View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Pulling 98 Fuel pump, yellow connector on tank cap
  2. New Era Performance can now Flowtest your injectors!
  3. Ford test pressure 40 or 43.5 psi?
  4. pros and cons to fuel pump trap door
  5. What make/model/year takes this type of injector
  6. fuel question for head & cam swap
  7. Procharger warranty transferable?
  8. will i need bigger injectors???
  9. differences between tb's
  10. this is getting rediculous
  11. Help Plz!!!
  12. What injectors for 355 LT1?
  13. Stock fuel vent system
  14. Car Dies at 5000 RPM's
  15. What size injectors and fuel pump for MS4 and 125 shot
  16. sts kit @ 5psi 42# delphi duty cycle
  17. 383 lt1 fuel pump reccomendation
  18. What kinda of fuel injectors are these?
  19. Checking fuel pump relay...
  20. What fuel pressure? 06 GTO
  21. Where to buy flow matched injectors?
  22. Installed Walbro....now it won't start...
  23. No clutter fpss and sending unit?
  24. 42lb SVO VS. 42lb Lucas....any difference
  25. APS C6 fuel rails
  26. professional products fuel rails
  27. H/C set up questions
  28. %$%# What is this??
  29. Fuel gauge not working right.
  30. Would this be okay or is it a big no no.....
  31. Injector size recomendation
  32. Wiring question
  33. LT1 Fuel rails
  34. have a question: Racetronix fuel pump install
  35. little white clips
  36. NE1 had SVO 30's flow tested @ 58 psi?
  37. Cobra 39lb injector questions??
  38. BAP wiring diagram?
  39. Fuel Rail O-rings
  40. Vaccum ???
  41. Looking 4 a fuel rail?
  42. Fast 36# injectors
  43. Fuel lines?
  44. Vacuum modulated FP or static?
  45. Fuel Problem? Cutting out past 5K. help
  46. 16 volt setups...for 160lb injectors
  47. Need help, in the middle of fuel pump replacement
  48. Fuel line question???
  49. Fuel pressure?
  50. Why is this not working
  51. fuel rails/line help please. w/ pics.
  52. Max RWHP on stock fuel pump
  53. 96# vs 160#
  54. Anybody bought a pump from here?
  55. Ford SVO 30's?
  56. Fuel System Suggestions wanted
  57. What fuel system upgrades are needed for Heads/cam and a dry 100 ?
  58. ls2
  59. Tailoring injectors to specific cylinders
  60. How to drain fuel from tank?
  61. Quick release fuel tank fitting
  62. injector size on stock cube single 76 gts?
  63. Where To Get Oring For Mototron Injectors
  64. need some help on injectors
  65. Need fuel system suggestions
  66. Is pump always on at same speed when engine is running?
  67. Whats stock fuel pressure on ......
  68. 40 psi ????
  69. fuel pump assy/sending unit
  70. High fuel pressure that goes up and down
  71. anyone ever use this fuel pressure gauge?
  72. Can anyone define the fitting on a stock LS1 tank?
  73. Help! Gas Leak
  74. O2 sensor help
  75. car not starting?!?!?!?
  76. evap question
  77. Racetronix pump dropping to 40 psi at peak rpm.. Is this about to fail or what?
  78. Any Help W/Fuel Pump Install (Lonnies Twin Intank)
  79. Fuel Gauge...
  80. are lt1 and ls1 injectors the same?
  81. what size injectors to run on a 418ci 12:1
  82. injector, fuel sys. suggestions
  83. injector size?
  84. Injector ?
  85. Will I need tuning immiatly after injectors?
  86. Speed Inc. Fuel Rail install ????
  87. What is my pump doing?
  88. Running evap without the solenoid
  89. Injectors for a 98 Camaro
  90. 402 with 150 hp wet shot Fuel setup question
  91. Dual intank and New Feed line questions
  92. My proposed fuel system...please make suggestions
  93. Idle A/F with versa nd 96lb... outcome?
  94. Pump gas...
  95. what upgrades for fuel system and 700 rwhp?
  96. Is the trap door measurements in a 98 the same as the LT1
  97. Fuel Pump Install Help!
  98. need help
  99. pump is stuck
  100. stock fuel sys + 60# Injectors supports ?HP?
  101. Correct SVO 42# Part Number ?
  102. Driving w/ Stock Injectors on 60# Injector Tune?
  103. Best Injectors ?
  104. Relieving fuel pressure before removing intake?
  105. 1500hp fuel system sugestions?
  106. pushloc, twistloc plastic fuel lines nhra legal?
  107. need some tech. info?
  108. Who sells direct fit walbro 255
  109. Boosta Pump Install?
  110. Need Help - leaning out 4500 rpms and up
  111. Would a stock fuel pump run lean @ 4000rpms in 408cid?
  112. Anyone just replacing the pump?
  113. Fuel Pressure Regulator to look into?
  114. Help me choose injectors
  115. We need a "fuel systems" sticky in here SOOOO bad!
  116. pump install
  117. Injectors- high or low impedance?
  118. What to do for fuel??
  119. Do stock fuel systems on ls1's have a return line???
  120. need a little help
  121. Any one use this?
  122. help with iac
  123. Cracked fuel injector?
  124. Car hard to start AFTER fillup?
  125. Can stock lines/rails/regulator handle dual intanks?
  126. 60lb injectors for h/c car?
  127. Car starts but won't idle?
  128. carb help...
  129. How many 90 bends are too many??
  130. Racetronix plug and play,is it enough for my setup?
  131. Fuel Pressure guage on stock rails...
  132. Drive through ~FIRE~ ?
  133. doing my fuel system, let me see some fuel rails
  134. doing my fuel system, let me see some fuel rails
  135. injector and spray question
  136. my idea for a nasty tank ventilation system
  137. Save PSI for My Setup.
  138. Fuel line help
  139. Racetronix pump plus a BAP can support how much max hp?
  140. 2 fuel cells, is it possible?
  141. fuel pump install questions....will this work
  142. Fuel system questions, turbo !
  143. pics of fuel systems
  144. 93 fuel pump problems
  145. nate fuel tank guys
  146. Fuel System recommendations for my Twin Turbo build...
  147. Is Fuel Pressure a PCM Parameter?
  148. fuel rail question
  149. Injector noob question...
  150. Racetronix fuel pump but do i really need injectors too?
  151. Any one used the racetronix regulator?
  152. Fuel lines
  153. Need help, possible fuel pump problem
  154. Racetronix pressure issue
  155. Fuel tank problem
  156. what sponsor sells the katech fuel rail adapter kit?
  157. 39lb injectors?
  158. Is 71 psi to high?
  159. Help needed: Intermittent dying/no start condition
  160. MSD BAP install question.
  161. going from 28lb to 30lb injectors worth it??
  162. Fuel Pressure Regulator help....
  163. how to make fuel pump shutoff?
  164. Kenne Bell BAP installation instructions
  165. edelbrock fuel rails question.
  166. Is 42-49psi normal on an 01 ws6?
  167. In the middle of install... Need help ASAP!
  168. dual walbro harness problems
  169. how big are stock gas tanks?
  170. There is a 15-gallon cell that works!
  171. ls7 42lb in ls1 ???
  172. stock pcm 96# injectors
  173. what size injectors with 610 horsepower
  174. SVO 42#'s good for 500 RWHP FI
  175. gotta replace fuel pump
  176. Injector Pulse-Width Puzzle
  177. Injector question?
  178. time to upgrade fuel system
  179. how to hook fuel lines to SPeed Inc rails?!?!
  180. whos using Lucas injectors?
  181. Submersible fuel line......who and where??
  182. Injectors
  183. whats the stock fuel system limit of a 02 fbody
  184. GMPP manifold and oem mounting style fuel rails?
  185. new dual intank idea with pictures, i guess its a new idea
  186. Esclade fueling help please!!!!!!!!!!
  187. LS7 injectors on an LS1 with a FAST intake?
  188. evap removed
  189. injector converter box... who makes
  190. 98 V6 Fuel pump asembly with v8 pump
  191. Walbro/Racetronix ?'s
  192. stock fuel
  193. My twin Walbro's/01 T/A, Pics and schizz
  194. 1200 hp guys- fuel rails?
  195. Hw to fix idle after injectors???
  196. do I need a new sending unit
  197. wiring fuel pump relay
  198. Where to buy in tank regulator??Help!!
  199. retrotekspeed fuel injection
  200. Return-style fuel rails on a SSR manifold?
  201. purchasing injectors what to know?
  202. need help
  203. Hard Starting
  204. Racetronix Fuel Pump Kit LS1: Do i need a retunne?
  205. What psi should i be at?
  206. Melted wires on pump harness and sending unit???
  207. Fuel Pump & Injectors Sanity check
  208. Looking for suggestions on #30 fuel injectors
  209. Ran into a couple of problems...
  210. DTC: P1441 EVAP Code? Need to know how to fix!
  211. fuel guage stuck
  212. TSP In-Tank Fuel Pump
  213. how do i go about picking injectors?
  214. Price Question (Fuel Injectors and Fuel Pump)
  215. Faulty gas gauge? 01 TA
  216. ANy aftermarket Fuel Rails still allow use of FRC's?
  217. Quick Tips on installing AN Fittings And Lines?
  218. 4th gen tank in 3rd gen car
  219. Speed Inc budjet rail kit
  220. Wheres the regulator on an 01 ws6?
  221. stuck in open loop??
  222. Question about brand of injector
  223. Racetronics Fuel Kit. Need to talk with sponsor!
  224. Calculating HP vs Fuel Injector Size
  225. Help!!!
  226. Fuel System Sale up to $100 OFF
  227. 39 lb mustang cobra injectors
  228. injector life
  229. trottle body
  230. Carb VS Fuel injected tank
  231. New to AN fittings, braided lines and hard-lines. School me on this stuff.
  232. Fuel Filter
  233. Injector sizing question...
  234. Aftermarket fuel system???
  235. Fuel pump overheating?
  236. Walbro 255 in-tank install question!!!
  237. bosch 420 external pump inside the tank?
  238. Where to find 1 30ound svo injector?
  239. GTP injectors
  240. Fuel Injectors
  241. Intake or Inline? 500rwhp + Nitrous.
  242. Injector Question??
  243. what are 42lb injectors good too
  244. Diagnostic fuel pressure guage
  245. big fuel injectors with stock pcm
  246. Nasty Performance vent fix? Maybe.
  247. F.I. guys with 1000-1200hp fuel set up???
  248. Dual fuel rails/injectors
  249. Is my fuel pump dead?
  250. stock fuel line limit?
