View Full Version : Fueling & Injection
- Looking for instructions on installing the Racetronix system in a C5
- fuel gauge fix??
- Bad gas mileage
- fuel injection cleaner in a bottle ?
- strainer
- Cutting for fuel pump
- Alcohol Use For Passing Emission
- Walbro 255 Filter?
- Just finished H/C swap...have a couple injector questions!
- 98+ Fuel Pump install [Did search need a couple specifics]
- OEM LS1 injectors?
- 36's
- Svo 30# Ok?
- Just install H/C and injector at 95%....?
- Help Me with 42lb Injector Purchase - PLEASE
- fuel pressure gauge
- Fuel level sensor
- I need advise on an external fuel pump
- Aftr.mrkt.rails,stock Setup...
- ethanol in fuel?
- Gas gage is tripping,maybe my fuel pump??
- NEED HELP: N2O Fuel System
- Fittings???
- Fuel Sys
- Custom Size Tanks
- Billet Fuel Rail Problems: Fumes and Fittings Seeping
- Bosch injectors
- I need a lot of help
- Stock Injector Size?
- Do I need a new fuel pump?
- Injector queston??????????
- I need new fuel pump.
- Where is the fuel filter?
- What HP with Walbro Intank??? Search Button no luck..
- InTank Regulator Is Bad? - 02 WS6
- Anyone make fuel tanks?
- Fuel Fittings Question
- is there such a thing as too much injector?
- Speed Inc Fuel Systems
- Ford Injectors
- Walbro 255 problem
- Bosch 420 Part #' ?'s
- upgrade fuel system
- Don't know if it belongs here, but I saw fuel
- Car will not run after pump/injector install
- OMG I need a bucket!
- Gas indicator
- Need directions
- What size injectors for this H/C setup in a 99 C5? FMS 30's? 42's?
- fuel pump install
- ANyone know average specific gravity of most pump gas?
- system pressure
- HELP: O2 Sensor help for a Mitsu Montero
- 60lbs injectors?
- How to remove the vapor purge line?
- Max HP from a stock 99 Vette with 30lb Injectors
- Changing Injectors, Any Tips?
- inline fuel pump problem?
- Fuel Line/Pump Lost Prime?
- Need help: Leaking injector=No start?
- when do I upgrade injectors/fuel pump?
- Whistling Sound
- Gas tank pressurizing problem
- I know this doesn't belong here but I really need to know
- Upgrade to 1/2" Fuel line?
- fuel pressure bleeding off
- Somebody Explain to me the fuel return
- fuel pressure drop at WOT
- sts turbo fuel questions.
- Crazy fuel pressure problem
- Fuel Line Question
- Accidently Put 87 Octane In My Z :-(
- LS1 FI O-Rings?
- OK somethings gotta be wrong with my gauge
- difference in ford injectors (green vs yello)??
- Fuel Pressure too High??
- What all will I need for this?
- Pressure Regulator?
- Aeromotive fuel pump controller ?'s
- Need help with Fuel Pressure Drop
- Mechanical fuel gauge
- Stupid Question of the Day
- 98 dual walbro in tank pics
- Fuel PSI dropping at idle, HELP.
- Is there any difference between the racetronix pump and a plain walbro 255?
- Weiland-Holly alum. intake fuel rail question?
- Stock good enough/??
- Anyone Heard of Nitro Power Octane Booster by Pro-Blend?
- Fuel guage pegged past full... help troubleshooting?
- is anyone running that msd carb thing?
- stutters
- Lean Detonation Thoughts?
- What fuel setup to use for ~800hp
- Where is 97/98 Vette FPR Reference?
- 97/98 Vette FPR Reference
- Problems again!
- Propylene Oxide fuel additive?
- Faulty gas gauge?
- 97/8 Vette Stock Regulator question??
- Trying to mix 116 and 101 to make 104???
- Is the Adj FPR for 97/98 rail worth it?
- starting from scratch...what fuel system.
- Ford cobra injectors in a ls1
- F.A.S.T. fuel rails
- misfiring
- What causes rich condition?
- Aeromotive and Magnafuel pumps
- fuel rail question
- Bad 02's?
- Intresting find on Bosch injector #0280155868
- Any one have a formula for...
- racetronix and bap and stock lines
- Fuel Smell / Odor at Gas Cap
- Rodchester Injectors...a little help here
- cold air intake
- Injector Size and IFR
- question on injectiors and new pump
- Injector servicing/flowtesting....where is the best place to get it done?
- Dual intank pump pics?
- larger fuel injectors and fuel pump for procharger
- Racetronix Questions, Quick please
- Msd Bap ???
- stocker pump question
- SVOs on LS!?
- Running rich
- SVO 42#'s - Installed !
- RXP gas treatment works~
- Anyone useing racetronix injecters?
- Instant 25 psi fuel pressure drop, whats the cause?
- Double In tank or In line booster - which is better?
- old gas quest
- Advice needed on Injectors/pump
- in tank or inline
- shi**y gas gauge
- How Do I Change My Fuel Pump?
- DO you need LOW Impedance for LT1's & where to BUY 60 #'s from?
- Fuel Question - SIze Injector and Pump or Pumps?
- Socketless hose?? Good to use or stick with braided?
- 104+ octane booster causes misfires/fouls plugs
- Disc vs. Pintle Injectors(Racetronics vs. SVO's)
- Using only an inline fuel pump possible
- Anyone help with too much fuel pressure, please come in
- Leaded race gas and 02 sensors
- aeroquip socketless??
- Biodiesel?
- NEW injectors?
- standalone fuel pics
- Where to buy MSD 50's?
- 94 octane?
- Injector ratings???
- Where/What Fuel Pump To get? Racetronics?
- Getting new injectors, need help
- What injectors do I have??
- working on tuning 38#ers with cam, looks like i picked the right ones
- I need instructions for Racetronix fuel pump
- moto 60s?
- external fuel pump......puller or pusher??
- Downside of using injector too big?
- What Injectors For A Vortec Blower?
- Best gas station?
- questions on 98 metal to 99+ plastic tank conversion
- Need to get this 98 tank out of my way..
- Threw a code after pump install
- Quiet PUMP
- question about duty cycle.
- Is my fuel pressure right
- No fuel gauge after Racetronix install
- Fuel pressure dropping SEVERELY under load....
- ls1 injectors in a lt1?
- F-99 harness w/ stock pump
- edelbrock injectors
- O2 millivolt to AF conversion
- octane numbers
- NA water/methanol injection
- any benefits to racetronix vs walbro fuel pump?
- What injectors are these exactly?
- Walbro Fuel In-Tank Pump #
- Please help!! Fuel pressure regulator leaking fuel big time
- Bad injector?
- How much HP does the stock 24lbs LT1 fuel injectors can handle up to?
- Do I need to replace my fuel pump?
- 03 c5 vette injector size questions
- Need Help Please
- Installing Fast Intake, NW TB and Fast FR's, ???
- guys with the 30lbs SVO Fuel injectors! HELP
- vette rails
- Just installed my racetronix wiring harness and is it sweet!
- T.B.I coversion to T.P.I
- Fuel pump?
- Fuel Injector Questions?
- Racetronix & Thunder Racing
- Racetronix Fuel pump and fuel pressure regulator with MSD BAP
- Will these injectors work?
- another do i need injectors thread
- Fuel pump install kit
- Paging Racetronix
- Help Me Diagnose This Problem!!
- C5 2003-2004 Fuel Pump Upgrade Harness
- oil filter? oil suggestion [Amsoil]?
- Who Makes Billet Fuel Rails For Ls2 Intake?
- Fueling needs for a Twin Turbo 398 iron block with a *possible max* of 1000rwhp
- think my pump is going out
- Dumb question!! What would happen if an injector would go bad or stop working.
- can i hook the fuel pump up to a switch?
- Racetronix kit 99+ install
- randomly doesn't start
- Walbro 255 Question
- New fuel system
- 98 car 99 fuel tank serious ?
- stock fuel pressure.
- Part #'s for these?
- Install pic's
- Question on fuel rail kits (did search)
- Cn someone tell me who has the Innovative LC-1 in stock??
- Venum injectors
- Fuel Pressure Shot Up
- 255intank and a 255inline?
- twin turbo T/A with alot of fuel problems
- for my 700+hp goal
- HELP!!! Need quick info
- racetronix delphi/lucas fuel injectors
- are these injectors worth a dam
- O-rings in the fuel tank....HELP!!!
- couple questions
- How to calibrate Fuel Gauge
- Best Race Fuel ??
- 98 SS Fuel Pump Hatch?
- 87 Octane
- 98 sending unit in 99+ tank
- Fuel Pump/Injector ?
- Who has meth kits for sale?
- I need help with fuel pump... is?
- Please help me with my fuel setup
- 2000 TA not idling right
- what fuel set up for t76
- Inside Dia. of Different Rails, need 5/8"????
- 10 psi drop @wot?
- Racetronix or someone?
- Fuel pump question
- Injector Info HERE!
- Fuel Pump and Injectors.
- Got a flat spot! Need help!
- How many ppl using Twin Walbro's intank?
- What fuel pump?
- siemens deka injectors
- HP Supported with -8 compared to -10?
- fuel pump booster
- Where can I get a racetronix dual intank set up for my 98?
- 42lb injectors? delphi or svo? Delphi is cheaper!!
- what octane do you use?
