View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Newbie Questions Sorry
  2. anyone used the new NGK wideband?
  3. Which racetronix kit do i need
  4. Whining fuel pump
  5. Any 03-04 C5's using APS fuel system?
  6. Fuel injector help
  7. Anyone wanting to do a dual walbro 98 setup..
  8. How do you setup an air/fuel ratio guage?
  9. My car is flooding HELP!!!!!
  10. FAST Fuel Rail install?
  11. hardwiring magnafuel pump
  12. loud injectors?
  13. Walbro 255 external pump
  14. fuel probs
  15. Anyone sella similar setup to this?
  16. 35lb enough?
  17. Gas problem? Not sure?
  18. quick fuel line question
  19. fuel injection ?s
  20. 2 Walbro 340 intank fuel pump install
  21. when to upgrade pump
  22. Fuel Rail fitting - how do I remove??
  23. Gas tank guru's please help.
  24. simple... wher to get a set of bosch 420 pumps?
  25. need help with seleting fuel line and pump
  26. Tanks inc setup
  27. fuel system diagram
  28. question/opinion external regulator and return line
  29. noob oil pressure question
  30. Standalone Help
  31. Fuel pump
  32. Speed Inc stg 2 fuel system???
  33. external fuel pump for daily driving?
  34. all that is needed for fuel rail and braided hose install?
  35. 96lb/hr injectors can idle like stock!
  36. do Injectors go bad ?
  37. GTO fuel tank
  38. Dual in-tank pumps?
  39. max power on single in tank f/i ?
  40. Duty cycle really high...
  41. Will Cobra 42# injectors work for an LS6 setup as well as green tops?
  42. nastyperformace fuel tank, fuel sending unit
  43. injector duty cycle dropping
  44. can't fuel her up
  45. Stock injectors on 38# tune?
  46. Putt Putt Mobile...What Gives???
  47. RUS 640850 doesn't fit my rail?
  48. Pos. Vacuum Leak...where?
  49. fuel system setup recommendations
  50. 36lb injector question?
  51. Ethenol E-10
  52. Post pics of your nasty fuel setup
  53. fuel pump on convertable?
  54. Anyone using the Professional Products fuel rails?
  55. In middle of intake swap & need help! Can I swap 26.6lbs to 28.8lbs with no tune??
  56. Injector/Fuel rail cleaning frequency request
  57. Me no stumble now!
  58. Cleaning and flowmatching? who does it?
  59. Fuel pump is acting up
  60. Fuel Line Q
  61. '96 Firebird V6 Fuel Pump
  62. Injector size does a small change need a tune?
  63. Regulator location vs. fuel temperature WOW!
  64. Tool for measuring fuel pressure?
  65. bad fuel fuel pump?
  66. ls1 injectors
  67. What size injectors are these?
  68. Injector experts, question about SVO 30lb/hr injectors
  69. Fuel line...
  70. Damn fuel pump relay!
  71. Fuel gauge problem.
  72. MAF air leak causing "too lean code"?
  73. Leaky MAF hose = too lean code?
  74. Power gains on 42# injectors?
  75. Fuel pump for 500-700hp
  76. Can Bank 2 issues cause Bank 1 code?
  77. Quick Question please!
  78. Extra Pickup on Pump/Bucket?
  79. Fuel gauge issues after racetronix install
  80. What size injectors
  81. got my fiel rails and install kit, have no idea how to install! HELP
  82. Return style fuel system questions
  83. braided line interior turned to black sludge..what gives?
  84. FPR Plumbing Questions
  85. just installed new pump, thru the trap door
  86. Mounting FPR before rails
  87. Megasquirt and Carb??
  88. L36/LS1 fuel pump question
  89. Harrisspeedworks Stand Alone
  90. plug size for return
  91. 60# motron question
  92. So which is it??
  93. Fuel Pressure ?
  94. fuel line picture?
  95. Anyone had issues with the Eliminator pump?
  96. Stumbles - too lean code - what fuel pressure?
  97. Fuel or electrical problem Cranks but does not run
  98. ? for those who HAVE the nasty performance fuel setup
  99. Belt drive fuel pumps?
  100. 2002 z, fuel pump on its last leg, and
  101. Enough fuel?
  102. 42# injectors w/ stock pump?
  103. Loud fuel pump, need replaced?
  104. What prevents our cars from blowing up with an in-tank pump? Bare wires and all?
  105. fuel pressure to high
  106. Injector swap question
  107. Different Brands of Gas and Manufacturing process?
  108. 94 Fuel pump relay?????????
  109. H/C motors need fuel injectors?
  110. what should i set my base FP at?
  111. Fuel Flow Ratings for Venom Injectors
  112. Do I need bigger injectors?
  113. Intank pump fuel cell
  114. Twin Intake pump guys check in
  115. Need help with Fuel PSI dropping under boost.
  116. Need some feed back on this product!!!
  117. Stupid F***ing garage floor monster.
  118. what is stock fuel pressure at wide open throttle on an LT1?
  119. what octane
  120. 100 LL Avgas aviation fuel
  121. Best inline pump for fuel cell?
  122. need help assembling dual fuel pumps
  123. which walbro fuel pumo do i get? high or low pressure?
  124. Fuel System finishing touches
  125. Fuel pump/ pressure ? Inside
  126. Not Holding a CHARGE! HELP!
  127. 100 octane on stock motor
  128. 97 vett
  129. Guys with flow matched injectors
  130. tank leaks when full..
  131. what injectors are better..?bosch-tsp-lucas..#42??
  132. Fuel Question
  133. Messed up my fuel tank need Help asap!!!!!!!
  134. swapping injectors
  135. Upgrade???
  136. HELP ASAP! 98 T/A Racetronix wiring harness
  137. I need help to install my Racetronix Fuel system..
  138. Will my racetronix setup be enough for 525 rwhp?
  139. Elimanator
  140. installed racetronix fuel pump...running rich now
  141. gas gauge/tank problems
  142. fuel pressure 20osi
  143. Question on Fuel Pressure fluction
  144. Braided hose to AN fit question
  145. Tetraethyl Lead -- Progressive Injection
  146. 04 gmc truck fuel filter?
  147. Nasty fuel system
  148. stupid braided hose question...
  149. p600B?
  150. Installing boost-a-pump
  151. chrysler 4.9 injectors...
  152. F.A.S.T. 36# injectors..anyone running them?
  153. Race fuel in a stock ls1?
  154. Injector size recomendation
  155. Y cant we install another OEM fuel bucket to get a dual pump system?
  156. remove and clean fuel inj.
  157. FI 800+ RWHP... what fuel setup?
  158. A/F&O2 inline pigtail
  159. racetronix PnP kit recieved!!
  160. Flow Rate ?'s
  161. Help Car keeps blowing pump fuses
  162. Racetronix Vs Greentops
  163. Need 2000 Camaro Fuel Pump Info.
  164. Fuel System Upgrade Help
  165. A new twist to the what size injector question.
  166. some 42 # injector help needed please
  167. Best fuel filter
  168. Injector sizing help!!! Nasty and other experts please!!!
  169. 98 steel tank question
  170. Got a problem a big problem
  171. Single injector not firing....
  172. what size fuel pump is sufficeint enough?
  173. fuel system cleaners?
  174. Can the LPH on a inline fuel pump be higher than the intank lph?
  175. Boost referenced fuel system installed, and functional
  176. Installing a Fuel Pressure Gauge?
  177. car wont start :-/
  178. should fuel system hold pressure overnight?
  179. gas gauge compatability
  180. need racetronix with 408???
  181. stock fuel inector
  182. which injector for me mototron #60 or siemens #60?
  183. fuel pump strainer?
  184. injector size
  185. Can the stock fuel lines.......
  186. Weird fuel Problem need help.
  187. whats this wire?
  188. fuel cooler?
  189. Walbro Dual Intank Link ???
  190. Sponsors-Need hot wire Kit
  191. Help me understand flow matched?
  192. Running bad
  193. 30lb vs 42lb
  194. Bosch 42# Injectors
  195. gas gauge broken
  196. Newer tank question - filling and venting
  197. Walbro 255 thermal protection?
  198. Question concerning fuel pump power(long)
  199. need help with racetronix harness
  200. are the stock injectors big enough for this setup?
  201. Aeromotive rails, racetronix injectors and problems
  202. 383 ci
  203. Injector o ring size ?
  204. Which lines on the fuel pump module
  205. anyone running "cool cans"?
  206. injector question
  207. How loud are your Motorons?
  208. Impedance? High Low? Explain
  209. low fuel pressure
  210. Who makes a dual intank pump setup?
  211. Upgrades on a 427 for 150 shot
  212. Fuel Pump is talking to me ?
  213. Need brainstorming help...
  214. Those with Racetronix fuel pump
  215. fuel injectors...
  216. Will this work?
  217. Typical injectpr/pump combo for head/cam/100shot?
  218. ls7 fuel pump
  219. Fueling system for a 427
  220. A1000 Aeromotive fuel pump.. whos running them?
  221. runnin rich?
  222. Walbro 255 vs Racetronix set up
  223. 42#?
  224. help with injector size
  225. 02' Z06 fuel system limits?
  226. #26 injectors to # 28
  227. injector/pump question
  228. When does factory regulator need to be replaced with an aftermarket one
  229. Removing the factory fuel pressure regulator?
  230. Fuel pump choices for a 1998 FBody...?
  231. 224 cam, ls6 heads, need bigger injectors?
  232. Brown Top, Red Top? Which injectors work?
  233. 30 lb fuel injectors
  234. General fuel pressure question
  235. REturn fuel system...diections or how-to thread?
  236. Return fuel system questions
  237. Controlling 96lb Injectors
  238. fitting ?
  239. injector o-rings
  240. Not Starting most of the time
  241. Fuel Filter
  242. Low impedance LS1/LS7 fuel injector...
  243. anyone run a boost-a-pump all the time? Does it hurt the intank pump?
  244. Fuel Rail Question
  245. non OEM fuel rails what do you do about the dampener?
  246. fuel injector size and brand
  247. Need some pics of regulators mounted under the hood
  248. where to instal Methanol nozzle on a LS1
  249. 100% Xylene???
  250. how to clean injectors
