View Full Version : Generation IV Internal Engine
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. o-ring issue?
  2. What cam and head work to do for stock daily driver LS3?
  3. Skirt wear on 4" stroke motors, show me yours...
  4. Cam choice with Holley Mini Ram
  5. Going from ls1 to ls2. Looking to pick up 50rw. What's needed?
  6. What can I expect outta this build
  7. need advice to make 500rwhp on 6.0 lfa
  8. Running a GEN IV (LY6) in GEN III (LQ4) form
  9. Stroke a 5.3L to 359?
  10. To be or not to be, NA or FI? LS3 to 550-600whp range
  11. Pistons/Rods for LY6
  12. Need help in getting the right Alternator
  13. Rocker arm/lifter/pushrod suggestions in a 408
  14. Lopey Cam for LS3 Headed LS2 for 69 Camaro
  15. 220 /228 cam 117 lsa help!!!!!
  16. Lunati single bolt cam
  17. engine builders help please
  18. LS4 tuning help
  19. Will this camshaft work without flycutting
  20. ever wonder what inside your cylinder looks like
  21. Timing Chain Help?!
  22. rebuild question
  23. Custom grind cam without knowing how heads flow?
  24. LS2 Fuel Rails Options
  25. Rod clearance issues
  26. Learning from experience
  27. 440 ls2 zero miles. blown heaed gasket?
  28. cam bearings clearance?
  29. Help! Car Wont Start!
  30. LS3 wear questions with pics
  31. Best price on Wiseco pistons?!
  32. LS3 Heads on a 5.3?
  33. Lsx main bearing problem questions with pic
  34. CNC LS3 heads on L99
  35. LSx Oil Pan Spacers
  36. What can I do to help feed my engine oil?
  37. Opinions On this cam
  38. 07 5.3 Cam Suggestions
  39. what is best cr for procharged (p-1sc-1) g8 gt around 800-850 rwhp
  40. RHS 450cid and AllPro Heads - 2days to Install
  41. 4.0" stroker with stock rods
  42. P0342, p0343, p0430
  43. First Build Help
  44. Throttle actuator problems 5.3l
  45. Trick Flow LS3 Cylinder Head... Finally is there
  46. ls7 bent rod
  47. Main Bearing Clearances HELP
  48. Dallas Performance d6 camshafts specs?
  49. 06 GXP 5.3 engine questions
  50. LSX vs. LS3/L92 boost capacity
  51. Piston options 4.125 bore with stock 3.622 stroke?
  52. Heads/cam or stroker?
  53. 243 Valve/Seat Sizing Question
  54. Need help picking and LS engine
  55. Another ls2 not starting thread..
  56. 402 with AI 243 heads for road race app. How good?
  57. rod and main bearing clearances?
  58. New ls3 oil pump
  59. GM's LS break In Procedures
  60. please help cam specs needed
  61. Which LS Block for 600+ hp with boost?
  62. correct cam sprocket?
  63. Oil Pump, swap or not?
  64. 416-418 ls3?
  65. L33 details needed (OEM chain used, rods used, and max bore limit)
  66. My pushrod measurements don't seem right. Opinions?
  67. what causes ls2 to spin rod bearing
  68. Build ideas for a 402 LS2 stroker going in a 1979 T/A.
  69. Help my troubleshoot p0011 cam over advance on vvt
  70. anybody running c-16 in their street car? do the o2 sensors live long?
  71. Procomp head mini review.
  72. N-motion timing chain, too much slack? Video added
  73. Help me build the best boosted engine for my $
  74. LSx454 Header Gasket Question
  75. setting up 6.0 vette to reach the maximum HP
  76. New Katech Motorsports 550hp Crate Engine
  77. Does head gasket sealant really work?
  78. What really needs replaced/Done if you lost a bearing.
  79. ARP thread chaser... Can i barrow one PLEASE
  80. Will swapping to LS2 pistons make that big a difference in power?
  81. RHS Pro Elite 291cc/69cc Heads LS7
  82. Lifter Preload Specs?
  83. Livernois Motorsports LS Bronze Lifter Bushing Install Demonstration
  84. L76 Question
  85. MAF location question
  86. Engine Weight Reduction
  87. LS7 intake on LS2
  88. Need some suggestions on cam for new setup
  89. Comp trunion upgrade failure (Check yours)
  90. i am so confoused between cams!
  91. AES Announces Our First Year End Sale!!!!
  92. DOD delete front cover
  93. LS7 Rockers ???
  94. Cam phasing, oil cooler trouble Ly6 VVT
  95. LS3 Cam Help
  96. Livernois Motorsports LS3 Big Bore Block Sleeving Demonstration
  97. What direction to take? 402, 408, ect...?
  98. forged 376 ls3 vs forged lq9 408
  99. best ci for g8 gt twin turbo setup
  100. Cam Question
  101. VVT & Oil Pressure
  102. LS7 Lifter limits
  103. Holley hi-ram on 2011 camaro
  104. Precision Race Components – SEE Why We Build Superior Cylinder Heads!
  105. Link-bar Lifters - get in here
  106. Cam gurus come on in...
  107. head porting
  108. Sierra Speed Shop Eagle Stroker Kits, on sale!
  109. Max Effort Cam Only LQ4
  110. 5.3 crank swap question 12552216
  111. ls2/l92 problems
  112. cam help
  113. 5.3 with ls1 crank
  114. Cam & lifter change with afm delete?
  115. Reluctor wheel question
  116. Finishing my 408 today. Thoughts/Suggestions....
  117. Ly5
  118. Head studs or bolts?????
  119. 408 LQ9 build question
  120. Cylinder Head Question
  121. Cam gurus step in need ls3 cam help
  122. Mamo ported AFR heads
  123. LS2 Oil Pump
  124. Score !
  125. PRC 237cc Heads
  126. DOD delete diy
  127. dead cylinder, I am stumped
  128. Hp tuners / VVT help
  129. Turbo LQ9
  130. cam advice on 427lsx with trickflow 245 heads
  131. i need some advice on what to buy.. LFA or L92
  132. Target lambda with e-85 and LSA?
  133. LQ9 build help
  134. G7X1 camshaft specs?
  135. which rings for LY6
  136. Pat G or Tony Mamo or anyone else
  137. LQ9 budget build need advice.
  138. 370 build questions
  139. New to the LS engine, looking to do a swap or stroker
  140. Cheapest place to buy lsx block and callies magnum crank?
  141. Looking to do a 500RWHP N/A build
  142. recommended plugs?
  143. DOD Delete kits
  144. Cam shaft recommendation for 408
  145. if money wasn't too much of an object... what heads and intake?
  146. Aluminum 6.0L with windows above main bores?
  147. LSX 440 PRC 247's or LS7 265's ?
  148. Valve spring recommendation for LS3 heads on LQ4
  149. Head install...
  150. Ls1 valve covers on ls3 heads?
  151. LSX question
  152. Putting head back on...
  153. s3 swaps cooling issues?
  154. LS6 cam into Gen 4
  155. More boost or nitrous plus boost
  156. Help with Avalanche Motor Issue
  157. Can anyone help, please!!!!
  158. LS3 rocker arm stands....what am I missing?
  159. thinkin.about.going from a 408 to a 434 or 441lsx
  160. been a long time coming...
  161. LSX carbed intakes?
  162. Help required Preload
  163. 53 boring
  164. 2006 Livernois Z06
  165. A quick Dyno of my HC E85 Z06
  166. Cam question
  167. Push Rod length
  168. i am looking for oil pump
  169. ls2 swap/ fuel mileage
  170. LS3 build
  171. Installed Harland sharps, now...
  172. Can Someone identify these Rods?
  173. Difference in cnc ported heads vs non cnc
  174. ARP Rod Bolts
  175. what 6.0 ls motor for boost and how much can it handle
  176. L92 / 6.2 Engine Noise HELP!
  177. Cam swap help
  178. How much can you mill L92's before Intake alignment issues?
  179. Does anyone know what cam this is?
  180. looking for good cam for c6 LS2 Corvette
  181. 12,xxx Miles, Change Valve Springs?
  182. Champion 800+hp emissions legal 502
  183. LS7 small bore vs PRC 260 ls3 heads on 427
  184. New 6.0L setup..
  185. Is Crankshaft Weight A Concern?
  186. Cam Induced Velocity Question(s)
  187. should i add more pressure?
  188. 370 truck motor
  189. New GM LS3 block
  190. 370cid ls3 heads cam advice ?
  191. SDPC 413 LS2 Shortblock???
  192. Replacement build
  193. Black Friday Deals and Sales
  194. Harland Sharp LS trunion upgrade review & how to
  195. looking for cam for my 2005 corvette
  196. Crank reluctor wheel swap?..
  197. Piston Vendor Comparison?
  198. Best oil for custom carbed Ls7 running E85?
  199. Rebuild or pull another?
  200. LS2 Stock looking for some help in modify help
  201. Realistic cost on l92 swap into 99 SS labor is free
  202. LS2 timing chain dampener
  203. Anyone successfully rewind a phaser spring?
  204. LQ4 with milled L92's and TSP 224r - PTV issues?
  205. Ls2 swapped camaro z
  206. Please help identify this piston
  207. Sudgestions on cam swap?
  208. L92 shortblock 113k miles $1200 -Too much $$$. .???
  209. LS3 with stock exhaust manifolds cam?
  210. hydraulic lifters issue..
  211. Please Help Ls3 (480hp) going into 66 GTO
  212. Ls1 knocking.
  213. LS3 valvetrain questions
  214. Can LS9 head gaskets be reused?
  215. will my prc 227's do well on a 427 ls3?
  216. variable timing
  217. Lets Play "Name That Cam!" And the Winner Gets A Free Camshaft!!
  218. 5.3 cam piston to valve clearance
  219. LS2 crankshaft replacement question
  220. 20% off sale on EVERYTHING
  221. 3 bolt cam on 2011 VVT Silverado need some advice
  222. Looking for the best cam from texas speed performance
  223. Need advice for my 408 build
  224. 500rwhp LS2 6.0L & Auto... Possible?
  225. Gen iv 5.3 help please
  226. iron or ali.... which is better
  227. LS3 deck height.
  228. ls7 heads on a ls2/3 block
  229. Adding a cam to my Ls3. What should my power expectations be?
  230. please help identify these 'ls7' crankshafts
  231. Ls2 rods
  232. LS2/LS3 topend build - Shortbloack clearence questions
  233. Ls2 build, not sure which way to go
  234. ly6 exhaust valves in 317 heads
  235. Cam selection, 6.0/LS3 build
  236. Warhawk 15* LS...
  237. Denali Ideas
  238. Ideals for a 6.2 build
  239. VVT opinions & help please!!!!
  240. lq4 bolts?
  241. Best Spark Plug for Cam Only LS3
  242. Is 0.070 PTV intake clearance too tight?
  243. motor plates
  244. File Fit Rings are to Include.. Napier Seconds...Right?
  245. 427ci stroker install for a Pontiac G8
  246. 4 Pattern Camshaft?
  247. $600 a good price for a ls2 block?
  248. computer & wiring help for ls3
  249. Ideas on how to salvage my TFS 225s?
  250. LS3 timing chain tensioners: differences?
