View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. 60 lb mototron injectors
  2. injector sizes??
  3. fuel line size: turbo, 60lbers
  4. 98-99-02 fuel pump assembly are they interchangeable ?
  5. Injector size??
  6. fuel issue
  7. Fuel cell costs.....
  8. Fuel Pump Write-Ups??
  9. What fuel pump????
  10. Who sells the best/cheapest fule pressure/nitrous pressure gauges?
  11. walbro
  12. Question for anyone with the Speed inc., Fast fuel rail hook up kit.
  13. Help with 04+/C6 Fuel system
  14. New injectors
  15. Are the stock LS1 and LS6 injectors (26 and 28s)rated at 43 or 58 psi?
  16. Car wont run. Is it my fuel pump ?
  17. Need fuel pressure regulator or boost a pump?
  18. What componets for 1200rwhp fuel system
  19. Underhood FP Gauge, where to mount?
  20. meth kit and fuel system?
  21. Fuel pressure problems.
  22. Fuel Rail ???????
  23. Gas smell?
  24. need help with a fuel set up
  25. fuel pressure regulator going??
  26. Bosch fuel injector question
  27. Injector question
  28. Is my fuel pump going bad?
  29. Fuel Pump with cam install
  30. Which injectors do you recommend?
  31. 98 fuel tank swap with an 01
  32. Can running rich make idling rough??
  33. SVO vs Delphi/Lucas
  34. evap solenoid, anyone who has swapped intakes
  35. Walbro 255 inline, Did I just waste my money?
  36. help, fuel system high HP?
  37. Who can clean and flow test injectors?
  38. Anyone running carb style intake and carb style TB on stock PCM?
  39. guys check out this FPR
  40. fuel sending unit?
  41. adding an inline pump?? (trex 50/70)
  42. fuel pump horsepower
  43. Took TNT kit off and Fuel shooting out end of fuel rail...I'm an idiot
  44. high/low impedance
  45. 110 race gas?
  46. keep blowing FI fuse.
  47. Injector Sizing W/ Nos
  48. best price on 50lb injectors
  49. RACETRONIX question
  50. fuel pump sizing ?
  51. Stock Fuel Rail Question.
  52. How long can I go on stock pump and injectors?
  53. Fuel Rails ? What's needed
  54. More fuel problems
  55. Fuel cell that fits where the gas tank does
  56. $500 for a fuel pump :( any cheaper fix ?
  57. LS2 90mm intake & TB on LS1 help
  58. Delphi/Lucas 37# Fuel Injectors
  59. any body know bout inline cheap pumps
  60. Aftermarket Fuel Pump+Harness = Worse MPG?
  61. where can i get a air filter with 90 cm id?
  62. Fuel system requirement?
  63. 99 firebird w/3.8
  64. Fuel Pump Replacements
  65. Car running lean
  66. Who cleans your injectors
  67. ls7 billet fuel rails?
  68. Sealant/epoxy for fuel (metal to plastic)
  69. Most To Spray On Zex
  70. How To Install A Fuel Pump
  71. Fuel Pressure vs. Volume
  72. injector o ring
  73. fuel filter question CARB or Fuel Injection
  74. Racetronics/walbro (only 42PSI?)
  75. Should have done thise low impedence injectors long ago..
  76. thanks to Delphi/Lucas and Racetronix
  77. Race Fuel Question
  78. leaky or stuck injector?
  79. fuel injector ?...help me out
  80. fuel injector clips
  81. fuel in my oil....throwin crazy codes...HELP
  82. How to install injectors
  83. What injectors and pump
  84. who carries kenne bell BAP?
  85. injector size for STS
  86. For those running dual 255's intank...
  87. 150 miles to a tank.. what to do?
  88. injector question #2
  89. 02 chevy tahoe problems
  90. What Injectors?
  91. How do you cut Braided fuel line and put AN fittings on.
  92. Fuel rail leak HELP!!!
  93. are these plug and play?
  94. Fuel Pressure Bleed Off?
  95. sea foam
  96. Alternatives to Walbro?
  97. Typical fuel pressure drop at WOT?
  98. Can u use a v6 fuel sender w/255!!!!!
  99. Fuel rail cap
  100. Tuning my independent throttle body intake
  101. Fuel injector service.
  102. throttle body
  103. What's a neat way to run fuel lines down frame?
  104. twin inline pumps wireing help needed
  105. Clarification on injector sizing
  106. Acess Panel Measurements??
  107. sea foam
  108. octane? is 87 ok?
  109. NastyPerformance fuel tank vapor hose leak FIXED....
  110. E85+stock tune=lean codes?
  111. Nasty Help
  112. nasty performance fuel systems
  113. 98 metal tank + external pump
  114. PART NUMBERS NEED Bosch 420L/hr Inline pump, with #10 in and #8 out fittings
  115. Carb on LS1/6: info needed
  116. Cold Fuel
  117. fuel tank question
  118. best way to flush the tank?
  119. Injector size: ET 215's & 233/239
  120. what size injectors for my setup
  121. Help with Walbro 255!!
  122. cant get fuel down the filler neck
  123. fuel pump help, info needed
  124. Fuel systen upgrades??
  125. GTO fuel tank complete
  126. 10% OFF all MagnaFuel products
  127. question about acetone and MPG
  128. Air/fuel Ratio Gauge
  129. Cng?
  130. Puralator Recall
  131. Is fueling the same regardless of gear?
  132. Getting Enough Fuel?
  133. Low fuel pressure, reg or pump?
  134. Get New Injectors? Fuel Rail?
  135. What to do???
  136. Benefits?
  137. jb weld ok on fuelrail?
  138. Fuel rail install problem.
  139. Injector size
  140. How big is to big?
  141. FAST 36# injector
  142. Will LQ4 injectors work with an LS1 intake?
  143. BOSCH wire colors?
  144. Cutting 6AN Braided
  145. fuel rails
  146. Anyone familiar with the venturi pump system in the c5's?
  147. can svo injectors work on a 4.8?
  148. Difference in horsepower and/or fuel efficiency with different octane rating gas
  149. Speed Inc. Fuel Rails
  150. Stock FP Regulator, where to buy?
  151. OK, I've done some searches, but please post pics of fuel rail installs
  152. fuel pump connector
  153. 03-04 cobra injectors
  154. what determines gas mileage factor?
  155. Lighting injectors on ls1???
  156. How long can 93 Fuel sit before its bad
  157. Need help with fuel setup
  158. Trap Door
  159. How far can stock fueling go?
  160. 100 Octane Gas
  161. are 36lb injectors enough?
  162. Got parts in from Nasty today.
  163. Car wont start plz help urgent!
  164. problems with aeromotive 1000
  165. Noob fuel cell and pump question
  166. walbro pumps...
  167. Fuel pumps and needed fuel pressure
  168. braided hose routing
  169. install of walbro fuel pump
  170. Speed Inc 38lb Injectors, need info on them.
  171. gas pump ?
  172. ran out of gas
  173. 60lb injecters with a heads cam set-up OK until the supercharger goes on?
  174. Two stage fuel system
  175. Is this bad for the Walbro?
  176. fuel pressure ?
  177. Help with injectors
  178. Aeromotive pump controller
  179. Fuel rail question...
  180. not really a fuel question... but
  181. connections for bosch O2s
  182. Mild turbo setups, fuel system ?'s.
  183. Pump in tank
  184. Nasty Fuel Tank Problem!!!!!
  185. New Motor...Need Advice on fuel system
  186. Best intake pump 4 402/nos!!
  187. in line or in tank??
  188. How much can the stock pump handle?
  189. Speed Inc fuel rail problem
  190. Fuel pressure sending unit question
  191. Injectors for an 04' 6.0l
  192. Fuel Rail question
  193. afpr question
  194. Cheapest way to mount fuel pressure gauge on rail?
  195. How many of you think I have a problem??
  196. Low Fuel Pressure..20 PSI
  197. Fuel Pressure Drop at WOT
  198. Fuel injectors are popping out of the rail
  199. Fuel injectors and kerosene
  200. Help I think I just screwed up my new walbro
  201. any1 w/ 90+ LB HI emp injectors around?
  202. Anyone have a pic of the Speed inc., Fuel rail connectin kit?
  203. How much does race fuel go for nowadays at the track?
  204. Are the LT1 and LS1 fuel pumps the same?
  205. Installing FAST fuel rails & injectors
  206. 99 stock injectors
  207. Swapping the fuel pump...
  208. NEED stock 28lbers very SOON!!!
  209. fuel pressure to high?
  210. Alky on a N/A motor, worth the time and $$$?
  211. Number 7 cylinder lean
  212. So I am driving down the highway and....
  213. Fuel injector o-ring...
  214. code PO200 Injector Circuit
  215. Cold start problem today.
  216. buzzing relays??
  217. 2001 Trans Am LS1 Injectors
  218. Losing fuel pressure while off
  219. Whats your mpg?
  220. Fuel pump size LS1
  221. Injector sizing?
  222. Before I Order
  223. 42# injectors enough for ~600 whp?
  224. Q for those with aftermarket regulator..
  225. system too lean?
  226. Problem starting up
  227. Car won't start / No Fuel Pressure
  228. Injector help....
  229. new fuel pump, noticing some problems
  230. My thuper duper fuel system...
  231. Surprised at MPG
  232. need injectors Torquer 2 cam?
  233. cheapers place to buy fuel injectors?
  234. fuel pump problems
  235. installed racetronix PnP fuel pump
  236. Fuel pressure dropping under normal driving???
  237. Popping with Flames....
  238. Fuel pump removal question!? Help
  239. Is 21MPG Bad??????
  240. Need injectors tested
  241. Contacting Racetronix
  242. eBay Fuel Pump?
  243. calculating injector size for STS @ 5psi
  244. Fuel saving ideas
  245. More fuel without a pressure regulator to pass smog in California?
  246. svo injectors?
  247. where to mount wideband O2 sensor
  248. Mototron 60's light throttle hesitation
  249. My brand New Racetronix Pump doesnt work
  250. 945hp on stock pump
