- 12591720 tan cam sensor- compatible with LS1 PCM?
- Lq9 to L92 conversion ?
- Stroker Build Advice Needed
- Ls3, ls7 question
- ls7 lifter restrictors are the needed ?
- build a 454 lsx
- P0343 and cam to far back?
- Need some advise on H/C combo.
- LS3 , L92 Intake and Exhaust Valves for sale
- Help with setting up valve springs/valvetrain
- Need a new budgetish engine
- 408 build
- Decided on a LS3.. what parts from my LS1 can I swap over?
- Crankshaft Question
- 416 oil consumption...when under load?
- will venting both valve covers create a lean condition?
- Opinions on this build?
- New ls2 block
- LS3 breakdown report
- head studs
- LS7 MAF extension
- Lsx iron block
- anyone use elliotts cams before?
- LS3 doesn´t start ?
- LQ9 question
- about to buy a 6.0L now what
- PRC 2.5 LS6 Heads w/Cam results, A4 only please!
- ly5 oil pan
- 454 cu in Katech piston Ti rod Callies crank assembly
- compression ratio
- LS7 rocker arms
- Yella Terra rocker clearance?
- 416 LS3/L92 vs. 427/LS7 which one?
- carb'ed lq4 into an 85 z28?
- i need opinions on this setup im going with
- need some help
- Heads to match cam...
- How do I modify LS1 valve covers for LS7 heads (or should I)?
- Reluctors
- 408 Heads & intake question
- iron 370 or iron 408 build for APS TT?
- Checking pushrod length / lifter preload - Hot or Cold?
- 421 vs lq4
- Biggest cam with stock Stall
- MS4 with A/C?
- LS3/L92 vs. LS2 block
- LSA CTS-V LS engine upgrades...
- L76 questions
- Iron 408 vs. iron 415 (with 250 shot)
- New TCI Starter for LS Engines!
- Is the LS3 padding/cover necessary?
- An Open Letter to SCAT Crankshafts
- Thread pitch - SCAT crank- flywheel bolts?
- LS3 and Manley Valves different height
- 800 HP naturally asperated
- blew out valve cover gasket on new motor
- knocking after cam install..
- Raising CR?
- direction of coolant flow?
- what parts are needed to convert from ls1 to lsx???
- LQ4 PTV clearance with 59cc heads
- LQ4 in 01 camaro
- Dipstick relocation?
- Need help with LS3 Build
- these heads
- LS2 piston failure
- Bumpsticks
- 408 Build Help
- Do i have an LS2 or not?
- LSX what block
- Need cam ideas for Stroker 383 with STS
- Is it Worth swapping from ported l92's/l76 to TFS 225/235'S on a 402CI?
- milled 243 heads & PTV clearance in LS2...
- What is need to run a LS7 dry sump in a ls2 block ?
- What size Cam?
- LS3 Rear Cover Bolt size
- Cam for a 3600 stall
- l92, g6x3,prc heads
- LS3 timed vacuum source
- L92 Head Flow Results
- Anyone have livernois l92 st3 heads,motor and dyno #'s?
- L19
- ls3 l92 cam expert needed.. opinion
- ARP Rod bolt specs
- 408 L92 cam question
- Pass Valve Cover doesn't fit w/ YT's / LS3 heads
- 500 hp on "Big Mutha Thumpr"
- want to make 440ish cam only and all bolt ons 03' C5Z any advice?????
- wanting to make big power!!
- Valley cover
- RR-STRIKER CAM - Check it out(Vid & Graph)
- Help me make more power ;)
- Racetronix knock sensor extension harness
- Got a LS3
- L92 on a LS7 block
- L92 roller rockers
- What's Wrong With This 402
- Loud knock need help
- Stock longblock LS2 HP record? Anyone know what it is?
- LS1 dipstick in LS3 block?
- ls7 swap in 1999 camaro no start
- what is the size of the gm mls ls2 headgaskets?
- Katech High Capacity LS7 oil pump - Hard data
- Lookn for some shorty 60lb injectors for my LS4
- Question about heads on an 02 Camaro SS i'm looking at.
- What bolcks will accept trad. intake(90/90)
- 243 casting heads question..
- LS3 head gaskets
- 408 or 418???
- Standard LS7 C/H specs
- Occaisionally going lean on the drivers side only ... Why???
- Time for a 418, maybe?
- F/S LT1 w/ 4L60E tranny
- please help choose ls2 cam..
- ERL superdeck 2 block
- need help with LY6 cam
- Cam Question
- 408 with LS3 heads
- ls7 rod lenght
- Anyone in Ca running the 224R or 228R cam?
- Burnt LSX block Main Bearing
- in a nutshell, 976/l92/l99 AFM with Cam phasing
- do LS2 & LS3 motors ping like the LS1
- speed shops
- Need exhaust help bad
- what do I need?
- Lsa
- 402 or 408?
- Anyone help? weird
- Morel link bar lifter issue
- low power, new cam?
- New 06 trailblazer SS
- which retainers for these valve springs
- 241 head questions..
- 02 firebird Terrible piston slap
- Main Cap Bolts!
- stock ls3 rod and piston capabilities?
- 6.0 heads??
- head/cam combo for 2000 Trans
- LS7 Crank in LQ4 Block
- ATTN: Sponsors i need a kick@ss cam
- GenIV cam question?
- LS7 rods with a 4.10 crank?
- Hey!!!!!! Stop and look at this
- 06 TB SS LS2 into 02 SS
- L76 cam questions (dod)
- Can different oil filters produce different idle oil pressures?
- engine siezed
- Shaving Stock LS6 Heads -Power Gain?
- Valley cover PCV provisions on ls2 in ls1 car
- l76 engine size
- Biggest bore for LS7 heads???
- No oil pressure HELP!!!!
- oil temps in ls2 404 quite higher than ls1
- GM Engineer Explains the LS7, LSX, C5R, and LSX-DR Heads... Cool Vid.
- Parting Out LS7 Build
- carb'd 6.0L + L92 heads what cam you all running?
- Strange Oil Pressure issue at WOT.
- Building a 402 have a choice to make between two sets of heads....
- LS2 bock question
- 404 ls2 first start, everything great, no tach
- 422 w LS7 top end - Suggest a new cam?
- Ls2 cam swap?
- Anyone put a LS2 pan on a LS1/LS6 Corvette?
- Ls2/lq9 ideas
- Recommendations for my L92 in 68 Camaro
- Forged Piston Recommendations???
- Nick Williams 96mm t body
- LS7 vs LS3
- Car won't start !! ZERO CODES !! Video in..
- Timing chains for high rpm LS motors?
- LS2 conversion wiring questions.
- Tourqe specs.?????????????
- Question on Fast 102MM
- ARP intallation without ARP moly?
- LSX376 Power Potential...
- Can't start my car after engine swap
- question about t.b.'s
- Am I better off with 215 heads vs 225's on a Ls2?
- has anyone used the Comp short travel lifters?
- Getting TSP 233/239, .595"/.603" cam
- Alright, I didn't want to do this...
- LS7 Lifter question
- Need new heads for the 408.
- Victory Racing Engines BEWARE!!!
- Motor starts to tap and squeal please help
- ls1 crank pulley on ls2 crank
- Cant plug in cam sensor need Help what to do ?
- LS2 402 just isn't running right.
- LS3 build -OR- LS2 build
- WTB: stock LS7 bare block
- Crank is locked..
- Whats the big secret with ls3 cam specs?
- cam gurus needed
- Droppin in my new ls2 stroker, any small details?
- Titanium valves or noy?
- L92 in 61 belair, do heads need update ?
- Roller Rockers?????
- ls2 thrust bearing problems
- ls2 lifters
- Cam and heads question!
- ls3 swap why god why!!!!
- Anything to keep in mind when building a 440 LSX?
- Paging Erik from HKE ...
- Ls7 Issues with dropping valves?
- ls3 valve cover clearance??
- Pushrod length?
- LSA crank in LS2 block?
- Advise on Ls3 427 CAM
- L76 for performance?
- Carnage PICS-Need help with autopsy
- knurled bolts?
- LS7 based 440cid dyno numbers
- Used Engine prep - L92 - Advice?
- TPE is looking to SPONSOR YOU!!!
- my LME built LSX 427
- piston ?
- 416/418 build for g8 gt
- Will 241 heads fit on an ls2?
- LQ4 cam swap
- Race LSX block.. lifter, timing chain, rocker, and valley cover questions??
- LS3 Coolant flow diagram?
- Texas Speed Engine Dyno Cell FINALLY COMPLETE!
- Replacing VVT cam with gen 3 cam?
- Best block for a 440
- Billit Mains
- Looking for a shop that can get me a 427 LSX....
- (l92)aftermarket cam help
- Fast 102mm Intake--Real Results --NO BS
- DCR Calculation Help (Piston Selection Issue)
- XR275 cam in LS2, what else in the valvetrain needs an upgrade?
- Recommendations on oil pump
- Torquer v3 too small for 402 ls2?
- Worth getting 799 heads ported?
- livernois stage 2 what cam?
- 2500 to spend
- i bought a crate motor - cam experts (Patrick G) come in
- Torque spec for timing chain dampner?
- 2010 camaro and z06 corvette rwhp
- Getting back to really vechiles have engine questions
- Steam tubes on LS7
- The LSx 102mm LS7 Intakes Are In Stock @ TSP!!!
- Urgent Help [Block casting numbers]
- LS7 6bolt Heads for 440ci LSX
- In english
- Lets talk about valves...
- Thermostat Help finding 160 Degree
- Performance With Big Inch 416-441 Engines
- Question about LS1/LS2 windage trays
- ls2, ls3, ls6 valley pan restictor removal?
