- maf question
- LC-1 issue...suggestions welcome
- A few ??'s, VE, PE, IFR
- Dyno-Jet
- harness side O2 sensor connector ?
- Anybody tune motorcycle with innovate?
- ls1 scan. Someone look at this scan log?
- 98 tunning
- Dip in RPMS and then stall from park to reverse.
- A few Q's about running C-16 and its effect on my LC-1?
- HELP! can't keep off the rev-limit/fuel-cut
- Cam only MS3 bin file?
- Getting started with HP Tuners??
- I'm a newb at this, don't be cruel!
- "CHECK ENGINE LIGHT" C-5
- what kind of tune?
- P0748 - Pressure Control Solenoid Circuit Electrical
- Need to finally solve the .3 difference
- Logging MAF frequency
- 98 to 99+ PCM.. what is needed?
- Help with LS1 edit install
- Car hesitates off idle to 1500rpms
- Help with startup (open loop) fuel problems
- A4 running force motor off MAP?
- ? on VE Tune with MAF Disabled
- HPP3 ??? problem>>>>>
- Torco Unleaded fuel additive?
- Tuning Results so far with EfiLive....
- 2 lean need help
- Decel after closed loop, AFR gets too FAT
- If you had one place to take your car...
- Spark correction tables...
- Log files in the LS1 computer?
- battery size for 02 z28 !!
- Would this be a tuning problem?
- tune?
- lc-1 question??
- P 0135
- '95 formula getting craptacular gas milage...
- Bad gas mileage after tuning
- runing lean and get pcm reprogramed
- Heads & p0300 .
- Activating P/N switch in an M6 Qs
- Logging wideband with no EIO?
- IAT sensor question--what does the computer do with IAT reading?
- any way to lose a tune?
- cam/heads
- Adj MAF for Boost?
- Low Imp injector tuning
- stuttering at start
- Rear o2 code removal
- Actron CP9135
- Gorillachipz
- 2000 auto camaro v-8
- Does ported maf send lean codes??
- Big Stuff How can REACH THEM?
- Yet another injector flow question...
- Data Logging with Wideband O2
- Livernois Motorsports now has 2006 C6/Trailblazer SS Tuning Software
- New Sponsor - Green Light Motorsports
- PCM Ground?
- Idle Speed On A 224
- Best way to make trans. shift better?
- Need help with a 06 Silverado Stoich AFR table.
- SES light was FLASHING this morning....
- 6500RPMs on Stock ls1
- Premature O2 failure. Why??
- Need Help ASAP!! What could cause the surging?
- Vats Trouble Need Help.
- MAP low input?code
- ls1 edit vin lock ASAP??
- stumped on VE AFR error% logging/tuning...
- Outgrown Crane Power Tuner! HPTuners?
- Do i trust stock STFTs or WB?
- What's the worst that can happen?
- Torque Management ?
- What changes for 3.73 gears (Yes I Searched)
- Hypertech Power Programmer III for 99 Z28
- what is the best way to tune with wide band???
- Idle Fluctuates
- Coil Choices
- RFG and efffects on HP
- Is this safe?
- IAT sensor fooling?
- corvette front 02's on fbody?
- miss fire issues
- running lean
- Need Some help w/ weird Knock
- MAF calibration differences I've noticed....
- Vortec Tuning???
- car is running rich i think
- IAC control counts and respective position
- P0440
- Alternator putting out 24V???
- Need help with lc1 wideband.
- most hp out of a bolt-on ls1....?
- Tuner software question
- Tuning after cam
- Tuning idle issue on a 408, need help
- installed some long tubes..
- Help me get a safe A/F for the dry shot...PLEASE
- do the computers effect this?
- diablo predator tuner?
- Need help with Gen7 wire question
- Hp tuners ?
- Evaporative System Test
- Question about 408 tune....
- Rusted Knock Sensor
- AeroForce Interceptor
- if my car is tune with ls1 edit can i still use hp tuners?
- front 02 code
- Gen 7 pro's NEED HELP !
- LS1edit A4 1-2 Shift Question?
- Wtf???
- Time to replace my LM1 WB sensor?
- LS1 coil pack pinouts
- bin. File Needed!!!!
- Car wont stay running after header install.
- Download request timed out........
- How Far Off Can MAF Be?
- HP tuning without EIO input.
- HPTuners write to PCM
- anywhere else?
- Clutch Switch Input Circuit
- Where's the 2 Bar SD OS for the 98 PCM?
- tps code problems....
- Aftermarket MAF on GTO
- VCM flashed crapped out on me....
- 05 pontiac Grand Prix
- Logging with Autotap
- go maf-less??
- will an 02 ECM/harness work on a 99 LS1?
- Options for tail pipe mounting wideband
- Hypertech "engine power' (or something)
- P0300&P0200 DTC , what to do?
- GTO Wiring harness questions/ Coil pack Q
- O2 sensor malfunction (P0135) vs OBDII Car Inspection???
- Able to connect (hptuners) last year fine, now i cant!
- A4 to M6 swap, new m6 bin file = another liscence?
- P0412 CODE??? help
- Tuning W/out Having Car
- Why would a file not start
- Tach Output - Resolution
- injector duty cycle
- AFR Tuning question?? (HPTuners)
- DTC Codes HELP!
- URGENT: plz help p0155
- Question regarding tuning/diagnostic software
- Why am I getting detonation?? HELP!
- need tuning help
- HP bin file needed!!!! t76 gts turbo, with 60 p injectors,317 HEADS...PLEASE HELP!
- Scaling 36# injectors
- HPtuners and the LM-1
- Code P0420 anyone have any information?
- Least Expensive Wideband
- HP Tuners question
- Gear Tuning (Outlaw Motorsports)
- EFI Live/ Moates.net Road runner
- Stock T-Stat Fan Settings
- Question about HPP3
- Mounting my new 3 BAR MAP
- Safe tune for a new motor
- hp tuners no open ports
- Trans Table Base Shift and Force Motor
- anyone have a working 228R tune?
- Help with performance chip etc.
- those in SD..if you removed your maf come in.
- Tuning a 2002 Z06 Tomorrow..
- LS2 Edit Lock
- LTFT's way positive
- Tuning out CAGS "skip shift"
- Basically stock LS1 pinging?
- F*ck DTC P0300.
- looking for HPTUNERS BIN FILE for stock 346, 60# injectors, 317 heads, small cam
- Hypertech ??
- HP Tuners updated VCM Suite Feature List
- Rich Exhaust/Gas smell what is the best solution?
- Please Help!!!!
- Just ordered EFILive commercial!
- Question on EFiLive!!!!
- Anybody change the analog output of a LM1 for more resolution?
- Timing Retarded
- ANOTHER overheating issue with the WB????
- Tuning "funny"
- Stock Cats Question
- Need stock bin/tun file for 04 GTO A4
- Using HPTuners or other software w/ DESKTOP PC and LONG cable?
- Rev Limiter Setting
- Need some help....
- Force induction questions
- Camaro speed limiter
- Wideband temporary install for tuning?
- HP Tuners VATS Security Light Question
- Laptop+Scanner+Brains=Tuning (Maybe?)
- What Would Cause......
- SES after headers
- WOT Timing? for Big Cam, Heads, High Compression on pump gas
- lm1 /hptuners
- check out my graph pls
- Tuned my Ve Table
- LS2 and LS7 binaries now available :)
- HP Tuners VCM Suite Help Files Are Now Online!!!
- What kind of power increase?!
- would this 2 step work i head msd has something now!!!
- HP Tuners VCM Suite Demos
- highway vibration
- How much timing on 91 octane 11:1 and stock cats?
- newb here needs help
- Supercharged Guys!!!! In Here!!!!
- Quick autotap question
- big problem
- Back to the Airflow vs rwhp calc discussion
- just bought a laptop. how to connect to car
- How many !Maf/ !O2 sensor cars?
- iam i missing out on a lot?
- P0101 & P0121
- Which 2 tables for FAST 90/90
- Header codes
- now wich is the right 2bar?? part#>.
- i messed up
- cannot figure this out????????
- EFI Live OS question from their tutorial.
- Quick VE table question
- Converter and Gear Tuning Help Needed!!
- idle after cam install
- Trex tune...can i borrow yours?
- How to reset a 95 sonoma SES light?
- Timing, Colder plugs, high compression ect...
- Scan tool shows MAP in KPA, but LS1_edit shows Grams of air per cylinder ??
- Would I be a retard if I upgraded Autotap instead of just buying HPTuners?
- 2bar upgrade help....
- yet ANOTHER O2 problem!!
- diablo predator
- Do I need a tune?
- Maf?
- IAC - hptuners
- need help fast //please//// read//////////
- Electric fan question
- HPT histo MAF Tuning
- How to put stock tune back in PCM - Predator killed it!!
- Air Fuel ratio 14.6-14.7 at WOT is the best?
- Car is retarding timing for no reason!!
- EFILive tuning help
- "Advanced" Predator/A4 tranny tuning
- 02 SS Tuning?
- ms3 bin
- Predator Question
- Saving A Hpt File (quick Help Please)
- Using A Stock Tune File
- Difference in O2's???
