- Starting my Mamo Ported FAST90/NW90 + Custom Ground Mamo Cam upgrade in LS2 402.
- anyone got a ls2 402ci longblock from wheel to wheel in michigan?
- AFR (1510) 205cc and AFR (1660) 225cc Heads In Stock
- LS7 Heads! 1 Set on the shelf!
- LS7 Block questions
- LS7 Camshaft in a LS2 Engine
- LS2 Water Pump Flow #'s?
- 06 C6 Dyno Bolt-ons
- LS2 Pistons
- LS7/Z06 manual
- LS7 In F-Body
- what radiators are you ls7 guys running?
- warhawk block, what LS style is it?
- Finalizing LS2 Build and Need some expert help
- ProCharged C6 Z06?
- What cam match to AFR 205 heads and headers and tune will get 500rwhp on LS2 C6 Coupe
- LS2 exhaust downpipe with no converter...
- L92 valve to cyl wall clearance w/4 in.bore
- will a FAST TB fit a LS2 intake?
- Calling PatrickG /PredatorZ - Experts??? - Please help with cam selection
- LS7 intake manifold with ETP C5R heads, will the intake fit?
- Question for Anyone with a LS2 stroker and Dart 225 Heads
- Finally results from ETP’s LS7 style heads
- LS1 bits that fit LS2 & LS7
- Rubber PCM Seals?
- LS2 connecting rod Q?
- LS7 Intake Manifold.
- Windage tray LS2 402, is shimming ok?
- Yellow springs
- what is needed to fit LS7 topend in LS1 camaro?
- ls2 crankshaft
- what is the c5r capable of?
- Springs for ls7 heads?
- Has anyone flow tested a new L92 truck intake?
- L92 Useful information?
- How are the LS2 coils grounded?
- Forged Boost 6.0L 364" /w 6.3" Rods & 402" Pistons, impressions?
- Z06 - Viper - Evo9 Track Vid Clip
- Cam for a 402
- More LS2 problems Please Help!
- Knock sensors
- Camshaft Lift ???
- Finding head gaskets
- LS2 Power Loss
- Got The Ls2 To The Track!!!
- LS2 Cable Driven TB
- 446ci with LS7 Heads
- FAST rails on LS2???
- Source for LS2 engine covers...
- Valve Covers !! LS1 to LS2
- Just got my L92 heads in
- LH6 5.3 heads...
- who built your ls2 402ci & how is it performong?
- hp comparison
- LS2 6.0L Head Gaskets
- Question about Ls7 oil tank cap
- 402: What Rockers?
- ls1 rockers
- Block questions
- LS7 Swap Running
- rear main seal install tool
- Aluminum Flywheel for LS7
- A helpful LS7 fitting we are making
- Is there a benefit from doing a 90mm LSX & TB when you have just LT's and an Xpipe?
- Problem with LS2...
- L92 intake
- Injectors for 402?
- Making a LS7 head rev?
- Need help in Nor-Cal with cam and headers install
- Oil pan swap From LS1 to LS2
- LS2 MAF Descreen?
- 402 oil pressure
- LS1 to LS2 Firing order ?
- Oil leak on new LS2
- Building The World's Baddest Pontiac Solstice
- Optimum Operating Temp??
- converting Oill Sending Unit
- ls1 converson to LS2 question
- PLEASE question about LS2
- What is this Sensor for ?
- GMPP LS 7 cars on the Hot Rod Power Tour
- Mail order LS2 intake porting available
- Pushrod length ques.
- LS2 oil pan on an LS1
- ported LS2 intake questions
- Dream LS Engine
- Someone ought to...
- how many rpm?????????
- Will everything be ok?
- Ls2 402 first start problems
- ESP Built LS2!!!!!!!!!! good stuff!
- ls7 rods and lsx pistons in a sbc?
- Short audio of my LS2 402 idling
- Ordering TSP 402 Longblock tomorow ???
- Converting LS1 wiring to LS2 PLEASE HELP !!!
- Where to get LS7 lifters?
- LS7 heads, which heads are better?
- ETP LS7 small bore heads
- ls6 manifold
- worth swapping motors?
- Ls6 to ls2 cam sensor.
- drop the lower control arm
- Forged flatop piston for ls2...sponsers?
- Proposed Cam (Patrick G, J-Rod, Other Cam Gurus)
- Just started the 402
- Are LS2 injectors longer or shorter than LS1 injectors..
- Fuel Pump for 98 LS1 conversion to LS7???
- 402 Special @ SDPC ** Today Only **
- 402 ls2 sdpc shortblock and g5x-3 cam
- Does LS7 use a MLS GM head gasket?
- GM LS7 hot cam
- Looking for ETP Heads
- LS7 build up
- Building a BIG cube LS2 motor - throttlebody recommendation?
- 427 with LS6 ported Heads?
- Memorial Day 402 Short Block Special @ SDPC
- Meziere LS2/LS7 Electric Water Pumps Available!
- Starting LS7 engine
- Finally...the LS7 Monte SS vid's from the track!
- 427 Aluminum Block options 427?
- LS2 402 with ET LS7 heads?
- Has anyone put a ls7 cam in an ls1?
- Just rolled over my new 402, no oil pressure, and bent dipstick?!?!?
- Have you seen the new Hemi crate motor??? Holy shit!
- Rotating Assembly Sale @ SDPC
- Calling AFR : will there be an LS7 AFR head?
- ? on LS7
- Need input on doing heads or a nitrous kit
- Need repinning Help
- LS2 new shortblock break in period
- LS7 question...and yes I searched for it first
- Money aside, who makes the best LS7 head?
- How much power with LS7 42lbs injectors?
- Flow #’s, Fast 90 vs LS7 intake?
- Cheapest place to buy 2005 C6 Service Manuals?
- SSR with LS7 engine?
- LS2 + C5 = grind block for motor mount clearance?
- Ls2 Tb
- ETP lS7 heads on my 408?
- Anodizing stock t/b
- More cam duration to improve LS7?
- Another Cheatr Cam dyno
- dod tunablity question.
- Can you use a LS7 rocker in a LS1?
- what about this set-up?
- What would a S/C L76 cost?
- What gaskets needed for LS2 swap?
- *Video* Turn-Key Start Equalizer S3 Heads/Cam LS2 GTO
- 2006 Z06 baseline testing on Mustang dyno
- Got the build sheet for my 427
- has anyone converted ls7 to wet sump
- LS7 427 Short Blocks @ SDPC
- LS7 crank // LS1 flywheel ?
- LS2 / with a ProCharger
- ls7 question
- L92 heads work on a 4.000" bore?
- Help me choose!!!
- Tuning Software for ls7, when???
- LS7 engine Vs the World
- feedback on Patriot heads
- What heads to drop compression on GTO LS2?
- Windage tray clearance on LS2 402?
- Jesel rockers for L92
- could this thread be brought back?
- ET 265 head Valve Covers now available
- Harland Sharp Rockers for ET 215-245 heads
- LS7 price
- ls2 trailblazer ss
- Can I run dart 225 2.05/1.60 with this cam
- Help with a simple serpentine system please!
- 6.0 Vortec to 5 speed Trans
- Ls2 Rwhp
- L92 heads
- LS2 Thermostat?
- LS2 Freeze plugs/block holes????? knock sens?
- ls2 402
- cam for nitous ls2 race motor
- will my valve covers fit.......
- LS7 valves
- Are L92 rockers same as the LS7 rockers?
- Jesel rockers for LS7
- LS2 heads on LS1 block
- Need help with LS2 tune.
- Smallest bore for ls7 heads?
- 2005 6.0 liter truck motors improvements over older motors? (2004)
- ls7 cam specs?
- LS7 oil tank dimensions?
- 4.125" stroke in a LS2 block = ____ cu. "
- LS2 stock manifolds on LS7?
- 498.46rwhp and 462.77rwtq tune ONLY zo6
- LS2 and boost
- First LS7 conversion track results!!!
- L92 Intake valve material?
- Part # for LS2 fron/rear covers??
- Ls2 intake on LS1
- LS7 Front Cover Part Number?
- LS7 Harmonic Balancer Part Number?
- To someone that knows..!
- Pro & con running LS7 wet vs dry & 24X vs 58X
- Weight difference...LS2 vs 6.0L Iron
- Aftermarket Intake Manifold
- ETP small bore LS7 heads OR AFR 205s
- Are these heads/intake from an 8.1 or ls7???
- Where to buy LS2 block?
- LS2 rotating assembly
- Engine Oil Life Monitor Question
- What is the CSA of the ET LS7 heads?
- would ETP 240 heads be too much for 402 N/A?
- cam and heads for trailblazer ss
- Comp r lifter preload
- Need to know if it will fit....
- engine options {warning, very long}
- C6 Vette exhaust?
- I'm looking for an air pressure monitor for a Budnik...
- noisy left side.
- LS7 with L92 heads?
- Edelbrock intake
- Opinions on Livernois 404 stroker kit?
- 402/LS2 Head and Cam Reccommendations
- LS2 - what size injectors and what are the stock cam specs?
- L92 Combustion Chamber Volume?
- Warhawk Update
- times goin down!
- Controlling an LS7 with an '01 LS1 PCM
- 2006 Katech catalog PDF
- LS2 Rotating Assmbly
- LS7 emissions, 24X, cable TB?
- Cheatr Cam/414RWHP traps 121MPH
- weight of 2.16 ls92 intake valve
- ETP LS7 dyno/track results?
- Anyone get an engine from FFHP?
- Mizfit's LS7 427!!! 607 rwhp!!!!
- Best LS2 H/C combo for max TQ & HP?
- LS2 in a 98 F-body
- Dyno'd my stock LS2 today.. woot!
- Added the Kooks w/ cat midpipes, HID's shot a quick Video
- VHP XXX Cam
- Where did they go???
- A little insight would be nice...
- *Budget!* 427 cam recommendations
- 408 clearance problem
- SLP LS2 shortblock for Road racing in a 01 Z06?
- Anyone have any luck getting the Aussie L92 car intake or part # for it?
- just a poll
- need help with head choice.
- part # needed
- Truck accessory (alternator only) bracket and LS7
- 190 mph Z06 Video!
- Stock LS2 Lifters Have Changed!
