- *** VIDEO- My Single Turbo C5 at the track ****
- Boweryboy's Turbo Corvette IRS Sets a C5 IRS Best-8.60@163.95[VIDEO]
- sell off turbo parts
- Truck manifolds VS C5-Z06 Vette manifolds
- Learn me how to Procharge! Please!!
- Who all ordered an OFI kit!!!!
- Pulley What size?
- Phamspeed - Flatten pipe
- Congrats, all you guys finally convinced me to buy a turbo
- ATI ProCharger Supercharger Specifications, including F1A
- 600-700 rwhp?
- If anyone cares
- Intercooler for turbo
- 4" DP piping
- 5.3L turbo garret
- intercooler core
- Head Gasket?
- Custom turbo cam specs...how's this look?
- Which power adder would you recommend?
- intercooler pics inside
- Took my little Vortech T trim to the track!
- Whistling ATI bypass valve?
- ls1 swap turbo
- Looking for guys who make 900+rwhp with turbo: block opinions
- Engineer types, and general brainiacs.. opinion wanted
- Next mod: ported heads or a bigger blower?
- Thunders racings cheater camshaft? anyone using it?
- ProCharger Parts(Bracket)
- Its now official
- Supercharging
- Supercharger
- What wideband are you BS3 guys runing?
- New best ET, last time out for the year.
- 88mm turbo guys, mounting question
- bov/sts question
- What Intake Manifold
- 383 + Blower + Nitrous - Fuel = Ouch!
- mp t-70 dimensions vs TC-76MPS
- Best location for WG?
- Can going to a .060 copper head gasket drop comp enough?
- Carburating and supercharged
- hey FM 6.0 guys , do any of you run your exhuast over the K member?
- Max boost with a 98 PCM?
- Boost and Winter Gas!
- Turbo questions
- When is Intake Change Necessary?
- Info for Procharger
- GT500 w/ Kenne Bell - 810rwhp/745rwtq
- turbo kit
- Bov and Wg
- guys will 3100 cfm of air from the fan cool the car fine
- Same cam for turbo/SC?
- Measuring blower speed
- 2-speed supercharger at the SEMA
- Aftermarket heads?
- question about a VERY VERY VERY small turbo
- TTi T-76 Street Kit Turbo System FS (Link to FS section)
- Has anyone run a set of L92s with boost yet?
- Please Help! Thunder blower 214-230 Cam
- Need Help Ati Crank Pin!!
- New Turbo kit manufacture
- VTG or VATN turbos
- Turbo questions..
- W2W on e-bay
- LT1 guys inside..turbo/engine ?
- help me choose a blower cam....
- Belt Size
- gt40 oil inlet flange
- I'll be listing my car for sale next week
- Set-up for turbo on stock z28 advice.
- Why do I have boost before throttle body but not after and into the manifold
- I just got the Mondo Bypass valve and found this
- Possible Turbo Problems? HELP!!!
- Boosted Engine Life
- Procharger Intake Air Temps IAT
- Bone Stock other than rear turbo and stall?
- Will a 12 rib fit on an F-body?
- Thinking about selling my TTi Street Kit
- sts kit questions
- How bad are chinese turbos?
- High boosted (16psi+) PCV setups?
- Clipped Wheel Thread
- Finally!!!
- AZPS 750TT package on 91 octane... vid inside!
- Turbine sizing -- how small is too small?
- Th400
- WOW ... not for the weak at heart....
- 2005 Procharged Vette
- Blower Cars, what stall speed you running?
- Ohio Forced Inductions Inc 93-97 LT1 Hot parts pics
- New T76mm Turbocharger on it's way to mi casa!
- Poll - stay FI or back to n/a
- New GT-K and GT-M series turbos
- Got a Street/Strip Single Turbo LT1?
- Victor Jr EFI intake on a 346 with D1-is it worth it?
- Procharger P-1SC or D-1SC
- which will spool faster?
- Good Electronic Boost Controller?
- carb style manifold, how to attach map sensor
- what size twins?
- Twins or Single???
- Urgent Members With Relocated Alt Come Inside
- wastegate springs- need more boost
- Timing Question
- 408ci Twin 67mm preliminary dyno results...
- Supercharger Qusestion
- Cam with STS question
- Reverse STS question.
- ebay threads
- dropped my turbo and down pipe off to get coated...
- Thunder 214-230 600/575 117LSA Blower cam?
- what rwhp are you seeing on boost w/stock bottom end?
- Nothing mindblowing, but made some clean hits in the Formy
- My C5 Corvette Single turbo kit is for sale
- procharger question
- T76 and Nitrous
- Forged 346 + Blower for the street ... what to expect?
- 1st thread ever! I am condering a Procharger..
- Powerblock Horsepower TV Procharger
- Cooling fan
- Fan settings
- anyone tried these turbos?
- Procharger P1SC
- Those who have done turbo builds
- For those of you waiting
- I had a Blast racing at Richmond Yesterday
- Ohio Forced induction hot parts installed
- Can I see Procharger setups on your fbody?
- 11.5:1 compression
- Blown pistons and sleeve... Lots of rebuilding and ?'s... Paging EPP and KP
- Planning for a Procharger... questions
- d1sc intake hat
- How much lift? Cam selection
- Lifetime of a 408 w/ boost???
- Now I guess turbos are cheating too.
- what is a turbonetics MPS turbine wheel?
- How much do you have in your motor?
- What cam? T-76,ported heads,stock cubes.
- Turbo vs Blower rear gear question
- Lbs of boost same as PSI?
- What stall with a big single mount?
- A new MP70??
- How much compression
- STS Muffler Pic!
- HP potential on a built 346ci
- School me on PSI????
- What do you like better about your boost setup or n/a or spray?
- M6 rear gear?
- sts t61
- Deliberate 383 split personality?
- Boosted LT1's need some suggestions
- Harlan 2 step
- How much boost?
- over heating procharged 408... my solution.. hope it works
- launching a turbo automatic
- how much hp/boost can a built lt1 take?
- STS Twin Turbo For C5 Corvette
- Reason for switching to a carb intake??
- FI Cars: What gear ratio are you running?
- FI help needed- Dyno Tuning problems
- something has to be wrong...
- LT1 vs LS1 boostwise
- Truck Manifold TT build: few questions
- c5+forced induction questions.
- Should i go twin turbo or just on big turbo???
- nitrous to Forced induction...need some advice
- Solution for the ATI heating inpaired: Be Cool
- 382 stroker motor w/ -21.4 mahle pistons
- New 60mm Piston Driven Wastegates!!
- I'm rear mounting my 402, need help........
- Who's running cats with thier S/C?
- FI intake airflow , and egts
- **** Cartek P-1 Procharged C6 Vette breaks into the 9-second zone ****
- Whats the difference between these two?
- install procharger?
- Just a couple of rear mount pics
- Procharger F1C
- Hogan Intake or carburated conv.?
- rear mount turbo oiling??
- intercooler piping to tb
- wtb d1 procharger
- T88 FM and a 370CI.....do you have this combo?
- How do you find the BEST comp. ratio for a power level?
- high HP, what recommended mods for Oiling system?
- how many cubes will the gt70 support
- Cats with Rear Mount?
- Cats and PE Mode!
- PT88 rear mount... so far... it sucks LOL
- smaller runner VS large runner on FI
- cam selection
- What do I need to do to make my car reliable
- Procharger rebuild
- Ported manifolds/TB's?
- STS Turbo Questions
- 6L manifold kit with twin T61s good idea?
- so im trying to plan my friends turbo build ... questions
- question for EPP or someone good with cams
- My video and slip
- Turbo question
- My 408 is here (Cam decision)
- Goodbye to boost for a while
- procharger parts
- Lt1 buildup for boost - Need help for set-up
- What transmission would you go with for my Twin Turbo set up?
- Advice pls, if you are not too busy!
- A little advice....2-Step
- New D1 Price?
- Venting crankcase pressure
- will meth kill a fuel injector?
- Last 1/8 mile passes on this combo..
- superchargers
- turbo motor
- Do you have to change out the computer and wiring for a twin turbo setup????
- Question about parasitic loss with centrifugal sc
- If you were me would you sell your Incon TT kit?
- low gear for turbo
- Placement of Oil cooler
- Truck Manifold ?
- Hot part clearance
- New personal Best 7.54 @ 187.89
- 355 LT1 built for boost
- What size single with stock cube motor?
- I owe Devil's Own an apology
- T6 flange
- New Best 10.45@136.32 STOCK MOTOR!
- Got 2 new Rides...
- Decided to sart tossing another kit together... pics
- T.Smart Ultra gate..good for 5psi on a t70?
- SEMA Show-New Magnuson Blower
- how streetable is TT?
- Super Charger, rear gears 3.42 0r 3.90
- Max boost?
- a2a intercooler...
- supercharger worth it?
- how many members have blown there motors at 5 psi
- roots/twin screw intake manifolds
- Best friends or worst enemies (pic)
- Pick my turbo cam!
- will GTO ATI kit fit on a Fbody (vette thread deleted)
- New build - have questions
- my sts install pics
- Wastegate on a supercharger
- E-85 fuel more efficient for FI
- to let everyone no tondss is no longer my name.....this is!
- Does alky injection help N/A motors at all?
- intake and throttle plate
- Which turbos for twin setup? Like Incon but cheaper...
- turning 6.0ltr manifolds upside down?
- Where can i get ....
- Internals for procharger on a LS1
