View Full Version : Fueling & Injection
  1. Adapting 67 Camaro Fuel Line?
  2. Special Wire type needed in tank?
  3. Walbro 310 or 340
  4. What's needed
  5. need help shop cant even figure it out
  6. Newb help..
  7. Are there any issues running "T" fitting instead of Y fuel block?
  8. Fuel pressure too high w/ twin walbros - Will this change work??
  9. 3/8" Submersible fuel line over 12"
  10. Ls 6.0
  11. Putting LS1 fuel rails on LS3 intake
  12. fuel system for methanol only?
  13. Need help with return line setup.
  14. Necessary to run fuel filter after pump in Aux pump setup?
  15. Fuel injector test and rebuild
  16. Megasquirt works awesomely!
  17. Help/Opinions on E85 Fuel pieces needed
  18. [ e-85 ] is my setup good 4 [ e-85 ]
  19. FAST 3/8 to AN6 adapter wont fit!!!
  20. stupid question.....
  21. simple, quick question about aeromotive
  22. 1982-2002 F-Body Fuel Pump, 255 LPH In-Tank
  23. Need help in figuring out if I need bigger injectors
  24. Edelbrock 24-3638 fuel rail issues!!!!
  25. Open injector?
  26. Intermittent Fuel Gauge
  27. 160lb injectors Help
  28. Walbro 255 vs Walbro 400
  29. Stock tank evap line question
  30. need some help here
  31. A1000. Good for 650+ supercharged RWHP?
  32. 99+ fuel system in a 98 body
  33. what injectors?
  34. Injector Flow vs Pump Flow
  35. who has added a return line to their stock system?
  36. How much HP will 79lb injector with meth support?
  37. Connecting aftermarket rails + A1000 FPR to stock fuel lines
  38. Smartfire injectors not fitting into Holley Hi-Ram
  39. Can Someone Confirm I wired this up correctly?
  40. Walbro, Racetronix or Lonnies/Racetronixs
  41. Anyone running meth/water inj on natural aspirated ls1?
  42. Aftermarket fuel rails on LS6 intake manifold?
  43. 99+ plastic tank in a 98 body
  44. Need anything other than pump to fix cranking / priming issue?
  45. Fast 36 lb inject. Single racetronix ok for 404 Ci
  46. need help on fuel pump selection
  47. Are my LS6 injectors enough for my setup?
  48. Need help! Nasty fuel tank with factory fuel gauge.
  49. Injector advice please
  50. running ~95% IDC with my mods?
  51. E85 shelf life
  52. What Fuel Pump?
  53. Which Part # Aeromotive 340 to Buy for 2000-2002 F-body?
  54. 4150 fast throttle body
  55. dual pumps on all the time??
  56. 1/2 submersable fuel hose -
  57. three duce fuel injection- tri power
  58. A/F mixture?
  59. fuel regulator problems?
  60. electronic Fuel Pressure gauge WRONG
  61. Fuel Pump Location for my swap?
  62. smartfire injectors and hptuerns
  63. Injector connector question.
  64. Dual Pump Install w/ Pics. Tutorial.
  65. GTO Fuel Smell = Rusted Tank
  66. fuel smell
  67. fuel system upgrades for turbo
  68. anyone run a FAST 4150 throttle body and vic jr
  69. Need some help diagnosing a fuel delivery issue on a turbo build
  70. Questions about new fuel rail setup
  71. 96 camaro fuel filter ?
  72. Fuel line question
  73. Ls6/1 compatibility
  74. Symptoms of a bad fuel pump please help
  75. Help with fuel pressure 1998 camaro
  76. Question about avoiding rust with metal tank sump
  77. need some help on injector size
  78. BD Injectors are NOISY! Why?
  79. SSR LS2 injectors
  80. megasquirt 1 issue
  81. Inline fuel pump
  82. Do I need an adjustable fuel pressure regulator?
  83. Which injectors?
  84. Nylon corrugated fuel hose install help
  85. Enough Fuel (Turbo E85)
  86. Walbro 255 Part Number
  87. Victor jr. Distribution problem?
  88. EVAP delete
  89. Injector fit on 5.3/6.0 intakes
  90. Fuel pump and regulator fittings
  91. Walboro 400's in 2000 trans am
  92. Fuel Rail Nightmare :) Please help....
  93. Need some e85 knowledge
  94. low cost intake for swap. LM7 to GM A Body
  95. Ls1 383 stroker hesitation runs rich
  96. 98 Fuel Tank ?
  97. Delphi fuel injector question. Need help
  98. Fuel system help needed!!!!!
  99. 98 EVAP Component Location Help
  100. 60 lb fuel injectors too big for setup?
  101. msd ls wiredless efi
  102. injectors or no injectors?
  103. 98 Dual pump kit modified for 99 and up fuel setup
  104. Rough between 1800 and 3000 rpm... Help!
  105. 2000 Camaro SS Walbro intank fuel pump issue
  106. Fuel smell after fillup plus gas gauge not working
  107. fuel pump and rail advise needed
  108. high mileage with stock pump
  109. direct injection = more horsepower ?
  110. Can Edelbrock 3849 be ported to 102mmTB
  111. dual pump and bucket hacking??
  112. Need help sizing my system
  113. aeromotive 340 in tank pump and hot wire kit, what vendor sells it
  114. Hot wire kit
  115. Throttle body question for LS7 single plane
  116. LS7 INJECTORS vs LSA INJECTOR COMPATIBILITY
  117. wires in the fuel tank
  118. hot wire kit??
  119. Any sponsors a holley rep?
  120. fuel rail and evap fuel line HELP
  121. Fuel pump/ Injectors?
  122. Stock Fuel Pump Bad? Works w Stabil.
  123. flex fuel fbody?
  124. need fuel lines and boost regulator for 00
  125. New ID1000 fuel injectors for sale
  126. trick flow fuel injecters
  127. LS1 with different injectors
  128. trans-cooler in radiator or not????????
  129. Fuel injector capacity
  130. Ok... What fuel system for 1000whp on e85?
  131. Fuel pressure drops instantly right befor boost 105kpa!!!
  132. Fuel cell with in tank pump?
  133. will stock '98 ls1 injectors be fine ?
  134. fuel rail plumbing help
  135. running rich on different fuels?
  136. need help on fuel system
  137. Ls1 to ls6 swap help
  138. which injectors for l76 intake and ls2 rail?
  139. autometer fuel press. gauge issue?
  140. Fuel lines to the rails?
  141. will Permatex Aviation Form-A-Gasket work with e85?
  142. who makes aftermarket fuel rails for an ls3 manifold and shorty inj.
  143. Bad Fuel Pump???
  144. estimated capability of setup
  145. will someone give me some advice fuel issue
  146. 8 stack fuel Injection systems
  147. Nubile 5.3 ls6 cam ls2 injectors
  148. 2000 LS1 injectors vs 2004 4.8 injectors?
  149. Turning injector rails around
  150. Professional Products Intake Fuel Rail Options
  151. redneck injector test
  152. fuel pump interchangeability??????
  153. Boosted LS fuel system configuration
  154. is my A1000 enough? 3 questions
  155. Running a second fuel pump off eboost 2
  156. FIC 2000cc Bosch injector group buy
  157. Fittings to add a line to GTO fuel hat
  158. INJECTOR SIZE ?'s FOR HIGH HP BUILD
  159. Injector size
  160. fuel pump or something else
  161. fuel pressure surging
  162. Nitrous fuel system build
  163. fuel problems
  164. Victor Jr How to drill to install injectors?
  165. walbro 255 vs aeromotive 340 stealth
  166. FAST injector spacers on a LS2 manifold ... stock O-rings?
  167. Bosch Green Giants work with FAST LSX 102?
  168. Where to get injectors serviced?
  169. Connect -6 hose to truck fuel lines?
  170. Injectors differences
  171. Ls engine harness for lsx swap.
  172. Do stock fuel lines have hp limit?
  173. twin 255's or aeromotive stealth 340?
  174. Need help. Swaping from LT1 to turbo LQ4
  175. Braided fuel lines and AN fittings
  176. Ls376/525
  177. pump suggestions
  178. Suggestions for Best In-Line Fuel Pump
  179. Walbro 450LPH E85 pump in a 98?
  180. fuel level sender
  181. race fuel/gas???
  182. Aeromotive fuel rails on FAST 90?
  183. Please help me indentify these injectors and harness connectors
  184. FAST fuel rail setups
  185. Where's a good place to get a bosch 044 inline pump?
  186. Fast 57lb injectors to big?
  187. Fuel hose length ?
  188. fuel pressure
  189. Do I actually need this?
  190. Issue with fuel pump
  191. 2001 Corvette Maggie: Fuel Pressure Drop, Stumped.
  192. What inline fuel pump should I run for a 347 TVS1900 setup?
  193. Possible fuel pump problem?
  194. injector help acell 42 lb/hr
  195. 2003 gt mustang not getting fuel. Help please
  196. Reworking factory fuel lines
  197. New 383 LS1, which fuel pump?
  198. Anyone tried the 2 stage Holley Dominator Billet Fuel Pumps?
  199. Fuel requirements for cam(+) applications
  200. Help...What injectors are these?
  201. First H/C motor, need injector advice
  202. Fuel tank fitting question
  203. LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
  204. Fuel Cell help!
  205. Fuel rails for a truck intake.
  206. doesn anybody make an LS1 Super Victor Fuel rail with a 5/8 NPT or 8an or 10an inlet
  207. Injectors fuel pump shopping
  208. Recomend me a fuel regulator
  209. Need schooling on a stock '99 fuel system.
  210. ls 403 stroker
  211. powerjection III
  212. Help Dual Pumps not working
  213. Walbro fuel pump 255?
  214. TAC actuator questions
  215. can I connect the return line to the service port on the fuel rail
  216. IDC of 38-40%?
  217. Fuel pressure drop with racetronix kit.
  218. e85. what injectors and fuel pump
  219. Best size injectors for me?
  220. Miles per Gallon?
  221. When is it time to upgrade injectors/fuel pump
  222. Racetronix kit 1998 poppin fuses
  223. 98 Racetronix Fuel pump and hotwire harness /w trap door
  224. Looking for help with my fuel system
  225. injector cleaning
  226. What happened to my gas tank?
  227. walbro in-tank
  228. Recommendations Plz
  229. Anyone using powerjection 3 system???
  230. Soo confused...please make this la-mans terms for me
  231. odd fuel set up
  232. LS1 Stock Pump Relay
  233. What should I do to upgrade my current system
  234. Easy Fuel Regulator Question
  235. Will LS7 injectors fit in an LS2 and will they support 550WHP(NA)
  236. Return or no return?
  237. racetronix pump install wiring?
  238. quick question
  239. Vapor lock?
  240. Making a stand alone fuel setup
  241. Injector Size
  242. Vacuum manifold & Catch can (Help)
  243. Injector help!
  244. Walbro e85 racing fuel pump f90000267 450lph
  245. can you add an extra fuel pump to existing ractronix single setup
  246. Best fuel system for boost?
  247. How to test my fuel pump with the driveline removed?
  248. aeromotive 340 dead after 9mth e85
  249. Aeromotive FPR plumbing
  250. Fuel pump and injectors
