- L92 exhaust valve question?
- Twin Turbo
- any supercharged GTO owners??!!
- flat top pistons for boost?
- D1SC and F1 Boost levels with a 346
- to main stud or not to main stud, that is the question
- piston to wall clearance for blower motor
- A couple methanol questions
- Question about piston size?
- Pics of my custom kit
- S78/80/88 etc.. guys: What size is the oil inlet?
- hp performance
- Hot Side Help?
- fi cars in cowtown?
- May be a stupid question
- 4" downpipe vs. K-member clearance..
- Turbo Exhust Setup
- Question for you higher horsepower FI guy - DRs, cold, and tire shake?
- Anyone have any info on this Monster?
- meth kit for 9# vortech kit
- Opinions?
- Which to install
- Question about GT25's
- New 1/4 and 1/8 mile bests today with the F1A
- 65 chevelle with ls1 twin turbos(help)
- exhaust doughnuts...where to find em?
- Stock motor mounts flexed too much with turbo torque..fix pics.
- precision 70mm .85 a/r max boost and spool time
- Am I missing anything?
- Boost + nitrous, what should i know?
- will 8 psi work with 64cc heads?
- Need Vortech pulley suggestions for Vette.
- Any homemade/jk yard turbo builders in here?
- ATI Damper
- LS1 STS Turbokit...FRONT MOUNT INTERCOOLER in need
- busted # 7 ringland minutes after
- Crank case ventilation on blower motor
- Bob, and everyone else, please help me pick between these 2 cams!!!
- 6-71s/8-71s with EFI???
- how do i attach downpipe to gerrett housing this thing is TOO big
- how much
- Should I Put My Stock Crank Pulley On With Fi?
- The V6 beast lives again...... only better now
- Is This Cam Good For My Setup?
- Evolution 35mm wastegate!!!???
- Turbo,twin screw,or centrifical supercharger
- D1SC Question
- evac system
- Anyone Using Twins Over 10#
- f1r sdce setup
- procharged 6.0
- FormulaFire is such a fitting Name
- anyone have a 8psi stock block 2bar SD HPtuners tune they can send me?
- Need some opinions here
- 3 Bar Map
- Lopey blower cams and heads
- anyone use ARP head bolts instead of studs?
- Give Input Please....
- More pictures of the new setup!!
- Selling my cold piping and DP guys! Link...
- WHich would be faster all other things being equal
- Ohio Forced inductions
- 88mm truck manifold set-up
- Short bus with boost=fun!!!!
- Speed inc twin kit...
- Headers
- What Effect A Bov Has????
- Looking for F-body D1 Installation Instructions
- How about this cam?
- Air -Air intercooler w/ Vortech
- best junk yard engine
- ProCharger belt - pulley matrix 6 and 8 rib F-Body
- What do you honestly think about my numbers?
- why does the gt 2-3 cam seem to make such good F.I. power when it seems so mild?
- NEW BEST take a look leave a comment
- F1A cons on a 347?
- holset turbo
- Exotic Performance Plus Engine Rebuild
- 6.0 engine how much do they sell for
- Magnacharger-Fbody Help!
- Cylinder Presure & gasket Bore
- Help me pick the better A/R
- alt bracket still not right
- need some opinions/ideas/suggestions
- point me in the right direction
- turbo sbc
- Paging Bob@EPP
- Highest RWHP TC76MPS LS1
- kPa to boost
- The Ultimate Turbo Cam
- SLP 85MM mass air with boost ?
- PAGING Jose and other!!!!
- What did I do?
- Incon kit - where to put BOV
- Victor Jr Manifold vs. LS6 intake
- thread side on OBX intercooler mounting holes?
- D1SC... Opinions?
- Close to engine/turbo time
- Longtubes not worth it with a supercharger?
- NEW #s take a look
- cam question
- On a turbo car how big of a cam for CC 921's?
- Vortech install help yet again......
- Delphi confirms Cobalt sensor #12580698 is 2bar.
- S95/PT96mm crossover pipe sizing
- C5 Procharger bracket on F-body?
- Is this boost to high?
- stock blocks
- My Cam and Boost?
- how much boost can I get without belt slippage on a stock 8 rib setup
- ATI ProCharger price hike coming in February!!!
- Tial WG spring colors
- cam recommendations?
- need some advice.... stay with my STS or procharge!
- Header size on 347 with a F1R
- Front Mount and IAT sensor
- Pics of 17psi 9second ET 1year old TR6 sparkplugs.
- Head/cam suggestion for a 370 D1SC build
- People with MP70s...
- 8 ribb sdce tensioner
- do i need a bung for my oil return in the pan?
- Is this a good turbo?
- Can i run this setup?
- STS Kit piping different for verts vs. coupes?
- HELP !!!! HELP !!!! Gear info
- baby steps to my build up
- Clearance issue???
- Help with diagnosis?
- Tan or On center?
- Procharger crank pulley coming loose
- Turbo guys help the brother out pls.
- 20'' of vacuum?
- Trex cam
- Part# for L19 head studs
- What Sled28(Canadian Performance) does over the holidays!
- Pics, one day b4 start up.
- Give me your opinion
- Anyone know belt size for D1SC 8#
- O.F.I. Updated kit info
- Expert Opinion 80mm TB
- has any one used this crank pinning tool
- Street build critique
- Rear mount parts list, am I missing anything?
- Twin Turbo Ss
- My new #s D1SC
- SD-Concepts Tensioner????
- Best FI cam?
- what is the oversize crank pulley for procharger 8 rib setups that help eliminate
- what do you guys use for head gaskets and C.R. in a forged 14-16psi 346?
- almost ready to start her up, got some ??'s(Hiflo-guys in here)
- finally dyno tuned-good news + bad news
- Custom Rear mount questions
- Cam for 402 tt
- looking for opinions/comments
- MAF and Boost guage.
- Specific Turbo Specs Needed - Turbo Guru's in Please
- I have the chance..
- Buying F/I gauges questions.............
- Guys with manual boost controllers
- tial bov vid???
- Lookee what Santa brought!
- Ceramic Coated Pipes on Turbo Cars
- Methanol
- What size fittings for garrett/sts turbo?
- twin T 70's: what's wrong
- Different then usual alternator relocation question
- What turbo
- hey bob @ EPP???
- Who has gone the fastest with a non "MID" aluminum block?
- "Street Tuna" kit for fbodys?
- Turbo guys
- TTi kit
- 370 or 346 tti street
- What size downpipe for S95/PT96mm
- More sutle mods that keep on helping
- FI Tune
- How well do gears affect us F/I guys? mainly SC stuff
- Turbo mounting pics??
- T76 T-netics MPS dyno!
- Turbo Charging a 2003 s10 Extreme
- how much like stock could it stay w/procharger?
- gains going from 02 zo6 cam to 224
- full boost time question
- Crank set up for Procharger...
- 90mm+ turbo cars
- 3 bar and 96# inj question
- cam gurus inside please, need input..
- O-ringing heads?
- Any 347 F1R combo's out there?
- single vs. twin: underhood temps and coolig problems?
- Thinking of going FI
- True dauls not good on a Turbo car?
- Need New Radiator...I'm FI need suggestions ASAP!
- Turbonetics T76MPS
- How much rwhp estimated?
- Power Outlook
- single or twin?
- Little video of the TA
- new turbo
- 2 short videos of my car on the street...
- z06 cam in a 370
- Finished up my new heads.. Now on to the bottom end.
- how to drill for oil drain while pan still on car
- Should I pin the crank and spark plug question
- T3 T4 garrett turbo question
- How's this looking guys
- compression ratio
- Rough Idle Cam Question
- supercharger or turbo
- is there a divided T6 housing availabe for PT-88?
- Speed Inc TU1?
- just wondering what supercharger u would suggest for my 01 z28 ls1?
- 01 z28 what ls1 supercharger to get?
- wondering what symptoms come with lifting the heads?
- 2007 boost list...idk , but just posting
- eBay turbo's?
- PVC Quick Question PIC Inside!
- Happy New Year
- Front mount single intercooler for Corvette??
- My Buildup thread 87 rx7/turbo 5.3/th400/8.8 etc
- max boost on 408
- High boosted applications (16-22psi) Spark Plugs
- big turbo-stock lt1
- Front mount and bumper pics
- Turbo pistons, rods
- valve springs on a 1200hp motor???
- when is it time to go air to water
- Anyone put a T88 on a 370ci??
- Vortech Installation help...
- Supercharger idea???
- how much timing with .....
- STS install pics... and stuff...
- what's better STS turbo or LT4 hot cam
- m6 and procharger
- Front mount intercooler
- Any worthwhile gains from larger TB?
- turbos + X-pipe?
- supercharger
- FMIC's that don't require removal of front license plate
- TR224 as a turbo cam, what do you think?
- STS..wiring
- Gears and Procharger
- help: LS1 Turbo
- Next step above 76GTS
- DIY FMIC Install
- finally - new dyno numbers
- what wastegate? where, and turbo , where?
- rag 1 camaro 0
- 370 ci LS2 FI
