adapting AEM LS1 ECU in different vehicle
- Need help fixing these codes Please!
- speed density tune
- Long tubes ses light..
- EGR monitor for 2001+
- Is there such a thing as "most easily tunable" injector.
- Albany NY Area and surroung ares(BEST PLACE TO GO FOR A TUNE)
- bolt on car getting a cam install
- car wants 30% increase in VE after FAST intake
- Tune or o2 Sensors?
- Lean across board on warm start
- Why does the VE table change by itself?
- 04 ls1 engine management
- I want to slow it down
- Diablo tuner troubles
- Tuning problem - way lean everywhere?
- $2500 for 30rwhp????
- 02 into 99
- Help disabling my theft system
- Autometer Speedo VSS hookup?
- After street tuned, PCM no longer retards timing to 0 under deceleration...??
- trading PCM and harness, will it work?
- code: 1336 crank relearn ?
- put in a clutch that weighs a total of 23 lbs, car wants to stall (UPDATED)
- just did longtubes, used denso 234-...corvette sensors.now no communication to o2s
- Holley HP/ Dominator EFI Help Needed
- HP EFI Tach Wiring
- Knock after sitting in hot traffice 4.5+
- Car won't start after holley dominator efi install
- Arizona emissions fail***UPDATE**PASS!
- mail order tune for heads/cam/rear mount turbo?
- Gears for HPTuners.
- 2001 Camaro SS computer tuning and programming
- qestions about efans.
- Not detecting OBD2 protocol
- Question about non ethanol gas and tuning.
- kansas city area tune?
- 98 knock sensors vs. new type
- HPtuners EFI live Bluetooth support?
- edcmat-l1 tuning in Pittsburgh 5/18-22
- edcmat-l1 tuning in Frederick Md 5/16-17
- Tune in Park vs. Drive. vs. Neutral?
- Misfire count, knock retard. How much is too much?
- help with my 98 turbo ws6
- Holley EFI demo software
- 5.3 Turbo 2 Bar Siemens 80 Tune Question
- Knock sensor and missfire problems!! Please help!!!
- Idle issues with EFI Live and LTX?
- What is the differance!
- 80lb injector data base tune
- False knock?
- PCM bad?
- HPT erasing PIDs/histograms when they're unsupported.
- DFCO Not possible with loose converter?
- Newb question on wideband readings
- recommended tuner in colorado
- PCM gaskets
- 95 ls1 vats issues
- Tune and pcm relearn.
- Surging idle problem
- F.A.S.T. , BS3 or Holley EFI?
- Spark Correction
- msd 6ls install with stock pcm tuning help
- 08-12 CTS wiring diagram V6.
- F.A.S.T. Guys In Here Please
- what spark plugs are you runnin with your frost tune?
- How to reset PCM
- Whos using a Innovative LC-1 with HPT Pro?
- WS6 LS3 2002 A4 tune file
- why wont my truck start?
- LT1 tuner in Charlotte NC area?
- stock tune
- ODB2 Scanner/Logger Download?
- NGK AFX wideband and E85
- Heelp!!!
- need help on my car for tunning
- Wide band harness extension
- Is this burst knock? Log, tune and config inside
- Map sensor help Please
- Problem with skip shift electrical plug
- tune getting worse?
- EFI Live and HP tuners in same PCM?
- Need a tune
- Some surge with TCC Lockup.
- WOT issue
- Flashing gauges under acceleration
- Weird SES light
- low oil level light
- Email tuning, HPtuners and more
- Good Tuner in the NC Area?
- Sensors not completing cycle
- Can anyone review this HPT scan?
- Lc-1 wideband
- Why is my car knocking at randomly rpms?
- 0411 into 98 f body cradle?
- LQ4 with cam and more... but no tune :(
- why wont hp tuners read ECM?
- Help me identify this harness, 98 or 99+?
- new tune, no MAF ?
- GMPP controller
- holley dominator EFI does someone have a parts list?
- Yay or nay to dyno tune after just exhaust & intake? (LS2 C6)
- warren (ls1) to E40 PCM/ECM (ls2)
- 99-02 Harness in my 98 TA
- EFI live, 160lb injs, E85, resistors, only runs WITHOUT the fuel pump on?
- Will oil affect wideband readings
- hypertech question
- EFI Live COS ???
- Any mail order tuners not need the PCM sent in?
- Scan only questions
- Pcm for less tune
- wiring one fan off the stock PCM and harness.
- Ls376/480 Diagnostic??
- Wideband questions?
- RPM Surging at Constant Speed
- Need info on Tuners for a stock 99 ss
- DBW Throttle Body Response (hanging rpm)
- P0300 after heads/cam swap
- problems with swap harness and 411 pcm
- 0411 pcm reflashing
- Rapid Motorsports?
- O2's not switching properly..tune related?
- o2 sensors, where should they be placed?
- PCM Question
- Maybe a pcm problem??
- Tuning help!
- New to HP Tuners - 1st Initial Tune, Log, would appreciate some feedback!
- what programmers will work for my 98 ss
- Running a Cam untuned in an Ls3.
- 07+ E38 ECM OBD2 port wiring
- mod harness ecu trouble 4.8
- wide band o2 graph
- Where does this plug in go???
- New efi setup won't start - fuel pump relay kicks out '09 LY6
- loading a mail order tune
- Tachometer inop & can not retrieve DTC's
- anybody know what this box is?????
- Need your help!!!! Please
- OBD2 sensor readings for 2000 camaro z28
- Anyone using an Accel Gen7 with your LS?
- Bs3 dealers step inside
- Lingenfelter GT 1-1 cam tune issue..
- Liscense Issue?
- Tune shop around north east Arkansas
- what is this???
- WOT shift problems
- Voltage on tuned out rear O2's?
- code P0507
- Engine grounds
- MAF fluctuation under WOT?
- EFI Live Main VE Table problems?
- bucking at low rpms
- Efi live v1 scan only worth?
- Tuners in Oklahoma?
- SD tune for FI?
- changing tires
- Frost vs hand held
- Car won't idle after new setup
- EFI Live, trying to tune a turbo LT1.
- efi live tune
- Is it ok to start car without MAF plugged in
- Can't install Flashscan V1.2 on new windows 7 laptop
- EFI Live - Abuse Management Table?
- using post cat oxygen censors as a pre cat?
- Which adapter to use for LS7 maf?
- Cam Sensor rewire LS3 in 98 Trans Am
- Does Holley Dominator use a MAF?
- I don't know anything about vehicle emissions
- help with ecu trouble
- So sick of smelling like my exhaust fumes.
- Just installed Brand new denso rear vette o2s and code p1133 pops up
- speed and odo wrong after tune?
- Remote tuning for driveability issues?
- Dedicated Scan Tool?
- MAF code with Speed Density tune???
- Basic tuning help and understanding for a noob.
- Tsunami Cam in a 347...(surging)trailer hitching, while at cruise speeds
- Which wideband with HP Tuners pro
- How much will a tune help me?
- minimal mod tuning
- New to ls1!!
- Split BLM headache
- holley dominator global tune needed, please help!
- Dies when coming to a stop p0101
- throwing knock sensor code?
- Wideband O2 Extension Harness
- What's your Cammed LS1 M6 idle at ?
- Tuning a larger TB
- serious problem and no one can figure it out.
- FlashpaQ tuning diablo sport
- My experience with idle tuning
- speedo question
- procedures????
- Just added heads
- Cam and headers. Got some codes?
- Can i start my new engine without a tune?
- Desired Idle for G5x3 112LSA and AFR 205 62cc
- Should I get a tune
- TBSS + 4L80E: TCM / File?
- Need base tune; hp tuners; 4psi; 60# injectors
- 98 to 02 ECU with EFI live
- Trouble codes inspection failed help
- 92-90
- Both fans, and removing AC?
- need help with P0300 and P0332
- Pro and Cons to Mail Order Tune Vs. Dyno Tune
- How to correct MPH??(HP)
- MSD 6LS Tuning on 408LSX
- DBW speed limiter
- What if I have normal injectors and flex fuel tune?
