View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Electric fuel pump?
  2. What kind of fuel pump?
  3. size of C5 fuel lines?
  4. Do I need bigger???
  5. Will Truck Throttle Body Work? Worth It?
  6. can the 1999 fuel tank be droped without a lift?
  7. Fuel Pressure Question
  8. Problems after Walbro 255 install
  9. ATTN: All owners of Nasty Performance fuel tanks
  10. Stock fuel feed to AN adaptor
  11. Fuel Pump
  12. Walbro 255???
  13. Fast fuel rail pics.
  14. Wiring BAP
  15. How many gallons does my gas tank hold on my 01 SS?
  16. Gas Gauge Not working
  17. need fuel part #s
  18. Racetronix Fuel Pump Install
  19. Guys w aftermarket fuel rails, how did u run fuel lines?
  20. Carb'd LS1 ...Anyone done it?
  21. 600hp on 42lb injectors?
  22. Bigger inj. w/ heads cam?
  23. NOS octane boost? Raise octane by 60 points?
  24. Help w/Fuel Pressure Issues with Vortech
  25. To return or not to return....
  26. injector messed up??
  27. Anyone else have a nasty perf.fuel tank
  28. 98 gas tank
  29. Fuel pressure regulator on a '98
  30. 42lb Ford Lightning Injectors?
  31. what size are red top SVO injectors?
  32. fuel pump install gone bad?
  33. ok simple race fuel ?
  34. regulator necessary for 255 pump?
  35. Racetronics 32lbs inj good enough for this set up?
  36. Fuel problem or Ignition problem
  37. Switching from stock 01 injectors to ford 42 lbs
  38. Convert your car to Hydrogen
  39. Plastic or steel fuel lines
  40. Fuel gage ohm readings for custom tank installs inside.
  41. quick disconnect -an fittings?
  42. nitrous newbie
  43. Will it idle with 30# SVOs and no tune?
  44. 2 tries to start engine
  45. Fuel filter options..
  46. what threads do edelbrock fuel rails have?
  47. Fuel Injector Size w/my setup?
  48. Returnless style regulator?
  49. anybody installed nasty performance
  50. Fuel Hose
  51. supercharger noise
  52. Slightly bended the fuel line
  53. Quick Injector question?
  54. help on fuel pump install on a 98
  55. stock injector sizes
  56. Fuel Logs
  57. direct replacement injectors 6.0L
  58. Fuel injector size?
  59. Simple question
  60. Largest high impedence injectors?
  61. gas milage
  62. Racetronix hotwire kit
  63. injectors?
  64. returnless fuel system
  65. LS1 Fuel Pump?
  66. octane boost = race gas?
  67. FAST fuel rail question???
  68. I need the wiring instructions for a racetronics wiring kit.
  69. Do I need a tune if i change injectors?
  70. What gas grade?
  71. NX 150 + TSP CAM...run out of fuel?
  72. EV1 to EV6 injector adapters.
  73. fuel pump nosy
  74. starting problem
  75. Need new Injectors
  76. need help
  77. External Pump Help...
  78. fuel pump ground
  79. Flow matched injectors
  80. Getting actual injector offset data?
  81. Changing injectors without tuning
  82. Does Anyone use a low-impedance driver?
  83. Ned help installing Walbro 255lph pump????
  84. Installing a Electric Fuel Pump
  85. which adjustable fuel regulator
  86. Racetronix fuel system
  87. Fuel pump hotwire + volt blaster necessary?
  88. injectors: 01 ls6 vs 00 ls1
  89. few fuel pump questions....
  90. tell me what you think about this
  91. Fuel sender wire
  92. Need help fast Fuel sender Thanks
  93. Swapping my 68k injectors for barely used ones
  94. Injectors?
  95. Fuel Injector Size??
  96. stock 28.8 with heads and cam, good or not
  97. Advice on fixing this fuel setup....
  98. Too little injector??
  99. Casper Fuel Pump Hotwire and/or Volt Booster?
  100. Down Leg vs. Annular Boosters
  101. Weldon 2025 no pressure?
  102. 99 vortech 5.7 injector flow rate...
  103. fuel smell
  104. 42# injectors
  105. Motron 60#????
  106. did my intank fuel pump just die?
  107. fuel pump/system question
  108. LS-1 Carb vs Fuel Injection
  109. fuel pump for twin turbo LS1
  110. fuel pump trouble?
  111. How can i make sure injectors are 28#'s
  112. Installing Injectors
  113. Walbro 255lph pressure/ flow chart??
  114. Fuel pressure variation
  115. Mechanical Fuel Injection
  116. Draining the Fuel Tank
  117. fuel pressure to high??????
  118. Stock fuel rails not enough for XXX rwhp???
  119. Bosch fuel pumps
  120. Tank will not fill
  121. fuel pump help
  122. Fuel Filter
  123. Best 42lbs injectors for 408?
  124. intake
  125. throttlebody
  126. installing fuel pump
  127. fuel rail plumbing.
  128. fuel cells for f-bodys??
  129. Fuel Rails for Carb style intake?
  130. Where to get Injectors flow tested?
  131. Need fuel system plan for TT402!
  132. fuel system upgrade?
  133. What size injectors for a projected 550 rwhp?
  134. FS Speed Pro/FAST EFI
  135. Matched Injector Question
  136. Fuel Rails
  137. Fuel Pump???Need help
  138. New Rails... Stock System...
  139. Injectors
  140. ? LS2 throttle body
  141. Racetronix Harness HELP ASAP!!
  142. Racetronix optional pump booster interface?
  143. leaded gas
  144. Injectors
  145. fuel pressure safety switch help
  146. fuel system??
  147. Has this happened to you??? oil gauge
  148. Liquid filled or Dry gauges, whats better?
  149. empty a fuel tank
  150. Maxed out injector duty%
  151. inline fuel pump setup for returnless system
  152. Aftermarket Fuel Rails
  153. anybody using nasty performance fuel system
  154. Replacing the O-Rings on Lucas 42# injectors?
  155. Need help identifying injectors-part #s
  156. Granatelli Fuel Pumps
  157. getting new electric fuel pump....what else do i need
  158. Fuel Pressure Gauge
  159. Fuel pump problem
  160. 30 lb injectors worth it ???
  161. Other options for tank fittings?
  162. what pressure fuel pump
  163. Car shuts off after I start it, WTF!
  164. cleaning out tank to weld sump questions
  165. fuel pressure when engine off?
  166. Are 42 lb Delphi's too big
  167. Quick Question About Aeromotive Fuel Pump
  168. Just ordered a Racetronix dual pump setup
  169. Grrr!!! Search is down, what's the part number for the fuel rails on a 2000 SS?
  170. Pulsator Questions?
  171. loud whining noise coming from gas tank?????
  172. Are injectors universal?
  173. Octane boost?
  174. Injectors?
  175. Return style conversion
  176. RC 75's or 83 low Z's & convertor box?
  177. FMU W/factory return?? possible?
  178. ?about right size
  179. high vs. low impedance injectors??
  180. I need a good in-tank fuel system for FI
  181. help setting up fuel system
  182. fuel t-fitting
  183. Car won't start
  184. msd inline fuel pump question
  185. fuel pressure regulator adjustable
  186. where to get an adapter from fuel rail feed fitting to -8AN
  187. msd inline install
  188. 408ci injectors?
  189. Race gas SES light?
  190. Welbro 255 and BAP RWHP limit on FI is?
  191. How to FUEL a 423 w/550rwhp??
  192. LS1 injectors on an L98
  193. what is the flow rate of the stock fuel pump?
  194. best place to get 42lb injectors?
  195. Should I go with -6an or -8an fuel setup
  196. having short block built now what about the fuel?
  197. Walbro fuel pump?
  198. Well, don't bother running dual walbros with vette return rails
  199. Looking for AN to NPT adapter for fuel pressure gauge
  200. What FMU should I use?
  201. Need help disconnecting fuel line from fuel rail..
  202. Which race gas to use?
  203. 42lb injectors on stock 6.0L LS2
  204. Question about installing fuel pump
  205. Granatelli Fuel Pump
  206. Which companies make 96 and 160 lb injectors?
  207. help with fuel schrader valve!
  208. Fast intake fuel Rails??
  209. Who sales -8AN Teflon lined fuel hose?
  210. My Fuel Rails
  211. What part is this?
  212. Trying to understand a few things...
  213. plug and play harness
  214. Are these the SVO #30s ?
  215. Fuel pump access door/racetronix
  216. 255lph in tank wiring help
  217. SS fuel line questions, -6an
  218. Octane question
  219. stock regulator has too much pressure, what to do?
  220. 99 Camaro SS Metal or Plastic Fuel Tank...
  221. HELP...need pics of 99+ plastic tank, intank pump fuel sys.
  222. Question about 5.3 Fuel Pump
  223. A Few Fuel Injector Questions...
  224. fuel system help
  225. Meth Fuel Pump
  226. fuel system question for all?
  227. 2000 model 6.0 what size injectors factory
  228. cleaning my maf
  229. STS kit fuel question
  230. no gauge pressure
  231. Can you use 60# injectors on a stock motor
  232. Walbro very loud, video inside
  233. Air/Fuel gauge wiring?
  234. best stock fuel rail
  235. Any technical reasons why Earl's braided hose is 50% more $ than Aeroquip?
  236. How much power on stock injectors
  237. Simple testing screwed up the car.
  238. Fuel pump making a hummin noise Need Help!!
  239. 5.7 Fuel Pieces Work On 5.3??
  240. Injectors?
  241. Nasty fuel cell users: can you keep your catback?
  242. 42# injectors too much for h/c car??
  243. Help with: Removing fuel line, installing injector clips
  244. Cleaning out my fuel injection (need some tips)
  245. H/C stock fuel system do i need upgrade?
  246. Which vacuum referenced FPR for 2003 Z06
  247. Injectors? Which Ones???
  248. Fuel pressure question/problem
  249. New injector wiring question.
  250. Fuel pressure is now 64-60PSI w/new ractronix fuel system?
