PDA
View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Need some guidance
  2. LS2 in a 98-02 Camaro
  3. LS9 oil pump
  4. front mount distributor
  5. Head bolt swap to studs
  6. Crank shaft timming gear (how do you get it off)
  7. Need a few part numbers to put an LS3 in my F-body
  8. head gasket thickness/823-LS3 heads on 6.0
  9. Question about combo & horsepower
  10. cam question
  11. l92 or Dart CNC 250 heads
  12. LS3 cam choise.
  13. LSA/LS9 part numbers?
  14. Bore/Stroke Idea
  15. LS2 with L92 heads and LS3 intake/tb
  16. Does your L92 Block leak oil??
  17. LS7 manifold options
  18. 416 at Idle
  19. L33, stock bottom & new cam...mill the heads? (yes I searched LOL)
  20. Limitations of a Solid roller for street.
  21. Build Date on Heads
  22. questions to those with 4bbl th bodys on your cars?
  23. Can someone tell me the valve drop on a stock L92 head?
  24. Need help to identify this GM cam
  25. LSX454 Crate motor
  26. What heads/cam/intake for a 402?
  27. Touch-up wall finish for stock LS2 piston/ring combo?
  28. LSX nitrous piston
  29. Quick question
  30. 40X ci engines w/ head/cam combos post dynos
  31. link bar lifters
  32. reluctor wheel options 24X or 58X
  33. Lets get me h/c/i for 404 ls2 on a budget.
  34. Head and Cam recommendation for ls2- Input
  35. L92 Alternator bracket and L92 Harness w/LS1 Accessories
  36. BRP oilpump pickup girdle
  37. 6.0 vs 6.2 LS3
  38. L33 cam in a 2000 GMC
  39. F/S lq4 l92
  40. Afr 245
  41. Wanting to convert DOD lifters in LS4 to Non DOD lifters
  42. lsx engine ( need advice )
  43. stock 243 heads of gto?
  44. Milling LS3 heads
  45. thermostat help
  46. Dipstick problems
  47. vibration on 402 at 2100-2300 rpm
  48. 650 hps in a 416 l92 heads n/a pump gas
  49. C100 connector
  50. LS3, how much you can rev it with standard infernals?
  51. need help identifying cam sensor pins
  52. cutouts
  53. Calling All Cam Guros
  54. LS7 Solid roller cam ?
  55. ls3 cam change?
  56. LS2 Clunking Noise When Staring Engine
  57. New TBSS looking to get a cam what size???
  58. Anyone got a spare wiseco piston 6462F125-5016C
  59. Compression Calculation
  60. New crank from GM
  61. Dual or Single beehive?
  62. ls3 heads, intake and injectors on forged 370 going into a 2001 c5 corvette question
  63. Quick PTV ??
  64. Can I run a LS3 with LS2 harness and PCM?
  65. Used LS2 block F/S?
  66. Anyone have insight on these guys?
  67. 6.0 Liter Long block
  68. fast 30462-8 injectors??
  69. Can I run ported LS3 heads on my 370CI LS1
  70. 408 on a budget questions
  71. cyl. Volume LS2 402 ????
  72. LQ4 Questions
  73. 09 G8 GT bank 1 and 2 code violations (after kooks install)
  74. For those who are running a front distributer
  75. would this cam be ok 4 l92 heads?
  76. correct pushrod length
  77. ARP head stud part number for 6.2 alum block?
  78. Change of plans: Cam and piston choice questions.
  79. break in process...
  80. Cylinder #7 misfire at idle only!! TRIED IT ALL!! help please
  81. Cam Discussion New LSL Lobes from Comp
  82. Comp 227/235 LSL Cam
  83. Shortblock question/help
  84. The new Lunati LS .660 lift dual valvespring kit????
  85. Take a look at this and tell me what you think.
  86. Oil pressure issues (LQ9)
  87. ls2 injectors
  88. Ls9 NRE video.
  89. Trick flow out of the box modifications.
  90. Which CamShaft Is Best For A 408?
  91. Reluctor wheel swapping
  92. 2010 camaro ss hypertech
  93. 823 heads on a lq9 help
  94. ls7 heads
  95. Crank dowl pin. need help Dragonslayer
  96. New motor options - opinions needed
  97. oil pan issue
  98. The Forum Wars - My350z vs. Stangnet
  99. Z06 Engine Build Movie
  100. Safe N/A Pump Gas Compression SCR/DCR
  101. how much power am i lookin at??
  102. any luck with getting an ls9 bare block and ls9 heads ?
  103. '76 K20 Engine Swap
  104. tfs cnc 225 head flow #s ?
  105. 408 Stroker cam help
  106. Head studs or bolt
  107. First LSX stroker build....HELP!
  108. what heads and cam for LS7
  109. Harland sharp rocker? Opinions.
  110. timing chain Dampener New VS Old
  111. l92/ls3 internal motor questions
  112. Did I instal my heads wrong?
  113. VVT removal on L76
  114. PCV and crankcase pressure.........experts come in
  115. Anyone built 482 LSX GM?
  116. Anyone sell the VVT single cam bolt? Or know where to buy one?
  117. 454 LS2 build
  118. My 416 Build - GTO
  119. ls7 lifters?
  120. WCCH LSX-LS7 heads - lotsa pics
  121. Has anyone line bored a lsx block??
  122. lsx tall deck block
  123. lq9 with ls3 heads help!!
  124. Istalled my new cam. (VRX5)
  125. TF CNC 225 flow over .600?
  126. LQ4 - L76 Clone
  127. Lsx ls3 head vs l92 head
  128. Rear crankshaft oil galley plug
  129. Valley Cover seals part # ?
  130. Using truely gapless rings...
  131. mezerie pump and new belt?
  132. Need help re-instaling Head Studs
  133. ETP Heads and proper rocker arms
  134. LS3 tightening torques
  135. lq4 with milled l92s what compression?
  136. water pum and pulley questions (gm ls3 accessoery drive)
  137. Gen IV block + Gen III heads-----Which head bolts?
  138. My VA Speed Engine Build
  139. Valves cover problem !??
  140. Piston fly cutting and cam help. LS2
  141. 3 to 4.5" reducer Do they make one??
  142. LS2 Rods which way to install
  143. flycutting pistons strength questions?
  144. ARP rod bolt question
  145. head dowel pins
  146. Zero oil pressure pump failure?
  147. l92 piston notching?
  148. LG Super Cool Radiator vs Ron Davis Radiator
  149. LS1 swap to LS3.
  150. ls3 vs l76 intakes
  151. Help with TFS/Harland install
  152. Edelbrock Vic Jr LSR head
  153. Yet another L92 question
  154. Aftermarket Block
  155. Has any one used the TEA L92 CNC Stage 2 heads
  156. How to get a little over 500fwhp from 6.0 LS2
  157. What the hell is this part, and what does it do?
  158. oil pickup bolt size
  159. L92 cam phaser...
  160. installing timing chain stabilizer
  161. Do 11/32" Pushrods fit GM Heads?
  162. Sponsors: what cam for LQ4
  163. How to identify LS3 valves?
  164. lq4 swap cooling system question
  165. Replacing valve springs and retainers
  166. motor oil article
  167. LSX-dr thread
  168. LS2 timing chain?
  169. Use a new oil pump?
  170. motor missing badly
  171. Gen 3 LS1 in a Gen 4 vehicle?
  172. LG G6XE or G5XE Cam
  173. L92 in an offroad buggy, oiling problem and needs rebuilt
  174. Drag car build
  175. help me go fast next year ls3!!
  176. Parts to spin higher than 7000RPM+???
  177. 402ci w/l92's back w/new numbers.
  178. 427 for $10k is it possible?
  179. To 9 sec NA car. What is best combo
  180. L92's.. are they worth it?
  181. FI LS3 - 1.85 rockers? Or deck the heads?
  182. rattling noise..
  183. Tsp 402 ! ms4 or vr7 ????
  184. lq4 rods and pistons
  185. Backfiring after camshaft install
  186. nitrous piston and boost
  187. TSP TX-giant cam in LS2 402 sound clip....
  188. TBSS WHAT'S A good cam for DD and some spray..Pred Z ...Pat G...
  189. L92 CAM and other info to get to 540-560 hp
  190. how far down mill 243's
  191. Crate Eng VS from dismantler
  192. L-92 piston rock?
  193. 2007 L92 Escalade no DOD?
  194. Ls2 cam only numbers??
  195. Which one 416 or 427 with a l92 block?
  196. Building a iron 370.... buy a new block or search for used block.. Pros/Cons?
  197. Blueprinting a build
  198. Tuning Problem (VE Table)
  199. cost to change reluctor
  200. 2010 camaro engine ls3 up for grabs
  201. Issues with HS rockers & AFR 205s
  202. check my numbers! PTV & push rod length
  203. Which Cam Lobes to Use for 7000rpm+ LS7, w/ Stainless 2.205" Valves?
  204. LFA compression?!
  205. This Kit ok?
  206. Ls2 and Ls7 Cam Part #'s?
  207. LQ4 Head ARP head bolt Q's
  208. lq4 bore?
  209. 12:1:1 comp on a ls2?
  210. What heads to buy. Help me out tech
  211. possibly extremely stupid ?s but cant find the answer
  212. Valve Foat--Comp Shaft mount rockers---
  213. Who has a stock, or lower than stock idle in their big cube motor?
  214. Valve Stem Heigths Are Different - L92
  215. On average what does a stock rebuild....
  216. 408's plz come in
  217. OIL PUMP, engine builders, SDPC, someone help?
  218. Header???
  219. LSX-LS3 heads info
  220. 4.25 inch stroke L-92
  221. Rust on some engine parts, am I ok?
  222. Anyone make DI Heads?
  223. Great LS2 Stock Numbers
  224. 425rwhp possible with?
  225. LQ4/LQ9 gasket list
  226. need part number for mls ls2 head gaskets
  227. Virginia Speed 656hp 427
  228. ls2 gen 4 i think???
  229. Head Gaskets
  230. LY6 cam upgrade
  231. Ls3 heads which patriot springs??
  232. Where can I get a 24x wheel?
  233. Clearances
  234. lq4 compression estimates??
  235. 6.0 lq4 in a 1998 SS camaro
  236. Has anybody dealt with Gulf coast racing engines?
  237. coating
  238. reuse cometics??
  239. need oil pan bolts and one windage tray nut
  240. Anyone using piston squirters on a RHS block based build?
  241. which cam would you run asa cam or gm hot-cam
  242. Rough Start/Idle -- What's going on?
  243. LS3 drive by cable??
  244. Help. Oil on bolt.
  245. looking for a single junk bare L92 head
  246. 370 help
  247. What is a 04 lq4 consider
  248. rent l92 flycutting tool?
  249. stock bore pistons w l92 reliefs
  250. Ls1 parts list! Need help!
