View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52
  1. new iron block from GM???
  2. L92 in a LS1 F-body?
  3. Lsx engine builders
  4. Wanting to know the engine build codes.
  5. 480ci lsx?
  6. How to figure engine size?
  7. .030 gaskets w/ l92s on lq4
  8. Gmm Perf block???
  9. What is missing???
  10. Need a little help.....
  11. What's you opinion on an electronic throttle?
  12. 3valve head for genIV
  13. Silly question - swapping LS2 throttle bodies...
  14. Porting LS7 heads
  15. Truck intake for L92 heads
  16. ? for those with stock T.B. mounted upside down...
  17. front of LS2 oil galley plug?
  18. bearings
  19. LS7 Heads offered Unported?
  20. 402 Short Blocks @ Texas Speed and Performance!!!
  21. 4.1" or 4.125" stroke possible in a stock LS2 block?
  22. this bore and stroke...vs...this one ??????
  23. How long are LS7 sleeves??????
  24. Best method to seperate LS2 intake?
  25. ls7 nitrous limits?
  26. Will LS7 Rockers Work on L92 Heads?
  27. HPE Big Nitrous ZO6 update
  28. L92's Came in
  29. How much power out of this LS2 418cid?
  30. C5 engine cover on Fbody ls1
  31. Which heads for a naturally aspirated 402 LS2 drag application?
  32. All aluminum truck motors ?
  33. LS2 RPM Capability
  34. LS7 Swappers ?????
  35. New toy in the Noyzee Toy box! ls???
  36. Blue Devil Powertrain....
  37. TSP LS6 Stg. 2.5, any info?
  38. 402 help
  39. Do I need coolant crossover pipe ?
  40. Will LS1 coil packs fit on an LS2?
  41. Is 500rwhp possible with a H/C LS2?
  42. Help with engine build....
  43. Flipping LS2 throttle body
  44. Ls7 is a badmofo
  45. LS2 headgasket/piston clearance question
  46. LSX Long Block Proposed Price?
  47. Max bore on a ls2???
  48. valve keeper
  49. L92 Intake manifold Update
  50. Who Makes the Most Durable, Reliable and Best Assembled 402 LS2 ?
  51. what is l92
  52. LS1 computer on LS2/L92
  53. L92 Combustion Chamber
  54. Got My Ls7 Carbed Intake Today
  55. LS7Harland Sharp rocker mod info.
  56. Where the heck can I get a....
  57. ls6 vs ls2 block differences?
  58. LS2 head gasket on a 4.040 bore????
  59. whats this set screw called?
  60. 402 cid LS2 Short-Blocks In Stock at Texas Speed!
  61. LS7/LS2 Intake Manifold Porting and Tuning Results Inside
  62. First Warhawk Release
  63. Newbie:bolt pattern...
  64. Here are my bare casting L92 flow numbers
  65. Is this hp correct???
  66. HELP! firing order for 454
  67. anyone have the re-worked AFR heads from TEA?
  68. PRC Springs
  69. 6.0L head gasket bore for a 408???
  70. L92
  71. any l92 short or long block assemblies yet?
  72. LS-2 coolant crossover question
  73. fuel rail connector,where from????
  74. Ihave 2 L76 /L92 intake in my hands
  75. Straight from SDPC:
  76. ls2 rod bolts vs ls6 ones
  77. LS2 LS7 CAD Model
  78. MS4 v. Torquer v.3
  79. L92 rockers
  80. What rockers with my heads?
  81. Need to know
  82. LQ4 block?
  83. 402 vs 427?
  84. Lingenfelter oil pump
  85. Wilson Sheet Metal Intake
  86. GM new LSX Block 480ci?
  87. Front cover, LS2 or LS7?
  88. Whats the revision on LS7 lifters?
  89. for those of you looking for LS7 heads w/ Jesels
  90. Intake for L92 heads in an F-body?
  91. psi 1511 with high lift?
  92. TEA trick flow 225 heads came today....
  93. Ls7 Rocker choices
  94. Ram Dual Disc Clutch
  95. Gas Milage.. 402 vs 427
  96. 07 LS2+ cam gear/mounting change
  97. 6.0 block
  98. Cam shaft for ls7 headed 441
  99. LS7 factory intake vs. sheet metal?
  100. 4.030 bore???how about 4.040 ls2
  101. LS7 Block/Oil Dip Stick?
  102. Racetronix LS1 to LS2 cam sensor harness correct?
  103. 402 oil leak?
  104. Best price on McLeod clutch for the LS2???
  105. Max Compression on a 5.3 Gen IV engine? ( Patriot heads preferred )
  106. HELP: LS2 TPS & Throttle actuator
  107. Edited: B&B bullet cat-back for c6
  108. Precisely what WILL the L92 heads fit? And LS7 heads fit?
  109. GM p/n for a COMPLETE L92 head?
  110. question on ls7 headers
  111. Did I just find the L76 complete Intake Part Number with rails??
  112. LS2 Head gasket on 4.0625 bore?
  113. what do you think???
  114. Flywheel cover T56 for LS2
  115. Smaller is better trend, what do you think about this???
  116. The FULL LS7 Cam Specs
  117. ls7 in f-body
  118. C5R heads & LS7 Carbed Intake ??
  119. New 6.2 + boost?
  120. who does 427 AZ
  121. UMI 90mm cable throttle bodies back in stock
  122. need ideas on reasons for broken ls7 rockers?
  123. LSX cast numbers?
  124. Bore size???? how big??
  125. Knock Sensors on LS2
  126. Patriot LS6 Stg III heads with big cam
  127. Head Gaskets
  128. Looking for LS7 Cyl Head Flow #s & Dimensions
  129. Timing Chain for LS2
  130. Will L92 heads fit?
  131. is the wilson manifold ready to go?
  132. etp heads
  133. L92 heads on an LS1?
  134. LS2 for road racing???????
  135. some Q's
  136. another ls7 rocker failure
  137. LSX drawing oil from PCV, catch?
  138. etp LS7 heads & 408...anyone done it?
  139. 90 mm tb 'top in' vs 'bottom in' results
  140. LS2 intake material
  141. L92/l76 402 cam??? Now I need it.
  142. TBSS Cam ???
  143. What is the LS7 valve spring install height?
  144. LS2 Fuel Rail cover Part #'s
  145. MS4 cam need flycutting?
  146. Jesel on GM LS7 head?
  147. TSP Motors In Stock!
  148. C5 and C6 transmission mounted behind driveshaft???
  149. L76 intake is in my hands!!!!!
  150. Anyone make new fuel rails for the LS7 Intake?
  151. Lunati 60512 cam?
  152. Will LS1 stroker parts fit an LS2 block?
  153. Katech Value 427 dyno test - 3 cams
  154. ls7 compression ratio 11.8:1?
  155. LS2 427 Bearing Clearances?
  156. LS7 valve springs on 317 6.0L heads
  157. Help w/ my LS2........
  158. All motor ls2 times????
  159. mahle pistons/eagle rods
  160. Moving LS2 PCV Vent
  161. How to get a 6.0L from a 5.3?
  162. need valve springs help
  163. LS2 Stroker/Smoker - Does your's smoke?
  164. need part number help!
  165. Cartek 366ci anyone?
  166. Stock LS7 Pushrod Length?
  167. 228/230 XER vs TRex in Iron 408?
  168. Ls5?
  169. Block Sleeve length LS1, LS2, LS6 LS7, L92?
  170. Katech sneek attack 346, 8000 rpms?!?
  171. Need complete list of what is needed to convert "LS7" to wet sump.
  172. Need help deciding on SB
  173. Which power adder for 07 z06?
  174. L92 Block vs. LS2 resleeved to a 4.125 Block?
  175. VIDEO: HPE C6Z w/ fogger
  176. Looking to purchase ETP LS7 4" heads
  177. L76 manifold on Ebay...
  178. Actual difference in Ls7 intake bolt pattern and C5R bolt pattern
  179. LS2 nitrous
  180. 408 n/a
  181. Is anyone selling the L92 heads?
  182. L92 vs LS7 intake?
  183. Biggest valve for a 4in bore???
  184. LS7 Heads, what size is the intake runner?
  185. can a 402 do over 500 rwhp?
  186. 6.0L Iron Block from Truck Questions?
  187. specs on ls7 cam?
  188. My LS7 Valvetrain Info
  189. How much difference is 14cfm?
  190. Lingenfelter 366 CID LS2 to a 427 LS2
  191. LS7 coils ?
  192. spring kits for ls7 gm head's
  193. pondering the idea...whatcha think
  194. Trak recipie??
  195. LME LS2 shortblock, to buy or not to buy.
  196. Ls2 402 plus ETP small bore LS7 heads- Anyone?
  197. ls7 in a c5..Header Q??
  198. Eagle crank issues
  199. Most recomended rebuilders in SE US
  200. F-Body with LS6
  201. Anyone use the adjustable LS2 timing chain
  202. This might have been talked about but I was wondering some info on LS7 block
  203. What else Do I NEed?
  204. 6.0 GTO ideas. What's your opinion?
  205. Ported L-92 Heads
  206. Holley 90mm Throttle Body
  207. need your ls2 opinion
  208. Anyboby Mock up a LS7 head on a 4.060 bore?
  209. Livernois Motorsports tests the GM L76 and L92 carb manifolds for GMHTP Magazine
  210. ls7 potential
  211. What do you think about this set-up (LS2 402)?
  212. Rattling Sodium Filled Valves?
  213. LS7 Crate Engine vs Service Engine?
  214. Strength of ls7 titanium rods?
  215. CAn I stroke
  216. LS7 ac compressor
  217. ls2 stroker/l92 set up
  218. LS2:Pistons, Rods, Crank suggestions?
  219. 3.75" Stroke Crank?
  220. Need Help On ls7 FI Build up
  221. Katech Street Attack Z06 w/World Challenge Hood
  222. LS2 GTO Potential?
  223. Fuel questions?
  224. SERIOUSLY! I am ready to pay for my parts!!!
  225. stock fuel system
  226. exhaust ports
  227. L92 intake?????
  228. remote oil adaptor for LS7
  229. help needed TBSS LS2
  230. head/cam for 06 GTO
  231. how to block dod holes?
  232. LS7 ported intake Dyno info
  233. stock 6.0 GTO times
  234. Putting an LQ4 6.0 in a 98 Camaro...
  235. what parts for a 470bhp ls2???
  236. ls2 manual tb's which is best???
  237. Warhawk Progress
  238. Nice intake manifold...
  239. Cam for LS7 Heads... Help Needed
  240. Excessive blowby ???
  241. l92 comp. question
  242. Do heads make much of a difference on a stock displacement LS2?
  243. Cylinder Length
  244. LS7 into 65 chevelle Questions
  245. L92 Heads/Intake - Cam Question
  246. how do you take a fast 90mm intake apart
  247. LS7 intake BOLT TO LS1 heads
  248. ls2 chain slack fix?
  249. power difference between 402ci & 427ci w/same heads and cam?
  250. How much power from 441"
