View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. LS3 vs. L92 heads...whats the difference?
  2. Little confused
  3. Milodon remote oil kit for moroso pan ?
  4. how many rpm's are stock L92 heads good for?
  5. How can I tell if a LY6 by looking?
  6. Can you mill L92's or are they too thin?
  7. 408 vs. 421 Iron Stroker
  8. Need Help with engine build decision
  9. New cam with new stroker? Please help
  10. Piston Shopping
  11. What heads did LY6 come with?
  12. Buy new 418 alum block or rebuild 422 iron block
  13. LS3 415 Stroker build need opinions
  14. Oil pump & timing chain question
  15. 427 bore/stroke question
  16. Ls3 block and 150+ nano shot
  17. L92 casting #823?
  18. A little Cam help
  19. 2007 ls2 questions/cam help
  20. lq9 to 376ci?
  21. new to the LS motor
  22. Building bottom end of lsa motor
  23. Developed a bad missfire L92
  24. help! knocking noise!
  25. L99 build or sell
  26. LS3 fuel injectors
  27. Livernois Motorsports LS3 419 Stroker Shortblock Build
  28. visual difference between ls1, ls3, ls376/480 and ls376/525 engines
  29. Cam swap with AFM lifters
  30. Break in period for a new motor?
  31. Any advice on LS3cam choice
  32. 427 cam question
  33. Mod suggestions?
  34. Very odd Oil Pressure issue with new LQ9.
  35. Which rockers for a boosted engine? (15-25psi or maybe more)
  36. Bearing for LS3 Racing engine
  37. Erl 398
  38. LY6 harness for L92?
  39. Speedo on dash, VSS wiring question
  40. Forged dome pistons for lq4 who's gotem?
  41. Who makes a forged 6.098 rod with.945 pin?
  42. deleting vvt on a ly6, what do i need?
  43. Solid cam choice for 416???
  44. Heads
  45. Anyone useing these heads?
  46. Ly6 questions and cam swap
  47. new ls376/525 crate engine...
  48. LS3 vs LS7 pushrod length/size dilemma. Help
  49. Single or Dual Exhaust for 416?
  50. PRC Aftermarket Casting 250cc LS3 Heads Shipping!
  51. Fly cutting pistons on lq4/lq9 or ls3 for g6x3?
  52. I want to hit 400rwhp. Help!
  53. Any benifits of smaller rod journals?
  54. LS7 Rail Rocker Options?
  55. how much do clearances open up at temp??
  56. Should have known better
  57. Air conditioning compressor question
  58. PTV Question
  59. Help please
  60. Valve chatter????
  61. Keep Fast 90 and get ported or sell for 102
  62. Please help builders No Oil Up top!!
  63. good deal on forged pistons?
  64. exact symptoms of bad oil pump o-ring?
  65. how will this cam work
  66. 4.010 Weisco pistons / Vendors
  67. Difference between a gen III and gen IV 6.0
  68. Please who can calculate my CR
  69. ls1 parts fit ls2?
  70. G6X3 cam surge issues?
  71. Can i spray my LQ9/L92 motor ? PLEASE READ
  72. Crank Reluctor Main Clearance
  73. breakin oil weight vs bearing clearances
  74. Help with a seal
  75. Coolant leak Question
  76. Texas Speed LS3-B blower cam
  77. LS3 water pump heater out and inlets - needed?
  78. Another destroke thread
  79. Three cam suggestions for a LS3 DD
  80. compression test confusion
  81. Help me choose a cam
  82. Hey camshaft guru's
  83. 6.0L Questions
  84. 408 fi 06 gto build
  85. Mast LS7 vs PRC LS7
  86. coil relocation
  87. Can LQ4 & LQ9 Bored to 4.125"!!!
  88. PTV clearance
  89. ls2 camshaft sensor part
  90. lsx?
  91. LS3 Pushrods Any Good
  92. ls7 or lsx
  93. LS3 and prc stage 2.5 5.3L heads?
  94. 6.0 budget performance help
  95. Need some help lq4 build
  96. Are my LS3's trashed?
  97. milling AFR heads
  98. Warhawk 481 talldeck build!
  99. LS3 Pistons in 6.0 Iron block?
  100. Is it alright to have unvented valve covers using LS3 valley cover with catchcan?
  101. Comp LSL Cam Premature Wear, Kills Lifters
  102. iron 408 or ls3 416 n/a
  103. 6.0 performance cause emissions problems?
  104. Thinking about using PRC LS3 heads for a moderate boost application (15-25 psi)
  105. LFA Block
  106. 700-750hp at flywheel
  107. Anyone go solid roller with....
  108. RHS block head studs?
  109. Cam for 6.0 HELP plz !!!!
  110. cathederal or square port heads
  111. Update: KATECH Value 427 LS3 engine 605hp/575ft-lbs!
  112. ls2 head question(messed up)
  113. Texas Speed PRC LS7 Heads
  114. L92 cam swap
  115. Thinking of buying an LS3
  116. LS2 403 cam for LS3 heads
  117. PHR 425 Iron 6.0
  118. ls3 480 newbie question
  119. Oil Consumption 4.125 stroke 427 How bad?
  120. L92 modifications
  121. LS3 MAP Sensor End Connector with LS1 Engine Harness end Connector Issue...
  122. ls7 stroker kits
  123. 418 ls3 injector sizing
  124. Building an LS for a 350Z
  125. high volume truck oil pump w/ shallow pan?
  126. Why not more 6.200" con rods for LSx strokers?
  127. LQ402/8 with ls3 heads- Compression Ratios
  128. H/C recommendations for an '08 Denali w/a Procharger
  129. aftermarket ls3 rocker arma
  130. When to upgrade oil pimp? Is it necessary
  131. Cloyes hex adjust c5r or slp double roller chain?
  132. Still use Damper with Double roller chain?
  133. Odd design of LS7 connecting rods + bearings
  134. LS 2 clearences
  135. STOCK LS3 Heads/Intake Combo or P&P 243s/LS2 intake?
  136. Ls2 402
  137. low oil preasure lq4
  138. Lubrciation Specialties
  139. LS2 swap worth it?
  140. Rotella Oil ?
  141. What is the Piston to valve clearance
  142. More info on LS2 erl dry sleeved block?
  143. Upgraded to some WCCH LS7's from some LS3's
  144. Factory flat top piston for LY6?
  145. MAST MOZEZ heads cast or billet?
  146. PRC Aftermarket Casting 250cc LS3 Cylinder Heads In Stock & Available!
  147. #7 bent spark plug electrode???whats wrong?
  148. undersized bearings available/
  149. LQ9 vs LS2 vs L92 for something oldschool
  150. valve spring life
  151. Barbell installation
  152. 4.190" bore and big N2O shot?
  153. whats it worth in HP.......11.3:1 to 12.5:1
  154. Long stroke stock sleeve pics
  155. LS2 L92 Heads/Cam - Missing Anything?
  156. 441 LS7 and a 150 shot?
  157. Bad A/C Compressor?
  158. Anyone using LS7 heads, without a cam thats on a LS7 cam base circle
  159. L92 build advice
  160. 862 heads worth touching?
  161. higher duration or higher lift??
  162. Help a 16yrs old guy with his 427 build setup!
  163. Bearing Clearance? on new motor
  164. TF 235 PatG Cam vs AFR 230 Mamo Cam ?
  165. valve seal problem? oil in intake # plugs with oil
  166. TFS 235 vs Brodix LS7 Results
  167. need help with cam desicion
  168. oil in intake - is this normal?
  169. Thrust Bearing Failure!
  170. Smallest Cam for LS3 416
  171. Is this cam too much?
  172. is there a GM # for a screw in freeze plug?
  173. Finding Engine Part #s
  174. 1000rwhp guys inside please
  175. 370ci LSx--LS3 Top-end--Input needed!
  176. ls2 600 rwhp
  177. PRC 285cc LS7 heads. Ti or Hollow valves?
  178. mast mozez heads or all pro?
  179. Torque to yield cap bolts Part #
  180. Reher Morrison LS3 CNC package?
  181. MAF Sensor cutting out at high RPM HELP
  182. Piston selection for 6.100 rod
  183. Lq4 compression
  184. lq9 ls7 or ls9 cam?
  185. lq4 which heads?????
  186. Airflow Numbers
  187. which motor for budget nitrous build
  188. LSX block camshaft thrust plate bolts?
  189. Ls2 valley plate on Lq9 or Lq4
  190. Can I put an ls2 rotating assembly in an ly6 block?
  191. Help with cam?
  192. Can this LS3 head clean up?
  193. LQ9 & PRC 5.3l heads. Whats my compression?
  194. LS3 6.2 cutting out
  195. LS7 rods into a 5.3 block?
  196. Manley NexTEk Springs
  197. Crankshaft Help?
  198. ls3 418 windage tray
  199. cam question
  200. 05 GTO LS2. 24x reluctor wheel?
  201. ls2
  202. LS3 Oil pressure problem-whats the next step? Help?
  203. Help rebuilt engine is smoking, burning oil, and but has suction from oil fill tube
  204. Callies cranks, what's the difference ?
  205. Two Different Engines, Two Builders, Same Price.... Which to Choose?
  206. LS3/L92 head coolant crossover port question
  207. Help with cam ID please
  208. Crack in brand new LS2 block**** Updated please read****
  209. Solid Roller Cam possibly killed my motor
  210. Anyone have/seen Jesel SS Rockers for L92/LS3?
  211. LS2 How much oil does it hold ?
  212. Help on LS2 build!
  213. I think my new LS7 is hurt :-(
  214. I want cam for my LS2
  215. Katech releases full LS9.R specs
  216. Camed LS4 with mods=110-111mph. Goal 115mph. Suggestions?
  217. Best heads 3k and under for a 418 LS3?
  218. Ls2 or ls3 top end???
  219. Trick Flow Kit vs my LS6 CNC and cam.
  220. eps 226/234 lsa 113 cam idle video 2010 camaro
  221. Siezed Piston. What caused this and how to fix? Pics inside
  222. Cam question for you gurus
  223. Check engine fuel lean?
  224. Any sponsors have diamond pistons and rings?
  225. Need a Quick answer to this question help!!!
  226. Do cams harm lifters or vice versa?
  227. swaping engine
  228. L92s: Which rockers for 7500 rpm?
  229. Forged Crank in 2009 LY6?
  230. LS3 cam/crank sensor input voltage
  231. GTO, G8 and Camaro Anti-Starvation Oil Pan Baffles
  232. RHS dry sump setup?
  233. ls2/ls3 build...k1? Need advice
  234. Lifter/oil pressure question
  235. Cam to big for springs?
  236. Camaro SS LS3 swap into a G8 GT
  237. Does a bad lifter HAVE to = a bad cam?
  238. LS2 with LS3 Top End: Cam Selection
  239. gen V question
  240. RED LS2 Resleeved 434ci vs LS3 416ci (( Street car N/A & N2O ))
  241. Ditch Maggie and go H/C?
  242. Wet sleeve question
  243. LS7 for boost w/good internals, would the material between the cylinder be the issue?
  244. Where is the 27hp come from L92 vs lS3
  245. LS2 Backfire issue
  246. Vortec gen IV 6.0
  247. 2000+ HP build. ERL or LSX block?
  248. Blowing smoke thru oil filler.
  249. Bad Lifter
  250. rod bearing fell out of my new lq9 block!!
