View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58
  1. LS1 Rails (need to Y?)
  2. 50* injectors FS!
  3. New injectors????
  4. Hard line adapter for billet rails
  5. Inline Fuel Pumps and dual pumps.....
  6. Fuel Gauge reading Wrong after intank install
  7. low impedance injectors?
  8. Slight Hesitation (Need Help Please)
  9. G2 Fuel Pressure Regulator???
  10. fuel pressure drop even with new system!
  11. Boost-A-Pump (simple wiring question)
  12. HELP! Car is running awful!!
  13. Fuel System Cleaners?
  14. Injectors & fuel pump
  15. Mototron Fuel Injectors
  16. Big time fuel leak - Help !!!
  17. will my fuel system hold up?
  18. Walbro Intank Install Instructions
  19. Mototron 60# injector GP
  20. HP drop with Big injectors and proper A/F?
  21. CAS Regulator (FI Stroker)... where do I start?
  22. !GasTank and the PCM ??
  23. Around 445rwhp.Should I use 98 28lb or 30lb SVO's???
  24. What's required to run dual intank fuel pumps??
  25. 99 Silverado backfiring especially after buying gas
  26. Fuel Pressure Dropping @ WOT
  27. Walbro Fuel pumps installed
  28. Syptoms of a bad injector? ticking?
  29. Suggestions on Venting a Race Fuel Cell?
  30. LS1 car vs. truck coils?
  31. How HP can the stock pump handle?
  32. do they make a fuel pressure gauge for the fuel rail....
  33. When is it time for a fuel injection cleaner? Best product?
  34. 80 psi fuel pressure
  35. boost pressure and injector size
  36. Will Auto Tap read fuel pressure?
  37. 25psi after walbro in-tank install
  38. Racetronix DP to #6 or #8 line
  39. injector size
  40. Injectors
  41. Help with MAF tuning
  42. Car won't start.
  43. Accel injectors any good?
  44. Rebuild injectors
  45. if you had to choose 42 lb injectors would you go with lucas or the ford???
  46. External Fuel Pump Question
  47. Paging ScottWS6 (fueling q)
  48. upgrade from 2000 injectors or no?
  49. Walboro Dying after 250 miles??
  50. Fuel Pump "trap door"...
  51. Walbro for a tpi ?
  52. Which fuel pump?
  53. Is it ok if fuel gets to open wire on a fuel pump?
  54. injector spray pattern ??
  55. anyone run 700rwhp on a warbo 255 intank.
  56. anyone have a fuel pump install faq?
  57. Need Injector Size Help
  58. fuel gauge stopped working what to check
  59. My modified set-up: What initial fuel pressure??
  60. What regulator?
  61. Question About Ford Fuel Injectors{42.5lb}???
  62. Removing the Vapor return line?
  63. Shooting for 650rwhp, do I need different rails/supply lines?
  64. How to remove fuel rails and crossover
  65. Friend in Need!
  66. Help)+=
  67. Choosing an 02Z fuel pump setup, got questions!
  68. Fuel starvation problem
  69. What fuel system for 650rwhp
  70. Is 50psi fp too low to start car?
  71. Turbo guys...Fuel question!
  72. Fuel PSI REG.???????
  73. shoulb my fuel pressure gauge work all the time with the engine on
  74. Help, cannot put fuel in the gas tank! i am not fimiliar with this at all!
  75. Fuel pump trap door
  76. New injectors, now it's running rich again..
  77. need help with my 2002 z28
  78. Limit of stock '01 injectors
  79. What size are stock 02 injectors??
  80. ls1 intake questions....
  81. 26 to 28.8 injectors w/o tuning
  82. looking for low impedence injectors
  83. stock fuel damper hard line to TB problem
  84. How much should fuel pressure drop at WOT
  85. new regulator installed *pics*
  86. How do you scale larger injectors?
  87. fuel pump help please
  88. What wideband to use....
  89. Fuel Level Gauge working at times and not
  90. Fuel cutoff
  91. Fuel pump relay??
  92. Am I just stupid?
  93. Fuel problem
  94. What Injectors for a blown 408?
  95. wtb stock ls1/ls1 injectors
  96. Major Problems! Please Help Me!
  97. Is this for real?
  98. Issue with spark plug and possible faulty injector?
  99. need help with fuel pump on 01 ta,please.
  100. I need a fuel pressure regulator
  101. another problem with pump...
  102. For those who need Teflon heat shrink for soldering fuel pump wiring look here.
  103. asap!!where could i get a 3/8 fuel line disconecter
  104. Fuel Pump Question
  105. Methanol
  106. Fuel pump recommendation
  107. Fuel rail fitting
  108. faulty fuel injector causing a missfire?
  109. Fuel Question
  110. 42lbs or should I go bigger for 410 stroker?
  111. T1 cam, stock injectors not enough.
  112. fuel pump install problem...
  113. 120*F Fuel pump overheating - help?
  114. Fuel Pump gods help out a mortal lol
  115. Got a a pic of fuel access door!!
  116. Options on where to install power for Hotwire kit?
  117. 30lb SVO's where to get them flowed cleaned?
  118. Stupid Question?
  119. Tb Bypass
  120. Minimum stable pulse width of larger injectors
  121. How much injector?
  122. Water injection
  123. 38# Lucas Injectors F/S
  124. Passenger fuel rail shrader valve
  125. Low Fuel Pressure????
  126. 15 or 30 degree spray pattern, a difference of 40 rwhp???
  127. Has anyone got the new walbro 255lph high pressure???
  128. can I lower fuel pressure
  129. 38 or 42 lb injectors
  130. my car wont start...help
  131. Does leaded gas hurt fuel Injectors?
  132. Stock Regulator no good?
  133. Brians is the man! Re: Nibbler!
  134. changing fuel filter
  135. 28lb injectors
  136. GP on SD-Concepts Spring Tensioner kit
  137. my new fuel system. supports up to 1200hp
  138. Fuel system almost done... Pics
  139. Fuel Pump About To Die?
  140. 13:1+ Compression/Race Gas Discussion - Leaded/Unleaded/Oxygenated
  141. Quick xylene question
  142. alternate fuel?
  143. Walbro 340 pickup strainer???
  144. Did I put to big injectors in?
  145. To much fuel From where?Help
  146. have any idea??
  147. Is there a way to clean/test fuel injectors?
  148. Where can somebody buy teflon heat shrink locally?
  149. Will my car run if I install 42.5's SVO injectors and...
  150. Convertible FUel Pump Access Trap Door?
  151. 30# injectors vs. bigger MAF
  152. My walbro is Fu*#!ng Loud!!
  153. Mototrons Are Badass!!!
  154. how loud are the 255 intank walbros.???
  155. would it hurt to switch from premium to regular gas??
  156. Anyone use an autometer fuel gauge on cas tank
  157. A friend needs help with this problem about his gas tank?
  158. Need advice-Ive searched the forums
  159. Racetroniix install question
  160. Barry Grant fuel pumps
  161. Fueling Question
  162. Need Help With Fuel Problem
  163. Is there a 75 lb/hr high impedance injector?
  164. Worried fuel tank might ignite
  165. ??autometer electric fuel pressure gauge took a crap??
  166. What size is stock hard fuel line in 2002 Z28?
  167. How much Hp will 86# and 95# Injectors support?
  168. Has anyone that has done the access door regretted it?
  169. LT1 and LS1 injectors
  170. Need advice for my fuel system?
  171. After ADJ FPR install should car be hard to start
  172. Fuel system upgrade
  173. Want to install a FPR on my 98 T/A. Can it be done??
  174. Wiring External Fuel pump Questions...
  175. Tricks to installing an intank fuel pump?
  176. installed a walbro 340 intank and now problems....
  177. 28.6lb injectors rated at what psi??
  178. truck rails
  179. do i need new injectors
  180. FAST fuel management
  181. fuel pressure
  182. help-broke my fuel pump assembly
  183. What year had the biggest injectors ?????
  184. Newbie,what 255 pump is easiest install for supercharged application?
  185. What is the maximum pulse width of stock injectors?
  186. Installing a Walbro 255LPH in a 98 Z28
  187. Fuel Pump: D1-SC, TR224/227, 42lb injectors?
  188. #42lb injectors, no tune..how will car run?
  189. Got my SVO 30#ers in, are they new?
  190. Recieved my Motron 60#ers Today
  191. That was fun..
  192. fuel injector to big?
  193. Whats the max rwhp Walbro 340 intank, hotwire kit, volt booster will support? 725rwhp
  194. 99 TA FUEL PUMP Assembly
  195. WTB 36-40lb Injectors...
  196. 255 lph conversion to gph?
  197. MAF Translator Plus vs. LT1 Edit???
  198. Do I need bigger injectors?
  199. Bosch 420L next to stock pump pic?
  200. Na$ty Performance Billit Rails on my Weiand Intake
  201. 2nd Fuel filter/Regulator blown
  202. will stock injector's be enough??
  203. What kind of injectors do i have??? HELP
  204. What are the exact numbers the 30# SVO injectors are putting out?
  205. where to get 30# injectors?
  206. Got a problem while starting up car....
  207. Injector size?
  208. Using stock feed as return? Tube, Nut, Sleeve?
  209. Can someone tell me what size these injectors are??
  210. Walbro And Injectors: Need Tips
  211. Need help picking injectors
  212. Are there any write up on how to install new injectors?
  213. Cleaning injectors.
  214. Do I need the hotwire kit for the Walbro 255lph?
  215. Need Confirmation on part of this project....
  216. Need help finding (Race Tronics)
  217. 6 liter intake info
  218. Help With Setup Guys!
  219. what is up with my mileage
  220. 1998 V6 vs V8 fuel lines
  221. Have you had to remove the entire intake to install aftermarket rails?
  222. Can I run a Universal Fuel Pressure Regulator off my Fuel Rails?
  223. 90MM TB for corvette
  224. Selecting an Injector
  225. Fuel System Help
  226. Injector Duty Cycle
  227. Easiest way to remove fuel rails???????
  228. What injectors for 650 rwhp? 30s, 36s, or 42s?
  229. Need help with fuel system setup
  230. Anyway to get a replacement fuel sock for the Walbro?
  231. Dying Fuel Pump
  232. Ok so tell me what I am losing here?
  233. Would running a high octane unleaded gas help a non-FI car?
  234. GM GTP Injectors (Tuning Related)
  235. how to HOTWIRED the fuel pump
  236. Racetronixs intank pump???'s
  237. In-line or In-tank Fuel Pump?
  238. Walbro 255 Lph Gss307
  239. Stock Injectors
  240. C5 fuel rail covers
  241. Walbro pump came with 5.0 install kit. Will the gaskets work?
  242. any one make a "soft" rev limiter?
  243. What comes with an elec fuel pressure guage? How did you run the wiring?
  244. problem....input needed!
  245. Motron 60# Injectors
  246. VP fuel for Michigan residents???
  247. Installing Fuel Injectors, a few tips
  248. how to test fuel pressure on ls1?
  249. what should I get intake or out of tank fuel pump
  250. Pics of my speed inc rails...
