View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52
  1. BIG cube DD?
  2. Map sensor use with carb intake??
  3. Post Up if you are buying a set of L92 Heads for a 370ci or larger setup.
  4. LS2 Performance Intakes
  5. what are the LS7 427 stock cam specs?
  6. whats a stock ls2 shorty worth?
  7. ls1 or ls2
  8. Is it safe to go .030 bore on a LS2?
  9. Another Tach Issue
  10. Patriot Xtreme Gold Springs Have Arrived !!
  11. Junk?
  12. ***[merged]L-92/LS-3 / 6.2 L blocks core/liner shift***
  13. LS7 GM Intake vs. Sheet Metal?
  14. ls1 or ls2
  15. LS2/LS7 cam sprocket?
  16. 58x Reluctor and Crankshaft Position Sensor
  17. Heads/cam questions help needed
  18. Carb style or 90/90 intake for large cubic inch
  19. LS2 block question
  20. Ls coils.
  21. LS2 startup...worried???
  22. is the 454 ls1 Available for sale ?
  23. Spun Bearing
  24. Factory LS7 block price
  25. WOW ... nice setup for a 418 L92 GTO
  26. Recieved my L76 Intake.... this thing is huge!!!
  27. too much?
  28. I want a new set up
  29. ls2 402 idle clip
  30. Aluminum or Iron???
  31. What to do with PCV system on a L92 drag application?
  32. Corp Magazine article - Katech Street Attack Z06
  33. dynoed 408 with l92 ported heads and disappointed
  34. Are LS2 and LS1 plug wires interchangeable?
  35. LS2 intake questions
  36. ls2 402 install tach doesnt work.
  37. New 402 install my tach doesnt work help !!!
  38. Can you hear your electronic throttle body?
  39. 402 w/ L92 & L76 Pics
  40. ls2.. dry sump oil?
  41. LS7.R named Race engine of the year
  42. Ls1 engine harness work on a Ls7?
  43. LS2 98 Firebird 500hp what is top end speed
  44. LS6 heads "243's".. Can they be fixed???
  45. L92 heads flowing 374cfm & exh 250cfm
  46. Using LS1 heads on an LS7-Valvetrain noise?
  47. Advantages on carburated
  48. Overall height of LS2/LS7/L92
  49. Anyone done an LS2 swap into a 98?
  50. vegas emissions engine combination
  51. Anyone running larger than 427 on street??
  52. Anyone for a billet LSx block? (eye candy within)
  53. Patriot Announces Our NEW Gold Xtreme Spring !!
  54. Lingenfelter LS7 Camshaft Specs
  55. L76 compatible with LS2 intake manifold parts
  56. if you know about carbs, help please!
  57. ls2 part # questions
  58. L92 aftermarket valvetrain?
  59. How much timing is your 402 on.
  60. LS7 MLS head gaskets
  61. Need help on LH6 engine
  62. PCV Setup (LS1 Conversion)
  63. 402, 408, 412, or 418 LS2?
  64. LS7 retrofit running - very rich
  65. Details of the electronic throttle (wiring, internals)
  66. L92 heads/L76 intake on turbo car
  67. LS2 Crankshafts
  68. Solidworks drawing needed
  69. 402/TH400 cam grind?custom?who?help.
  70. Has anyone tried L92 heads on a 3.9 bore?
  71. L76 complete package arrived in the mail today!
  72. 418 c.i. L92 Short Blocks at Texas Speed and Performance!!
  73. Got the L92 Carb Intake today
  74. L92 heads/L76 intake
  75. L92 heads
  76. **** Carteks new LS2 " Ultimate " Street Package ****
  77. VIN Decode
  78. What is the recommended......
  79. CNC Ported Assembled 243 Castings $995 per pair !!
  80. 600+ SEMA Photos!
  81. LS1 -> LS2 Hows this look?
  82. LS2/LS7 Lifters
  83. L92 part Numbers?
  84. ls1/ls2 cranks??????????????
  85. L92 questions, need some help
  86. Installing a ls7
  87. 600 bhp and stock rod bolts...
  88. LS2 to LS7 conversion kit?
  89. lt1 to ls1 swap
  90. L92 Radius Flow Plate
  91. ported ls1 head on 402
  92. What to do With the heads?
  93. L92 Differences?
  94. TSP 402 runs strong
  95. L92 flow results with manifold.
  96. assembeled l76 intake (just got it)
  97. Best Heads/Cam Package for the money?
  98. Degree Cam.how Many Do It?
  99. LS2 Build question
  100. LS7 head stud kit question.
  101. looking to build a ls2 402 motor
  102. 6.0Iron 370 + L92 heads + Trex Cam + Valve Reliefs = will it clear PTV & make power?
  103. Are all GMPP blocks finish honed ??
  104. Does anyone have ported LS7 head photos and flow # ?
  105. L76 vs. L92
  106. Iron 408 in LS2 based vehicle???
  107. LS7 oil pan adapter
  108. boosted L76/L92 setup possible?
  109. Canadian Performance LS2 427 Shortblocks
  110. Canadian Performance 402 Shortblocks in Stock!
  111. Multiple misfire detected.....questions
  112. LS7 stock crank
  113. What is the part# for the L92 "longblock" &/or complete engine.
  114. Ls1 Vs, Ls2
  115. Solid vs poly
  116. ANyone hitting over 500rwhp with an LS2 stock bottom end???
  117. looking to get to 500rwhp
  118. L92 heads + 4" bore...
  119. Need help: 402 oil breather tank?
  120. Ls2 F Body Swap
  121. Any negatives on Hooker's on 427
  122. what ls2/ls7 combo would you build to BATTLE a c6 z06?
  123. Pictures of the GMPP LSX Block
  124. 5.3 heads on a 6.0
  125. what octane gas are you running?
  126. Cam questions for C6 A6
  127. LS7 rods for 80 bucks each
  128. What is the breakdown of the extra cost to build an LS7 motor versus an LS2 motor?
  129. Crank Bolt
  130. l92 heads question
  131. what goes here??
  132. Fuel system upgrades for LS2 427
  133. L76 manifold flow
  134. 402 or 418?
  135. Are there 47cc Heads OR other ways to get close to 12:1 CR on a 5.3?
  136. ls7 intake on ls1?
  137. 427 times
  138. Over 1 million dollars worth of engines in my shipping dept - pics
  139. OK... so realistically
  140. OK... where do i get these things?
  141. Found a Breather C6
  142. Flycutting needed to fit L92 heads on a stock shortblock LS2
  143. Roller rockers
  144. who is making 500 rwhp with a ls2 402???
  145. Need help with LS2 cam question,
  146. Need help completing 415 c.i. L92 build.
  147. Big cube/stroker forum?
  148. Could someone make a L76/L92 parts number 'sticky' .....
  149. E.T Heads
  150. new LS2 motor
  151. This should make for some discussion...
  152. LS2 or LQ9 pistons and rods
  153. ls2 cylinder head torque sequence
  154. Patriot Gold Spring kit and ls2
  155. LS2 vally cover?
  156. L92 vs Ls7
  157. PCV problems
  158. solid roller cam vs. hydraulic......power gains with the solid???
  159. Driveability/Streetability w/ FM13 or G5X3
  160. Any one 30 over on ls2 block?
  161. LS7 Shaft mount?
  162. Arethe 2007 Vortec Max 6.0L V8 VVT (L76) heads the same as the (L92) heads ??
  163. L92 or LS7 block? What heads/intake? Need to make a decision.
  164. LS7 Cam Swap Questions
  165. How can you tell if its LS2 or LS6 block?
  166. 418ci L92 from TSP
  167. air consumption for heads/cam LS2 364
  168. ls1 cable mount for ls2 intake
  169. knock sensors quesiton LS2
  170. Will the L92 head/L76 intake combo render other H/C combos obsolete?
  171. Finally my intake!!
  172. walkthrought for adding ls6 knock sensors to ls2?
  173. 414 L92 Long Block
  174. LS2 stock shortblock cost
  175. LS7 or 402 solid roller set up
  176. Breather??
  177. L92 valve angles?
  178. I need factory LS2 rods and pistons
  179. RHS Heads
  180. need help identify ls engine
  181. Anyone with the L92 heads on a 6.0L?
  182. How high can you safely rev a 325 CI Bottom End on a daylie drive basis ?
  183. LS2 Carb Result N/A
  184. Still Looking for LS7 Valves
  185. Car Runs!!! Quick Question...
  186. 427ci GMPP LS type block?
  187. ls1 vs ls2 weight?
  188. Dampner usually included in a long block?
  189. ls1 heads on ls2
  190. Head Install... Just double checking...
  191. simple ls2 head question
  192. Crap! Engine problems.... please help!
  193. Corvette Magazine Article - Katech Street Attack Z06
  194. i dont know why noone will answer my questions...
  195. UMI 90mm throttle bodies back in stock
  196. Looking to build 6.0l stroker
  197. ls7 crate engine question...
  198. Pcv
  199. LS1 differences between the 98-02 years?
  200. Should I get an LS2?
  201. LS2 PCV Delete???
  202. Fly-cutting for the L92 heads - Question
  203. ls2 intake what do you think
  204. for a precision t88... etp or ls7 heads???
  205. Anyone using the GMPP valve covers from Scoggin Dickey??
  206. raising compression on L92s
  207. 572hp/505tq LS2 dyno story now online
  208. ls7 cam specs?
  209. LSX cam swap
  210. LS2: 12-14grand, what do I get?
  211. A little birdy brought me something nice
  212. if using ls2 longblock
  213. Low RPM "shudder"- also, hard start at times.
  214. 2004 silverado SS heads
  215. porting with stock cam
  216. how can i tell if i have the different reluctor ring?
  217. World Warhawk Production Blocks
  218. TSP Dart Stg II fixed?
  219. 427 ci in a Firebird Trans Am
  220. LS7 Heads and Intake on an LS1, Will this work?
  221. LS2's in the Trailer Blazer SS's, LS2 guru's come in
  222. check this out...
  223. Listen to sound clips of the "Street Attack Z06"
  224. How strong are the stock LS2 head bolts
  225. tranny and rear end for an ls7?
  226. L76/LS7 manifolds
  227. How Much Was Your 408...is This About Right??
  228. what sponsors have L92 heads?
  229. ls1 coil packs on an ls2
  230. Will the new LS7 race lifter handle the Comp 977 springs??
  231. LS1 to LS2 :differences
  232. What extra is needed to go LS1 to LS2 ?
  233. Help me choose a cam.
  234. Have you heard of this? Expert opinion please..
  235. Warhawk LS7X 12deg.
  236. inspection(s) and cats
  237. Resleeved LS2 or Stock LS7 Block for Max effort NA 427?
  238. Plate for 500 plus cubes
  239. LS7 and LS6 Cam and Crank pickup and sensors
  240. Max stroke on a L92 with stock sleeve?
  241. LS2 build Question
  242. LS2/L92 H/C vs. LS1/LS6 383
  243. picking a cam
  244. lq4 heads VS 5.3 heads
  245. On a Cammed/Full exhaust ls7....
  246. LS7 head compatibility
  247. LS7 torque values
  248. L92 and LS7 size?
  249. Anyone using Rhoads lifters?
  250. couple questions on the ls7...
