View Full Version : Forced Induction
- Anyone tried the LS9 ZR1 camshaft
- New Intake & Fuel System?
- gm 12615136 2bar sensor
- My flipped manifold mustang build
- Machine shop says a 408 isnt good for boost...
- keep twin high flow i/c's or upgrade to fmic
- F body Intercooler mounting idea's
- RR-Stage 5 LS3 A6 570rwhp
- What intake manifold? PT88+22psi
- Need a little guidance
- Procharger 408 ported 317's. ?????
- procharger
- machine shop in northen ca ?
- Legit 8 sec street car
- what is this help please.
- spark plug wires for coil relocation
- Stock bottom T76 guys come in
- which sponsors sell turbo cams
- Reducer Coupling HELP!!
- FMIC build
- What is a basic bolt on s/c kit?
- Tell me what you think???
- Budget 347 forged bottom end. build or buy?
- Finished my Setup (truck manifold kit)
- alternator relocation bracket
- 71 chevelle LS3 turbo build
- Lt1 turbo setup...
- What pushrods to use in my turbo 5.3?
- Probe FPS pistons?
- Where to mount a FPR for return style system?
- Largest Procharger to fit...
- map sensor wiring help
- Loss of traction AFTER launch... weird pulsing vibration on decel...
- Need help guys
- To achieve 500-550rwhp
- World's fastest Ebay Kit!
- A/W IC water lines
- Need some type of guard or shield for my ATI race valve
- Procharger piping replacement
- What belt for SDCE with 4.25" pulley
- AES Racing Engines FI Shortblock, longblock sale
- FMIC Build Help Needed
- need help turbo header
- Thinking about Procharging
- Need Gaskets
- TTI upgrade
- Turbo Woes
- got the kit coated
- boosted fuel pressure regulator
- Supercharged M6 guys (and girls?)...
- LMR Twin Turbo C6Z makes 1153rwhp through Auto!!!
- Finally Got Dyno #'s With Maxed Out D1SC
- need some suggestions on a 408 FI build
- Procharger and MS4
- LQ4 or LQ9 heads on my LS2
- High Flow LSx Injectors All Flow Matched
- quad turbo lsx powered sand car video
- A few Procharged L92/LS3 questions...
- SBC turbo needs help
- Running 20 psi around 4300+
- sts kit failure?
- KY-Turbo Inc. T4 A/C Header Setup
- Boost/ Power limits of ls7 and l92 heads
- Procharger Oil?
- oil drain return front mount ptk clone
- Himni Racing
- 3 bar MAP - install Qs
- procharger and cam choice?
- STS on Convertible? Please come in!
- Supercharged LT1 ???? need help
- anyone running a turbo on an lt1 please come in..
- where to tap into for water lines for TT incon kit?
- Will an atmospheric wastegate dump make more power?
- Procharger Setup LS1
- C5 hot section
- magna charger or slp supercharger???
- What size injectors
- supercharged ls1 t/a
- bettor or worse vacume source's?
- GM Boost solenoid
- Where to buy 2 bar map>!??!?!
- 427 Twin Turbo LSX Dyno Video
- remote radiator fill setup
- Holset HX55(72mm) single setups out there????
- Would running way rich cause the motor to idle high after boosting
- WTF 92mm TB wont bolt to Edelbrock Elbow
- Holset turbo sizes?
- Those with stainless works tube headers.... Plug wires?????
- How much boost can I run with a 402 and twin 58's?
- Procharger belt part number??
- my home built gt-88 setup
- Choosing a cam... 365 or 403, daily driven
- Re-Re-Re-Re-did my turbo kit
- whats what for turbo kits?
- powerdyne supercharger
- 918853 ATI pulley; does it have A/C?
- New Procharger and the fuel is running rich HELP!
- Intercoolers
- Help - Alternator Relocation
- 01 Camaro SS APS - track results
- found some procharger inlet goodies
- what's the max boost I can run on a STS 60mm turbo
- New Record for my 99+ Procharged Truck
- aem true boost on twins
- Supercharger Q?
- Accessory interchangeability with diff procharger set ups?
- YSI or 80m turbo
- Re pinning an LT1 for a 12200411 ECM
- Victory JR.
- Procharger twin intercooler installation
- dragon race engineering whipple?
- looking for a good F1A procharger inlet/filter for f body
- Finally got my BOOST heads pics.
- Install new clutch before tuning or wait?
- 1.85 RR on a StS turbo car?
- What gauges do I need?
- Did i mess up the rear main?
- F-body oil pan blockoff plate
- map sensor #
- max power 70mm
- best way to go about supercharging
- Best working/looking turbo blanket
- How to convert PS lines to AN and run aftermarket PS fluid cooler?
- Feed size for TC78
- add another map sensor or replace it?
- Turbo 3:90s how bad will they hurt.
- 396ci LT4, YSI and 15lb of boost dyno result :(
- single gauge pod
- Spark Plugs and Wires help
- Poll - Oil press gauge?
- New LSX376 "Boost Ready" ???
- 2 bar or 3 bar?
- is this the 2 bar map sensor i need?
- Turbo TA about there...
- dei titanium wrap with silicone spray
- Belt size
- 1900 or 2300
- G5xB
- Clarity on 2-bars and 3-bars
- My single turbo Build. My Design. (w/pics)
- Which Snow Methanol Kit
- gto aps tt changing exhaust system retune??
- good turbo kit for 6.0 lq4??
- 2004 gto ls1
- FAST wide band help
- WG piping question
- Looking for Vetical rad pics.
- 23 psi from a D1sc, up from 15 psi, yet no improvement in times...WTF!
- Got The car running...have a few problems.
- wastegate and tubo vaccum lines
- cam question
- is this 2 bar map / bap sensor ok?
- ETP 225 Heads...Need spring info asap
- Cooling Fans Shutting Off
- My 347 build complete (56k=death)
- 6.0 spark plugs
- AES 317 6.0 Heads full machined castings
- Meth Injection on STS Kit
- alternator relocation belt size
- Best budget forged bottome end?
- Forged 347 what cam and turbo?
- Which LT1 radiator for my '98?
- Jgs wg
- Progressive boost for the street.
- Oil check valves..good idea in cases of oil flowing back from oil pan into turbos??
- Lsx Tall Deck Street Build
- Lt1 turbo headers
- PCV check valve help?
- 2-Step knobs - assistance
- radiator for turbo setup
- Maggie intake S'ploded - BOOM
- Turbo K member
- rearmount help, having slight problems
- anyone else run pre-turbo meth injection
- Stainless Works turbo headers in an F Body
- Project: GXP-TN20
- Have any of you installed an MSD BTM??
- 91mm t4 finally home
- Boost leak = Backfire => Question
- Vid of my build and dyno video
- car insurance for our high dollar cars
- turbos too big?
- Twin Turbo 99 Camaro with all the amenities
- Thought I'd Try Here.
- pro turbo kit??????
- Quick question - 6 Rib Standoffs?
- Help me choose my fuel pump for turbo set up!
- LMR Twin Turbo Corvette runs 8.64 @145mph FIRST PASS!
- Nitrous with turbo
- STS Turbo Discussion
- Anyone need any stainless truck manifold flanges???
- low boost on p1sc
- ET ? with a gear change in my front mount car
- rear gear question with turbo
- LMR's 09ZR1 makes 810rwhp and 816rwtq!
- WTB Stock LS1, LS2, LS3/L76 Ls7 Injectors
- victor jr intake and elbow help please
- Should I turbo Now or wait????
- how you guys checkin for leaks in ure tubing?
- Can I measure boost here?
- Best way? - Cross over pipes to Manis
- Turbo Shock Set Up
- Video of my cars drivability and and spoolup with new 3" piping
- Alc injection and nhra rules..
- exhaust size for maggie122 on 5.7L
- F1 ls1 set ups
- MP 112 on LSX376?
- Really quick teaser vid of the new setup on the highway
- Turbo manifold with v-band question
- STS Cat Delete or Replacement?
- turbo with stock map sensor?
- G-FORCE 1069 HP Procharged Vette (930 RWHP)
- Procharger bracket question...
- LS1 Camaro Turbo 101 - Turbo Kit Photo ID
- looking into procharging the 408
- Bob from EPP
- 9.0-1 compression tfs heads and 15lbs
- Advise?
- What cam is better 4 a sts rear mount?
- What size turbo is this?
- Quick Question
- please dont call josh@kyturbo right now....
- Recomendations on roots-type chargers
- Blower Cam w/ good MPG? YACQ
- anyone around 750rwhp with LS2 cam
- Eboost2 guys and particularly aps guys where did you mount the solenoids..pics ??
- Rebuilding my LS2 with Maggie 112 questions
- Wanted aps upgraded inlet hoses prefer pair ,dealer or not dealer fine.
- FAST 102mm CATHEDRAL pics or compare vs old one for boost
- procharger guys.
- Lets see your lt1 turbo setups
- a/f r on the 2 step
- ATI balancer acts like it's installed to far?
- pinned crank
- Intercooler Questions
- turbo track time
- Anybody running a EPP FI cam in a 5.3
- Pics of Turbos Located in Battery Location
- Part number for GM(cobalt?) map sensor for 2.5bar programming(hp tuners)
- F1A pully change/hp increase, belt size
- Where NOT to ceramic coat
- Finally done with setup and got some times
- Wheres Bob at EPP?
- Stock motor mounts..are you destroying them with big power?
- Forged 347 & TVS 1900 build...heads & cam?
- Any Issues with running FI setup N/A?
- broke crank / need a crank support
- more dead aps turbo's.....!!
- Coil Packs
- Wastegate Size?
