- flat mounted FMIC ideas ???
- turbo, or blower? prep work? any help?
- Hooking up 02's
- Its no problem to run GM 6 liter gaskets with stock LS6 heads on LS6 motor right?
- STS and Lowered Car help
- BOV position
- GT40-88 Rear Mount Z06 - Build pics!!
- GMPP ASA cam OK for blower?
- D1SC procharger cali emissions legal?
- KBs and Whipples
- TSP long block any good
- Replacing my oil pump and had a pulley question
- water cooled?
- Sts Vids
- Vortech V9-kit
- D1SC or OFI? What would you go with?
- anyone else make a sumped tank?
- slp smooth below strong enough?
- Front mount set up needs ideas
- what kinda track/dyno numers should i expect
- why can't turbo th400 cars be dyno'd?
- Tool need to cut front end for FMIC
- What size spring
- STS dyno results from TRT.
- New Dyno Numbers for the STS
- 408 / S85 turbo project halfway there
- Fuel System Limits
- Speed Inc's TT kit
- Sts Boost Controller Reference
- New Turbo kit!!!
- How much torque on ARP 12pt studs?
- which blower with my brackets - hybrid 69 Camaro?
- fuel pump part# comes with procharger
- Confused? Bypass Valve / BOV
- Cog Pulley - way noisier or not?
- Who wants to upgrade away from their new forged LS6 346/7 blower motor?
- 2 38mm wastegates f/s in classified's
- Procharger P/S Pump Re-location Kit
- sts & sub frame connectors?
- LS6 Valley Cover (PCV)
- Supercharger drive belt needed
- compression
- Where to find MS 1/2" header flanges
- F/I Compression Experts-How much will comp drop on stock LS6 by going to 72 cc heads
- twin turbo kit... need some help
- Think I blew a head gasket?
- Any reason not to use an aluminum AN fitting on a chra?
- 6.0 turning rpms
- LQ9 317 Head Guys, are you using stock LS1/6 head gaskets or 4.0 gaskets on 346 LS1/6
- STS guys What have you replaced
- 2007 Boosted List
- Procharger heads?
- STS oil pump????
- Question on boost at the line???
- Cam/Power Question
- F/I experts, for D1SC blown 346 LS6, go with 225 or 205 LQ9 72cc Patriot Blower heads
- Upright radiator mod pics.
- New best with the trusty old D1SC today..
- Who has any experience of the Patriot LQ9 72cc F/I heads!
- Progress pics of my CDNPERF 347 F1R combo
- 2 Wastegates...
- OFI 4" downpipe with stock accessories!!!
- Can u run a lumpy cam w/a blower?
- Do both LQ4 and LQ9 heads offer 317 castings with 72 cc chambers?
- When is 3" Needed
- Lets Try This Again...
- Pump Gas Drags
- what are good heads for FI?
- ? about forged SB and convert to FI from n2o
- STS Dyno!
- PCV on STS HELP!!!
- Best setup for the money?
- Inspector12...part 1
- custom blower pulleys?
- anyone interested?
- 8.1L whipple supercharger
- Size WG and BOV
- Q trim vs P trim
- juist got my wideband in, where do I put the bung?
- lower CR on stock internals
- Pics of my new custom front mount what ya think
- Any Good Steps On How To Install Fmic??
- Re: TTi Fox Body: 8 second street car [vid]
- I love cleveland weather...
- IC pipe w/ no bead will the silicone hose blow off?
- Supercharger/OilPump Question
- Any 1 every used this kit?
- High boost T-76gts results please......
- GT4294/gt42 who has run this......
- GM MLS gaskets good enough for YSi?
- Anyone running turbo with higher compression?
- How do these sound?
- Anybody done with their manual? 98 F-body
- What does 199 MPH look like??? **Video**
- procharger vs turbo sound thread!!
- HP potential calculator......turbo engine
- Twin Setups?
- pistons for s/c 383
- too much milage for a blower
- Not a LSX BUT I think you'll all approve.. [vid]
- 383 stroker or Intercooler...
- Reading Compressor Maps For TT setup
- no response from ptk
- Dynatech split flow muffler
- possible sts turbo oil sources (pic)
- What Electric Source For Sts Oil Pump?
- turbo on pre 87 motor
- Peeps w/ TURBOS & STOCK eninge!
- Exhaust leak at Flange for turbo...what to do??
- Will D1SC be adequate?
- plug on block
- Getting ready to spend alot more $ and need some advice.
- boost and f/p guages
- 2001 Z06 Preliminary Results, 403ci, Novi 2000 Blower
- ebay aluminum intercooler tubing kits?
- How much power on stock botom end+rod bolts
- fabricated turbo!!!
- Need help with Cam selection...
- tt "re-build" pics
- BS3 Help.
- ~Budget Engine Build...Turbo Set Up~
- Boost bleeding/staying constant
- NEED HELP! Welding exhaust while turbo is on the car??
- F.A.S.T Intake
- Finally an In-Car Vid
- Selling my gauges
- Large Twin Selection
- Procharger Guys Inside Please!
- STS Guys Help Plz!!!!
- Turbo Oil Pressure Gauge??
- New TC T-76 is in and tuned.
- Effects of varying turbo AR
- SLP cold air intake?
- Dynoing the car soon-question about fuel
- Got my STS SS running last night!!
- OFI twin turbo mustang kit
- OFI downpipes are ready
- manual control over bypass valve possible?
- Powder coating a procharger? Can it take it?
- when buying a used procharger kit....
- 99LS1 a good platform to build turbo?
- o2 sensor location
- EBoost electronic boost controller wiring
- Damn STS Buzzer
- OFI progress pics
- Oil return from turbo
- Thinking about Kenny bell
- 3" pipe into T4 flange tricks
- head gasket for 408
- MAF Help
- PSI Loss over twin IC
- Anyone know the Dayco part # for a vortech tensioner?
- Best blower for F-body?
- how about supercharger pcv venting? what do I need to do?
- VIDEO: 5.97@118 3900+ lbs
- I put our newly released ATI ProCharger CTS-V kit on Ebay
- ideal set up for an F1A
- Quickest spool possible...
- vortech ls1 edit tune
- TSP Twin Turbo C6
- who has the fastest stock bottom end turbo or any for of supercharger here???
- Will spraying Alky (on a Maggie) change the AFR???
- thinking of Fast 90/90
- True 3" Dual Side Exit Twin Turbo!
- Where to buy air werks turbochargers?
- New Turbo kits on E-bay 690.00?
- Blower Manifold
- a quick question about prochargers
- Which size headers for my combo ?
- how far do the pistons come over the deck on ls1/ls6
- How much boost is lost over the FMIC??
- Keeping them down....
- hey guys got one last question
- Z28 project help
- Do I just need to change heads to go FI?
- working on a custom sts turbo setup
- Emissions Legal Supercharger Cam
- Plz Help !!!!!!!!
- SD tune
- Procharger ID without a Tag?
- Turbo Manifold/Header Question/Help
- asp underdrive pulley VS stock VS ATI superdampner 4 FI
- My Turbo project Finally done.
- putting kit on a vert
- do good flowing bolt ons really matter?
- compressed thickness for stock mls gm head gasket
- 3 Bar Connector Help
- Probe pistons
- 64cc AFR 210 with a 5cc Piston?
- 317 heads
- looking for procharger...
- Source for aluminum tubing
- Twin rear mount turbo sizes
- 92 LS1 FM T76 Build
- 8 rib balancer' available
- Maggie owners - what other mods?
- Boost compression chart
- Building FI manifolds which collector to use?
- Turbo guys, what plugs and gaps are you running?
- 402 and Maggie
- Cheatr Cam w/D1SC?
- CTS-V ATI ProCharger kit from EPP!
- Setting up my PCV. Will this work?
- Pistons for 408ci F/I
- how long did your stock 10 bolt last?
- help me call BS on this...
- Compression ratio on a Procharger car
- question on the Speed Inc TT kit for ls1s....
- t bolt sizes for sts
- twin turbo 05 mustang LSX.......
- looking for some 408/402 idle and cold start tables
- How often do you drive your FI car?
- Would like some motor advice and input please for an incon setup.
- Does DCR matter as much.....
- And so it begins...............
- T3-T4 Turbos
- sts dyno!!
- ? for STS guys
- CTS-V Twin Turbo Options
- TSP 370ci iron block BEST F.I. shortblock for the MONEY???
- 370ci rotating assembly
- Tuning a Turbo car on a non load dyno?
- LS1 Supercharge intake roots style 6-71/8-71
- PCV Confusion
- F1C/F1R on 6 Litre Iron Block?
- E.t?
- boost and lt1
- Oil lines for turbo
- At what power level do you need to change cylinder heads?
- Chosing between Forced Induction, and Natural Aspirated motor
- How fast on pump gas?
- FMIC fab work!!??
- Need help!!!
- intake tubing for forced induction?
- need help installin meth kit.
- Turbo To Supercharger
- ati plastic plentum, how much boost can it handle?
- Dart heads with FI
- Lingenfelter cam ques?
- need help on what turbo cam to get and where??
- Quick and easy question.. cooling fan connector.Please identify this connector.(pic)
- The 500 RWHP mark has finally been hit with the V6 Fbodies!!!
- Custom Forward Facing headers done
- Attn: New trick for FI FMIC?
- please post your turbo or procharged or supercharged track video here!!
- Help Wanted! Best blower for ZO6?
- How does a wastegate work?
- What Sponsers....
- what size pump/tank for TT air/water IC
- Have a new Project now.
