PDA
View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Using the Edelbrock fuel rails on oem intake?
  2. Best place to get Holley efi
  3. Fuel pressure sending unit
  4. Help!! fuel pumps maxed, what next?
  5. dual intank install- jet pump question?
  6. evap converted to return with tank reg for free
  7. 1995 Camaro 3.4L v6 (Getting gas into oil pan.)
  8. 99-02 Racetronix Hotwire Instructions
  9. Lonnies Douple Pumper Install w/ Pics
  10. Fic 127 hptuner settings
  11. fpr on stock 5.3l truck rails
  12. Fuel problem on my 99 Hugger orange..
  13. School me on Engine Delta Pressure
  14. Boost and fi newb question
  15. Newb with E85 Questions
  16. Racetronix hotwire kit with OE pump.
  17. Fuel Pump , Venturi Tube help !! Thanks!!!
  18. drop fuel tank or cut "trap door" for fuel pump swap
  19. need help fast
  20. Fuel rails for edelbrock pro flo xt. Good or no?
  21. 6an same as 3/8?
  22. in line or in tank for my swap?
  23. Procharged on E85: Nitrous or Meth injection?
  24. e85 with racetronix pump?
  25. Fuel injection tank... vent line?
  26. Dual In-tank pumps with Racetronix components
  27. 01 LS1 injector size sufficient on 6.0
  28. Nasty Performance Pro Touring Tank Install Issue
  29. dual pump fuel pressure issue
  30. Fuel Pump Questions
  31. FAST LS1 rails on a LS2 intake??
  32. Fuel system install
  33. fuel system question y or t
  34. a1000 fuel pump speed controller use this or different pump for a daily?
  35. how to convert from MAF to MAP
  36. Do twin fuel pumps have to match?
  37. converting to return style need help please
  38. LS3 style vs 4 barl. style TB
  39. Switching fuel pump questions
  40. Fuel rail adapter fitting for braided hose.
  41. Injector choice
  42. holley midram
  43. Flex fuel injectors
  44. Fuel system questions
  45. fuel injectors are maxed out..getting stock ones resized?
  46. Injector question
  47. Dual Walbro In Tank Users Please Step In
  48. need direction on fuel system
  49. New walbro 400 lph pump
  50. injector question
  51. How many guys use fuel surge tanks?
  52. Edelbrock 1600cfm tb combos questions
  53. Super victor injector question
  54. Trap Door for fuel pump
  55. best brand injectors????
  56. Stock injectors or upgrade?
  57. Ev3 to ev6 connectors any good?
  58. fast 33lb injectors
  59. EBAY fuel rails? Anyone using?
  60. switching to 28# Injectors
  61. dual or single 044 LS1
  62. not getting fuel
  63. Fuel system routing?
  64. Fuel Line/Fittings Summary for My Application
  65. Choke down 62 psi 24 gpm pump?
  66. Dual in tank help...questions.
  67. External Pump makes noie but no fuel
  68. Fast 92 questions
  69. Volant CAI
  70. injector spacers
  71. Holley or Fast
  72. Sho-Me Speed Dual pump. Can hose be submersed?
  73. Aluminum line max pressure
  74. Trying to figure out if 30 lb injectors will work
  75. Racetronix Hotwire Kit (any advice welcome)
  76. Carb
  77. 98 Camaro Fuel filter/ Regulater question.
  78. Help with fuel lines with ls swap
  79. Building a fuel system for 800+ hp need help with the return regulator
  80. fuel pump questions
  81. ls1 computer on sbc what injectors?
  82. return system on 98-02 f body need help.
  83. Fragola Vendors?
  84. Turbo fuel help!
  85. will ev1 injectors work in a ls3 intake?
  86. Are lq4 injectors enough
  87. need info on how to delete or disable fuel press reg on 99-02 in tank module!
  88. A1000 external pump/tank sump help
  89. Could someone point me in the direction to get siemens 60 lb flow matched injectors
  90. Extremely lean LTFT's
  91. where to get 99-02 fuel pump module
  92. Need Help with fuel rail swap
  93. regulator before the rail?
  94. throttle body recommendations for Holley Hi-Ram
  95. Fuel Pressue slow drop over time - is this acceptable?
  96. Injector help please
  97. Will my injectors and rails swap
  98. edelbrock pro flo xt fuel rails
  99. L59 Injector options?
  100. fast fuel rail fittment problems
  101. Any reviews of HFP fuel pumps?
  102. Fast 36 lb injectors
  103. Fueling/Tuning Issue Help!
  104. Vic jr,accufab
  105. Wideband on E85. AFR differance?
  106. Fuel System Required?
  107. LT1 rich, BLM 108, can anyone look at my Datamaster logs?
  108. need help with build
  109. Bigger injectors loss of 18hp??
  110. 5.3/4l60e returnless fuel system??
  111. is this normal
  112. What pump doesn't require modifying the bucket?
  113. Best place to get injectors tested.
  114. Fuel pump / Injectors for LQ9 408
  115. Buick white injector capability
  116. From Tank to Rail
  117. fuel pressure rise/temps
  118. Do I need bigger injectors?
  119. EFI pump on carb setup?
  120. Does anyone know what injectors these are?
  121. Fuel pressure @ 68#
  122. Anybody recognize this ECU?
  123. LS3 and L92 injector size comparison
  124. bungs in plastic tank?
  125. Siemens Deka 60lb injectors, are they Flow Matched?
  126. e85 low compression ok?
  127. How do I repair my Fast 90 intake?
  128. Proffesional Products LS2 96mm Throttle Body Review
  129. Tell me if im crazy or not? Fuel system help!
  130. Gbody lq4 turbo build....need fuel system advice
  131. Selecting the "right" injector
  132. fast ez efi 2.0 vs factory gm injection
  133. Stock Fuel Line??
  134. anyone selling fuel pressure guage
  135. fuel level sensor 02 HELP!!!
  136. need help with these injectors
  137. What Size Fuel Line
  138. Injectors/Fuel Pump Questions
  139. new to ecu and fwil injecting
  140. Fuel rail plumbing
  141. Stock Injectors to Bosch 0 280 155 931
  142. Fuel pressure holds at 70psi but not at 60psi??? (WOT)
  143. Bosch 160# High Impedance Injectors
  144. Is anyone running FAST EZ EFI 2.0 on an LS???
  145. Injector? LQ4, 228r, LS6 Intake, LT
  146. Single fuel external pump
  147. Speed Inc now sells Squash Performance fuel systems!
  148. fuel system options
  149. BBK fuel rail leak......HELP!
  150. LS1 fuel rail with corvette filter/fpr question
  151. S/S Fuel Lines LS1
  152. Fuel system for 4.8 turbo build
  153. 90 degree line from fuel filter 2000 camaro
  154. LS3 Injector Angle and Spacing
  155. Full Flow -8AN/-8AN In-tank twin setup, Holley Hi Ram, Walbro 450s
  156. Aeromotive wont adjust past 35-38psi
  157. Trying to find a stock vacuum reference line
  158. Help with AN fuel rail/nitrous sizes, pretty noob question
  159. Where to buy o rings?
  160. Racetronix FPA-002 fuel pump HP ratings...
  161. bosch injectors on edelbrock pro flo ???
  162. External pump suggestions 500 crank hp
  163. Fast fuel rail issue
  164. Which fuel pump??
  165. Efi fueling help
  166. Fuel injector question
  167. What yaw think about the holley hi ram with dual 4150 tb
  168. Fuel Filter question
  169. Corvette FPR and Russell fittings question
  170. Ebay 4150??
  171. ID1000 Connector Adaptors
  172. Push on EFI fittings
  173. -8 feed/ -6 return ?
  174. Who except nasty performance makes a street legal fuel cell for fbodys?
  175. 99-02 Fuel Pump help
  176. Fuel injector, pump & regluator question
  177. Anyone running the ls9 injectors on ls1/ls6 intake? Need your help.
  178. 2000 5.3 silverado loosing fuel pressure possibly? Help
  179. injector and fuel rail for a 5.3
  180. ? on ford lightning 42s or 04 cobra inj on lq4 with vic jr efi
  181. Looking for a cheap factory style regulator
  182. BBK fuel rails with 98 fbody fuel system
  183. 5.3l vortec fuel pump?
  184. 346 N/A Injector Size??
  185. Thoughts on E85? What all components of the fuel system would need to be upgraded?
  186. OEM injectors for 2002 LS6 engine
  187. FAST Injectors
  188. Help me build my fuel system. LTx to LSx with big turbo
  189. 97-98 Fuel Rail?
  190. Are the 80lbs/hr Ford racing injector any good
  191. ? About Racetronix 160lb Injectors
  192. F/S FAST 85lbs Fuel Injectors for LS3/LS7
  193. what sending units will work with a 98 Fbird v6
  194. Car won't take gas but is empty
  195. Need new Fuel pressure regulator
  196. Bigger injectors or no?
  197. do I need Injectors?
  198. Wiring harness help
  199. TB question
  200. LS2 injector flow rate??
  201. Lonnie's Performance--- Do 340LPH pumps fit??
  202. 02 Ls1 injectors
  203. How and where to add AFPR on a 98 vette?
  204. Build or Buy dual pump setup?
  205. fuel vapor canister purge line
  206. LQ4 to LS3 INTAKE
  207. Considering switch to E85 on 1000rwhp turbo car, need advice.
  208. injector flow rate table
  209. No change in fuel pressure c5 corvette
  210. right wiring harness?
  211. Fast xfi
  212. truck rails. how much can they flow
  213. Fuel line setup question
  214. Guys running Wilson 4500 throttle body
  215. What injectors
  216. ls6 injectors
  217. Converting to an external pump?
  218. Deka 80# blue-tops, TB questions...
  219. fuel pump wiring
  220. truck fuel rail spacers.
  221. -6AN return line for 1000 WHP E85?
  222. Best place for injector connectors???
  223. Fuel system wiring?
  224. "Car" fuel injector connectors? EV1?
  225. Mounted my FPR,is this ok?
  226. S480 5.3 fuel system ?s
  227. not sure if right section
  228. id1000's spacers q's
  229. fuel pump for 04 gto ls1
  230. Fuel pump only kicks on with programmer plugged in?
  231. LS3 intake flange blanks?
  232. *Our Holiday Sale is going on! Great gifts at great prices!*
  233. Fuel Pump Whine
  234. Racetronix/Standard Motor Parts 160LB Low Z Injectors
  235. injectors with stopck truck intake
  236. LQ9 starts but wont idle
  237. Single carb on a Holley Hi-ram
  238. E85 and Dual 340s
  239. E85 and ~1000whp
  240. Racetronix wire harness install
  241. Methanol injectors
  242. LQ4/4L80E swap.... first fire up.... no luck
  243. Single fuel set up??
  244. Where to get stock injectors?
  245. Fuel Line choice E85
  246. Racetronix fuel pump/hotwire install instructions????
  247. Fast fuel rails?
  248. is my injectors/pump enough to handle my setup
  249. Fuel rails
  250. Nitro
