View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. I need a built LS2 , who should I buy from?
  2. LS2 & L92 Engine Assembly Screensaver
  3. Highest lift anyone is running with stock LS7 rocker arms?
  4. Up close with the LSX cutaway
  5. Tans Am Formula
  6. PVC issues
  7. LS7 vs L92 stroker install on a C6
  8. LQ9 and the L92/L76 combo?
  9. How much more actual power does a COMP 228-232 make over the 224-228,at what cost ?
  10. 220/323 For L92/427?
  11. zl402 into a 98 camaro?
  12. L92 head gaskets
  13. basic info wanted
  14. Any strokers w/TFS 225cc heads on them
  15. Katech cam sensor harness wire swap??
  16. 408 + L92 + CTV lifters + stock rockers = What RPM? and what to do to Peak up high?
  17. New Lsx Block
  18. LS2 Cam ??
  19. Patriot stage 3 heads
  20. 402 swap questions, need help fast plz!
  21. strongest 6.125 rod?
  22. L76 L92 comp. ratio
  23. Morel link bar lifters LS1/2/6 picture
  24. HPE's new S2 cam (dyno graph)
  25. L-92 70cc chamb -28 dish pistons What head gasket?
  26. 416 l92 with flat top pistons
  27. 408 L92 231/235 LSK CTSV is back on the dyno...
  28. Stock LS2 cam suggestions
  29. My Comp spec'd L92 cam
  30. A couple of Questions
  31. LS7 headed LS6 427 stroker questions
  32. Ls2 402 idle problem
  33. Power Estimate?
  34. L92/L76 + Thunder CheatR in an LS2 = ???
  35. TFS 225's **PICS**
  36. Fastest LS7
  37. 4L80E w/05 gto LS2 issues.
  38. PRC L92 CNC Head Vs. Stock L92 Head Results
  39. SLP L92 Cylinder Head/Manifold Package
  40. 402 for around 6-7500 bucks
  41. L92L76 combos post your details
  42. 4.1 stroke guys... come on in....
  43. Does cam size affect exaust smell?
  44. How hard can you spin a 402?
  45. 10.5:1 on a 402/L92/L76<--that bad??
  46. 402/L92/L76= what stall speed?
  47. L92 stroker 1/4 mile times?
  48. Where and WHo had best price for ??????
  49. LS2 Heads???
  50. 440 bbc out 408 L92 in
  51. L92 crate engine
  52. 2007 Reluctor wheel
  53. I am lost, need help LS7 L76 setup????
  54. 414 with l92 heads
  55. who's cam for l92 heads,VENGEANCE,LG motorsport or TSP?
  56. L92 head and intake swap
  57. what do you think about your 408?
  58. Help Getting In Touch With T.E.A.
  59. Boost Friendly Motor Build Help!!
  60. 04 GTO needs a cam, any suggestions PLEASE!!
  61. What does it take to put a crate LS7 into a 2006 C6?
  62. trik flow heads and huge cam
  63. best initial mods?
  64. How big of a cam do you need for 550rwhp on a LS7 in a 99 SS A/4
  65. LSX motor
  66. L76 intake w/injectors Who has them in stock?
  67. What kinda piston rings on 6.0L
  68. 402 w/ 250/258 .580/.580---heads??
  69. L92 vs. LS2 v. LQ9 (500rwhp DD)
  70. New"B" with a quick rocker arm spacer question
  71. Scoggin Dickey's New Look On The Web!
  72. so whos making the most power on an ls2 block?
  73. LQ9 shortblock and L92 heads
  74. Some L92 + cam engine dyno numbers
  75. Small Cube L92 Heads?
  76. Norris Motorsports Warhawk Block and LS7X Heads Recieved - Project Moving Ahead
  77. Good deal on 6.0's?
  78. LS1/LSX blocks, heads, cams, manifolds, and rotating assembly: HELP!
  79. LS7/L92 shortblock
  80. Anyone Sellin' Their Stock LS2 TB?
  81. LS7 % TPS at idle
  82. LS2 & Roller Rockers
  83. 6.0 liter and l92 heads
  84. Whatever happend to.......
  85. Random LS7 thoughts?
  86. Help with CR, quench etc...
  87. LS7 technical specifications
  88. Maximum RPM on stock bottom end LS2?
  89. Cam Spec's for L76?
  90. 6.0 Engine Help
  91. Best compression for 408.
  92. LQ9 Parts interchange.
  93. New L92 shortblock looks bad, need opinions
  94. more cam questions
  95. L92's for 3.9" bore coming soon?
  96. Cam specs
  97. L92 heads on a LM4?
  98. So who's ready for the LSX?
  99. 402 Specs =)
  100. 4.060 bore on ls2?
  101. My build thread
  102. GMPP LSX L92 L76 Crate???
  103. GM LSX really how much heavier than a 6.0 iron block?
  104. Help! Will LS1 oil pump fit a LS2 block?
  105. April GMHTP has a little message about L92 heads for 3.898 bore
  106. Out of box VS ported L92s
  107. Who's leading the cam race for L92/L76 combos?
  108. Watch Katech on SPEED Channel, Feb 22nd 9:30
  109. Katech Street Attack Z06 in Winding Road magazine
  110. LS& clutch or Spec3+ clutch?
  111. Best shortblock warranty from sponsors
  112. Cam Experts
  113. LS1TECH Sponsors, Shipping to Australia
  114. Ls1/2 Swap...what am I missing?
  115. L92 DynoJet Numbers Plus Plan B, C, D, E and F...
  116. 402 Motor Build parts list
  117. I'm floating the hell out of my valves
  118. Doesspeedturnuon inside......
  119. Double check my math please.
  120. LQ9 402 build w/ L92/L76-advice!
  121. those actually running L92s, what valves are you using?
  122. L76 Intake
  123. ET 245`s and Greg Good flow #`s
  124. 99 silverado swap
  125. LS2 bore variance
  126. 4" crank and pistons for the LQ4 ???
  127. ls2 rebuild kit
  128. What vehicles have the LQ4 and LQ9?
  129. Can LS7 crate motor be switched to wet sump for a C5?
  130. SS LS7 Headers
  131. Carb intake
  132. Anyone know this car?
  133. How to make 450WHP in a TBSS
  134. Jesel LS7 rockers Pics???
  135. LS1 crank?
  136. Video-Hear the new Cam/ET heads 408
  137. what thoughts on a cam for a 402
  138. weight of ls2 with l92'S???
  139. C6-R engine lubrication
  140. L76 Throttle Body
  141. LS2 aftermarket TB
  142. L92 milling and cam size
  143. LS2 TB Help
  144. l92 l76
  145. Aftermarket Options For The Ls7
  146. Has anyone had any problems with there 402 from SDSC?
  147. Quick Question for you l92's gurus
  148. So , what is this new R07 NASCAR cup engine ?????
  149. L92 Heads on 5.7 LS1
  150. Fly cutting the LS2 pistons for a cammed LS2 with L92 heads.
  151. What head gaskets to use on a LS2 with L92 heads
  152. ET 245`s flow down low (with pics)
  153. l92 heads what pistons?
  154. 427 Project Questions
  155. yet another L92 build - GET IN HERE!
  156. LS 7 vs LS X
  157. ls2 swap to 2005 silveradp
  158. TPS headers and connecting pipe.
  159. Difference Between Vette LS2 and TBSS LS2
  160. LS7 GTO Build Log
  161. Stroker Motor Guys: Compare the feeling of a 550(ish)rwhp to 400's!!
  162. 6.0 block Q
  163. MS4 Cam question
  164. LS7 lifter perload question.......
  165. Tuning for a C5.
  166. ls1 to ls2
  167. Heads for 408 build.
  168. Throttle Body for 408.
  169. Drivetrain Question for C5 Corvettes.
  170. L92 dyno numbers
  171. Livernois Motorsports LS2 540hp
  172. 2 Questions on porting LS2 intake manifolds
  173. Low oil Pressure
  174. 460 horse out of the question?
  175. Will L92 heads work on a LS2?
  176. T56 in 6.0 Iron Block?
  177. ls6 ls2 manifold
  178. L92 valve location
  179. Installing LS2 from GTO into 99-02 LS1 Fbody
  180. ordered a cam for my LS2
  181. LS7 Engine Differences
  182. Who makes 4.005 dished pistons?
  183. LS7 Dry Sump vs Wet Sump applications
  184. L92 crankshaft
  185. who's using SB2.2 manifold? where'd you get it?
  186. What rings for a turbo ls2?
  187. L92 rocker stands
  188. L76 ?
  189. O-ringed Block + Head Combo
  190. ARP stud help needed
  191. Bird 2 Pheonix project
  192. What is the stock LS2 injector size?
  193. Dished vs Reverse Dome pistons
  194. NEW L76 rear drive G8 Pontiac on sale early 2008....
  195. cam for 416 l92
  196. can i use the L76/L92?
  197. G5X4...good for a 402?
  198. L92 deck thickness...minimum.
  199. Which headers for 370ci 1 3/4 or step 1 7/8?
  200. Sponsors?? Has someone test flowed the L76 intake??
  201. Any Interest in LS7 Dry-Sleeve Blocks?
  202. FD Ls7 Rx7 at New Tech
  203. Anyone milled L92's and what cam on LS2
  204. Installing 4.00" sleeves into an LS1
  205. GMPP claims 30-40hp from breathing windows on the LS7?
  206. are these ls7 heads
  207. PVC on stock LQ9 w/ Dart 225 head....
  208. 6.0
  209. *408 FI build up-advice welcome
  210. Katech makes it into superbowl commercial
  211. need info on 408 andl92 heads
  212. Cam & High Compreshion ?
  213. Does anyone make
  214. high compression
  215. SCR and DCR on 408/L92 setup
  216. Why does the L76 have less hp than LS2?
  217. Katech Camaro SS street video
  218. 402 w maggie or 440 w/ LS7 - Build Options
  219. It's Christmas morning again at Katech
  220. TSP 402/408 SB Motors In Stock!
  221. 402s poping up all over
  222. ls7 heads
  223. Lifter suggestions for L92 408 build....... ?
  224. LS 7 Crate engine Gm part numbering
  225. N2O kit recommendations
  226. Where can I pick up a stock LS2 shortblock?
  227. Free Porn !!! Come on In !!!!
  228. Tpis 427 L92 Results
  229. 250/256 .644/.646 112 LSA in 408?
  230. Lifter and Rocker questions for L92 heads
  231. cam is finally in!! idle vid inside
  232. My 403 LS2 L92 L76 is finally running! [video]
  233. can i run a 4.130" gasket on my 4.030 bore
  234. L92 head bolts
  235. ARP LQ9 Part number help?
  236. 346 chamber heads(3.9 bore) on a 402 stroker(4.0)bore??'s
  237. Question for Brian or Matt @ SDPC
  238. specs C6 Z06 camshaft?
  239. LS2 with L76 intak, L92 heads and CZ06 cam setup
  240. .700+ solid W/factory ls7 heads
  241. Advice na monster
  242. L92 Video interview with GMPP
  243. connecting rod interchangeability
  244. L92 Truck intake questions
  245. LQ4 with l92 head how I can increase compression??
  246. What's the max the L92 block can be bored?
  247. Getting a 408 Stroker wanted to know a few??
  248. Spun Mains in 402
  249. l92 heads on a 6L iron block
  250. Who is answering the phones for SDPC??? looking for 402 or 416
