View Full Version : Fueling & Injection
- Where can I get a racetronix dual intank set up for my 98?
- 42lb injectors? delphi or svo? Delphi is cheaper!!
- what octane do you use?
- Racetronix, need your help on a new pump
- High or low impedence injectors?
- fuel rails ??
- Fuel Pump issues after new motor install..PLEASE HELP!!!
- Fuel pump filter part number
- Air/Fuel Raito @ 14.6:1 Good-Bad????
- which octane with h/c setup?
- 20# Fuel Pressure drop
- Racetronix Pump, only 20pis at Rail
- holley stealth ram
- Wierd fuel issue
- So what kind of power can get out of a single 98 intank racetronix?
- Need confirmation of Fuel Inj size by PN
- Mystery no start issue.
- Swapping out 2000 injectors for 01+, retune?
- Which gas tank do I have? Steel or plastic?
- will '98 sending unit work with 2002 wiring harness
- Cheaper solution to fuel lines?
- Locking Gas Cap
- Anyone buy 75 lb high impedance injectors lately? Who's got the lowest price??
- Fuel pressure falling off?
- upgrade fuel pump & injectors?
- Any way to modify a Walbro 340 to make the factory venturi system work with it?
- Has anyone tried a Bosch 310lph intank pump?
- LSx alternate fuel system
- Injector size VS Speed Density ?????
- Quick.. Lucas 38lb Injector Question
- inline fuel pump
- do i have enough gas for a 75-100 shot
- Walbro 340M to 340 replacement - Problems?
- Does Anyone Have the Fuel Line Diagrams for a 98?
- ok heres a question........
- megasquirt questions?
- minimum pulsewidth measured
- Removing injectors....
- Adapters for 03/04 cobra injectors
- Car hard to start...Not Holding fuel pressure.
- Just Finished Racetronix 99+ Fuel Pump Install
- bad fuel gage anyone?
- Do i have to program my car when using SVO 30 Fuel injectors?
- How do I connect stock fuel line to Speed Inc Rails
- How do I connect Speed Inc Fuel rails to hard fuel line?
- Can I use 5/16" lines for LS1 fuel system?
- Running 60's with a Radix on a 2004
- injector size
- Bad Idle Please help
- Maxed out injectors, upgrade fuel pump too?
- Should I sell my Imedance converter and run 75lb High imp injectors??
- 98 In-Tank Aftermarket Fuel Pump Question
- Help with Fuel system.
- Noise heard from pump?
- Will I need new Injectors
- How to Install Fuel Pressure Sender, PIC
- fuel pump questions......
- walbro fuel pump.. need help!!
- ?? Injectors
- Corvette Fuel Filter Adapter
- Anyone run Meth with 100 octane?
- 01 WS6 Fuel Pump flow rate
- Cartek Got My Sts Gto Drunk With Meth !!!
- What is the part number for the SVO 30lbs/hr Fuel injectors?
- Please help! I need fuel, but no solutions.
- Cleaning the fuel injection?
- What pump?
- Need Some HELP!
- Walbro fuel pump
- Fuel pres drops to 52@wot with new 255
- o2 senors
- Same Fuel Rails? 97 Vette & 98' F-Bod
- Do SVO 42lb injectors work well in modified LS1 applications???
- injector duty drop when going from 26.4->svo30
- 2 Questions
- Installing injectors w/o tuning?!?!
- installed a racetronix fuel pump but have a lil problem..help me
- injector ohm testing b/c of DTC p0200?
- high or low impedence injectors?
- Gas Cap Question.
- ?? Pricing for used 30# SVO Injectors
- '98 Racetronix Fuel pump owners:
- who makes the best/easiest to tune 42lb injectors for NA LS1 engines???
- How to check Injectors for proper operation?
- Please Help: Should i go with the accel 26lbs/hr fuel injectors?
- which injectors for wild 382 cube setup?
- Paging Racetronics..
- rail mounted-LS1 adjustable pressure regulator
- 60's what did you guys pay?
- Fuel pump Question
- Good Fuel Filter. LS1
- anyone ever used these injectors?
- how to clean a gas tank?
- fuel on blower ls1
- No fuel
- Speed Inc fuel rails
- How can I clean my SVO 30# injectors?
- violent afterfire
- Is There A Difference In Gas?
- Depth of stock 4th gen F body fuel tank?
- ls2 fuel rail and injectors w/ ls6 intake?
- Fuel line fitting question?
- What size injectors for my application?
- How good are the Lucas 32# injectors?
- Install new injectors before or at the dyno tune?
- Tank leak
- Less fuel from the injectors by going to 11.1?
- which injectors?
- Anyone used or knwo who makes adj fuel press reg for 97/98 return style rails?
- How many rwhp for 36lb injectors
- Alcohol Conversion questions
- Is a boost referenced FPR a necessity?
- Fuel pump part #??
- Trouble Starting!!! Please Help!!
- Need Help Quick!!!!
- Racetronix fuel systems
- Tee vs Y fittings
- What fuel filter to use ????
- Where to mount fuel return line?
- Racetronix, question about how your injectors are designed to work
- Fuel Injection Cleaning
- Fuel Pressure Check?
- P0440 code, Fuel Pressure seems kinda high too?
- fpr keeps changing on me
- How to: Fuel injector swap
- when to upgrade stock fuel system
- from stock to 32# injectors
- Installing 30# injectors on my LT1, and have a ? about the clips>
- How will my car run untuned?
- Doing Racetronix Install Heeelllpppp
- Injector response time?
- Fuel System for 650rwhp?
- Oil Pressure gauge for fuel pressure???
- Am I running out of injector?
- Need suggestions on what kind of Fuel Regulator
- Best/easiest way to clean injectors??????
- Corvette Fuel filter w/ built in regulator
- 116% duty cylcle with 98 injectors
- gas?
- is a 38# injector too much to run on stock engine?
- Gas Gauge Doesn't Work?
- Mototron 60# Noisy?
- Starting Problems: Pump? Ignition? Filter? HELP!
- Drilled a hole in tube coming off the gas tank *oops*
- where can I purchase the Racetronix intank dual pump setup?
- FPR to Stock Fuel Lines
- P0440, Too high fuel pressure??
- need schooled on adj. regulators
- Fuel Rail Plumbing
- Which Fuel Pump, Walbro or Holley?
- Car Shut Down After 43 Mph
- Walbro 255 fuel pump mods for LS1?
- what are the stock injectors rated at 3 or 4 bar??
- which fuel pump is easiest to install
- Where can I get Meth?
- car problem please help!!!!!
- How long will C16 stay good in a gas tank?
- Fuel system limits am I good to go?
- Just installed Walbro 255 pump. Now having problems. HELP please.
- what size injectors
- BAP Questions, Need Some Help.
- Torco Fuel additive
- Fuel pump install how to?
- anyone heard of or use brisk plugs?
- Injectors problem on a 2000 SS HELP needed!!!
- Would It be a bad idea to. . . .
- largest high impedance injectors?
- Best deal on 60# injectors?
- Fuel pump recomendation
- quick question
- Add acetone to your gas?
- Do I need to upgrade the injectors with an F11 cam and LS6 intake install?
- fuel rail modification
- Need Help ASAP "Car dies out"
- What Injectors & PSI in a 97 LT1
- return line do i need one ?
- 110 octane at the pump
- What benefits from aftermarket fuel rails?
- Z06 Injectors - flow rate?
- Gas?!?
- help with max effort duel tank fuel system
- Fuel Pump Whine
- A1000 pump question
- 2004 Vette fuel system with turbo or SC
- schrader valve
- JEG'S 1 1/2" fuel pressure guage
- Anyone have a good IFR for Motorons (60lbs) at 62PSI Returnless?
- delphi 50#
- new gauge and psi prob
- So, there's Big Stuff 3 and now...
- Remove the supercharger
- Can AN aluminium fittings be used on steel line?
- Pump/sending unit....
- Gauge still doesn't work!!!!
- what size injectors for 440rwhp?
- Custom Y fuel block
- What electric gauge are you guys using....
- what size injectors to use
- intake modification(angle of injectors)
- Dual Intank pump full time
- Racetronics Plug and Play Install
- loss of power from 2000-3000 rpm
- Any pics of drag racing Fuel Rails ?
- Starting Problem
- GTO factory fuel pump
- What should I do for injectors
- fuel press. dropping to 50lbs.
- Pics of catback with a sump tank
- 32 lb injectors
- need help... elec. fuel psi gauge???
- Aluminium fuel line, moroso or russell anodized?
- Walbro 255's
- need fuel rails
- Electric fuel press. gauge
- general fuel injector question
- ticking sounds
- Racetronix Fuel Pump Install Instructions Wanted 2001 F-body Plastic Tank.
- ? about stock regulater
- injectors work intermitant and engine wont start
- Aeromotive fuel pump controller instructions
- Where to order Racetronix fuel pump?
- Bigger injectors
- Where to buy GM quick connect ends?
- New to fuel delivery
- Need intank fuel pump
- Help on injector size
- Fuel sump problems please help!
- 39# 03 cobra injectors
- injector size?
- no fuel to the passenger bank
- Are 42lbs Enough??
- Racetronix + Me = Never again
- how hard is it to instal the racetronix 255lph pump kit-lt1
- Fuel Injector Size Calculator & FUEL PUMP Chart
- Engine Fuel Rail Covers
- What's the problem?
- Injector size formula
- diagnosing fuel injectors?
- fuel pressure question
- Problems with Autometer Electronic Fuel Gauge
- Walbro 255 Inline pump, what sie are supplied fittings? 5/16" or 3/8"
- Intank fuel pump question on plumbing
- biggest injector for good idle
- injector identification
- what size injectors for 400 rwhp with less than 80% duty cylce.
- anyone have a fuel pressure test kit i can borrow??
- Cylinders 7 and 8 fouling out?!!!
- LT1 Running Rich - Scan Results Inside - Help
