View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. New to me 2006 GTO
  2. LS2 427 having issues...HELP
  3. 418 ls3 with cathedral port heads??
  4. Maximum RPM from a 08 5.3 liter
  5. Opinons on ERL Dry Sleeve setup for DD
  6. Can you use stock LS3 Crank Sprocket with Aftermarket Timing Chain Set?
  7. LS7 Reliability at Redline?
  8. [PICS] Katech Track Attack Z06 SN#048 breaks chassis dyno record
  9. Lifter Question
  10. Waitin on new cam spec
  11. Where to buy shor/long block for G8 GT?
  12. Future Plans (Engine Advice Inquiry)
  13. 4.005 bore head gasket question
  14. I have around $1k to spend on fully assembled L92 style heads. These Procomps?
  15. LS7 Lifter
  16. how to fabricate a baffle in valve covers
  17. l92 valves uneven?
  18. LS2 -LS3 Valley cover difference
  19. lowoil pressure
  20. Anybody running titanium valves on a set of 243's on a DD ?
  21. Wrist Pin height?
  22. LSX Bowtie block questions
  23. Budget 440 ls2 build
  24. Larger EPS cam choice for LS2? Advice please-
  25. Can i reuse my morel lifters after i had a bearing go out?
  26. how to get access to factory service manual for 2010 silverado w/o buying?
  27. LS2 push rods thickness?
  28. Are these head gaskets a problem?
  29. ERL shortblock question
  30. Ls3 418 stroker from Texas Speed
  31. ls7 piston dishing
  32. Ls3 oil pump bolt size.
  33. lsx 427 finally finished
  34. LS7 install ChevyII Wiring & oil pan
  35. LSA valve spring specs?? Part numbers?
  36. Information Needed...
  37. Are all L92 valve springs the same? Do L92 springs work w/LY6?
  38. Gm's offset rod ?
  39. 408
  40. 402 buildup for my cts-v
  41. Just started new engine...changing JUST the filter after intial warm up?
  42. ls2 low oil pressure
  43. noob question oil pan
  44. Titanium or hollow steel valves....which to choose
  45. Ti rods ls7 crank in ls3?
  46. Cranking and poping issues! Any help?
  47. Another LS3 427 cam question
  48. 408 LQ4 problems
  49. My heads came in !!!!!!
  50. 114 vs 112
  51. 239 mph
  52. Crank?
  53. 231/235 cam in L76/L98??
  54. LQ4 build what kind of RWHP??
  55. 05 gto l92 swap
  56. LS2 Engines use up alot of oil?
  57. Non stock Ls1 swap to Ls2 questions
  58. Which block for 4.185 bore
  59. AFR 205s + ERL 427 (Baseline dyno numbers added, ET Added)
  60. Tight Lobe Sep Cams
  61. best gasket brand to go with gm or aftermarket
  62. timing chain questions
  63. Questions for 5.3L into v6 F-body
  64. 243/tfs 225 head questions
  65. Thinking of using these cometic head gasket, will they work ok
  66. ls3 heads
  67. PRC LS7 6 Bolt Aftermarket Castings On The CNC Machine!
  68. underdrive pulley? worth it?
  69. What's a good choppy cam for LS2?
  70. H/C swap ls2 no spark
  71. ls1 crank fit a 6.0?
  72. What size is the front oil plug?
  73. stock oil pump.....hand ported oil pump
  74. mild cam
  75. biggest dome for L92 heads
  76. Cam ?
  77. need a cam recommendation 4 a 06 ls2
  78. Valve to piston contact
  79. Has anybody done their own trunion upgrade? If so any pointers?
  80. Help me nail down a combo
  81. ly6 or ls2 aluminum blocks are found in??
  82. LS6 Valley cover install questions
  83. How to tell Patriot Performance heads apart?
  84. Block coolant drain plugs
  85. Mast Motorsports LS7 cam kit
  86. Down 60-70rwhp? Leakdown results and video
  87. Best LS7 6-bolt heads
  88. Questions on the Cleaning of a Disassembled Motor
  89. What pushrod and lengths for me?
  90. Oil volume increased significantly in 24 hours?
  91. Pistons needed urgently 4.130"
  92. 2010 LS3 into 99 TA questions
  93. input needed lq4 build
  94. Need help doing my homework.
  95. LS2 timing chain Damper or tensioner?
  96. Lq9 build
  97. 2000 ARP Rod Bolt Question
  98. LS7 Ultra Pro Comp Magnum Roller Rockers
  99. In southern indiana looking for a speed shop?
  100. Should this combo work well?
  101. Mahle snap ring
  102. LS2/LQ9 Rod & Piston Compatible with LQ4?
  103. Reluctor wheel?
  104. LQ9 700 hp all motor pump gas possible?
  105. best l76 heads for $2500 or under?
  106. which rings to get for a 408?
  107. Need Help with 6.0 heads
  108. A spring thing?
  109. What LS3 style heads would you use?
  110. Any point in upgrading my DART 225's?
  111. Ls3 engined TVR
  112. reusing h/c
  113. Help deciding between LSX376 and LS3
  114. Compression height of stock LS3 pistons
  115. 416 Ls3 LONGBLOCK whats it cost???
  116. GMMP LS3 6 bolt heads ,What Shaft rockers fit ?
  117. I have 12 valves leaking...what am I doing wrong?
  118. 13:1 compression out of an aluminum 5.3 possible? just pistons replaced
  119. LS3: Do I need an oil cooler?
  120. want 525-565hp at the flywheel out of l76, what do i need?
  121. quick dumb lifter question
  122. 417 LS3 Stroker
  123. PR Length doesn't seem to measure right?
  124. L92 made it 53,700 miles
  125. LS3 headers
  126. Another i need help with head gaskets 853s on 6.0l
  127. How-to L92 home porting?
  128. Injectors for ls2 build?
  129. No oil pressure
  130. custom Ls7 cam
  131. Assembly / Checking Clearences with TTY bolts ? Reuse Torque to yield
  132. E-rod engine help
  133. Oil in the heads intake runners...
  134. custom gound cam
  135. Opinions needed for 402 build
  136. Just wondering
  137. cam swap/ oil pump question
  138. LS7 INJECTOR o Rings....
  139. stock rods on 04 6.0
  140. head bolts or studs
  141. L92/ls3 cam vendors
  142. accumulator?
  143. Which of these cams would fit my needs.
  144. stroke a 4.8l motor?
  145. Fuel/Oiling issues on newish motor
  146. Bolt pattern for LSX Flywheel
  147. LS3 vs L99 in 2010 Camaro & SWAPS
  148. ls2 cam sprocket.. which one?
  149. Lookig to buy a cam?
  150. What you guys recommend a cam for CR8 +470rwhp
  151. L96 (2010 LY6) VVT cam swap ??s for early GM A-body
  152. LS2 Assembled Heads Part #
  153. Black soot coming out of exhaust
  154. SPONSORS - need a budget, built LQ9 shortblock
  155. Anywhere to buy individual ARP bolts?
  156. After market Rocker arms
  157. 09 G8 GXP build advice needed (TSP cams)
  158. LS2 Build need some advice....
  159. Oil on spark plugs....
  160. Should I Pull The Motor For My Cam/Heads Swap?
  161. 09 LMG 5.3 Heads/Cam/Intake
  162. 6800-7000 rpm, how reliable, 05 GTO
  163. what grind should i go with ls3 build
  164. anyone measured what it takes to turn rotating assembly
  165. tfs 225's on a Ls3
  166. wha kind f cam is this?
  167. Are ls2 and ls7 push rods the same length?
  168. ls2 swap in fbody parts check..
  169. Are ALL hardened pushrods created equal?
  170. (quick response please)tb 95mm vs 92mm cable 4bolt
  171. LS2 Raptor cam info?
  172. Total budget build LS3
  173. what lifters should i buy?
  174. Are ls9 head gaskets better than ls2 head gaskets and why
  175. Quick Question about valve spring retainers
  176. anybody done a comp lsr269-13
  177. Ls7 cam ID? Pic
  178. what could have done this to my heads?
  179. Stock fuel pump mod?
  180. What intake should I run with 500+ cubic inches?
  181. Help pick heads??
  182. ls2 cam into l76
  183. Ls3 intake valve pushrod
  184. Question about my heads when changing bottom end
  185. Ls3 plug play cry conversion
  186. 2010 camaro ls-3 head casting...
  187. 6.0 pushrod
  188. Lifters upgrade?
  189. Cam bearings ?
  190. Need a head gasket for lq4 with ls3 heads
  191. Cam dowel doesn't fit
  192. VVT Phaser bolt tq settings
  193. My setup
  194. Building a big inch LS2. Need some help...
  195. My full build through AES LSX 454 ( +1000RWHP )
  196. How far can I push this setup??
  197. LS7 head gasket on LS2 block?
  198. CNC'd L92s worth the $$$?
  199. Best engine balance shop in Texas?
  200. Check push rod length after trunion upgrade?
  201. what H/C/I package for my truck
  202. Probe Pistons
  203. What modifications will i need to do to run a double roller timing chain?
  204. Will stock head gaskets be fine on my ls2?
  205. 235lbs on #7
  206. Opinions on build
  207. Looking for answers
  208. Eagle H-Beam rods and Crankshaft
  209. Best Complete Rotating Assembly?
  210. 440 CI smoking???
  211. How - To : Manley Double Roller Timing Set LS3/L92/LY6
  212. Head flow vs compression
  213. What should be my total timing
  214. Oil Catch Can
  215. u
  216. Any reason not to go with a 414 vs 402?
  217. L76 vs. Big Ugly Question...
  218. New Virginia Speed supercharger cams
  219. Lsx swap problems.. Cam position and tach..
  220. Are these Ls3 intake valves?
  221. Looking for NEW "Budget" LS3 ported heads with dual springs
  222. What rockers for bigger cam in LS3?
  223. What Timing Chain Do I Need?
  224. nos in L92
  225. LS2 Block w/ LS1 Heads
  226. Cam for carb LQ4/L92 heads
  227. AIRWOLF LS7 heads
  228. WCCH Small Bore LS7 heads
  229. Jessel Rocker Question
  230. will an ls1 crank work in an lq9?
  231. HELP, trouble starting LS3 416.
  232. LQ9 vs LS2 bottom end
  233. Recommended Spark Plug TFS 225 15#'s Boost
  234. Wanting 6.0 Aluminum Block Engine Info
  235. 600.00 water pump,is that right!!!
  236. PTV Clearance Question
  237. Ls7 exhaust manifold
  238. 6.0 build Suggestions
  239. Cost to install 427 shortblock?
  240. Attention Sponsors - I'm in need of Pistons
  241. ls1 into ls2 car
  242. 2010 Camaro LS3 into 99 LS1 TA questions
  243. Arp crank bolt keeps coming loose???
  244. Ls3 427 cam
  245. Luck with dropout engines from ebay etc?
  246. iron 415 for boost
  247. MAhle Ring end gap?
  248. g6x3 concerns
  249. WTB: LS2 Rods and Pistons
  250. ERL 454 (Dry Sleeve)
