View Full Version : Fueling & Injection
- A1000 and Eliminator e85 compatibility...
- Need help testing my fuel injectors
- how can i upgrade...
- best place to buy racetronix pump kit?
- fuel pump ?
- fuel cell newbie, got questions
- change rails???????????????
- Mixing race gas with pump gas?
- anyone interested in a racetronix group purchase?
- Return Line Pressure?
- wanting to convert to E85
- LS2 decelleration backfire
- what kind fuel set up should i go with?????
- My fuel system upgrade review
- Drop Tank DIY?
- what are stock ls1 injector size?
- stock fuel sending unit
- Rich on decceleration
- Blue cobra injectors
- Is this safe, or even neccassary??
- What kind of fuel pump is this?
- My homemade standalone !
- help!! cant find my leak...
- Lack of fuel pressure
- Stock 2000 Z28 going lean + knocking
- Bosch 044 help?
- Stock GTO Fuel pump
- can someone draw me a picture
- Intank AND inline?
- Help - Starting Issues
- Fuel Pump Controller
- Fuel pump options?
- Can't track down weird fueling issue on my front mount car... please help!
- A1000 pump
- Stock fuel pump replacement
- No start issue
- Are siemen deka / mototron 60lb and 80lb injectors e85 compatible?
- injector problem
- my car has a swapped plastic tank
- Aeromotive A1000 isn't keeping up...any ideas?
- suggestions?
- AEROMOTIVE A1000 system....would like to quiet it down a little
- Injector Interchange?
- Supercharged LS3 fuel requirement?
- Northstar question
- Please Help
- fuel trim help
- fuel injector question
- Got a serious injector problem, need pointed in a direction
- FIC new site for CORVETTE AND LS1-LS9 Injectors
- walbro knock offs look identical
- am i leaving power on the table without injectors?
- need help please...tank or pump leak
- what what fuel pump should i do
- injector size?
- LS-1 Fuel level Sensor question
- help with 02 gmc
- Has anyone used 03-04 Cobra injectors?
- fuel pump question
- aeromotive pump 8 years
- Fuel inj. question
- aviation fuel
- ? about a turbo????
- access panel to fuel pump
- Fuel tank takes 18gallons??
- what all do the hotwire kits upgrade?
- Fuel pressure dropping racetronix pump
- Fuel tank
- 210lb high impedance injectors in stock
- magna fuel fuel pump i need help
- anyone ever use this fuel line
- who makes a crossover line for aftermarket fuel rails?
- Need help with P0171 and P0174 codes
- Fuel Rail/FPR Question
- No fuel pressure WTF
- Wont crank up until about 2-3 tries
- Intermittent misfire
- stock ls1 style fuel rails question
- 12.5 volts to low?
- high fuel pressure
- Questions about a new fuel set up
- FIC 42lbs injectors any good?
- what regulator w aftermaket fuel rails??
- Lucas 120lb Low-Imp. & Versafueler
- Multiple Pump CTS-V?
- Who has bought injectors from Racetronix?
- Fuel dampener needed?
- Quick question about fuel pump issue>?>?>
- Fuel Systems for turbo setup?
- Ignition problem: Key won't turn far enough.
- Can the Racetronix hotwire kit be installed through a trap door?
- Installing Hotwire kit questions
- Help. No fuel!
- Injector Question
- fuel pump or ignition?
- Turbo Kit Fuel System
- def a stupid question
- Hard second start
- e98 or e85 with TFS 96lb injector?
- edlebrock fuel rail not fitting ls3 intake
- How to make a 98 sending unit work in a 99-02 car.
- '00 LS1 injectors
- Injectors 5-8 not firing
- ls7 injectors?
- If fuel bucket is leaking out the bottom.. check valve issue?
- Turbo 5.3 Fueling Question
- Injector size for 6.0 build?
- power guess 80lb injectors
- OK to skip the hotwire kit with the Racetronix pump?
- I need a stock fuel line and sock filter, where to get them?
- Racetronix 37lb in question
- Do I need a fuel pressure regulator for turbo build?
- Would this work?
- Best Way to Empty Tank
- Fuel pump went out!
- Injectors for LQ4???
- What style injectors with Super Victor?
- LS1 Fuel Rails with return
- Problems with the fuel system
- Fuel lab fuel pumps!?
- Adding an AFPR to stock truck rails....
- fuel pump weakens when car warms up~~~
- Mk IV big block with LS1 EFI?
- To drop the tank or not...
- NNBS truck, steady loss of pressure.
- no fuel to injectors
- New injectors needed for 233/239 cam swap?
- Racetronixs fuel pump problem
- give me link to buy ls2 injector spacers to run the long siemen 60lb'ers
- where do I buy the T fitting to run twin pumps
- Modified stock truck rails?
- Racetronix fuel harness?
- Dual pump question
- BS3--initial startup (or lack thereof)
- wtf----P.O.S.---corvette filter/reg
- Any good write ups on re doing bigger fuel lines?
- steel tank in 01 TA. gauge not working.
- Injector duty cycle
- 2002 Z28 fuel sending unit help!!!!!!!!!!
- do i need a fuel pressure regulator
- Fuel Pressure
- Racetronix web store
- 99 - 02 Fuel Pump wiring
- What fuel pump & reg. to use with boost
- Flowmatched Greentops vs. ls3 inj (hci)
- NEED HELP FAST. Stock feed for return question
- Another fuel system advice thread.... Need help deciding on a pump set-up
- 1997 C5 Help vs LS3
- using fast fuel rail what can i do with the vent line
- fuel issue on my daily driver... please help
- ls1 fuel rail w/ls2 injectors - adapter?
- gay fuel pump !
- No fuel press. when turned off
- need help with fuel setup..what am i missing?
- Heres a easy one for you guys....
- New Injectors needed for H/C?
- Fuel Pump Stuff
- FAST 102mm LS3 with Ford SVO 42lbs (EV1)
- need help asap
- Installing racetronix hotwire kit help
- Magnafuel Pro tuner 625 (electric) vs Magnafuel Pro Outlaw 625 (mechanical) fuel pump
- Fuel Octane Additive
- So I have a stupid idea!!
- What inj. plug
- 95LB Siemens Deka Low Impedance Injectors
- Can I use a racetronik wire kit on a walbro pump?
- Need some injection advice. E85! 454LSX
- Walbro fuel pump owners BEWARE!
- Converting to metal tank, how do I get the sender to work?
- do i need 60lb injectors
- best injector
- LS3 fuel injection cylinder balance
- casper hotwire....1998...
- do i need a new fuel pump?
- Horrible Gas Millage
- Is it my fuel pressure regulator?
- Help with fuel gauge
- fuel injetcer testing
- Racetronix hotwire MISSING PARTS WTF!?!?!
- 255 racetronics in lt1.. How to wire up?
- What does it take to go E85?
- Bosch brand Focus pump (LT1)
- car wont stop backfireing after pump instal.
- How long has your walbro pump lasted
- Stock metal tank with sump, need some advice.
- Need Fuel Pump Help
- Bad regulator? Or leaky injectors?
- Removed inline pump. Now I have low pressure.
- no power to fuel pump..Help
- 3rd gen - 2.8 efi to carb lsx e85
- Fuel Pressure drop, takes a while to prime
- 98 Corvette Evap System
- I don't know what rails to get, anyone running LS7 heads?
- Fuel line T at rails question.
- Racetronix F99 enough for me on E85?
- fuel line
- Anyone ever used aftermarket rails on a truck intake?
- high HP fuel system on low HP setup?
- Questions about sumping a stock metal tank.
- f body walbro
- can you run a stock style in-line filter with an 8an feed?
- Racetronix fuel pump problem
- Fuel System Critique
- 2007 GMC Sierra Low Fuel Pressure
- Were To Put Fuel Cooler
- Which 80lb injectors to use with vic jr?
- Running 80# Siemens at low pressure with BRFPR
- my nasty performance kit came in
- Flow Matched High Flow LSx Injectors Available
- whats easier to tune?
- Fuel pump walbro questions and racetronix
- just converted to E-85!!!!!!
- siemens 60# to long
- Injectors for prochcharger
- LQ intake/LS rails
- Bosch 044 In Tank?
- Wiring 98 255
- Fuel pressure on a lowly 3.4
- WTB Stock LS1/LS6, LS2 and LS3/LS7 Injectors
- E-85 ????
- Racetronix F99 & ASP Overdrive Alternator Pulley
- wierd fuel pump problem...need help
- Which Fuel Rails to use?
- reg problem or pump??
- 550 rwhp on 42lb/hr SVO Green tops
- F1-A Fuel System Questions!
- racetronic 255 how much power?
- 98 camaro fuel pump replacement questions!
- just installed racetronix/hotwire kit...questions
- Actron cp7818 fuel pressure gauge kit for a quick fuel pressure check
- Broken Quick Disconnect Locking Tab?
- fuel pressure is 48psi after pump primes
- Over 100psi at the rail
- Fuel Guage Question
- fuel pump fixed,Please do this before u replace
- Racetronix injector scaling
- new racetronixs fuel pump
- injectors and fuel pump
- Resistance range for a 94 gage cluster?
- gutted fuel regulator??
- What size is my fuel tank?
- Meth/Water system for street use with 14-1 compression ?
- Injector Conection ???
- FUEL system thoughts
- Walbo255+60lb injectors+boost+E85=?????
- procharger 340 pump question?
- Bosch 44 pump question?
- ls1 race fuel ???
- stock injectors?
- 42 pound green tops? 600whp??
