View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. It was cheeper
  2. Vortec 7400 EFI on a 540cid mark IV BBC
  3. Car ran out of gas? Hard time to start it
  4. what f/i pump to get
  5. Do I need bigger inj???
  6. Need help with fuel pressure
  7. No power pass 5500rpm passed the duty cycle?
  8. Custom Fuel system (CAD)
  9. newb's fuel question
  10. Need help with fuel system 1000hp please!! Long post
  11. stock fuel rails..
  12. GMPP Carb IM and fuel rail help!!!
  13. fuel cell for tubbed camero
  14. do I need bigger injectors
  15. SVO 30lb install/startup issue
  16. Is this a Speed Inc fuel cell?
  17. Installing fuel pump in convertible
  18. Walbro 255lph vs. Racetronix system.
  19. Idle problem, when coming to lights
  20. Fast fuel rails on LS2 Goat
  21. Fuel system help for 700+rwhp
  22. whats the deal with my car!!
  23. gas tips...
  24. boost referenced system idea
  25. Do race pumps require a special voltage regulator?
  26. Holley fuel pump leak?
  27. ever heard of this!!!!!!!!
  28. Help with injector length please
  29. fuel rail question/coil covers
  30. injector swap
  31. Injector help
  32. Need return quick connect fitting.
  33. '00 Injectors to '98 Injector swap questions
  34. What kinda of fuel system
  35. What size and brand injectors on full bolt on and 125 dry shot?
  36. my 00 ls1
  37. Big cam and bolt on car, what fuel pump to use?
  38. Hot wire on a stock pump?
  39. What fuel mods are suggested torquer v3 + 150 wet?
  40. what an fittings and line do i need with this?
  41. stock fuel pump? Need an inline/intank?
  42. Mechanical FP Gauge
  43. Should my FPR be hooked to vacuum?
  44. What injector for n/a set up that sees the jug
  45. 900 hp fuel system?
  46. Stock 26lb injectors at 113% duty cycle
  47. ford 39 pound injectors
  48. o4 gto injectors
  49. Fuel tank ?????????????????????
  50. Side-by-side comparison of GSS392, Bosch 044, and Magnafuel 4303
  51. Best FPR out of these choices...
  52. Fuel Pump Questions- HELP
  53. Best adjustable fuel pressure regulator?
  54. VIN for CID
  55. What is the injector spacing on an LS1 fuel rail?
  56. How long can I drive UNTUNED with SVO 30#
  57. Trap door, covering up?
  58. can my gas consumption be this crazy?
  59. Meth install...Need help
  60. Christmas Fuel special
  61. NRE & Mosler Bad ass LS
  62. Adjust fuel pressure to match injectors
  63. Post pics up of your aftermarket fuel system.
  64. do i need injectors and fuel pump
  65. safe to run super rich?
  66. are 60lb's too mush?
  67. Car wont hold fuel pressure!
  68. SVO red tops part number
  69. car will randomly not start (no fuel)
  70. gf ran her car dry and now wont start...
  71. Weldon 2025 questions...
  72. Changing intank on a 98 what's the difference from other years?
  73. 98 Ta/ws6 Biggest Injector W/ Stock Pcm
  74. How much power will -8an line support
  75. APS fuel system?
  76. Cam and bolt ons, what injector size to use?
  77. Splicing into hot wire kit for second in tank pump
  78. ? about walboro install
  79. What size do I have?
  80. Will there be a problem mounting the pump higher than the sump?
  81. Street car: Magnafuel 4302 or Aeromotive a1000??
  82. intake & injector question
  83. 99 Camaro Fuel System
  84. Weldon Dial A Flow or Aeromotive
  85. Fuel pumps quit working - electrical?
  86. Which injector to buy
  87. Happy Thanksgiving
  88. anyone have fjo instructions for injector driver kid0008
  89. which external pump will work
  90. Fuel pump install (intank)
  91. Venom 96lb High Impedance Injectors
  92. Weird question about injectors, what to buy
  93. Do I need fuel pump?
  94. how many ft of AN line for feed and return
  95. How to Know What I Have
  96. What size injectors on 408Ci N/A
  97. Pump sits higher than sump(pic inside)what kind of problems and I gonna run into??
  98. 408+T88+12lbs boost=What Size Injectors
  99. -AN fittings
  100. regulator placement
  101. Fuel Problem I Think!!!!!!!!!!help
  102. Injectors and Compression
  103. injector question
  104. injectors in a l92 intake????
  105. need help; on buying injectors and fuel pump
  106. What size injectors?
  107. Help Me With Fuel Injectors
  108. I wanna do a sumped tank setup with braided lines..help me out here.
  109. Question about installing a aftermarket Fuel Pump
  110. ? about stock fuel system
  111. Stock Fuel Pressure at the rails.
  112. my fuel system 2 walbro intanks
  113. injector size for boost
  114. Car is REALLY sluggish on first startup. Like it's loading up.
  115. 30 psi fuel pressure
  116. injector question
  117. Fuel level sender problem
  118. 42# about right?
  119. what is this?
  120. Who makes injectors larger than 160#?
  121. -Fuel System for Boost-
  122. Anyone use the Cheap LS1 Ebay Rails?
  123. 98 Fpr ???
  124. NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
  125. My LS1 ITB's
  126. high voltage fuel pump wiring harness
  127. injector fitment???
  128. Up for a fuel system challenge??? - Experience Required
  129. Twin Pumps & Lines with one return?
  130. Fuel setup for H/C/Juice?
  131. Inline Fuel pump mounting
  132. Bigger Injectors?????
  133. 60# injectors almost sold out
  134. whose running steel braided lines?
  135. high or low imperance injectors
  136. SVO 30# injectors wanted ASAP
  137. How to figure out what injectors I have
  138. Don't know if I have a problem or what
  139. Fuel System Help
  140. cellulose filter
  141. Slight pause at 1/2 throttle
  142. Fuel setup
  143. Leads on a fuel pressure test Schrader for custom rails?
  144. What year injectors were 28lbs?
  145. some help ... plz
  146. Got a couple dual bosch 420 setup questions
  147. No power to fuel pump :(
  148. Aeromotive Eliminator pump install
  149. 90lp high imp injectors
  150. Sponsors that Sell AN fittings?
  151. URGENT, need help with a fuel issue.
  152. Regulator Question
  153. lonnies twin intank pump kit (F-Body)
  154. Using Edelbrock Fuel Rails w/ FAST
  155. l76 injector
  156. help w/ fuel injectors
  157. how to use MSD BAP on NA/N20 setup?
  158. stock fuel lines and mild Hp numbers?
  159. H/C Nitrous fuel system help
  160. Hey N8 can you help me with wiring my pump
  161. do I need injectors? what size?
  162. Anyone know the limit of the fuel rails on the L76 intake?
  163. racetronix kit
  164. Bigred 91
  165. ls1 fuel line pics needed badly
  166. New to Fuel Systems: Need Your Help With My Project!
  167. will stock pump work??
  168. What fuel system for LS7 crate?
  169. How long is fuel good when sitting
  170. Racetronix fuel pump kit
  171. Fuel Pump Stays Running with key "ON"...??
  172. Anyone running this pump from Summit?
  173. What will cause fuel pressure to drop?
  174. Sale on Delphi | Lucas 42 lb. / hr. Fuel Injectors
  175. 340 fuel pump sock issue
  176. 340 Warlboro pump help install.
  177. in tank fuel inj. line
  178. injector question high/low impedance
  179. Opinions on Russell "ProClassic" hose & fittings?
  180. Which brand of fuel injectors do you use
  181. What size are the injectors that come with the L76 intake pkg from SDPC???
  182. Variances From offshelf 60LB Injectors
  183. 60lb Injectors on a N/A 406
  184. Twin Turbo Truck Dual 255 pumps
  185. Lucas Octane Booster?
  186. steel braided hose on a factory fuel rail?
  187. Fuel pressure bleeds off fast??? 42# injector scaling ???
  188. 97 Vette injectors
  189. FAST Fuel rails
  190. Help With Mass Air Flow Sensor
  191. How much voltage should be at the pump with my MSD BAP/racetronics hotwire.
  192. What if...
  193. Fuel pump power wire in cab
  194. fuel pressure gauge
  195. an fittings???
  196. fuel pump pressure
  197. Fuel pump question not LS1
  198. Fuel Rails
  199. Minimum pulse width and 42# injectors (SVO vs Lucas)
  200. adjustable fuel pressure regulator
  201. To those running 42# Injectors....H/C/I Cars
  202. Fuel Guage ?
  203. hot wire kit
  204. Will I need a new tune????
  205. fuel cell with stock sump
  206. 98 vette evap question
  207. identifiying injectors
  208. loosing fuel pressure up top?
  209. new problem with the shrader valve
  210. Adjusting the fuel pressure regulator, what pressure do I need to set it at?
  211. Quick disconnect for feed and return at tank?
  212. cant figure this out?
  213. Easiest way to replace fuel pump
  214. Got pictures of Fuel lines run under car???
  215. ??? injector question
  216. AN Tube Flares
  217. Where to get, and how are they received - SVO 30#'s
  218. Fuel smell?
  219. Walbro Inline Pump
  220. 16 injectors & Big Stuff 3
  221. Flow chart for 550 CC RC Engineering Injectors?
  222. HELP ASAP!!!!!!! How long to start after fuel pump installation! HELP ASAP!
  223. Gain in fuel pressure if I don't vent the tube to the atmosphere?
  224. 800hp Fuel System for LT1
  225. Best way to test a new fuel system?
  226. LS1 just began to not start. fuel ? sensors ?
  227. Fuel pump help please!! Strainer issues,99-98 converted. Also more issues help!
  228. car not starting!
  229. Racing Fuel causing a MIss ???
  230. Where to gas up?????
  231. Whos running this nasty fuel system
  232. Hard starting, Regulator????
  233. Installing aftermarket FPR. What will happen if I don't remove the factory FPR?
  234. 98 Fuel Pressure Regulator Location...Help
  235. anyone running a mechanical pump?
  236. Where can I get a Pressure gauge?
  237. '94 T/A Fuel Pump Change
  238. Alcohol injection on a stock 05 GTO?
  239. Redoing ls1 fuel system, several questions...
  240. In need of some injectors... need advice
  241. 72lb inj too big for NA application?
  242. Fuel strainer / sock for 3/8 or -6 hard line?
  243. What is the hinge for on '98 fuel pickups?
  244. Fuel pump whinning but no pressure? or somerthing else
  245. What is the best Fueling & Injection for this project?
  246. injector scaling again
  247. Small plastic canister on the driver side valve cover, can I do away with it?
  248. anyone messed with 'aviator' pumps
  249. Racetronics hotwire install without dropping tank?
  250. No Power at Top of Gear
