View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. Help an Aussie 6l cam l92 heads
  2. L92 dyno result question...
  3. Crankshaft endplay clearance?
  4. LS7 build for 95 Caprice
  5. 408 Cam Help
  6. Tfs/afr/tsp ls3 heads
  7. TSP Torquer V2 in a stock LS3
  8. hp and cam question
  9. Check out my valley pan, all paint!!! Like it or Not??
  10. Tsp 427
  11. Overheating ZO6 06 !!
  12. Have an L92 crank will I be ok just changing the reluctor wheel?
  13. LS7 exhaust valves Problems
  14. Need some help with compression
  15. Katech rodbolts out of stock?
  16. 6.0, will it work?
  17. ls2 tach signal
  18. 418 LS3/L92 Offset Rocker Needle bearings everywhere!
  19. L92 with LS3 oilpan. Do I need another oil pump??
  20. LS3 Build Opinions Please
  21. Ported 243s vs. untouched L92s on a 408
  22. ls3 Rpm ?
  23. chirping noise in a ls2
  24. Cam phaser bolt - Source?
  25. Milling ls7 c6z head...Changing pushrods ?
  26. Kick out Oil-pan's
  27. LY6 engine
  28. 427 Pros/Cons?
  29. LS2 w/ LS3 Heads and 227/239 .614/.624 115+3 Cam Vid!!
  30. LS2 Swap into LS1 Car
  31. l92 lsr cam results?
  32. L-92 pistons
  33. cam question
  34. L-92 overbore??
  35. Crank key come with the LS2 timing set?
  36. help with pistons for 6.2 block
  37. What is this inside my oil pan?
  38. need wiseco k456x3 pistons-anybody stock them??
  39. 2008 4.8 truck cylinder head combustion chambers?
  40. Center Counterweighted Crankshaft
  41. what weight oil do you run?
  42. 6.0 L92 cam choice help.
  43. 05 ls2 prc 215 and ms4 cam...low dyno numbers. please help[
  44. Respringing an L92 cam phaser
  45. L76 Info
  46. PRC 237 heads and stock LS1 rocker pedestals?
  47. aftermarket cooling fans
  48. L92 torque specs for rockers and thread locker?
  49. thank you at texas speed
  50. Virginia Speed 438" 2500hp LSx
  51. L92/heads-cam
  52. 404 w/ stock ls1 heads, dynoed
  53. 402/408 w/ stock l92 heads and l76 intake, power
  54. Need some help with my lsx 454 engine.
  55. Decent L92 setup
  56. Swapping crank tone rings
  57. TF 235's on a Ls3?
  58. Anyone have a MS4 in a 6.0???
  59. Cam bearings LSX block 19213964 - Erik? Robin?
  60. LS3 head work.
  61. stuck between 2 cams for my nitrous 454 build
  62. thinking about a lil more cam, tell me what ya think...
  63. I need help degreeing my cam
  64. Stroker Motor questions
  65. LS3 upgrade help needed
  66. AFR 225 vs. ported L92 Heads
  67. Egr
  68. Tall deck RHS nitrous build .....
  69. Need performance
  70. LS3 CT525 Break in - Robin and anyone else?
  71. HELP me decide on a cam for my LS3
  72. Help me ID this engine LQ4 or LY6
  73. Crazy coolant leak that fix it self?
  74. Main Bolt Q...
  75. A/C Delco Iridiums vs NGK TR5/TR55
  76. Troubleshoot a miss
  77. LS3 part ID question
  78. L-92 Dual plane
  79. having electric QTP cutouts problem
  80. `05 LS2 head & cam swap...EBCM brake issues
  81. Does a L92 Front Cover work with LS1 Accessories?
  82. 434 Lsx lifting heads
  83. LSx, swaping in LS2 rail
  84. Lq4 rebuild internal troubles
  85. LY6 / LS2 compatibility
  86. Crank Trigger Wheel
  87. My Ls2/Tfs build / Swap Into C5z
  88. Really torn between N/A (+n2o) and blower
  89. LS2/LS3 front cover part number changed
  90. Any LS7 lifter vendor that takes PAYPAL?
  91. Need help identifying pistons in iron 6.0
  92. HELP: Need oil pan & oil pump bolts ASAP!
  93. ls2 gto warm startup RPM' almost hit zero
  94. Lunati rotating assembly 58x? Any other kits better for similar price?
  95. milled 317 heads...
  96. How much compression for new motor in summer Florida heat?
  97. Some LS7 help?
  98. Technical Question: Why LSX block can go to 4.2" bore while the LQ9 can not???
  99. Ported LS7 heads and aftermarket heads..all flow same?
  100. Oil Leaks !@# Is the L92 rear cover different?
  101. Interchangable 5.3L and LS1 parts?
  102. Question on installing yellow ls2 springs on L92 heads
  103. K1 crank ?
  104. V.a. Speed
  105. help me to do my WS7 LS7 Project
  106. 6.0 out of a caddy suv
  107. another which cam thread
  108. l92 freeze plug
  109. FIRST PICS PRC LS-3 Aftermarket Casting Cylinder Heads Sneak Peak INSIDE!!
  110. LS7 valve layout vs LS3/L92 valve layout
  111. L92 Heads + 1/2 Studs
  112. 6.0L cast block question
  113. Any LS3 Torque Plates in Colorado?
  114. thickest pushrod in a LS3 block/head?
  115. Cam Spec Suggestions
  116. t-rex in ls3?
  117. Performance Inductions heads
  118. dragon slayer crank
  119. Roller rockers, LS2 Vs. LSA
  120. LS3 valve durability with aggressive cams?
  121. pushrods: 1-piece vs 3-piece?
  122. who to build shortblock?
  123. pistons wight
  124. harland sharpe rockers coming loose
  125. car is starting to smoke, need ideas?
  126. boosted iron 408 diamond-wiseco-or??
  127. TEA vs. TSP l92s.. help
  128. 242/250 Texas speed cam in 418?
  129. GMPP LS2 Engine controller kit w/LS3 motor
  130. Need to line hone when switching from OEM main bolts to ARP main studs?
  131. where to get and what brand piston rings to get??
  132. 370/364 vs big $h/c setup
  133. Who to go with for a LS3 lonblock???
  134. prep block for a stroker?
  135. Check out these ported L92's...
  136. anyone ever have a piston tapping the head
  137. LS1 swapping to a ls2 short block?
  138. C5-R torque spec.
  139. Thinking of going smaller on cam?
  140. 6.0 LS2 Longblock??
  141. Official pn for GMPP LS3 heads
  142. RHS LS7 Engine Build
  143. LSX camshaft centerline
  144. lq9 block l92 heads gaskets?
  145. Oil to water cooler. Water flow in heater
  146. LS3 block questions
  147. 440 or 454 Stroker, Which is better?
  148. best rotating assy for blown ls2???
  149. leaking coolant out of cylinder 7
  150. Best heads for LSX440??
  151. Best Cubes for a LS2/L92?
  152. Spraying Hylomar onto Gm Mls gaskets
  153. Misfire at High RPM causing Electrical Surge
  154. most possible displacement from 5.3?
  155. highest hp for an stock cubes ls3
  156. so just how much boost on the LS4... opinions
  157. Using copper spray on GM MLS head gaskets
  158. Window Switch Tach Wire Help!!!
  159. LS2 Cam Questions...
  160. Fair price for 243s? and size change
  161. L92 vs LS3 heads
  162. aprox. pushrod length?
  163. Fair price for a used LS2
  164. are harlands adjustable?
  165. 58X Crank in 6 liter block w/ older style cam sensor
  166. LS1 heads on L76 block
  167. Need Help! Rod Bearing, Lifter, Rocker, Exhaust Leak?
  168. Main bearing clearance LSX Block
  169. Low Oil Pressure With New Motor
  170. lq9 in my firehawk, easiest way to make power
  171. SBF torque plate
  172. Best place to buy a forged short block from?
  173. Need some guidance
  174. LS2 in a 98-02 Camaro
  175. LS9 oil pump
  176. front mount distributor
  177. Head bolt swap to studs
  178. Crank shaft timming gear (how do you get it off)
  179. Need a few part numbers to put an LS3 in my F-body
  180. head gasket thickness/823-LS3 heads on 6.0
  181. Question about combo & horsepower
  182. cam question
  183. l92 or Dart CNC 250 heads
  184. LS3 cam choise.
  185. LSA/LS9 part numbers?
  186. Bore/Stroke Idea
  187. LS2 with L92 heads and LS3 intake/tb
  188. Does your L92 Block leak oil??
  189. LS7 manifold options
  190. 416 at Idle
  191. L33, stock bottom & new cam...mill the heads? (yes I searched LOL)
  192. Limitations of a Solid roller for street.
  193. Build Date on Heads
  194. questions to those with 4bbl th bodys on your cars?
  195. Can someone tell me the valve drop on a stock L92 head?
  196. Need help to identify this GM cam
  197. LSX454 Crate motor
  198. What heads/cam/intake for a 402?
  199. Touch-up wall finish for stock LS2 piston/ring combo?
  200. LSX nitrous piston
  201. Quick question
  202. 40X ci engines w/ head/cam combos post dynos
  203. link bar lifters
  204. reluctor wheel options 24X or 58X
  205. Lets get me h/c/i for 404 ls2 on a budget.
  206. Head and Cam recommendation for ls2- Input
  207. L92 Alternator bracket and L92 Harness w/LS1 Accessories
  208. BRP oilpump pickup girdle
  209. 6.0 vs 6.2 LS3
  210. L33 cam in a 2000 GMC
  211. F/S lq4 l92
  212. Afr 245
  213. Wanting to convert DOD lifters in LS4 to Non DOD lifters
  214. lsx engine ( need advice )
  215. stock 243 heads of gto?
  216. Milling LS3 heads
  217. thermostat help
  218. Dipstick problems
  219. vibration on 402 at 2100-2300 rpm
  220. 650 hp´s in a 416 l92 heads n/a pump gas
  221. C100 connector
  222. LS3, how much you can rev it with standard infernals?
  223. need help identifying cam sensor pins
  224. cutouts
  225. Calling All Cam Guros
  226. LS7 Solid roller cam ?
  227. ls3 cam change?
  228. LS2 Clunking Noise When Staring Engine
  229. New TBSS looking to get a cam what size???
  230. Anyone got a spare wiseco piston 6462F125-5016C
  231. Compression Calculation
  232. New crank from GM
  233. Dual or Single beehive?
  234. ls3 heads, intake and injectors on forged 370 going into a 2001 c5 corvette question
  235. Quick PTV ??
  236. Can I run a LS3 with LS2 harness and PCM?
  237. Used LS2 block F/S?
  238. Anyone have insight on these guys?
  239. 6.0 Liter Long block
  240. fast 30462-8 injectors??
  241. Can I run ported LS3 heads on my 370CI LS1
  242. 408 on a budget questions
  243. cyl. Volume LS2 402 ????
  244. LQ4 Questions
  245. 09 G8 GT bank 1 and 2 code violations (after kooks install)
  246. For those who are running a front distributer
  247. would this cam be ok 4 l92 heads?
  248. correct pushrod length
  249. ARP head stud part number for 6.2 alum block?
  250. Change of plans: Cam and piston choice questions.
