View Full Version : Fueling & Injection
- VIN for CID
- What is the injector spacing on an LS1 fuel rail?
- How long can I drive UNTUNED with SVO 30#
- Trap door, covering up?
- can my gas consumption be this crazy?
- Meth install...Need help
- Christmas Fuel special
- NRE & Mosler Bad ass LS
- Adjust fuel pressure to match injectors
- Post pics up of your aftermarket fuel system.
- do i need injectors and fuel pump
- safe to run super rich?
- are 60lb's too mush?
- Car wont hold fuel pressure!
- SVO red tops part number
- car will randomly not start (no fuel)
- gf ran her car dry and now wont start...
- Weldon 2025 questions...
- Changing intank on a 98 what's the difference from other years?
- 98 Ta/ws6 Biggest Injector W/ Stock Pcm
- How much power will -8an line support
- APS fuel system?
- Cam and bolt ons, what injector size to use?
- Splicing into hot wire kit for second in tank pump
- ? about walboro install
- What size do I have?
- Will there be a problem mounting the pump higher than the sump?
- Street car: Magnafuel 4302 or Aeromotive a1000??
- intake & injector question
- 99 Camaro Fuel System
- Weldon Dial A Flow or Aeromotive
- Fuel pumps quit working - electrical?
- Which injector to buy
- Happy Thanksgiving
- anyone have fjo instructions for injector driver kid0008
- which external pump will work
- Fuel pump install (intank)
- Venom 96lb High Impedance Injectors
- Weird question about injectors, what to buy
- Do I need fuel pump?
- how many ft of AN line for feed and return
- How to Know What I Have
- What size injectors on 408Ci N/A
- Pump sits higher than sump(pic inside)what kind of problems and I gonna run into??
- 408+T88+12lbs boost=What Size Injectors
- -AN fittings
- regulator placement
- Fuel Problem I Think!!!!!!!!!!help
- Injectors and Compression
- injector question
- injectors in a l92 intake????
- need help; on buying injectors and fuel pump
- What size injectors?
- Help Me With Fuel Injectors
- I wanna do a sumped tank setup with braided lines..help me out here.
- Question about installing a aftermarket Fuel Pump
- ? about stock fuel system
- Stock Fuel Pressure at the rails.
- my fuel system 2 walbro intanks
- injector size for boost
- Car is REALLY sluggish on first startup. Like it's loading up.
- 30 psi fuel pressure
- injector question
- Fuel level sender problem
- 42# about right?
- what is this?
- Who makes injectors larger than 160#?
- -Fuel System for Boost-
- Anyone use the Cheap LS1 Ebay Rails?
- 98 Fpr ???
- NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
- My LS1 ITB's
- high voltage fuel pump wiring harness
- injector fitment???
- Up for a fuel system challenge??? - Experience Required
- Twin Pumps & Lines with one return?
- Fuel setup for H/C/Juice?
- Inline Fuel pump mounting
- Bigger Injectors?????
- 60# injectors almost sold out
- whose running steel braided lines?
- high or low imperance injectors
- SVO 30# injectors wanted ASAP
- How to figure out what injectors I have
- Don't know if I have a problem or what
- Fuel System Help
- cellulose filter
- Slight pause at 1/2 throttle
- Fuel setup
- Leads on a fuel pressure test Schrader for custom rails?
- What year injectors were 28lbs?
- some help ... plz
- Got a couple dual bosch 420 setup questions
- No power to fuel pump :(
- Aeromotive Eliminator pump install
- 90lp high imp injectors
- Sponsors that Sell AN fittings?
- URGENT, need help with a fuel issue.
- Regulator Question
- lonnies twin intank pump kit (F-Body)
- Using Edelbrock Fuel Rails w/ FAST
- l76 injector
- help w/ fuel injectors
- how to use MSD BAP on NA/N20 setup?
- stock fuel lines and mild Hp numbers?
- H/C Nitrous fuel system help
- Hey N8 can you help me with wiring my pump
- do I need injectors? what size?
- Anyone know the limit of the fuel rails on the L76 intake?
- racetronix kit
- Bigred 91
- ls1 fuel line pics needed badly
- New to Fuel Systems: Need Your Help With My Project!
- will stock pump work??
- What fuel system for LS7 crate?
- How long is fuel good when sitting
- Racetronix fuel pump kit
- Fuel Pump Stays Running with key "ON"...??
- Anyone running this pump from Summit?
- What will cause fuel pressure to drop?
- Sale on Delphi | Lucas 42 lb. / hr. Fuel Injectors
- 340 fuel pump sock issue
- 340 Warlboro pump help install.
- in tank fuel inj. line
- injector question high/low impedance
- Opinions on Russell "ProClassic" hose & fittings?
- Which brand of fuel injectors do you use
- What size are the injectors that come with the L76 intake pkg from SDPC???
- Variances From offshelf 60LB Injectors
- 60lb Injectors on a N/A 406
- Twin Turbo Truck Dual 255 pumps
- Lucas Octane Booster?
- steel braided hose on a factory fuel rail?
- Fuel pressure bleeds off fast??? 42# injector scaling ???
- 97 Vette injectors
- FAST Fuel rails
- Help With Mass Air Flow Sensor
- How much voltage should be at the pump with my MSD BAP/racetronics hotwire.
- What if...
- Fuel pump power wire in cab
- fuel pressure gauge
- an fittings???
- fuel pump pressure
- Fuel pump question not LS1
- Fuel Rails
- Minimum pulse width and 42# injectors (SVO vs Lucas)
- adjustable fuel pressure regulator
- To those running 42# Injectors....H/C/I Cars
- Fuel Guage ?
- hot wire kit
- Will I need a new tune????
- fuel cell with stock sump
- 98 vette evap question
- identifiying injectors
- loosing fuel pressure up top?
- new problem with the shrader valve
- Adjusting the fuel pressure regulator, what pressure do I need to set it at?
- Quick disconnect for feed and return at tank?
- cant figure this out?
- Easiest way to replace fuel pump
- Got pictures of Fuel lines run under car???
- ??? injector question
- AN Tube Flares
- Where to get, and how are they received - SVO 30#'s
- Fuel smell?
- Walbro Inline Pump
- 16 injectors & Big Stuff 3
- Flow chart for 550 CC RC Engineering Injectors?
- HELP ASAP!!!!!!! How long to start after fuel pump installation! HELP ASAP!
- Gain in fuel pressure if I don't vent the tube to the atmosphere?
- 800hp Fuel System for LT1
- Best way to test a new fuel system?
- LS1 just began to not start. fuel ? sensors ?
- Fuel pump help please!! Strainer issues,99-98 converted. Also more issues help!
- car not starting!
- Racing Fuel causing a MIss ???
- Where to gas up?????
- Whos running this nasty fuel system
- Hard starting, Regulator????
- Installing aftermarket FPR. What will happen if I don't remove the factory FPR?
- 98 Fuel Pressure Regulator Location...Help
- anyone running a mechanical pump?
- Where can I get a Pressure gauge?
- '94 T/A Fuel Pump Change
- Alcohol injection on a stock 05 GTO?
- Redoing ls1 fuel system, several questions...
- In need of some injectors... need advice
- 72lb inj too big for NA application?
- Fuel strainer / sock for 3/8 or -6 hard line?
- What is the hinge for on '98 fuel pickups?
- Fuel pump whinning but no pressure? or somerthing else
- What is the best Fueling & Injection for this project?
- injector scaling again
- Small plastic canister on the driver side valve cover, can I do away with it?
- anyone messed with 'aviator' pumps
- Racetronics hotwire install without dropping tank?
- No Power at Top of Gear
- Is it a Fuel problem, heat or plugs
- Lonnies/Racetronics Question
- 2005 Silverado 4.8l Injectors
- Any Ideas what is causing this
- Are these injectors for an LS1? (Racetronix)
- fuel gauge not reading right
- injector question
- define injector offset??
- Fuel Tank Capacity??
- Fuel Sending Unit...Help I broke it, fix it or buy your old one
- Fuel pump & 8AN line question.
- dumb injecter question!!!! jus need a quick response
- gasket between injector and wiring harness
- My double-pumper setup! (Dual intank - Twin intank - Walbro 255's)
- reason for high fuel pressure
- Racetronix plug n play harness
- Ok guys & gals, bust out your camera, it's time to post up pics of your fuel setup!
- motron or mototron 60 lbs injectors
- Best way to route/plumb fuel pressure regulator, gauge, aftermarket fuel rails, etc.
- hole in gas tank? help sealing it up!
- regulator
- Help Me Setup A Fuel System
- What brand/model fuel pressure regulator? Need to order ASAP! HELP QUICK!
- Any good 99-02 Trap Door pics/links?
- Fuel Cleaner Fixes Starting Problem?
- How to determine which injectors you have?
- 42# 36# Injectors?
- Is my Racetronix Fuel Pump installed in bucket right?
- Fuel Pressure Question
- Drain Tank?
- Do i need a new fuel pump?
- Ran out of gas? Screwed?
- Fuel Pump Voltage Boosters
- help me pick injectors
- hard start after walbro....
- Where To Buy Delphi Injectors.
- Looking to upgrade to...
- Fuel pump help?... 255 pump Leaking?
- Help make up my mind (fueling)
- aps twin kit fuel question
- fuel rails
- 98 hot wire.....help
- Wiring question: Dual Walbros.
- odd issue
- where to get Z06 MAF harness
- 42# injectors a good size?
- Injectors for 383 stroker?
- 75lb injectors too much for n/a 427???
- Injector question
- 416 ci., 13 to 1 compression, naturally aspirated race engine, what size injectors?
- For those that have deleted EVAP canister, do you just put a hose and filter on it?
- What do I need to do before starting after lines have been drained?
- Help with selling a D1sc
