View Full Version : Fueling & Injection
  1. Injectors powering down?
  2. engine not receiving fuel pls help!
  3. Bank 2 Running Lean
  4. Car will not start when hot
  5. built for E85 can i switch back to 93?
  6. anyone use this kit??
  7. Nasty Performance Stage3 Street Fuel systems on sale
  8. fuel pressure a/f question
  9. Will Accell 44lb/hr Injectors Support e85 On A H/C WS6?
  10. A1000 Fuel Line Question
  11. Fuel System Help
  12. A1000-6 FPR big enough?
  13. Need help installing billet rails on return style
  14. Fuel Pressure Issue
  15. Nasty Nate Stage 3 Fuel line kit
  16. Chilling the fuel?
  17. Stock inj/fuel pump support cam and bolt ons ?
  18. Simple Fuel Pump Question
  19. fuel psi drop after driving awhile
  20. Racetronix Venturi tube help
  21. fuel pressure
  22. Fuel System Adequate?
  23. Do I need to upgrade my C5 fuel system
  24. Bosch Part #'s for high flow injectors
  25. Pump won't prime after hotwire
  26. E85 Octane Rating
  27. 700whp E85
  28. Sending Unit to Vette Filter Swap ?'s
  29. Only 40lbs at idle and 25lbs at WOT dual 255's 408ci
  30. help with fuel pump issue.
  31. Ls1 swap questions
  32. Vic jr/accufab or fast intake
  33. "Big Mouth" fast 92 mm TB question
  34. Fuel Gauge.
  35. walbro 485 direct fit?
  36. Need Help with Racetronix Pump install w/hotwire kit
  37. HELP! Fuel pump problem
  38. Which meth controller to buy?
  39. 72 lbs fuel injectors overkill??
  40. Do i need a fuel pump
  41. am i getting enough fuel??
  42. Tuning injectors....
  43. Fuel pump dilemma. Weldon vs Magnafuel
  44. Difference in AFR between 110 race gas and 93 pump gas?
  45. anyone had this code thrown? p0102
  46. Racetronix Fuel Pressure Drop @ WOT!
  47. Need some help with injectors and fuel rail
  48. Fuel pump noise?
  49. Low Idle
  50. Help me build a fuel system
  51. injector data
  52. 2 in-line pumps?
  53. Looking for part # or place to buy this fuel line/fitting
  54. I think I have a fuel related problem
  55. Fuel injector rebuild and flow match?
  56. Fuel Cell Question
  57. Daul intank Aero 340's or external pump?
  58. Max hp on stock pump and lines
  59. flex fuel question
  60. Stock injector limit ?
  61. has anyone purchased smartfire injectors
  62. Dropping fuel pressure FAST!!!
  63. converting to e85 Need some questions answered
  64. Ebay Fuel Sender
  65. Bosch 044 fuel pump - what's max HP w/check valve and banjo fitting?
  66. TSP Ev6 injector saftey clip stuck! Help
  67. Fuel Fittings and Lines
  68. Fuel lines
  69. Can anyone tell me which vehicle this Paxton fuel regulator would apply to?
  70. Project ls1 z32 Injector dumping fuel into # 3 cylinder getting sparkplug soaked+vid
  71. autometer electric fuel pressure gauge problems
  72. Truck intake?
  73. ls1 intake block off plate
  74. Siemens 80's or fic 1000's
  75. Siemens 80's or fic 1000's
  76. Top off LY6 - Newbie @ EFI
  77. Turbo 5.3 Need advice
  78. fuel pump wont turn on new pump relay etc
  79. Siemens 46lbs LS2 Injectors
  80. best fuel pump for mild built 6.0
  81. what vendors offer complete e85 fuel systems?
  82. Fuel pump LS1
  83. Clearance FAST 102 fuel rails
  84. Manual Throttle Equivlent for TB
  85. 2 different pumps in a dual intank system
  86. fuel question
  87. TB gasket question
  88. 5.3 Return Setup and Routing Options
  89. LS2 with LS3 intake, LS9 injectors = Spacers Needed?
  90. Newbie fuel pump wiring question
  91. car hesitates and stumbles
  92. Hard line pressure rating
  93. FAST rails.. no lines with kit what to use???
  94. First Fuel System. Need Help
  95. Low fuel pressure during acceleration?
  96. dead fuel pump?
  97. Retrofit fuel system?
  98. Need help planning a fuel system for 700-750whp
  99. Fuel rails for a vic jr and a super vic is there a difference
  100. fuel line setup
  101. gauge calibration
  102. Intermittent Lean Fueling
  103. Fuel bucket Issue
  104. need help with fuel system layout
  105. Fuel gauge reads empty
  106. stock fuel pump vs racetronix
  107. Bosch SVO 30# red top injector where to buy a single one? Sponsors? Any1 who knows...
  108. Anyone run these EFI fittings? Waiting for Russell's back-order.
  109. Rich a/f cost how much power?
  110. Just picked up a WS6, Need some help.
  111. A little help please??
  112. Holley 12-890
  113. another fuel pump thread...
  114. 2013 ctsv injector size
  115. Installing FAST 36IB/HR injectors???
  116. Foxbody fuel hard lines to AN conversion
  117. Delphi metri-pack 150 connector??
  118. ID1000s with e85
  119. Fuel Pressure Problems!!!
  120. cant get more than 60psi under WOT with dual walbros.
  121. New Fuel pump & sender
  122. bought new injectors have questions!
  123. Fuel Gauge..
  124. Fuel delivery problems
  125. 50 miles and 40 spark plugs later...HELP!
  126. 98 z28 fuel pressure regulator housing
  127. Injector connector retainer wire help
  128. Richer injectors in cylinders 7 & 8?
  129. injectors or pump
  130. Cheap china ls1 fuel rails?
  131. fuel regulator? starting issues
  132. How to tell if it is the fuel sending unit or gauge
  133. Regulating LS3 Corvette Pump for Carb
  134. LS6 intake
  135. Is my fuel system adequate for E85 and 750rwhp?
  136. Erratic fuel pressure with Aeromotive eliminator and Controller
  137. Do I need another fuel pump? E85?
  138. What's the biggest injector you can use on a stock rail?
  139. Can Fbody specific racetronix pump be used in a C5?
  140. Best Inexpensive Fuel Rails
  141. Aftermarket fuel pump cause a 95 LT1 to gas out?
  142. Fuel Injector / Fuel rail setup for FAST 102
  143. ls6 repair
  144. Filter with E85
  145. Fuel Pump/Sending unit help
  146. An line size for 1000rhwp to 1300rwhp ?(e85)
  147. Fast 4 bbl throttle body vs. 80mm tb 90 elbow
  148. injectors needed for turbo 6.0/ls3 top end?
  149. TrickFlow Injectors
  150. race gas and afr
  151. 06 CTS V Fuel system recommendation
  152. E-85/M5....Street/Track...???
  153. 90 ohm fuel gauge with 40-290 sending unit?
  154. Do 98 F-bodys have the same fuel rails as 99-02 F-bodies
  155. Injectors / Fuel Pump
  156. Holley fuel rails
  157. Dual Pumps: Which One To Power Full Time?
  158. Injector/Pump setup for turbo e85. Maxed out my 95lbers.
  159. Walbro 255
  160. recommended fuel pressure for lt1
  161. fuel supply line size
  162. fuel pump for e85 and nitrous
  163. Attn Racetronix.
  164. Walbro 450 In Tank Pumps in a Custom Fuel Cell
  165. Calculating fuel line size
  166. e85?
  167. Hard starts
  168. need help with hotwire kit
  169. Fuel system needs in turbo 5.3..???HELP
  170. Fuel line and an fittings **Best price to get**
  171. factory 28lb injectors w/ h/c/i
  172. Any kinsler dealers on here?
  173. Siemens deka injector failure.
  174. When to Upgrade Stock Fuel System??
  175. Lm7 fuelrails on ls1 intake?
  176. procharger pulley help plz
  177. Fuel plumbing & fittings
  178. no fuel pump, no spark! help me out please.
  179. Found this in my pile of junk! need help
  180. Fuel Pump Line Inside the Bucket
  181. Injector question for nitrous
  182. can someone help me out?
  183. Hp difference between ls1 intake and ls2
  184. list of fittings needed for fuel system?
  185. What should my fuel pressure be and what filter?
  186. Crazy Question! How to drain G8 gas tank filled with 89 octane
  187. Help with 98 fuel bucket
  188. Accel DFI tuning help - won't idle
  189. fuel gauge/sending unit ?'s
  190. Dual in tanks with e85 fuel
  191. CSFI injector controls used on different injectors? HELP
  192. Fuel system help my turbo 5.3 notch build
  193. Fuel rail question?
  194. have injectors id like to sell but i dont remember what they are. help
  195. Did I get a defective AN fitting?
  196. Identifying fuel injector size
  197. Identify these injectors please.
  198. Blew the injectors out of rail
  199. Accufab set up on a LSX Motor
  200. Cheap ITB kit...
  201. ly6 carb to fuel injection
  202. 67 camaro fuel injected fuel tank needed !!!!! Any ideas
  203. LS1 Fuel Rail Adapter
  204. Running fuel lines and hoses
  205. Need any special tools to replace fuel pump?
  206. Fuel Rail Adapter Fitting
  207. E85
  208. Incorrect fuel level and P0451
  209. What all is actually needed (255 in tank)
  210. Fuel line help....
  211. Stock 5.3 gt45 eBay turbo nitrous/meth injection
  212. Input for injectors for 408
  213. 5.3 Injectors - Flex Fuel?
  214. Finalizing my fuel system, have a few questions
  215. Fuel pump, rails, injectors.. OPINIONS
  216. Carb to EFI
  217. fuel pump set up for 4th gen camaro
  218. Pump/regulator/filter question
  219. cannot get pump out of gas tank PLEASE HELP!!!
  220. Ls1 fuel Pressure help!!
  221. Fuel system Help for Maggie
  222. Bosch 044 vs Walbro 255
  223. Y fittings, what angle do they split at?
  224. Fast 102, ls3 rails on a 98 ta
  225. Truck injector spacers
  226. Anyone with pics of fuel bucket w/AM 340 Pump
  227. Camshaft
  228. Adapting 67 Camaro Fuel Line?
  229. Special Wire type needed in tank?
  230. Walbro 310 or 340
  231. What's needed
  232. need help shop cant even figure it out
  233. Newb help..
  234. Are there any issues running "T" fitting instead of Y fuel block?
  235. Fuel pressure too high w/ twin walbros - Will this change work??
  236. 3/8" Submersible fuel line over 12"
  237. Ls 6.0
  238. Putting LS1 fuel rails on LS3 intake
  239. fuel system for methanol only?
  240. Need help with return line setup.
  241. Necessary to run fuel filter after pump in Aux pump setup?
  242. Fuel injector test and rebuild
  243. Megasquirt works awesomely!
  244. Help/Opinions on E85 Fuel pieces needed
  245. [ e-85 ] is my setup good 4 [ e-85 ]
  246. FAST 3/8 to AN6 adapter wont fit!!!
  247. stupid question.....
  248. simple, quick question about aeromotive
  249. 1982-2002 F-Body Fuel Pump, 255 LPH In-Tank
  250. Need help in figuring out if I need bigger injectors
