View Full Version : Generation IV Internal Engine
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. Crank - GM LS7 vs aftermarket
  2. Most cost effective 470 WHP build?
  3. looking for motor...help plz
  4. Gold glitter in oil after head swap
  5. Cylinder head repair??
  6. How far off are the bob weights
  7. Bolt sizes
  8. Melling 10296 idles 50psi @ 205*F, increases psi with rpm.. how much is too much?
  9. TFS 255cc 821's vs. PRC 250cc 821's.. your preference?
  10. Texas Speed & Performance Engine Machining Shop Tour!
  11. Caddie Lifters preload
  12. knock sensor location
  13. Windage trays, all the same?
  14. ls3 dod help
  15. LY6 Piston ring size
  16. Ly6 piston
  17. PRC 260cc Heads
  18. heads for 408 ls2
  19. New Engine Low on Power
  20. Anyone running this cam Comp 247/255
  21. Building an LS2 402
  22. Cleaning Oil out of the intake and buildup on heads?
  23. what heads for 441 LS7?
  24. VVT Cam Phaser Limiter Kit
  25. pushrod/ valve question
  26. What rod and main bearings
  27. Katech C5-R tming chain..
  28. First Start Up/ Idle Video - RHS 450cid
  29. WCCH or AI??
  30. What is the Max bore/stroke for a LQ4?
  31. Ls3/l92 scorpian roller rockers
  32. Need Help with My LS3 Please
  33. l92 stroker
  34. Valve spring sanity check
  35. question about l92 stroker kit and the heads?
  36. Ccv
  37. LS7 Bronze Guides/SS Valves/Springs part number help
  38. Cold idle rough as shit! Help????
  39. 1-bolt cam to 3-bolt changeover.. required?
  40. LQ9 Engine combo question. I did search, but I'm new to LS engines
  41. Wiped a cam lobe....
  42. Rough idle at cold start
  43. No wonder the oil drain back sucks..
  44. how many stage dry sump? big lsx w/ 98+mm turbo
  45. ported 243 head vs aftermarket
  46. LS2 intake on a 5.3L LH9
  47. BBK throttle body
  48. ls7 Tunner in MD
  49. Problems with "NEW" GM LS2 blocks
  50. 823 heads on gto
  51. VVT Cam Bolt/Valve
  52. lq4 Question
  53. Lq9 cam only
  54. Cam advise?
  55. GMPP Blocks
  56. M295 oil pump
  57. ls2 h/c gto build
  58. The FIRST LS7 Polluter cam video!
  59. Oil flow pattern
  60. LS3 Cam Bearings and Clearings
  61. Invincible crank pulley bolt.
  62. Trick of the week on oil pump?
  63. LQ4 408 Build Questions
  64. LS7 valve guide wiggle : VIDEO
  65. R07 CGI block
  66. Compacted graphite Iron Cylinder block
  67. Need help from the Pros degreeing my cam, please.
  68. LS3 rods in LS2 block?
  69. Lost.
  70. Melling Oil Pumps / COMP Trunion Upgrade / Powerbond Pulleys / ARP Hardware- On Sale!
  71. 24 Tooth lLS2 Crank Replacement
  72. does someone make 6.2 file fit rings
  73. LS3 Engine swap
  74. Engine Swap
  75. oil pan for 4.5 stroke
  76. L76 with LS7 rotating assembly and dry sump?
  77. most cost effective gains for heads on LS7
  78. Cam and Cylinder Head Install Gasket Kits- Available Now!
  79. Thompson Motorsports
  80. A little advice?ported 243s and ls2 intake or ls3 heads and intake?
  81. Looking for an Ls7 engine builder
  82. LS3 416. LS3 heads or TFS 235 heads?
  83. Need cam advice, etc. for L92/LS3 retrofit
  84. best cam for a ls3
  85. Looking for feedback from people who have driven their LS and THEN stroked it
  86. tapered ring compressor for 4.065 (LS3)
  87. Hamstrung LS7 - armchair diagnos this engine
  88. brand new comp lifter collapsed?
  89. LS3 418 Stroker/LS3 CNC Ported heads...Need help deciding on cam
  90. L92 LS3 stroker build (Need Advice)
  91. Does anyone have a crankshaft reluctor install tool for rent?
  92. Advice before buying LQ9 engine parts
  93. What CP pistons do I need?
  94. Gen IV iron 6.0 casting numbers help...pics inside
  95. C6 Vette forged 402 build... feedback welcomed
  96. what intake should i use for a ls1 to ls3 swap
  97. tuning please help !!!
  98. 416 and cam question
  99. What are the best heads for a LS2 a LS3 top end?
  100. Any L92 guys running aftermarket rocker arms???
  101. Big cube lsx build -need help
  102. New to LS - Looking for recomendations
  103. 6.0L+7.0L rotating assem.
  104. Need help with stroker 408
  105. LS2 Stroker kits?
  106. Should I replace valves in 408 w/ LS3 Heads
  107. LS7 440 high compression - fuel system requirements
  108. Scat I-beam rods and stock LS2 pistons?
  109. looking for some opinion/diagnosis of clatter coming from my LS2
  110. Trying to pick witch one.
  111. Ls3 vvt cam?
  112. 434ci. 7000rpm redline 750+whp. Worth switching to ATI balancer from stock?
  113. cam help!??
  114. Cylinder head questions/suggestions
  115. LS7 and LS9 Cam base circle and pushrod length in a L92 or LS3?
  116. Pick apart my setup...
  117. l92. upgrade from 224/230 ???
  118. 224/224 114 cam question
  119. SPONSORS, BEST OIL for 400 HP and UP ENGINES
  120. LS3 VS L92 piston weight
  121. What would you build ls3 427 or lq4 427
  122. Bolt Torque Consensus
  123. How would you build an 04 Z06?
  124. lq4 build questions!
  125. What brand of break in oil, and more importantly, what weight?
  126. nos or boost?
  127. Ls3 procomp heads!!!!!!!!
  128. 05 GTO LS2 in race truck
  129. LS3, two different types of rod bearings?
  130. 6.0 LSx stroker missing parts help
  131. building my first engine got a couple questions
  132. Is it the end production of LS family even thr LSX iron
  133. 5.3 oil passages
  134. Oil Leak possibly rear main seal?
  135. Got my PRC Aftermarket 260cc LS3 Heads Today - Pics
  136. Heads and Cam for LS2
  137. Milling 243 heads on a 5.3 LH6 to increase CR
  138. ls3 Pcv question
  139. LS3 Fuel Pressure?
  140. VVT front cover, 1x cam gear question
  141. ARP main studs on LS3, assembly? Are those neccessary?
  142. Lost small oil pick up tube bolt, can I use generic hardware store bolt?
  143. L92 Cam Phaser Bolt (valve) Question
  144. Aftermarket LSX block question
  145. does anyone have a gen iv shortblock handy??
  146. If you were building a turbo + nitrous LS3...
  147. Oil pump "too big"?
  148. How are the 454's (and bigger) holding up ?
  149. lq9 cam advice needed.
  150. Opinions on whether this cam is junk or not
  151. Tainted's 408 240SX Build
  152. LQ9: 364 vs 408
  153. LQ4 options
  154. Swapping from ls1 to ls2 platform
  155. LS7 Heads
  156. 402 First Start - What Temp?
  157. How bad should my exhaust stink with this cam?
  158. TSP PRC heads on LS3/Nitrous setup?
  159. Fly cutting / valve relief - LS2 block with LS3 heads
  160. LS3/L92 Heads & Intake with an LS2 cam Advice
  161. Cylinder heads
  162. Anyone ever heard of #8 piston hitting the relector wheel?
  163. Any guesses on what this noise is?
  164. Tick Performance Rectangle Port cams are here!
  165. flycutting tool rental
  166. truck coil dwell
  167. LQ9 408 vs LS3 427
  168. windage tray question for LY6 w/ corvette LS3 oil pan
  169. Starting with LS2 block build - Goal 450 - 500 rwhp - Advice needed
  170. Engine kick back?
  171. camshaft degreeing question (results show retarded 1 degree?)
  172. Gen IV DOD towers blockoff
  173. How much oil?
  174. LS3, wise mods for supercharged engine, reliability wise?
  175. oil pump/balancer hub clearance
  176. Cam idle!
  177. Ls3 cam retainer plate bolts don't fit ly6 (gen iv iron) block....?
  178. would titanium valves make gains
  179. Blown motor - need a swap in West Texas
  180. burning oil
  181. tnag to tang--people who assembled ls2 motors step in
  182. Livernois Motorsports 2010 Camaro (Auto) LSX 454 Swap
  183. 2010 DOD and VVT delete parts list
  184. l92 head studs
  185. LS2 rebuild, suggestions
  186. LSA heads or Trickflow 220 on lq4
  187. Best Head for the job.Mast,Brodix,LsX
  188. what will this cam do in a 6.2
  189. 58x to 24x conversion?!?
  190. Lsx 454
  191. Ls2 AC Pulley Delete?
  192. LS2 maximum bore over size
  193. milling my heads
  194. factory LS-3 crankshaft weight
  195. How much horsepower do you guys think?(lsx454)
  196. Few questions on these heads
  197. Lq4 crank inside ls7 block?????
  198. Lsx 454 cam (with harrop intake)
  199. Do you have to bore when swapping pistons?
  200. 2002 b4c
  201. LS2 exhaust valve
  202. ordered GM part #12610716 (LSA head), received 0821 casting in 12610716 box
  203. Several ZL1's in the shop
  204. Tuning a ls3... MAF sensor?
  205. LS3 stock rebuild ring gaps and piston to wall too loose?
  206. Turbo 4.8 guys, get in here.
  207. Help with LSx Harmonic Balancer Swap
  208. what valve covers fit LS3 heads?
  209. Water pump options
  210. Scratch on deck of ls2 block repair
  211. A.E.S built 408,mast heads...SHould i upgrade
  212. 416 and cams
  213. 2000 Camaro LS3 Build
  214. What the final word on repairing a block with spun cam bearing?
  215. 91 firebird 5.3
  216. custom grind cam who would you use and how much are they
  217. Cam bearings too tight
  218. Mast LY6 HO
  219. Head Stud Question
  220. Repair LSA block?
  221. baby seal????
  222. custom cam
  223. crank size?
  224. cam and heads install
  225. Any High Mileage 408's out there??
  226. LS7 dry sump oil tank question
  227. Stock 6.0 problem with lifter/rocker
  228. LS3 build questions
  229. Doubt about current rocker setup
  230. Oiling system
  231. LSX Build 376 - 427 vs. 454
  232. PTV Clearance-screwed
  233. LS2 402 vs. LS3 418
  234. 2008 Vortec Max Silverado Cam Choice
  235. 402 vs. 408
  236. Pushrod length question/suggestions
  237. would u buy these heads?
  238. Pre-detonation when I step on it -
  239. Critique my cam choice
  240. LS3 / L92 supercharger intake manifold?
  241. Camshaft bearing tool for ls3?
  242. Help with 6.0 lsx build
  243. Help understanding Dynamic CR, quench and piston fly-cut
  244. where to hook up HVAC line to back of ls3 intake
  245. LSA damper
  246. 6.0 l96
  247. Weight of 402 Stroker?
  248. Engine OIL cooler...........
  249. worn valve stems on a 3yr old 13k mile stock motor?
  250. Thoughts on cam in 402 stroker
