View Full Version : Fueling & Injection
- Question before install
- Difference betwee JIC 37 degree flare fittings and -an fittings
- Anyone gone from 90/10 gas/ethanol to pure 100% gas?
- Looking for custom LT1 fuel rail setup pics
- fuel tank install help
- injectors
- Is there a way to add a external FPR to the stock returnless system?
- Fuel Injector O-rings
- Trap hole loaction for 98? Were to cut?
- ABS INOP light after intank pump install
- pic of tank install
- Brand new Walbro poop out on me?
- a little help please...
- Injectors and fuel pressure.
- Fuel system for KB blown LS1 in '68 Camaro
- speed inc fuel tanks from back in teh day
- fuel rail covers
- Closed thread on Nasty system?
- Racetronix pnp' worth it?
- ?? on injectors and fuel pump
- Dead pump
- single or twin fuel pump ??
- Single Walbro 255 good for XXX RWHP
- Fuel Pressure
- Bosch 044 external mounted fuel pump
- In tank install
- Where to buy Katech adapters?
- Not enough fuel?
- need injector help!
- E98 Ethanol
- injector size
- WOT fueling problem?
- ok im Fucking feedup with intank pump!!!!!!!
- Rain water leaking past injector o-rings??
- Fuel pressure regulator question
- Difference
- fuel pump going out??!
- what is the highest octane I can run in an ls1
- Will 110 octane race gas hurt stock motor?
- Anyone have pics of nasty fuel system with exhaust? Help with this system
- Question about LS1 Fuel Injectors
- 402 Ws6
- WTB 42lb injectors
- i want to get some nice looking fuel rails..
- Which Injectors For Forged 383 Stroker?
- Can you hot wire the inline pump to the harness?
- Good hi-impedance injectors...
- Ford #50 injectors
- Fuel Pump check price
- 01 SS Trouble starting
- My fuel pump in my stand alone whines really loud when I turn up the fuel pressure.
- MAF affects fuel pressure?
- twin in tank walbro?
- What Size Of Injectors Do The 8.1l Come With?
- Loud fuel pump?
- Walbro Inline, how do you install the line over the fitting?
- Dual fuel filters?
- Fuel filter between fuel cell and inline pump
- fuel rail/ "pulse regulator" questions
- need fuel pump... which one?!?!
- Gas tank removal question?
- walbro fuel pump???
- fuel psi regulator
- Question on Fuel Rails and Leaking Injector
- intake Feul Pump change
- LQ9 Injector questions
- fuel pump and injectors????
- Fuel Guage still off
- Racetronix fuel pump check valve problem? Leaks Fuel pressure down...shot 30sec vid.
- Is anyone using cpr sinister fuel pumps on fi.
- mototron injectors?
- Idle psi for weldon and 60# motron
- 255L In-Tank Pump ?
- Big loss in power for no reason
- No Fuel Pressure?
- Tuning with new fuel pump?
- Anyone ever had a faulty injector ??
- shorty mototron 60lb injectors ?
- Can't get fuel tank out 98
- return line
- Are RC 72# injectors good for 950 rwhp
- Can Anyone Help??
- Running Fat
- What kind of fuel pump is this?
- Stock Fuel Pump Limits
- What fuel pump for my setup? Inline or Intank?
- Fuel problems?
- Fuel System Upgrade Help
- Help in INline fuel pump install
- Who carries 160lb/hr injectors?
- Is it necessary to bleed air from fuel rails?
- Racetronix Install - Change the tune?
- Can i add a different brand pump to my fuel system?
- What's better for gas mileage 6th or 5th???
- used injectors
- Suggestions???
- Fuel injector spray pattern
- Air/Fuel guage??
- Fuel pump for 400hp 5.3
- Racetronix 009's
- What's the deal Nate (Nasty Performance)
- 30pound svo or just run the stockers?
- My Fuel level guage started "hunting"
- ITT We will edumacate me about fuel systems...
- Can anyone identify these injectors?
- Vapor Line?
- Best place to get FMS 30# injectors?
- Noisey Walbro 255, get whiney
- 99 & up tank in a 98 ?
- Racetronix our walbro 255?
- Racetronix 50 # injectors max rwhp
- Anyone ever seen this?? (high octane at regular gas station)
- differences in years for fuel system?
- Need some ideas
- Fuel Rail Installation Question.
- twin intank setup w/ kb bap
- fuel line/heat
- Is my stock fuel pump limiting me?
- Heads & Cam......Injectors?
- Ford svo 30# Injectors???
- Injectors
- upgrade for FI application
- fuel pump gone bad
- walbro 255 fuel pump
- Vapor tube on Nasty tank
- Nasty Performance fuel tanks in stock
- Not enough fuel?
- How to troubleshoot a bad fuel pump???
- Weldon 600-A PLEASE HELP!!!!!!!
- Sea Foam in the gas tank
- 1998 Camaro SS Running LEAN
- anyone runnin a aromotive 450lbs/hour external pump?
- Very poor gas mileage
- Fuel Efficiency
- how much will they hold?
- Leaking Injectors?
- Can anyone tell me where i can find a Walbro 255 for a decent price???
- fuel pump went out last week, what should i replace it with? Walbro 255?
- Fuel pressure
- upgrade injectors?
- larger injectors/pump and mileage
- Is the part# different for 98 and 01/02 injectors?
- ms3 guys, upgrade needed?
- Fuel Pump Question
- OEM return style fuel rails
- Cleaning injectors
- fuel injector or fuel pump???
- Fuel Regulator on 98Z?
- is anyone running a BAP on a hobbs switch?
- Question about fuel lines?
- Racetronix dynamic injector flow numbers - ???
- fuel pump failure?
- Help please
- What rail pressure
- Bap location
- -an fittings for modifying LT1 fuel rails
- need help on fuel pump install (LT1)
- Fuel gauge goes to full when drops to 1/2 tank?
- What about these injectors?
- fuel pressure dropoff?
- Stuck injector?
- Help with Racetronix fuel pump
- Acceleronics VersaFueler plus 8 Delphi 75#
- Who is running 160lb injectors?
- Which Boost-a-Pump are you using?
- Cure for gunk at 7th injector?
- e85 and ls1
- 255 Inline
- Fouled plugs?
- anyone know about these?
- Anyone order from racetronix.
- Kinked fuel lines
- Good lord fuel system stuff is expensive
- Where to get VP 101 fuel in bulk?
- Aeromotive voltage controller
- in tank or external
- Pintle or disk, which is better?
- What does FMS mean?
- Ethanol Alert! - Be Warned
- Pure Ethanol
- aluminum fuel cell for stock location..
- Fuel Fitting AN question?
- Surge tank?
- 60lb Mototron connectors?
- fuel line
- walbro part #
- ethanol ls1
- Quick wiring question about Walbro in-tank install
- Running rich after headers.
- car will not start after pump installation
- Needed Ideas
- Fuel ? For the fuel smart.
- Do I need bigger injectors for my cam?
- cranks hard and then starts but runs rich
- A1000 Pump mounting
- bhp capabilities of 43.5 multec II ????
- 98 tank, need to add 2x -10AN fittings
- Any word on Mototron or siemens fuel injectors?
- Fuel Pressure Still Dropping...
- fuel shrader valve, two of them on,,
- stock injector size on 2000 camaro??
- are supercharged GTP injectors rated for 58 psi? or no?
- Mototron injectors
- I Need Help!!!
- What fuel pressure gauge to get
- Walboro 255L '98 install
- Fuel additives? reccomendations
- Fuel system for 900rwhp.
- Injectors for the 2005 C6?
- 10% ethanol Gas, performance?
- Car stalls when shift into reverse. Help!
- Walbro epoxy mod ???
- cheapest place for SVO 30#
- Highest WHP on Stock Fuel Lines
- Advice needed for fuel injector storage
- Injector Size
- type of gas
- good air fuel guages?
- 42lberr? Are they to much
- What sealants/epoxies are safe to use with gasoline?
- what happens with regular fuel?
- Boosted 550rwhp-600rwhp..fuel system options.. opinions wanted!!!!
- Need help quick, low fuel pressure?
- How to hook up fuel pressure guage
- Dual FP users! Question for ya.
- electrical question ( fuel sender...still) haha
- Upgrade fuel injectors?
- A ? about fuel rail safety..
- Octane Question
- NEW Fuel systems added
- Holley intank pump PN HLY-12-914
- Home-made Fuel Cell
- Help ls6 swap/fuel injector..
- Missfire under hard acceleration??? PLease help
- questions on a tank swap...
- 01 LS 1 into a 36 chev, fuel system questions
- Car Is Lean After Fuel Pump Install???
- Racetronix wiring for the fuel pump...
- Nast Billet rails and stock fuel setup??
- Anyone use pure premium?
- Changed to 97-98 2 line rail
- fuel injector size
- fuel pressure gage question/problem
- Fuel Pump and Sending Unit
- ATTN: weldon 600-A pump owners
- Nasty Performance Fuel System Relay Wiring Diagram???
- Big trouble with Fuel Pump, Gurus Help!!!
- Will i need bigger injectors???
- Need some help...
