View Full Version : Generation IV Internal Engine
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. 1 Question RPM Small bore LS7 heads
  2. Best plugs for LS7 on 91 octane? Plug gap? 91/e85 mix change plugs?
  3. PAC 1519 or Manley 221438?
  4. VR C6 Z06 - 594-rwhp/520-rwtq N/A (pics/dyno)
  5. GM Ls9 Main bearing shell question.
  6. Desperately need help with tuning - IVA
  7. Need help with intake...
  8. GEN3/GEN4 conversion kit?!?
  9. 2006 5.3 AM Lifter or CAM Help **WITH VIDEO**
  10. circle track experience
  11. Ring end gap, Turbo LS3, Stock Internals.
  12. Best/Cheapest LS1 Heads
  13. 427 alum or iron for nitrous
  14. will ls1 ARP head studs work on a ls2?
  15. any tricks to pulling this pulley?
  16. ***LMR LS3 heads (Pictures and flow numbers inside!)***
  17. Wrist pin retainers
  18. Ms4 idle vacuum ?
  19. LS7 oil pressure dropped on Dyno
  20. looking to rent ls3/l92 flycutting tools...
  21. Rocker arm rubbing Valve covers
  22. Ls7 Fuel requirement
  23. Which is the engine number - URGENT!
  24. 416ci with prc 2.5 heads!!!
  25. TrickFlow GENX 255cc LS3 Heads
  26. PRC head and stroker question
  27. LS7 Yella Terra's
  28. Ls3/l92 cam
  29. ATI Balancer part number please help!!!
  30. Operating temp swap, opinions?
  31. Ls7 build
  32. 4.8L Cam Swap MPG LS2 vs. LS6 vs. Crane Cam 200
  33. LS1 Computer running a ls3?
  34. Avalanche w l98 !!
  35. LS1 vs LS3 valve guides.
  36. Iron LS3?
  37. LY6 Inconel exhaust valves
  38. LS Engine with 2 cams
  39. idle video - LS7 Polluter cam from Tick Performance installed
  40. Is the ls376 525 crate worth it?
  41. Trex valve lash????
  42. broken harland sharp rocker arm??
  43. Torque specs without degrees??,
  44. 6.0 cylinder ????
  45. new bullit cam
  46. Big decision 3-4000$ budget!!
  47. ctsv r - valvetrain noise?
  48. VVT Delete on LY6 and L96
  49. Stock Cube ls2 build ideas
  50. My Cam Kit
  51. should i run a bigger cam?
  52. Wiseco Piston best price?
  53. iron 6.0 cam suggestion
  54. Cam & Headers
  55. Stock LS7 heads on a LS3 416
  56. LS3/T56 possible combination?
  57. Katech 500&481ci billet blocks moved to the clearance section & price cut in half!
  58. looking for forged ls2 rotating assembly
  59. Cylinder Head Comparison
  60. lq9 243s hp?
  61. Will these valves fit my stock 243 valve seats?
  62. POLL - Which cam for LSA?
  63. Link Bar Lifters: Comp vs Morel / Lunati
  64. PRC 265 & LS7S Cam install near completion - strange valve issue when checking PR
  65. LS2 with LS1 oil pan
  66. LSA in a 91 Camaro
  67. are 317 rocker arms the same as 241 rocker arms???
  68. Looking for new heads
  69. what oil pump..so many different opinions
  70. valve lifters discharge...
  71. LS2 in a fox body coupe
  72. Need Help with my All Motor build!!
  73. Hewlp!!!!!!!
  74. HP Tuners
  75. copo replacement engine build
  76. Ls3 headed 370 cam question
  77. LS3/4L65E shifting problem
  78. Starting Ls2 after a long storage
  79. Building a roots blown ls
  80. L92 with prc heads-- help me choose cam
  81. Alum ERL 4.125 vs RHS
  82. LS3 ASA 12480110 Cam Card specs
  83. And the wait it over... TFS LS3's, FINALLY got em!
  84. specific upgrade advice needed
  85. LS Rocker Arm Bearing/Trunion Comparison to Upgrade kit
  86. LS7 for 2006 CTS-V build questions come on in with your experiences
  87. WTB....NEW RHS Block
  88. LSX 427 with 9:1 CR cam suggestions.
  89. testing oil pressure in ls2
  90. Should I be worried
  91. L76 short block with 317 heads..compression?
  92. Auto Trans not shifting above 2nd gear
  93. 441 build - 2001 Z06
  94. The best camshaft for hp
  95. LS2 oil pump
  96. Lsx 376
  97. ms4 cam swap
  98. Block disassembled time to pressure clean wish me luck!
  99. 2001 SS LS2 396 build
  100. does this sleeve look crooked?
  101. Wanted 6.0L aluminum block
  102. 408 on pump gas ?
  103. Configuring a new TSP Long block and looking for advice on heads
  104. LS2 GTO - Extending injector wires??
  105. Sorry but another cam question
  106. Independant flow testing on PRC 237 heads (with intake as well)
  107. wtf!!! How do you break an oil pump?
  108. LS3, Most Durable in the LS Family?
  109. Lifters?!? CTS VR or LS7?!?
  110. LS noob question
  111. vinci cam
  112. Vmax ported throttle bodies
  113. Crankshaft help please...
  114. 5.3 heads on a 6.6 stroker
  115. 58x Crank Sensor into Fbody, new ECU and Harness?
  116. Lingenfelter gt21 ?
  117. Cam Suggestions?
  118. head choosing
  119. callies ls3 key way size for crank?
  120. PRC ls7 265 small bore ???
  121. milled 241's or stock 706 heads ???
  122. MTI racing stage 3 cam ls7
  123. 6.2 rods
  124. Highest compression you can get away with on stock LS3?
  125. How much material can you notch out of LS3 pistons?
  126. Head Games
  127. Necessary to replace cam bearings (after hot tank)
  128. Aluminum 6.0 stamp # 51023?
  129. **LMR's new CNC program for all LS cylinder heads.**
  130. 4.8 o2 and harness issues need help
  131. ERL Superdeck II Build
  132. Chain tensioner and single bolt cam gear
  133. How to build 650 HP???
  134. LS3 Fabricated Intake on Ebay
  135. Excessive slack with LS2 dampener
  136. Head and main studs, what are you guys using?
  137. cam help, just need to know if this cam will work for me...
  138. Oil Leak on Fresh LS6 - Help!
  139. What are the pros & cons of VVT
  140. 418 vs 427
  141. Project: Thanos
  142. 406 stroker pistons fit 6.0?
  143. newbie with an 07 z06
  144. L92 power
  145. Ls2 build Just clearing up few detail
  146. Remote oil filter cause of oil pressure drop?
  147. ls7 cam install
  148. Spark Plugs
  149. 470 cu Inch Mozez Tractor Pulling Engine Build
  150. What is this?
  151. Weird Suspected Valve Train Noise
  152. diamond vs weisco
  153. Rebuild
  154. L92 heads, flat tops, compression?
  155. Help. How Do I Clearance My LS3 Valve Covers
  156. Keep my cam or go bigger...?
  157. What's next for engine my build?
  158. stubby spark plugs?
  159. Changing spark plugs help please, 2)e3 anyone have?
  160. custom speced comp cam
  161. Injector size
  162. lq4 6.0 cam suggestions
  163. MIsfire, Oil on spark plug , smoke on acc Need Help
  164. What cam should i get?
  165. High Rev Questions???
  166. Sleeving a 5.3 to 6.0?
  167. shaved 5.3 head questions
  168. ls3 cracked block help
  169. Plan for Stock Block LS3 500rwhp
  170. LS7 Ti rods vs Steel rods?
  171. Any flow #'s on LSX CT heads,
  172. Ls1 or blue tops
  173. LS2 gm pistons
  174. Matt Powers' Formula Drift Katech Track Attack 463ci engine making 714hp
  175. LS2 ARP Head Bolt Torque Spec Different than Stock?
  176. Max effort LS7 Cam suggestions needed
  177. ls3 418 or ls7
  178. Anyone Run the New TSP 235/239 Cam in their LS3/L92 Yet?
  179. Custom Build or LSX 376ci for Supercharged Trans Am
  180. Camshaft markings
  181. HUC lobes
  182. Piston guided rods -opinions
  183. Piston to valve clearance, rocker ratios?
  184. 5.3 LC9 AFM DOD Cam issues
  185. One ls3 head and one l92 head on same engine?
  186. Lifter broke on LQ9....what to do?
  187. Which engine builder to use?
  188. LS2 Lifter failure and aftermath... Why?
  189. Ls2 misfire trouble Help!! please
  190. oil pressure help
  191. FI LS3 427 or FI LS7
  192. VVT Cam Install Advance
  193. Will SBC rods work?
  194. help with my new build
  195. 2014 Chevrolet Camaro Z/28:
  196. pulling cam with motor still in
  197. cam help
  198. ls7 and ls3
  199. We do it Big in Houston
  200. need some help on my lh6 build
  201. fuel rail covers
  202. Help with cam selection for 06' A6 Vette...
  203. Difference between LS1 and LS7 Main Bearings
  204. LS3 Rockers...same issues as ls1?
  205. 416 help please
  206. need some guidance on this motor
  207. ls3 swap into 2000 ws6
  208. Curious to y'all's opinion
  209. Thrust Bearing Failure #2
  210. Best cam for stock motor with bolt ons??
  211. lq4 good buy?
  212. Building a badass Blazer with a 6.0 in it
  213. concerned motor swap.
  214. ls2/l92 couple of questions
  215. How much to take off for 1cc?
  216. XTREME MARINE lobes
  217. Inline Valve PXR 12 Degree Numbers
  218. Couple quick oil related questions
  219. Misfire
  220. Weak break after big cam 402 engine G8GT !!!
  221. Trunnion Bearings breaking in LS2 GTO
  222. ls6 head torque question please help !!!!!
  223. WCCH 245cc Cam Selection Help
  224. 408 results!
  225. compression for ls3 head swap
  226. Porting a TBSS intake
  227. How good is the Holley Ram intake
  228. cam choice 416 stroker set up for boost
  229. pricing help in ls3 418 or 427
  230. I need LSx Specific Cam Bearing Drivers and Support
  231. Small Cam LS3 build in a 4th gen
  232. RHS 450cid Dyno Numbers Posted
  233. L92 ring gap/ piston to wall clearance.
  234. ls3 and ls1 rocker tray difference?
  235. Need help finding thread
  236. i bought some prc ls7 heads...
  237. LH6 weight
  238. Lsx 454 oil pan
  239. Katech adds two new LS3 crate engines under $10k
  240. Rocker suggestions for LS3/L92 heads.
  241. LS3 427 question
  242. Help!!!!
  243. need help picking a cam, pistons, and injectors
  244. Newbie Question.......LSX402
  245. Lifters - Comp Pro Mag vs LS7
  246. Crank - GM LS7 vs aftermarket
  247. Most cost effective 470 WHP build?
  248. looking for motor...help plz
  249. Gold glitter in oil after head swap
  250. Cylinder head repair??
