- ? for STS guys
- CTS-V Twin Turbo Options
- TSP 370ci iron block BEST F.I. shortblock for the MONEY???
- 370ci rotating assembly
- Tuning a Turbo car on a non load dyno?
- LS1 Supercharge intake roots style 6-71/8-71
- PCV Confusion
- F1C/F1R on 6 Litre Iron Block?
- E.t?
- boost and lt1
- Oil lines for turbo
- At what power level do you need to change cylinder heads?
- Chosing between Forced Induction, and Natural Aspirated motor
- How fast on pump gas?
- FMIC fab work!!??
- Need help!!!
- intake tubing for forced induction?
- need help installin meth kit.
- Turbo To Supercharger
- ati plastic plentum, how much boost can it handle?
- Dart heads with FI
- Lingenfelter cam ques?
- need help on what turbo cam to get and where??
- Quick and easy question.. cooling fan connector.Please identify this connector.(pic)
- The 500 RWHP mark has finally been hit with the V6 Fbodies!!!
- Custom Forward Facing headers done
- Attn: New trick for FI FMIC?
- please post your turbo or procharged or supercharged track video here!!
- Help Wanted! Best blower for ZO6?
- How does a wastegate work?
- What Sponsers....
- what size pump/tank for TT air/water IC
- Have a new Project now.
- What clutch with a turbo?
- does anyone make one ????????????
- STS Turbo Pics on SS Camaro...
- Twin T-70 camaro dyno results
- Price on a setup
- thearded iat?
- Twin T-61 Mustang Project Complete
- Which Headers/Y-pipe for STS?
- Big Stuff 3 VS HP Tuners on turbo 403"
- Turbo(s) or ProCharger???
- Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
- Final build list for FI motor
- Removing chrome for ceramic coating?
- What Size Springs
- boost ?
- boost psi
- Who actually looks at compressor maps???
- Unconventional Cam Choices
- What size piping and WG/BOV
- T-trim and YSI ??
- damn Hi-Flo!
- A couple question
- question for you weldors/fabricators
- STS gains
- Intercooler
- exhaust question
- GTO twin turbo...
- Ls7 Supercharger
- APS C6 intercooled twin turbo tuner system - $6995 inc door to door freight
- Turbo or Supercharger.....
- L92's Turbo & blown Copper head gaskets...
- What do you guys think about turbozone turbo kits?
- Help Please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Help with horsepower!!!
- Tubing questions
- ??? About Twin Turbos
- How do identify a GT47-88
- e-85 and big boost
- meth kits, progressive or not, which is better?
- Higher boost with lq9's w/ D1sc
- Mps Wheel Confirmation
- Which pulley first?
- Supercharged and engine
- power from stock cubes
- How much boost will D1SC make
- procharger
- Which Turbo To Get
- twin turbo ls1 tuning
- 408ci / S-85mm pics
- 1000rwhp
- Turbos Peak Hp
- help****turbo kit for ls1
- New Product announcement, S-series Turbo
- Supercharger cost!!!
- Pulley Combo
- What year F-body to get?
- The big question.
- STS Turbo Kit!!!!
- Turbo BUILDUP
- HP question
- PT 88 402 build
- X-trim
- Safe for 5lbs?
- Tires for you FI guys.....
- EGR sim
- Boosted 4V cobra motor vs Ls1
- MAF being placed in the FMIC piping???
- supercharger/turbo...
- Where can I get manifolds?
- T6 flange
- Supercharger and EGR
- Which Spark Plugs to use with boost
- LPE GT2-3 VS GT7 which to do??
- Who makes the smallest turbo?
- anyone running the reichard racing ultra grip blower pulleys
- how much hp going from 3 to a 3.5" dp?
- Ed @ Late Model Speed - Any updates on the Magnuson kits?
- How to launch a turbo car?
- FI Cam help needed for 04 LS1
- 90deg fittings for heater hoses off of water pump
- Newbie FI question
- Stick with FI build (TT Z28) or go with a 02-04 Z06?
- STS oval intake tube?
- hot side pipe diameter ? quick spool/vs/power
- ported compressor housing (turbo)
- pulled the stock motor apart-still lots of oil in the intake!
- Is this a good cam for the sts?
- newbie
- STS Guys, need help!
- Compression Question
- Another Twin Turbo Cobra...
- Pics of OFI Turbo Headers for 98-01 F-Body?
- Going turbo got a couple ?'s
- how does compression effect power?
- procharger p1sc
- Whats the fastest/quickest G trim vortech car?
- Where to buy a vband for a GT47 compressor
- where is the best place to buy procharger pulleys?
- TTi LS1 Street kit how much power?
- Turbo is back on the car after the rag incident
- Less Maintenance -- FI vs. NA + Spray
- Starting to make some progress...turbo and radiator mounted
- Procharger F1C
- Damn PCV!!
- AEM TruBoost
- STS Turbo Drivetrain problems??
- Help Need Horsepower
- Couple Of Rear Mount Questions!!!
- Question on TTI kit
- Members Who Have Cut There Radiator Shroud Come In
- Getting close to starting her up! More pics.
- Single "16" or dual "12"-what offers the best cooling solution?
- turbo lt1 with this radiator?
- STS Turbo
- Prochargers with nitrous
- Updates and News... Turbo Technology Inc.
- LT1 crank pulley/balancer For Procharger F1
- Finally got the air back on the car. with PICS!!
- What am I looking at...
- What heads should i get?
- Got it up and running
- Coolant fill tank relocation?????????
- Will my fuel system support 13.5 lbs boost?
- Vortech Supercharger Price Increase 3/1
- Tc76mps
- which turbos should i get
- Exhaust backpressure
- Speed Inc. Turbo Project W/pics
- Is an extra .016" valve lift worth a rocker change for FI?
- STS oil feed line gasket...anybody using one???
- Educate me on Turbo's....
- HEY H2O intercooler guys
- ATI Piping
- any high HP FI guys have experience w/ coating???
- Boost Guage Question???
- Ohio forced inductions air to air support setup...
- I got my car running
- Oil Restrictor
- Magnacharger or Kenne Bell 2.6L
- STS Owners- Does your oil pump make too much noise?
- Do I need an aftermarket harmonic balancer?
- Pics of the new setup so far
- Car is up and running strong :) (new dyno numbers...)
- Procharger Fbody mounting Brackets
- Just became a fi guy
- Dyno numbers
- Superchargers
- Anyone have these..
- max on stock engine
- Have a budget of 11k what can I get?
- Top Mounted SC?
- What FI setup is more reliable for street driving?
- Ported 317 heads?
- Help with 408 turbo selection
- How much is my STS GT67 worth?
- How Much Boost and How Much Power with 10.2 Comp Ratio
- Just some eye candy.....
- Boost on stock motor...
- Shake down video
- FI vs. Head/cam
- Intercooler for Trans Am
- Boost limits... Engine efficiency...
- Theory Question. Turbo driven turbo...
- Procharger Problems
- The "New" Corvette
- My cam
- Supercharging C6
- Front mounted turbo vs. radiator plumbing
- Question for the FI guys
- Aps
- Turbo Stall
- These are the current turbo systems i found out there for LS1 F-bodies.
- FI on somewhat stock car?
- Sluggish car with low CR
- piston to wall clearance for diamond blower pistons
- ATI ProCharger Price Increase Feb 1st!
- info on whipple?
- 408 truckmanifold kit
- extra lubrication vortech with boosted air ?
- More pictures of a little progress.
- should i switch my turbo before i put it on???
- Cool thing about LS1's is..
- Vortech install coming soon
- boost/compression
- Gaskets for boost
- boost
- Hmmmmmmm Wtf?????
- TOO MUCH BOOST bleeding off (STS)
- 97/98 vette rails for you guys
- Methanol in an Aluminium tank ?
- Anyone know how to hook up a Turbo Timer??
- Will this fit a trans am 99+ with the LS1 , 4 Turbos!
- A true Turbo Guru will know what this pic is.
- Looking for a GTO mock-up car for T6 turbo
- Custom Vortech YSi intake
- turbo vs supercharger
- How Much $$$ Did You Spend????
- turbo location
- Efficient TT Setup
- Tt Ss
- 402 + F1 = Some fun
- whats the best meth kit???
- Insurance
- 2 bar Question?
- My new car and New build
- drive characteristics of MTI X1 cam with twin turbos
- PTK fitment
- eboost 2 set up favorites
- HKS EVC 6 electronic boost controller...thoughts???
- Anyone using a 2:1 Boost FPR?
- Vortech install
- i have a couple STS Turbo questions.
- X-Mas From OFI!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Turbo finally came in! pics
- which catch can do you prefer?
- meth injection/windshield washer fluid?!?!?!
- My Build. 3rd Front Mount single turbo GTO in the USA
